XGIMI MIRA Makes RGB Triple Laser 4K UST Projection More Affordable
2026 XGIMI Mira UST Projector Lifestyle
Ultra-short throw projectors occupy a strange corner of the home entertainment market in 2026. Televisions continue to grow larger, brighter, and less expensive, forcing projector manufacturers to offer something more compelling than “a very big picture without a very big box.”
XGIMI is addressing that challenge with MIRA, a new UST projector line built around performance, design, and more aggressive pricing. The first model, simply called the MIRA, is priced at $1,699 and is available now from XGIMI. A brighter MIRA Pro will follow in September 2026 with the same core feature set but a claimed 3,000 ISO lumens of brightness. Pricing for the Pro has not yet been announced.
That positioning matters. The MIRA is not trying to beat a large television on brightness or daytime usability. Its appeal rests on delivering a much larger 4K image from a compact chassis at a price that may give buyers a reason to choose projection rather than another increasingly enormous flat panel display.
Related Article: Best UST Projectors Revealed At 2025 UST Showdown – Check Out The Results
XGIMI MIRA
xgimi-mira-ust-projector-angle
The MIRA is an ultra-short-throw 4K projector designed for buyers seeking an affordable, extra-large-screen entertainment solution that does not dominate the room and can easily become part of it. Here are its core features.
Cinema-Grade RGB Triple Laser: The MIRA incorporates RGB triple-laser technology and delivers a claimed 20,000:1 contrast ratio with DBLE, or Dynamic Black Level Enhancement, enabled.
Immersive 4K Projection: The MIRA can project images up to 120 inches with a claimed brightness of 2,000 ISO lumens and a dynamic contrast ratio of 20,000:1. It can produce a 120-inch image when positioned just 10.8 inches from the screen, making it suitable for smaller rooms.
xgimi-mira-ust-projector-120-inch-screen
Easy Setup: XGIMI’s ISA 5.0 technology for UST projectors improves environmental awareness and setup precision in smaller spaces. The MIRA automatically adjusts image alignment and focus to maintain a clear, properly positioned picture across different viewing distances.
The MIRA can be used with either a projection screen or a blank wall. Image quality may vary depending on the wall color, however, and XGIMI recommends using the wall color adjustment feature in dimly lit environments for the best results.
As an added feature, the MIRA supports XGIMI WALL, which can display artwork from a library of 100 wallpaper designs when the projector is not being used to watch movies or television shows.
Smart Features: The MIRA includes Google TV, providing direct access to Netflix, Hulu, Amazon Prime Video, and thousands of other streaming apps. This makes it an all-in-one home entertainment solution right out of the box.
xgimi-mira-rear-connections
Audio: The MIRA incorporates a Harman/Kardon-tuned speaker system delivering 36 watts of total output through two 8-watt speakers and an internal 20-watt subwoofer. It also supports DTS Virtual and Dolby Audio.
For a more substantial listening experience, the MIRA can be connected to an external soundbar or audio system using HDMI ARC, analog audio, or digital optical output.
Room-Friendly Design: Featuring a soft, water-resistant fabric finish in Moonlight Sand color, MIRA’s aesthetic integrates effortlessly into your home.
Comparison
xgimi-mira-aura-2
XGIMI ModelMIRA (2026)AURA 2 (2024)
Product Type Ultra Short Throw Projector (UST)Ultra Short Throw Projector (UST)
Price$1,699$2,699
Light SourceRGB Triple LaserDual Light 2.0 for UST (Laser + LED)
Display TechniqueDLPDLP
Display Chip0.39” DMD0.47” DMD
3D Viewing OptionYes, Frame Packing & Side by SideYes, Frame Packing & Side by Side
HDR SupportHDR10, HLG, Dolby VisionHDR10, HLG, Dolby Vision, IMAX Enhanced
Gaming Support / Latency(Game Mode, VRR on, AK off) 1ms at 1080P@240HzUltra-Low Latency Down to 20ms (AK off)
MEMCYesYes
Brightness (ISO Lumens)2000 ISO Lumens2300 ISO Lumens
Resolution 3840 x 2160 pixels3840 x 2160 pixels
Color GamutBT.2020 110%DCI-P3 99%
Contrast Ratio20,000:1 (DBLE ON)Dynamic 1,000,000:1
LensHigh Light Transmission Coated LensHigh Light Transmission Coated Lens
Eye ProtectionISA 5.0 for USTISA 5.0 for UST
Auto Keystone CorrectionISA 5.0 for USTISA 5.0 for UST
FocusISA 5.0 for USTISA 5.0 for UST
Intelligent Screen AlignmentScreen Alignment AssistNot Indicated
Intelligent Obstacle AvoidanceNot IndicatedNot Indicated
Intelligent Wall Color AdaptationNot IndicatedNot Indicated
Optical ZoomNoNo
Digital ZoomNoNo
Throw Ratio0.175:10.177:1
Aspect Ratio16:916:9/4:3
Projection MethodUSTUST
Image Size80” – 120”90” – 150”
CPUMT9679Arm Cortex-A55
GPUMali-G52Mali-G52
RAM2GB2GB
Storage64GB32GB
SystemGoogle TVAndroid TV 11.0
Fast BootYes≤16 Seconds (Includes sliding door opening time)
Mirroring DisplayGoogle Cast/MagicastChromecast built-in/Magicast
Speaker36W Harman/Kardon4 x 15W Harman/Kardon 2.0 ch
DTS-Virtual:XYesYes
DTS-HDYesYes
Dolby Atmos–Yes
Dolby AudioYesNot Indicated
Dolby Digital (DD)YesYes
Dolby Digital Plus (DD+)YesYes
WiFiWiFi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/axWiFi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/ax
BluetoothBluetooth 5.2/BLEBluetooth 5.2/BLE
Input PortsHDMI x 2, HDMI (eARC Supported) x 1
USB x 2
DC x 1
LAN x 1
USB x 3
AC x 1
LAN x 1
Output PortsAUDIO x 1
OPTICAL x 1
Headphone x 1 (3.5mm)
OPTICAL x 1
Noise Level≤28dB@1m (Low Noise Mode)≤32dB@1m 18
Power Dissipation180W180W
PowerAC100-240V, 50/60HzAC100V-240V, 50Hz/60Hz, 3.25A
Product Size (HWD)122 x 464 x 268 mm144 x 510 x 270 mm
Product Weight4.8 kg 9 kg
xgimi-mira-remote-control
XGIMI Mira Remote
The Bottom Line
The UST projector category is under growing pressure from increasingly affordable 98-inch and larger televisions. Those TVs deliver higher brightness, deeper black levels, and better daytime performance, but getting a massive sheet of glass through doorways, around corners, and up or down a staircase can turn delivery day into an architectural survey.
A UST projector still makes a strong case in a light-controlled room. It can produce an image larger than most televisions without dominating the space, and owners can change screen sizes later without replacing the projector. A quality ambient-light-rejecting screen remains an additional expense, however, and should be included in the budget from the beginning.
Building on the AURA and AURA 2, the MIRA differentiates itself through its combination of an RGB triple-laser light engine, ISA 5.0 automated setup features, integrated Google TV, and a $1,529 price. None of those features is unique on its own, but finding them together at this price makes the MIRA more interesting.
The MIRA is aimed at movie fans, renters, apartment dwellers, and anyone who wants a 100- to 120-inch image without permanently surrendering an entire wall to an enormous television. Buyers seeking the brightest possible daytime image or the deepest black levels will still be better served by a large TV. For everyone else, the MIRA offers a flexible and relatively affordable path to a genuinely cinematic screen size—provided they leave room in the budget for a proper screen.
xgimi-mira-ust-projector-front
Price & Availability
The XGIMI MIRA is available for $1,699 at Amazon and the XGIMI website.
The XGIMI MIRA Pro is expected to follow in September 2026 with the same features as the MIRA but with higher 3,000 ISO lumens brightness. More details on pricing forthcoming.
2026 Soundpeats CC3 Pro Clip-on Wireless Earbuds Lifestyle Woman
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Our favorite home theater projectors of 2026 deliver best-in-class performance across UST, lifestyle, and long throw categories.
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
A/V Furniture & Accessories
CINÈST Core Collection media consoles integrate UST projector placement, AV storage, cooling, cable management, and optional floor-rising screens.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
Can XWALL’s TITAN Noir Ultra challenge Sony, JVC and Epson with 8,000 lumens, RGB laser and 12,000:1 native contrast?
Can the XGIMI AURA 3 Max challenge giant TVs with 5,700 ISO lumens, dual-iris contrast, Dolby Vision and 4K/120Hz gaming?
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
