ViewSonic LX60HD Smart LED Projector Delivers 1080p Big Screen Streaming for $299
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
ViewSonic LX60HD smart LED 1080p projector angle
The lifestyle projector category is no longer a niche sideshow in home theater. It is one of the fastest growing segments in the display market, driven by mobility, improving image quality, lower prices, and the simple reality that a 100-inch picture is more fun than a 55-inch TV when friends come over. Consumers want something they can move from the living room to the bedroom, take outside for movie night, or toss in a bag for a weekend away without hiring an installer.
The ViewSonic LX60HD lands squarely in that conversation. Known primarily for its PC monitors and business and home theater projectors, ViewSonic is leaning into the lifestyle trend with a portable Smart LED model that focuses on flexible placement, easy setup, and built in content access right out of the box. It is designed to make big screen viewing less intimidating, less permanent, and far more accessible at a price that does not require a second mortgage.
ViewSonic LX60HD Features & Specifications:
Product Design: The LX60HD uses the familiar cube-style chassis that’s become the default look for lifestyle projectors—compact, portable, and designed to sit just about anywhere without looking like “serious home theater equipment.”
Imaging Chip and Light Output: Inside, the LX60HD uses a single TFT LCD imaging chip paired with an LED light source rated at 630 ANSI lumens. ViewSonic also uses a sealed light engine to reduce the impact of dust and moisture over time.
Resolution: Native 1080p (Full HD).
Optical Engine: The sealed optical engine is designed to help keep dust and moisture from entering the light path—important for a projector that’s likely to be moved around, used in different rooms, or taken on the road.
viewsonic-lx60hd-rear-inputs
Connectivity: The LX60HD covers both wireless and wired use cases. Wireless support includes built-in Wi-Fi and Bluetooth. For physical connections, it offers HDMI, USB-C, AV-in, and an audio out port for external speakers or headphones.
viewsonic-lx60hd-setup
Easy Setup: The LX60HD includes a suite of automated setup tools designed to simplify placement and alignment. These features include auto four-corner adjustment, automatic horizontal and vertical keystone correction, auto screen fit, instant autofocus, and obstacle avoidance to help maintain a properly sized and aligned image with minimal manual intervention.
viewsonic-lx60hd-screen-sizes
Image Size Options: ViewSonic states that the LX60HD can project images up to 140 inches. In practical terms, it can produce an approximately 50 inch image from about 5 feet away, or scale up to around 100 inches from roughly 9 feet. As with any projector rated at 630 ANSI lumens, overall picture quality will vary depending on ambient light conditions, with best results achieved in dim or darkened rooms.
viewsonic-lx60hd-google-tv
Google TV: The LX60HD runs on the built-in Google TV platform, providing direct access to a wide range of streaming services, including Netflix, Amazon Prime Video, YouTube, Disney+, Max, and others. This allows users to stream content without needing an external media device, keeping setup simple and self-contained.
viewsonic-pj-wpd-700
Wireless Screen Casting Dongle (Optional): ViewSonic also offers the optional PJ-WPD-700 plug and play dongle, which enables wireless screen casting from compatible smartphones and laptops directly to the LX60HD. It is a practical add on for classrooms, meetings, or quick presentations where running cables is not ideal.
ViewSonic LX60HD Projector Specifications
ViewSonic ModelLX60HD
Projector TypeCompact LED Video Projector
Price$299.99
Display TypeTFT LCD x 1
Light Source TypeLED
Light Source Life, Normal 20,000 Hours
Color Depth16.7 Million Colors
Display ResolutionFull HD (1920×1080)
Brightness (ANSI Lumens)630
Dynamic Contrast Ratio4,200:1
Screen Size50″-140″
Aspect Ratio16:9
Throw Distance1.42m-3.8m (100″@2.28m)
Throw Ratio1.2
Keystone CorrectionVertical (+/- 40º)
Horizontal (+/- 40º)
Horizontal Scan Rate15K-135KHz
Vertical Scan Rate23-85Hz
PC Resolution (max)VGA (640 x 480) to
Full HD (1920 x 1080)
Mac® Resolution (max)480i, 480p, 576i, 576p, 720p, 1080i, 1080p
Wired InputsUSB 2.0 Type A: 1
HDMI 1.4 (with HDCP 1.4): 1
AV In: 1
Wired Outputs3.5mm Audio Out: 1
WiFi5Gn
Bluetooth Version5.0
Bluetooth Audio-In1 (BT5.0) – Direct streaming from compatible smartphones, PCs, etc..
Bluetooth Audio-out1 (BT5.0 – compatible with Bluetooth headphones or speakers
Power Supply100-240V+/- 10%, 50/60Hz AC
Stand-by<0.5W
Physical ControlKeypad, Power key
On-Screen DisplayDisplay Image
Power Management
Basic and Advanced System Information (See user guide for full OSD functionality)
Operating Temperature32-104º F (0 – 40 °C)
Kensington Lock Slot1
Dimensions 9.0 x 8.9 x 6.3 inches
228 x 227 x 159mm
Net Weight6.8 lbs
Package ContentsProjector
Power Cable
Remote Control
Quick Start Guide
Warranty: One-year limited warranty on parts and labor
The Bottom Line
The lifestyle projector space is crowded with inexpensive models that promise the world and deliver a dim flashlight. ViewSonic is at least playing this one straight. The LX60HD’s 630 ANSI lumens puts it ahead of portable competitors like the Xgimi MoGo 4 (450 lumens) and Samsung Freestyle (550 lumens), while still landing under the $300 mark. That matters.
You’re getting native 1080p, solid auto setup tools, built in Bluetooth, and Google TV in one compact cube. For a bedroom, dorm, office, or casual movie night, it makes a lot of sense. Setup is simple. Streaming is built in. Portability is the point.
But let’s keep expectations grounded. 630 lumens is not enough for a large screen home theater in a bright living room. This projector needs dim or near dark conditions to look its best, especially at 100 inches or larger. If you want a daylight TV replacement, this is not it.
The design is clean and easy to move, although a built in carry handle or optional floor stand would have made it even more flexible.
For under $300, the LX60HD offers a portable, affordable lifestyle projector that delivers usable brightness, smart features, and convenience without pretending it can replace a dedicated home theater setup.
Price & Availability
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
Projectors & Screens
Samsung Freestyle+ arrives for $1,200 with 1080p resolution, 430 ISO lumens, AI screen setup, Gaming Hub and Q-Symphony support.
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
JMGO N3 Ultimate delivers triple laser color, a 3-in-1 optical system, and up to 5,800 ISO lumens for screen sizes from 40 to 300...
3D never died, it evolved. Today’s high output home theater projectors bring Blu-ray 3D films to life with sharper detail, deeper immersion, and a...
