SOUNDPEATS Air5 Pro+ Launch: xMEMS Drivers, AI ANC, and Lossless Bluetooth for Under $130
SOUNDPEATS Air5 Pro+ adds xMEMS drivers, AI Adaptive ANC, LDAC, and aptX Lossless, delivering a true 2-way design and hi-res performance at a budget-friendly price.
SOUNDPEATS AIR5 PRO+ Wireless Earbuds in Case
SOUNDPEATS just dropped the Air5 Pro+, and it’s easily the most ambitious model in the lineup. The headline upgrade is the hybrid driver system: xMEMS paired with a dynamic driver, a combo you simply don’t see at this price. Add AI Adaptive ANC rated up to 55dB, plus support for LDAC, aptX Lossless, and every other major hi-res codec, and suddenly the “budget” category doesn’t look so budget anymore.
This is SOUNDPEATS signaling they’re done playing small ball—cleaner detail, stronger noise reduction, and real high-resolution wireless in a compact, lightweight design built for daily use.
Building on the momentum of the Capsule3 Pro+ launch in 2024, SOUNDPEATS has pushed its hybrid driver tech even further with the Air5 Pro+. The star of the show is the xMEMS “Cowell” driver, powered by a custom XAA-2000 Aptos Class-H amplifier. Machined from a single piece of silicon, Cowell acts as a dedicated mid/high driver in this 2-way design, delivering fast, ultra-low-distortion transients and cleaner upper-range detail than anything SOUNDPEATS has shipped before.
It’s essentially a miniature silicon tweeter tucked inside a budget-friendly earbud, and it’s doing the heavy lifting for mid and high frequencies with a level of precision you usually see in much pricier gear.
xMEMS speaker on finger tip
Handling the low end is a 10mm dynamic driver that completes the 2-way setup. SOUNDPEATS went with a dual copper coil and a PU+PEEK composite diaphragm—hardware choices that aren’t just marketing filler. This combo gives the Air5 Pro+ real low-frequency authority: deeper extension, tighter control, and bass that hits with intent without smearing into the mids. It’s designed to keep the bottom end punchy and precise, not bloated, and it rounds out the hybrid architecture with a level of balance that should translate well across genres.
soundpeats-air5-pro-earbuds
Qualcomm-Powered Hi-Res Audio with LDAC and aptX Lossless
The Air5 Pro+ is built around Qualcomm’s QCC3091 Bluetooth SoC and the S3 Sound Platform, a pairing that pushes wireless audio well beyond the typical budget-earbud ceiling. This setup unlocks every major hi-res Bluetooth codec: aptX Adaptive up to 96kHz/24-bit, aptX Lossless for true 44.1kHz/16-bit CD-quality playback, Sony’s LDAC for maximum detail retrieval, and the newer LC3 codec for low-latency, power-efficient streaming.
AI-Powered ANC
The Air5 Pro+ uses a hybrid ANC system combining feedforward and feedback microphones, constantly analyzing your surroundings and adjusting noise cancellation in real time. SOUNDPEATS rates it at up to 55dB of suppression, backed by sensors that claim 95% environmental noise detection accuracy with under 3% attenuation error. In practice, that means more consistent isolation—whether you’re on a train, in an office, or just trying to shut out the world at home—without the overly aggressive pressure or artifacts that plague cheaper ANC systems.
soundpeats-air5-pro-with-case
Fast Charging and All-Day Battery Performance
The Air5 Pro+ packs in enough efficiency to keep you moving without babysitting a charger. A quick 10-minute top-up gets you about 2 hours of listening—handy when you’re running out the door. On a full charge, the earbuds themselves deliver around 6 hours of playback, with the case extending total runtime to roughly 30 hours (tested using the AAC codec at 40% volume in normal mode). It’s a practical, realistic battery setup designed for commuters, office use, and anyone who doesn’t want to hunt for an outlet every few hours.
Multi-Device Connectivity
Bluetooth multipoint support lets the Air5 Pro+ stay connected to your phone and computer simultaneously, managing the handoff automatically. When a call comes in or a video starts playing on your PC, the earbuds shift to the active source without you poking through menus or reconnecting devices. It’s a simple quality-of-life upgrade that makes juggling work calls, music, and daily notifications a lot smoother.
The PeatsAudio App
soundpeats-air5-app
The PeatsAudio app (iOS/Android) allows users to customize sound performance. App features include adaptive EQ, which measures your hearing and adjusts sound automatically, a 10-band custom EQ, LDAC toggle, touch control assignment, and selectable voice guide languages. Periodic Firmware updates via the app maintain optimum earbud performance.
Comparison
soundpeats-comparison
Air5 Pro+ (2025)Air5 Pro (2025)Air5 (2024)Air5 Lite (2025)
Product TypeWireless EarbudsWireless EarbudsWireless EarbudsWireless Earbuds
Price$129.99$79.99$59.99$49.99
DriversxMEMS Cowell driver + 10mm dynamic driver (PU + PEEK diaphragm)10mm Composite Bio-Diaphragm Driver (PU + PEEK)13mm Dynamic13mm Dynamic
ChipQCC3091QCC3091QCC3091BT8932F
Bluetooth VersionV5.4V5.4V5.4V5.4
Supported Bluetooth ProfilesHSP / HFP / A2DP / AVRCPHSP/ HFP/ A2DP/ AVRCPHSP/ HFP/ A2DP/ AVRCPHSP/ HFP/ A2DP/ AVRCP
Noise CancellationHybrid ANC (-55dB)
AI Adaptive ANC (-55dB) 6-MIC
AI Call Noise Cancellation
 cVc™ 8.0 Wind Noise Reduction
AI Adaptive Noise Cancelling (ANC) & CVCDual-mic ENC
Supported Bluetooth CodecSBC/AAC/LC3/LDAC/aptX/aptX Adaptive/aptX LosslessSBC/AAC/LC3/LDAC/aptX/aptX Adaptive/aptX Lossless
Note: LC3 and LDAC are disabled by default. Enable via the PeatsAudio app
AAC/SBC/APTX Adaptive LosslessAAC/ SBC/ LDAC
Frequency Response20 Hz – 40 kHz20Hz-40KHz20Hz—40KHz20Hz-40KHz
Control MethodTouchTouchTouchTouch
Water ResistanceIPX5IPX5IPX5IPX5
Total Music Play Time at 60% Volume (AAC codec, standard mode)6 Hrs Playtime + 30 Hrs with Charging Case7.5Hrs Playtime + 37Hrs with Charging Case6Hrs Playtime + 30Hrs with Charging Case6Hrs Playtime + 24Hrs with Charging Case
Total Standby TimeNot Indicated35H30H50H
Auto-turn off if DisconnectedNoPowers off after 10 minutes if no device has ever been paired. Enters low-power mode after 10 minutes of disconnection if previously paired. 3min3mins
Charging Input5V/1A5V/1A5V/1A5V/1A
Battery CapacityNot Indicated:35mAh x 2 (Earbuds)
:520mAh (Case)
35x 2 mAH (Earbuds)
400mAh (Case)
35 x 2 mAH (Earbuds)
 400mAh (Case)
Charge TimeEarbuds: 1H
Charging Case: 2H
Earbuds: 1H
Charging Case: 2H
1.5H (Earbuds)
2H (Case)
<1H (Earbuds)
<1.5H(Case)
Fast Charging10 min → 2 h playSupported (10 minutes → 2 hours playback)NoNo
Charging portType-CType-CType-CType-C
Length*Width*Height  (mm)Earbuds: 34.6 x 19.87 x 23.50mm
Charging Case: 66.88 x 48.33 x 26.92mm
Earbuds: 34.60 x 17.20 x 17.90 mm
Charging Case: 56 x 51x 26mm
Earbuds: 34.6 x 17.2 x 17.8mm
Charging Case: 56 x 51 x 26mm
Net WeightSingle Earbud: 5g
Earbuds+Charging Case: 51.1g
Single Earbud: 4.8g
Earbuds+Charging Case: 50.3g
Single Earbud Weight: 3.8g
Charging Case with Earbuds: 44.56g
Single Earbud Weight: 4.47g
Charging Case with Earbuds: 44.09g
ColorsBlackBlack (White, Purple, and Beige will be available later)Black / White / Purple / BeigeBlack / White / Purple / Beige
APP Links Google Play – PeatsAudio APP
App Store – PeatsAudio APP
What’s included in the packageEarbuds
Charging Case
Charging Cable
Ear Tips (S/M/L) 3 pairs
User Manual
App Guide
Earbuds
Charging Case
Charging Cable
Ear Tips
User Manual
App Guide
SoundPEATS Stickers
Earbuds
Type-C Charging Cable
Charging Case
User Manual
App Guide
Earbuds
Charging Case
User Manual
App Guide
The Bottom Line
In our earlier coverage of the SOUNDPEATS Air5 Pro, we called it a standout value under $100. With the Air5 Pro+ SOUNDPEATS is pushing harder. The new model adds a full 2-way driver system built around the xMEMS Cowell micro solid state driver, while keeping almost everything that made the original Air5 Pro such an easy recommendation. The only real omission, according to SOUNDPEATS, is the lack of an Auto Shutoff feature when the earbuds are disconnected from a source.
SOUNDPEATS is also one of the latest brands to adopt xMEMS micro speakers, and the Air5 Pro+ is their second model to use the technology, following the Capsule3 Pro+ mentioned earlier. Between the hybrid architecture, the expanded Bluetooth codec support, and a price that stays firmly in the budget range, SOUNDPEATS is sending a clear message: they plan to stay aggressive in the wireless earbud market by bringing next generation tech to everyday listeners.
Price & Availability
The SOUNDPEATS Air5 Pro+ is launching globally for $129.99 at Amazon.
Final retail prices can differ by region or country due to local taxes, duties, and import regulations. For the exact price in your market, please visit the Amazon purchase link (US, UK, CA, AU).
AVID HiFi Pulsus II and Pellar II Phono Preamps
AVID HiFi launches Pulsus II and Pellar II phono preamps with MM and MC support, lower noise, and refined analog performance.
Jean-Marie Reynaud Auralis Loudspeaker Sides Jean-Marie Reynaud Auralis Loudspeaker Sides
Jean-Marie Reynaud’s AURALIS flagship pairs a tuned triangular transmission line, 120 mm AST tweeter, and hand-wired crossover for fall 2026.
Weiss DAC204-MK2 DAC Angled Weiss DAC204-MK2 DAC Angled
Weiss DAC204-MK2 arrives in the U.S. and Canada with an upgraded ESS DAC, improved jitter control, and a refined analog output stage.
2026 Google Home Speaker with Gemini 2026 Google Home Speaker with Gemini
Can Google Home Speaker with Gemini beat Alexa and Siri? New AI features, 360-degree audio, Matter support, and a costly subscription raise questions.
Kaleidescape Strato K 8K Media Player Kaleidescape Strato K 8K Media Player
Kaleidescape's new media player supports 8K resolution, but what it's doing with 4K content has us more intrigued.
2026 Sennheiser ACCENTUM Clip Wireless Earbuds in Cream Lifestyle 2026 Sennheiser ACCENTUM Clip Wireless Earbuds in Cream Lifestyle
Sennheiser ACCENTUM Clip open ear earbuds deliver LDAC, Bluetooth 6.0, IP54 durability, 36 hours of battery life and situational awareness.
Father's Day 2026 4K UHD Blu-ray Disc Movies
Noble Osprey brings hybrid drivers, ANC, app support, and Noble styling to true wireless earbuds under $200. But are codecs the catch?
Bose QuietComfort Ultra Earbuds Gen 2 refine a classic with Bluetooth 5.4, wireless charging, better call quality, and top-tier ANC. Sony is likely to...
Dongle DACs
Questyle M18i MAX adds LDAC, aptX HD, LE Audio, dual ESS DACs, and longer battery life. Is this the complete mobile DAC amp?
JBL Tour ONE M3 gets a Harman Sound Curve update, while Tour PRO 3 gains a smarter case interface and new green finish. Is...
Apple’s rumored AI AirPods with cameras and next-gen Apple TV could reshape wearables and streaming, but privacy questions loom.
SOUNDPEATS Air6 HS wireless earbuds offer LDAC, spatial audio, long battery life, and a comfortable fit for under $40, challenging typical budget options.
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
We're raffling off the first-ever, and one-and-only set of specially designed T10 BESPOKE in-ear computers! Find out how to enter.
