SOUNDPEATS Air6 HS Wireless Earbuds Announced with Hi-Res Audio, Spatial Audio, and Budget Price Under $40
SOUNDPEATS Air6 HS wireless earbuds offer LDAC, spatial audio, long battery life, and a comfortable fit for under $40, challenging typical budget options.
Soundpeats Air6 HS Wireless Earbuds
SOUNDPEATS has spent the past 16 years churning out wireless earbuds at a pace that would make most budget brands tap out, and the new Air6 HS aims squarely at a segment that usually disappoints. Most earbuds under $50 are the kind of last-minute “grab something at Wawa before the road trip” purchase; good enough to survive a commute, or to hand off to the kid who just launched your Apple AirPods out the car window. The Air6 HS tries to flip that script, combining all-day comfort, extended battery life, and support for hi-res and spatial audio at a price below $40.
soundpeats-air6-hs-earbuds
All-Day Wearing Comfort
With so many wireless earbud options available, choosing the right pair comes down to a few core factors that matter regardless of price.
Comfort and fit should come first. If an earbud does not sit securely or becomes uncomfortable over time, it will not get much use. Sound quality follows, along with battery life, call performance, and connection stability. Features like spatial audio or advanced codecs can add value, but they are secondary to the basics that determine how the earbuds perform day to day.
With that in mind, SOUNDPEATS says the Air6 HS was developed using ergonomic data from more than 10,000 ear canal samples. Each earbud weighs just 4 grams, which helps reduce pressure during longer listening sessions.
The semi in-ear design splits the difference between traditional in-ear tips and open ear designs. It sits more securely than open earbuds and offers a more consistent seal, which can improve perceived sound quality and reduce how much audio leaks out in quieter environments like an office. At the same time, it avoids the plugged feeling that some listeners experience with fully sealed in-ear tips.
soundpeats-air6-hs-inside-case
Driver Design & Tuning
On the inside, the Air6 HS uses a 13mm dynamic driver with a PU biological composite diaphragm and a triple magnetic circuit. That combination is intended to deliver a balanced presentation with a focus on natural vocals, rather than pushing any one part of the frequency range too far forward.
That matters, because a lot of affordable earbuds tend to lean on boosted bass or elevated treble to create the impression of detail or impact. It can sound exciting at first, but it often becomes fatiguing over time. The approach here appears more restrained, aiming for a sound that holds up over longer listening sessions without the sharp edges that can creep into budget tuning.
For those who want to adjust things further, the SOUNDPEATS app on Android and iOS includes Dynamic EQ settings that allow some control over bass and overall tonal balance.
Hi-Res Audio Support and Spatial Audio
The Air6 HS carries Hi-Res Audio certification and supports LDAC for Android devices, allowing higher bitrate wireless playback without moving away from its lightweight, semi in ear design.
It supports SBC, AAC, and LDAC codecs, covering the most common use cases, but there is no support for aptX HD or aptX Lossless. For most users, that will not be a deal breaker, but it is worth noting for those already invested in Qualcomm based devices.
Spatial audio support is also included, adding a wider sense of space for movies and streaming content, rather than focusing strictly on music playback.
Battery Life That Keeps Up with Daily Use
The Air6 HS is rated for up to 9 hours of listening on a single charge, with the charging case extending total playback to around 45 hours. When time is limited, a quick 10 minute charge can provide up to 3 hours of playback, which is useful for getting through a commute or a few calls without needing a full recharge.
soundpeats-air6-hs-earbuds-case
Bluetooth Connectivity, Call Quality, and Water Resistance
The Air6 HS incorporates Bluetooth 6.0 for stable, efficient wireless performance, including Bluetooth Multipoint connectivity.  This enables simultaneous pairing with two devices, allowing users to move between phone calls and laptop audio without needing to manually reconnect; a convenient feature for multitaskers and on-the-go commuters who don’t want to annoy the boss.
The Air6 HS uses a four microphone array with dual mic ENC processing to improve call clarity. That is not something you usually see at this price, and it should help voices come through more clearly in calls and virtual meetings, even in less than ideal environments.
SOUNDPEATS also gives the Air6 HS an IPX5 water-resistance rating, which is enough for sweat and light rain during workouts or daily use. That makes them a reasonable option for the gym, but they are not designed for full water exposure. Dropping them in a pool or the ocean is still a quick way to end the conversation.
Comparison
soundpeats-air6-hs-air5-pro
Soundpeats ModelAir6 HSAir5 ProAir5
Product TypeWireless EarbudsWireless EarbudsWireless Earbuds
Price$39.99$79.99$59.99
Ear Fit Type Semi In-EarIn-EarSemi In-Ear
Drivers13mm large dynamic driver featuring a PU biological composite diaphragm and triple-magnetic circuit10mm Composite Bio-Diaphragm Driver (PU + PEEK)13mm Dynamic
ChipQCC3091QCC3091QCC3091
BluetoothVersion 6Version 5.4Version 5.4
Supported Bluetooth ProfilesHSP / HFP / A2DP / AVRCPHSP/ HFP/ A2DP/ AVRCPHSP/ HFP/ A2DP/ AVRCP
Supported Bluetooth CodecsSBC/AAC/LDACSBC/AAC/LC3/LDAC/aptX/aptX Adaptive/aptX Lossless
Note: LC3 and LDAC are disabled by default. Enable via the PeatsAudio app
AAC/SBC/aptX Adaptive Lossless
Mics4 Mics (2 per earbud)6 Mics (3 per earbud)6 Mics (3 per earbud)
Noise CancellationEnvironmental Noise CancellationAI Adaptive ANC (-55dB) 6-MIC
AI Call Noise Cancellation
cVc™ 8.0 Wind Noise Reduction
AI Adaptive Noise Cancelling (ANC) & CVC
Frequency Response20Hz – 20 KHz20Hz – 40KHz20Hz – 40KHz
Control MethodTouchTouchTouch
Water Resistance (IPX Rating)IPX5IPX5IPX5
Total Music Play Time at 60% Volume (AAC codec, standard mode) AAC: 9Hrs Playtime + 45Hrs with Charging Case
SBC: 8 hours
LDAC” 5 Hours
7.5Hrs Playtime + 37Hrs with Charging Case6Hrs Playtime + 30Hrs with Charging Case
Total Standby TimeN/A35 hours30 hours
Auto-turn off if DisconnectedN/APowers off after 10 minutes if no device has ever been paired.
Enters low-power mode after 10 minutes of disconnection if previously paired.
3 min
Charging Input5V/1A5V/1A5V/1A
Battery Capacity41 mAh (per earbud)
500 mAh (case)
35mAh (per earbud)
520mAh (Case)
35 mAH (per earbud)
400mAh (Case)
Earbud Charge Time45 min1 hour1.5 hours
Case Charge Time1 h 36 min2 hours2 hours
Fast ChargingSupported (10 minutes → 3 hours playback)Supported (10 minutes → 2 hours playback)No
Charging portType-CType-CType-C
Earbud DimensionsN/A34.6 x 19.87 x 23.50mm34.6 x 17.2 x 17.9 mm
Case DimensionsN/A66.88 x 48.33 x 26.92 mm56 x 51x 26 mm
Earbud Weight4 g4.8 g3.8 g
Weight with Charging Case with Earbuds43.18 g50.3 g44.56 g
ColorsBlackBlack, White, Purple, BeigeBlack, White, Purple, Beige
App PeatsAudio for Android/iOSPeatsAudio for Android/iOSPeatsAudio for Android/iOS
What’s included in the packageSOUNDPEATS Air6 HS Wireless Earbuds
Charging Case
Type-C Charging Cable
User Manual
Earbuds
Charging Case
Charging Cable
Ear Tips (S/M/L) 3 pairs
User Manual
App Guide
SoundPEATS Stickers
Earbuds
Charging Case
User Manual
App Guide
soundpeats-air6-hs-package
The Bottom Line
The Air6 HS stands out by delivering a balanced feature set at a price where most earbuds cut corners. You get a large driver, LDAC support, a comfortable semi in-ear fit, and strong battery life for under $40, which is not common.
There are tradeoffs. The semi in-ear design means no active noise cancellation, and features like Dolby Atmos, head tracking, or advanced gaming modes are not part of the package.
This is aimed at everyday listeners who want something comfortable, reliable, and better than the usual budget options. It is not trying to replace higher end models, but it does offer a more complete experience than most wireless earbuds in this price range.
Price & Availability
The SOUNDPEATS Air6 HS are available now for $39.99 at Amazon.
Discover the best wireless earbuds of 2026 from Sony, Bose, Noble, and more. Our hands-on picks cover sound quality, ANC, comfort, features, and value.
Our favorite wireless noise cancelling earbuds of 2025 include Bose, Sony, Technics and Bowers & Wilkins.
Nothing's $59 milk carton delivers surprisingly good sound, Auracast, and over 17 hours of battery life. Got milk? This one's got swagger.
EarFun's flagship wireless noise cancelling headphones for 2026 offer adaptive ANC, Auracast, aptX Lossless, 90-hour battery life and custom EQ.
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and up to 8 hours of battery life per charge.
Can AI earbuds actually improve your workday? Viaim Rise records meetings, creates notes, and helps turn conversations into actionable tasks.
Can R-2R audio stand out in crowded TWS? HiFiMAN's $299 Svanar Wireless 2 adds Bluetooth 6.0, LDAC, ANC and a smaller HYMALAYA Mini DAC.
