Polk Audio Atrium Series: Innovation and Performance Redefining Outdoor Speakers
Priced from $225, Polk Audio Atrium Series outdoor speakers bring high-quality sound to patios, pools, and outdoor entertainment spaces.
Polk Audio Atrium 8SDI Outdoor Speaker in White mounted
Polk Audio was one of the pioneers in the outdoor custom-install (CI) speaker category, launching its first Atrium outdoor speakers back in 1991 and setting a benchmark for design and performance. Today, however, the outdoor speaker market has evolved dramatically, with dozens of manufacturers competing across every price point—from entry-level to high-end marine and outdoor CI solutions—making Polk’s legacy a tough act to follow in a crowded, fast-paced industry.
Introducing the Latest Generation of Polk Audio Atrium Series Outdoor Speakers
The latest generation of Polk Audio Atrium Series outdoor speakers is designed to meet today’s demanding performance and installation needs. With a focus on delivering quality sound across a variety of outdoor and transitional spaces—including porches, sunrooms, and decks—the refreshed Atrium lineup offers enhanced sonic performance, improved weather resistance, and versatile mounting options. Choose from four models labeled Atrium 4, Atrium 5, Atrium 6 and Atrium 8SDI, priced from $225 to $550 per pair.
Polk Audio’s mission with this update is to provide affordable, reliable, high-quality audio solutions that blend seamlessly into outdoor environments while standing up to the elements and evolving customer expectations. There are 4 models in Polk’s outdoor Atrium speaker line, labeled Atrium 4, Atrium 5, Atrium 6 and Atrium 8SDI.
polk-atrium-4-black-front-angle-left
Polk Atrium 4 Outdoor Speaker
Polk Audio Atrium Series Key Features and Benefits
  • Speed-Lock Mounting System (New): Enables easy, secure one-handed installations even in hard-to-reach locations. The simplified mounting process uses fewer parts, reducing installation hassle.
  • Anodized Aluminum Tweeter Domes With Rubber Surrounds (New): Provides clearer, more stable high-frequency response that can often be lost in outdoor environments.
  • Injection Molded Mid-Range Cones With Rubber Surrounds (New): Made from mineral-filled or aerated polypropylene—the same materials used in Polk’s high-end LSi Series—redesigned for improved outdoor efficiency.
  • Broad Coverage Baffle Design (New): Offers better sound dispersion compared to previous Atrium models.
  • Aluminum Grilles and Bracket: Combined with stainless steel and brass components, these materials eliminate rust issues, ensuring longer speaker life in outdoor conditions.
  • Polk Audio All-Weather Certified: Exceeds industry and military environmental standards (ASTM D5894-UV Salt Fog, Mil Standard 810 Immersion, Mil-Std 883 Method 1009.8 for salt and corrosion), providing durability and reliable performance for outdoor use.
  • Patented Water-Resistant PowerPort Bass Venting: Available on the Atrium 6, Atrium 7, and Atrium 8SDI models, this feature boosts bass output by approximately 3dB for more realistic, musical low-end.
  • Patented Dynamic Balance and Klippel Optimization Technologies: Enhances driver and tweeter material performance to minimize distortion and artifacts, delivering more accurate and natural sound reproduction at all volume levels.
Polk Audio Atrium Speaker Series Lineup Comparison — Features and Performance Overview
polk-atrium-4-5-6-8sdi
Atrium 4Atrium 5Atrium 6Atrium 8SDI
Product TypeOutdoor SpeakerOutdoor SpeakerOutdoor SpeakerOutdoor Speaker
Price $225/pair$325/pair$425/pair$275/each
Driver (Midrange/Woofer) 4 1/2″ (114mm)
Mineral-filled Dynamic Balance polymer cone rubber surround
5″ (127mm)
5 1/4″ (133mm)
6 1/2″ (165mm)
Dual Voice Coil Dynamic Balance aerated polypropylene   cone, rubber surround
Driver (Tweeter)3/4″ (19mm)
Anodized aluminum dome tweeter w/ rubber suneodymium motor structure
3/4″ (19mm)
Anodized aluminum dome tweeter w/ rubber surround and neodymium motor structure
1″ (25mm)
Two 1″ (25mm)
Frequency Response75Hz – 25kHz60Hz – 25kHz50Hz – 27kHz45Hz – 27kHz
Recommended Amplifier Power10-80W continuous10-100W continuous10-100W continuous10-125W x 2 continuous
Impedance8 ohm compatible8 ohm compatible8 ohm compatible8 ohm compatible
Efficiency aka Sensitivity (dB 1w/1m)89 dB90 dB90 dB91 db
EnvironmentalStandardsASTM D5894-UV Salt Fog
Mil Standard
810Immersion
Polk Audio Certification
ASTM D5894-UV Salt.Fog
Mil Standard 810Immersion
Cabinet materialMineral filled polypropyleneMineral filled polypropyleneMineral filled polypropyleneMineral filled polypropylene
Grille & Bracket materialpowder coated aluminumpowder coated aluminumpowder coated aluminumpowder coated aluminum
HardwareBrass or stainless steelBrass or stainless steelBrass or stainless steelBrass or stainless steel
Connection TerminalsGold-plated 5-way binding postsGold-plated 5-way binding postsGold-plated 5-way binding postsGold-plated 5-way binding posts
Mounting Options180° Speed-Lock™ mounting180° Speed-Lock™ mounting180° Speed-Lock™ mounting180° Speed-Lock™ mounting
Dimensions (HWD w/ bracket & knobs)8 5/8 x 5 11/16  x 6 11/16 -inches
21.9 x 14.4 x 17cm
10 5/16 x 6 3/4  x 7 3/4-inches
26.2 x 17.1 x 19.7cm
11 11/16 x 7 11/16 x 8 ¾ inches
29.7 x 19.5 x 22.2cm
12 7/8 x 8 1/2 x 9 3/16 inches
32.7 x 21.6 x 23.3cm
Product Weight (each)3.6lbs / 1.63kg4.6lbs / 2.09kg5.4lbs / 2.45kg9.7lbs / 4.4kg
Available FinishesBlack & WhiteBlack & WhiteBlack & WhiteBlack & White
polk-atrium-6-outdoor-speaker
Polk Atrium 6
Which Polk Audio Atrium Series Outdoor Speaker is Right For You?
Depending on the size of your installation and listening space, each Atrium model offers a tailored solution.
The Atrium 4 is the most compact and lightweight, making it ideal for smaller spaces. As you move up the lineup, models are designed to accommodate larger installation areas and deliver greater sound coverage.
All Atrium speakers are reasonably priced and sold in pairs, except for the largest model, the Atrium 8SDI, which is priced individually. Its bigger size not only produces the most bass of the range, but it also can provide stereo imaging from a single speaker thanks to its dual tweeter design.
To simplify installation and compatibility, the Atrium series uses standard speaker terminals with an 8-ohm impedance. This means they connect to regular audio gear you may already own such as A/V receivers, integrated amps, or even streaming amplifiers.
For outdoor surround sound setups, multiple pairs of Atrium 4, 5, or 6 speakers can be combined, or you can use five or more Atrium 8SDI units. Polk Audio recommends pairing these with the Atrium SUB100 subwoofer (priced at $499).
Available in weatherproof black and white finishes, the Atrium speakers suit most outdoor placement needs. They are also paintable, allowing customization to match your outdoor décor.
polk-atrium-8-outdoor-speaker
Amplifier Pairings
The complete your outdoor speaker oasis, the final consideration is what amplifiers and control systems to use. Although any amplifier can work, Polk recommends pairing with Denon, which is currently under the same corporate umbrella.
  • For someone who is just getting started with a smaller backyard or patio: Denon Home Amp + a pair of Atrium 4
  • For someone who wants a solution for indoor and outdoor, look for an A/V receiver with at least 2 zones: Denon AVR-X3800H to power a Dolby Atmos theater in your main zone, and create a second zone outside with a pair of Atrium 6
  • For someone who wants the ultimate outdoor listening solution, a Denon AVR-X3800H could be used with 4x Atrium 8, 2x Atrium SAT300 landscape speakers and 2x Atrium SUB100
By sticking with Denon, you also get total control of music playback to all of your outdoor speakers using the HEOS app on your smartphone at no extra charge.
The Bottom Line
The outdoor speaker market is booming as more homeowners seek to enhance their outdoor entertainment—from movie nights to pool and sports parties. Polk’s Atrium Series stands out by delivering sound quality that defies typical outdoor speaker expectations, elevating the entire listening experience with advanced driver materials, improved weatherproofing, and versatile mounting options.
In a crowded market filled with choices at every price point, Atrium strikes a balance between performance and affordability, making it a compelling option for those who want reliable, quality sound without breaking the bank. However, when considering these speakers, remember that amplification and source components play a critical role in your setup—matching your desired sound quality with your budget is key to unlocking their full potential.
Where to buy:
2 Comments
2 Comments
  1. Rich
    August 11, 2025 at 2:23 pm
    The worst thing about outdoor speakers. All of them: You’re in your backyard trying to for tranquility and listening to song birds, and your neighbor is blasting AC/DC on the other side of the fence. Help me Mr. wizard.
    • Ian White
      August 11, 2025 at 2:36 pm
      Rich,
      As someone who lives in a “summer beach” community all year long — I totally get that. And I did what any good neighbour would do in that scenario — I bought bigger speakers and pointed them outward. 🙂
      I actually prefer the covered patio (winter) scenario with in-ceiling speakers or on-wall where I can listen at lower levels while I read. The outdoor movie theater is only for the summer.
      IW
2026 Triangle Borea BR05 Stand-mount Loudspeakers
Triangle’s Borea BR05 combines retro styling, an 8-inch woofer, and serious cabinet engineering. Who decided bookshelf speakers had to be so small?
Moon 341 Integrated Amplifier Black Angle Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
Can Coastal Source turn the backyard into a true high-end system? Its CEDIA 2026 lineup combines outdoor audio, lighting and simplified power.
KEF takes Uni-Q outdoors with new landscape speakers, bollards, subwoofers and GaN KASA amps. Can it challenge Theory Audio Design?
Andover Audio FreePlay vs KEF Muo: which portable Bluetooth speaker sounds better at home, outdoors, and on the road?
Can the Andover Audio FreePlay deliver true stereo sound, long battery life, and real durability in a portable Bluetooth speaker?
Coastal Source 1000 Series Bollards bring ribbon tweeters, modular configurations, and serious all-weather sound to luxury outdoor installations.
Bang & Olufsen teams with Antolini on Beosound Haven, a high end outdoor speaker concept that blends stone, design, and integrated audio.
Our Best of 2022 Soundbar picks feature some great options from Sony, Polk, Sonos, Samsung, and Vizio for every budget.
Affordable audio for a lot less than you'd think from trusted brands that will payback dividends all year with sonic enjoyment.
