HiFiMAN Arya & HE1000 WiFi Debut at CanJam NYC 2026 Bringing Planar Magnetic Headphones Into the Wireless Era
Can HiFiMAN’s HE1000 WiFi and Arya WiFi bring true high resolution audio to wireless planar open-back headphones? We’ll find out at CanJam NYC 2026.
HiFiMAN Arya WiFI and HE1000 WiFi Headphones
The market for high end wireless headphones has expanded rapidly over the past few years. What was once dominated by mainstream Bluetooth models has evolved into a category that now includes serious audiophile contenders from brands such as Focal, Bowers & Wilkins, DALI, Mark Levinson, and Sennheiser. These companies have demonstrated that wireless headphones can deliver a level of performance that appeals to listeners who once insisted on wired designs and dedicated headphone amplifiers.
HiFiMAN is now pushing deeper into that space with the introduction of the HE1000 WiFi and Arya WiFi, two open back planar magnetic headphones that rely on Wi-Fi rather than Bluetooth as their primary wireless connection. The company has experimented with wireless concepts before, but these new models represent a more ambitious attempt to bring high bandwidth wireless audio to planar magnetic designs.
hifiman-he1000-wifi-headphones-lifestyle
HiFiMAN HE1000 WiFi
HiFiMAN has not announced pricing yet, but the company has indicated that both models will sit closer to the HE1000 Unveiled and Arya Unveiled in its lineup rather than its flagship tier. Both headphones are scheduled to begin shipping next month and will be demonstrated publicly at CanJam NYC 2026 this weekend, where we will have an opportunity to spend time listening to both models.
According to HiFiMAN, the key difference between these headphones and typical wireless designs is the use of Wi-Fi for audio transmission. Bluetooth’s limited bandwidth has long constrained wireless audio quality, while the Wi-Fi connection used here is designed to support full resolution lossless audio streams without compression.
Both headphones incorporate HiFiMAN’s proprietary Hymalaya R2R DAC, integrated amplification inside the earcups, and planar magnetic drivers based on the company’s established technologies.
hifiman-arya-wifi-headphones-lifestyle-woman
HiFiMAN Arya WiFi
Hymalaya What?
The Hymalaya DAC is HiFiMAN’s proprietary digital to analog converter built around a classic R2R ladder architecture, a design approach favored in many high end audio systems for its natural timing and accurate signal conversion. Unlike the delta sigma DAC chips used in most modern headphones and wireless devices, an R2R DAC converts digital audio using a network of precision resistors that translate binary data directly into analog voltage. This approach can deliver excellent transient response and tonal accuracy, but it is traditionally more complex and power hungry than conventional DAC designs.
HiFiMAN developed the Hymalaya DAC to overcome those limitations by combining the R2R ladder with an FPGA controlled architecture and extremely low power consumption. The result is a compact DAC capable of supporting high resolution audio formats, including PCM up to 768 kHz and native DSD, while drawing far less power than traditional ladder DACs. That efficiency allows HiFiMAN to integrate the technology into portable gear and wireless headphones.
In products such as the HE1000 WiFi and Arya WiFi, the Hymalaya DAC works alongside a built in amplifier to convert digital audio directly inside the headphone. This self contained signal chain allows the headphones to operate more like a complete playback system, handling the digital conversion and amplification internally rather than relying on the DAC and amplifier inside a phone or computer.
HiFiMAN HE1000 WiFi
hifiman-he1000-wifi-headphones-angle-left
The HE1000 WiFi is an open back planar magnetic headphone that combines HiFiMAN’s familiar driver architecture with onboard digital processing and wireless connectivity. The design incorporates the company’s Nano Diaphragm driver paired with its Stealth Magnet system, a magnet structure intended to reduce wave diffraction and maintain a more consistent sound wave path.
Inside the earcups is a custom Class A/B balanced amplifier working alongside HiFiMAN’s Hymalaya R2R DAC, which converts incoming digital audio streams directly within the headphone. This approach allows the headphone to function more like a self contained playback system rather than relying on the amplification stage of an external device.
hifiman-he1000-wifi-headphones-back
The HE1000 WiFi connects through a dedicated Wi-Fi network created by the headphone itself. Users simply select the headphone from the WiFi menu on a smartphone or tablet and stream audio directly to the headphone. This wireless link supports full resolution audio transmission and is capable of handling high bandwidth formats including PCM up to 768 kHz and native DSD up to DSD512.
HiFiMAN lists a frequency response of 8 Hz to 65 kHz with THD + N rated at 0.009 percent at 32 ohms when the DAC and amplifier are operating together. Channel separation is specified at 105 dB at 1 kHz, and the headphone weighs 452 grams. The HE1000 WiFi can operate in Wi-Fi, USB audio, or Bluetooth modes and charges via USB Type-C with a typical charging time of three to four hours. Standby time is rated at more than 30 days.
HiFiMAN Arya WiFi
hifiman-arya-wifi-headphones-angle
The Arya WiFi uses a similar architecture but incorporates HiFiMAN’s Super Nano diaphragm driver, a thinner variation of the company’s planar driver design intended to improve transient response and overall efficiency. As with the HE1000 WiFi, the Arya WiFi also uses Stealth Magnet technology, integrated amplification, and the Hymalaya R2R DAC.
Like its sibling, the Arya WiFi connects directly to smartphones and tablets through a Wi-Fi network created by the headphone. Once connected, audio streams are transmitted at full resolution without relying on Bluetooth compression. Support for high resolution audio formats is extensive, with PCM playback up to 768 kHz and native DSD up to DSD512.
HiFiMAN specifies a frequency response of 8 Hz to 55 kHz with THD + N rated at 0.009 percent at 32 ohms when the DAC and amplifier are operating together. Channel separation is listed at 105 dB at 1 kHz and the headphone weighs 452 grams.
The Arya WiFi supports Wi-Fi streaming, Bluetooth 5.1 connectivity with SBC, AAC, aptX, aptX HD, and LDAC codecs, and USB-C wired playback. Battery life is rated at approximately 6.5 to 7.5 hours when operating in Wi-Fi mode and up to 23 hours when using Bluetooth. Charging takes roughly three to four hours, and standby time is listed at more than 30 days.
hifiman-arya-wifi-headphones-back
Comparison
Arya UnveiledArya WiFiHE1000 Unveiled HE1000 WiFi
Product TypeHeadphonesHeadphonesHeadphonesHeadphones
Price$1,449$1,449$2,299$2700
DesignOpen-backOpen-backOpen-backOpen-back
Driver TypePlanar Magnetic with Stealth MagnetsPlanar Magnetic with Stealth Magnets.Planar Magnetic with Stealth MagnetsPlanar Magnetic with Stealth Magnets
Frequency Response8Hz – 65kHz8Hz – 55kHz8Hz – 65kHz8Hz – 65kHz
Impedance27 OhmsNot indicated28 OhmsNot indicated
Sensitivity94dBNot Indicated95dBNot indicated
DiaphragmNanometer thicknessNanometer thicknessNanometer thicknessNanometer thickness
THD+NN/ADAC: 0.0055%@-9dB, 1kHz
DAC + Amp: 0.009% @32 ohms, 1kHz
Channel SeparationN/A105dB @1kHzN/A105dB @1kHz
Connection ModesWired onlyWiFi, USB Audio, BluetoothWired onlyWiFi, USB Audio, Bluetooth
Battery Life (WiFi)N/A6.5-7.5 hoursN/A6.5-7.5 hours
Battery Life (BT)N/A23 hoursN/A23 hours
Charging TimeN/A3-4 hoursN/A3-4 hours
Standby TimeN/A30+ daysN/A30+ days
Audio FormatsN/APCM 44.1kHz-768kHz, 32/24/16Bit, DSD native 64-512N/APCM 44.1kHz-768kHz 32/24/16Bit, DSD native 64-512
Bluetooth CodecsN/ASBC, AAC, aptX, atpX HD, LDACN/ASBC, AAC, aptX, atpX HD, LDAC
Weight413g452g450g452g
The Bottom Line
The HE1000 WiFi and Arya WiFi take a different approach to wireless headphone design by focusing on bandwidth and signal integrity rather than convenience features. By combining planar magnetic drivers with a built-in Class A/B amplifier, HiFiMAN’s Hymalaya R2R DAC, and a Wi-Fi based audio connection, these headphones are designed to handle high resolution audio without relying solely on Bluetooth compression.
That said, these are clearly not lifestyle wireless headphones. Both models use open-back earcups, which means they leak sound and provide no isolation from the outside world. They are better suited for listening at home, where wireless freedom can be useful without the compromises that normally come with portable wireless designs.
HiFiMAN has not revealed pricing yet, but both models appear positioned for listeners who want something closer to a traditional audiophile headphone system that happens to operate wirelessly. We expect to learn more once we have the opportunity to spend time with both models at CanJam NYC 2026 this weekend.
Fezz Audio Luna Integrated Amplifier Big Calm Maroon Front Angle
Fezz Audio Luna brings Polish tube engineering, Toroidy transformers, bold finishes, and modern flexibility to U.S. hi-fi customers.
iFi Audio ZEN Air Phono 2 MM MC Preamplifier Lifestyle Stack iFi Audio ZEN Air Phono 2 MM MC Preamplifier Lifestyle Stack
iFi's ZEN Air Phono 2 adds MM and MC support with accurate RIAA playback and low noise, offering a flexible $129 upgrade for turntables...
Garmin JL Audio Primacy System Lifestyle Garmin JL Audio Primacy System Lifestyle
Garmin’s JL Audio Primacy system combines streaming, room correction, MM/MC phono, Dante, and active speakers from $50,000. Is this the new luxury hi-fi formula?
YG Acoustics Titan Loudspeakers Pair YG Acoustics Titan Loudspeakers Pair
7 feet tall and and weighing 1,000 pounds, YG Acoustics flagship 5-way loudspeakers come in fully active, semi-active or passive versions.
Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash
Devialet’s Roland Garros Phantom Ultimate serves clay court style, deep bass, and French attitude in a limited edition wireless speaker. Voilà.
2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle 2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle
Priced from $1,099 to $7,999 per pair, Jamo Concert Legacy and Element Series Loudspeakers preview August 2026 launch.
Mother's Day Tech Gift Ideas 2026
Upgrade Mom's audio experiences this Mother's Day with gift ideas she'll absolutely love -- and you might too.
Audeze ReSkin brings $39.99 and $59.99 magnetic earcup covers to Maxwell 2, giving gamers a cleaner way to personalize their headset.
Sony INZONE H6 Air adds an open-back wired gaming headset with spatial focus and low weight but no wireless. Is this the right trade...
Audio-Technica proved at AXPONA 2026 why it still matters, from $59 headphones to the $108,000 Narukami, plus phono cartridges and turntables.
Austrian Audio's The Arranger headphones promise studio roots, but is the tuning truly neutral or built for bass-driven listening?
Over-Ear Headphones
Can Axel Grell’s $599 OAE2 deliver true speaker-like imaging? Our review breaks down its neutral tuning, comfort, and real-world performance.
Packed rooms at CanJam NYC 2026 and a surge in vinyl, books, and Blu-ray. Is physical media quietly winning again?
Bowers & Wilkins flagship Pi8 wireless earbuds are now available in Dark Burgundy or Pale Mauve, while the Px7 S3 headphones arrive in Vintage...
