FiiO K13 R2R DAC: A Balanced Headphone Amp and Hi-Res Desktop Audio Hub With Enough Power for Planar Headphones
$319 hi-res desktop DAC/AMP with balanced/single-ended outputs, Bluetooth 5.4, USB, optical, coax, and I²S connectivity.
FiiO K13 R2R DAC Black Angle
One of the most compelling new products we got to try at CanJam London 2025 was FiiO’s upcoming K13 R2R. Positioned just below the K15 in the brand’s lineup, this desktop DAC and balanced headphone amp could easily be FiiO’s most interesting release of the year. With a resistor ladder (R-2R) DAC architecture, 2.3 watts of output, and a 10-band parametric EQ, the K13R2R promises organic, hi-res sound and precise tonal control—without the need for extra software or hardware.
After a short listening session with the HiFiMAN HE1000 Unveiled, eCoustics Headphone Contributor James Fiorucci (UK) was impressed. “The K13R2R added a natural warmth and smoothness that stood out immediately. It’s not a ‘wow’ sound—it’s a ‘settle in and listen for hours’ sound. If you’re sensitive to treble fatigue or just want a DAC/amp that disappears into the music, this could be the sleeper hit of FiiO’s 2025 lineup,” he noted.
Packing the latest discrete resistor ladder decoding, an ultra-low noise architecture, and desktop-class driving power, the K13 R2R manages to squeeze flagship-level sound into a unit small enough not to dominate your desk. And yes, there’s a window on top so you can gawp at the chipset like it’s a museum exhibit—because nothing says “hi-fi cred” like showing off your electronics.
This isn’t just a toy for your laptop or tablet; the K13 R2R delivers hi-res sound anywhere you stick it—desk, bedside table, or slotted neatly into a more elaborate hi-fi system. Pair it with the FiiO DM13 CD player and SP5 speakers, and suddenly you’ve got a full desktop hi-fi rig that doesn’t require a PhD to operate.
fiio-k13-r2r-dac-silver-front
FiiO K13 R2R: Discrete Resistor Ladder DAC for Natural, Hi-Res Sound
At the heart of the K13 R2R is a fully discrete resistor ladder DAC—a carefully engineered array of precision resistors designed for true multibit conversion. The R2R architecture delivers a sound that’s more natural and organic than most Delta-Sigma designs.
FiiO pairs the resistor network with its proprietary error correction algorithm, ensuring tight matching, linearity, and ultra-low distortion. The result is a presentation that balances technical accuracy with warmth and natural flow, making it just as comfortable for detailed, analytical listening as it is for long, immersive musical sessions.
To fully unlock the discrete R2R ladder, the K13 R2R pairs it with an FPGA + DSP system that manages digital signal processing, clocking, and oversampling. The unit handles up to PCM 1536 kHz and DSD1024, covering all current hi-res formats.
Measured performance is equally strong: THD+N reaches as low as 0.00037%, dynamic range is 124 dB, and the noise floor sits at –124 dB. These figures reflect a system capable of delivering accurate, clean, and natural sound across the audible spectrum.
Low-noise LDO regulators and dual-independent power supplies provide strong isolation and stable performance. Premium film capacitors and precision resistors maintain consistency throughout the R2R ladder, while the all-aluminium chassis with precision CNC machining ensures both durability and effective heat dissipation.
FiiO K13 R2R: Future-Proof DAC with USB, Optical, Coaxial, and I²S Inputs
With the K13 R2R, FiiO has built more than a DAC—it’s a full digital audio platform. It features an XMOS XU316 USB receiver and supports USB, optical, coaxial, and I²S inputs, making it compatible with PCs, streamers, CD transports, and other digital sources. An OLED display with an intuitive UI allows effortless control of input selection, gain, filters, and output modes. Bluetooth 5.4 is also supported for those who may wish to stream from their smartphones, tablets, or laptops.
One limitation to note: the K13 R2R has no analog line-level inputs, so connecting a phono stage directly is not possible—you’ll need a preamp or another digital conversion step.
The K13 R2R offers a full suite of digital filters that let users shape the sound to their liking, from smoother roll-offs for relaxed listening to sharper filters for more precise accuracy. Through the FiiO Control app, listeners can also access parametric EQ, creating and saving custom sound profiles tailored to their setup.
FiiO K13 R2R: High-Power Desktop DAC and Headphone Amp with Balanced and Single-Ended Outputs
The K13 R2R packs 2.4 watts of output, giving it the muscle to drive everything from sensitive IEMs to stubborn full-size planar headphones. Selectable gain levels let you dial in the right amount of juice—quiet enough for delicate monitors, plenty of headroom for 600-ohm beasts—so you don’t have to wrestle with hiss or underwhelming dynamics.
fiio-k13-r2r-dac-silver-back
Connectivity options cover all bases:
  • Balanced XLR and 4.4mm headphone outputs
  • Single-ended 6.35mm headphone jack
  • Balanced and single-ended line outputs for active monitors like the SP5 or an external amplifier
All of this makes the K13 R2R the control hub of any desktop or home setup—from a minimalist headphone rig to a full audiophile system. And yes, it manages all of this without looking like it tried too hard.
FiiO K13 R2R – Key Specifications
  • Main Control Chip (MCU): ESP32-S3
  • USB Chip: XMOS XU316
  • DAC: Fully differential 24-bit R2R resistor ladder
  • Volume Control: NJW1195AV
  • R2R & LPF Op-Amps: OPA1642 ×4
  • LO Buffer Op-Amps: LTA8092 ×2
  • Headphone Amplifier: OPA1642 ×2 + TPA6120A ×2
  • Digital Inputs:
    • USB: 384kHz/32-bit, DSD256
    • Coaxial: 192kHz/24-bit, DSD64
    • Optical: 96kHz/24-bit
    • USB Connector: Dual Type-C
    • Bluetooth: 5.4
  • Display: Custom LCD
  • Power Input: AC 100–240V 50/60Hz; DC 12V/2.5A
  • Dimensions & Weight: 210 × 188 × 42 mm (including feet); 980 g
  • Headphone Output Power:
  • Single-Ended:
    • 32Ω: ≥1220 mW + 1220 mW (high gain)
    • 300Ω: ≥150 mW + 150 mW (high gain)
  • Balanced:
    • 32Ω: ≥2400 mW + 2400 mW (high gain)
    • 300Ω: ≥600 mW + 600 mW (high gain)
  • Performance:
    • Frequency Response: 20 Hz–80 kHz, Attenuation <2.9 dB
    • SNR: ≥116 dB (A-weighted)
    • Noise Floor: SE <9 µV, BAL <18 µV (A-weighted)
    • Output Impedance: SE <0.7 Ω, BAL <1 Ω (32Ω load)
    • THD+N: ~0.0173% (1 kHz, –6 dB @ 32Ω)
  • Colors: Black, Silver
fiio-k13-r2r-dac-silver-angle
The Bottom Line
Set to arrive at authorized retailers in September 2025 for £279 / $319 / €319, the FiiO K13 R2R is a desktop DAC and headphone amp built for serious hi-res listening. Its discrete R2R ladder paired with an FPGA + DSP systemhandles PCM 1536 kHz and DSD1024, while low-noise, dual independent power supplies keep the output clean and stable.
The headphone amplifier delivers selectable gain with balanced XLR/4.4mm and single-ended 6.35mm outputs, alongside balanced and single-ended line outputs for active monitors or external amps. Connectivity covers USB, optical, coaxial, and I²S, though there are no analog line-level inputs, so phono stages aren’t supported.
In our initial listening session, the K13 R2R impressed with natural warmth, smoothness, and effortless control, making it a versatile hub for desktops, minimalist headphone setups, or full hi-res systems. At $319, it offers a carefully considered mix of features that most users would actually want—high-resolution playback, flexible outputs, and robust headphone amplification without unnecessary extras.
For more information: fiio.com/k13r2r
Where to buy: $319 at Apos Audio
2 Comments
2 Comments
  1. Anton
    September 9, 2025 at 7:30 pm
    The headphone amplifier doesn’t really interest me, but under $350 for that level of DAC seems like a bargain.
    • Ian White
      September 10, 2025 at 10:39 am
      There is a cheaper version of this one for under $150 that is also an R2R DAC. We plan on reviewing them once FiiO gets them to us.
      IW
Garmin JL Audio Primacy System Lifestyle
Garmin’s JL Audio Primacy system combines streaming, room correction, MM/MC phono, Dante, and active speakers from $50,000. Is this the new luxury hi-fi formula?
YG Acoustics Titan Loudspeakers Pair YG Acoustics Titan Loudspeakers Pair
7 feet tall and and weighing 1,000 pounds, YG Acoustics flagship 5-way loudspeakers come in fully active, semi-active or passive versions.
Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash
Devialet’s Roland Garros Phantom Ultimate serves clay court style, deep bass, and French attitude in a limited edition wireless speaker. Voilà.
2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle 2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle
Priced from $1,099 to $7,999 per pair, Jamo Concert Legacy and Element Series Loudspeakers preview August 2026 launch.
Audiovector R 5 Arrete Loudspeakers Lifestyle Audiovector R 5 Arrete Loudspeakers Lifestyle
Audiovector R 5 Arreté brings R 10 flagship tech, 23 Hz bass, and Danish build quality to a new high-end floorstanding loudspeaker.
Toshiba Z670R Series REGZA TV Lifestyle Toshiba Z670R Series REGZA TV Lifestyle
Mother's Day Tech Gift Ideas 2026
Upgrade Mom's audio experiences this Mother's Day with gift ideas she'll absolutely love -- and you might too.
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
CD Players
FiiO raises prices on key DAPs starting April 2026 amid tariffs and rising costs, but with stronger rivals closing in, will buyers stick around?
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
The Apos x Community Gremlin is a compact fully balanced Class A hybrid amp that delivers impressive warmth, tube rolling flexibility, and big performance...
Burson's Conductor Stellar packs an ESS9039PRO DAC, 8W Class-A power, and upgradeable design. Can rivals match this much performance for $1,800?
Dongle DACs
Can the $199 FiiO BTR17 still compete in 2026? With dual ESS DACs, THX power, and LDAC support, this pocket DAC/amp aims close to...
