Edifier Hecate G5 MAX Wireless Gaming Headset Debuts with THX Spatial Audio Plus for $149
Can Edifier’s $149 HECATE G5 MAX challenge Sony Pulse Elite with THX Spatial Audio+, low-latency wireless, and 305-hour battery life?
Gaming audio is no longer some awkward side quest attached to the PC and console market. It has become a serious category of its own, with Sony’s INZONE lineup, Audeze’s Maxwell gaming headsets, SteelSeries, Razer, Logitech, Corsair, and others all fighting for ears, desk space, and disposable income. Better positional audio, lower wireless latency, improved microphones, and longer battery life are now table stakes. The days of pretending that gamers only care about RGB lighting and explosions are mercifully behind us.
Edifier is the latest brand to push deeper into that crowded space with the HECATE G5 MAX, a $149.99 wireless gaming headset built around THX Spatial Audio, low-latency wireless support, Hi-Res Audio and Hi-Res Audio Wireless certification, LHDC 5.0 support, and a claimed battery life of up to 305 hours in Bluetooth mode with the lighting turned off. That is a lot of headset for the money, assuming the sound quality, comfort, and microphone performance can keep up with the spec sheet.
Drivers
At the heart of the G5 MAX are 53mm titanium-coated drivers that use PEN titanium diaphragm technology. Edifier says the driver system is tuned to deliver strong bass output, clear midrange reproduction, and extended treble detail with total harmonic distortion rated at less than 1%. That sounds promising on paper, although “reference-grade” is a phrase best earned in testing rather than awarded by a spec sheet wearing a gaming headset.
edifier-g5-max-black
THX Spatial Audio+
The G5 MAX also supports THX Spatial Audio+ for headsets, which Edifier says can create a 7.1.4 virtual surround sound field for more precise directional cues. In practical terms, that means the headset is designed to help users place footsteps, environmental effects, and overhead sounds more accurately in supported Windows 11 titles. That matters in competitive gaming, where hearing someone before seeing them can be the difference between winning the match and blaming the controller like a coward.
For the G5 MAX, Edifier says HECATE and THX co-developed a customized version of THX Spatial Audio+ for headsets. The system uses real-time rendering and spatial positioning to process stereo and multi-channel signals, creating a wider and more dimensional sound field.
Additional Audio Control
The G5 MAX also works with HECATE Driver software, giving users more control over the THX Spatial Audio+ experience. Available adjustments include EQ settings, Bass Boost, Vocal Clarity, and Volume Normalization, allowing users to create different sound profiles for games, music, movies, and voice-heavy content.
edifier-connex-app
In addition, with the Edifier Connex App (iOS, Android), users can switch between 2.4 GHz and Bluetooth modes as well as Game/Music sound effects. Users can also check battery status, adjust the lighting effects, and control the notification tone volume.
Voice Communication with AI Noise Cancellation
For voice communication, the G5 MAX combines dual ENC microphones with a detachable 9.75mm unidirectional boom microphone. Edifier says the system uses AI noise cancellation to focus on the user’s voice while reducing unwanted background noise. The microphone setup is designed for competitive gaming, team chat, live streaming, and phone calls, where consistent voice pickup matters as much as audio performance.
Ultra-Low Latency Wireless Connectivity
For wireless connectivity, the G5 MAX supports Bluetooth 6.0 with SBC and LHDC 5.0 codec support. For gaming, it also includes a dedicated 2.4GHz wireless mode that supports 48kHz audio and is designed to provide lower latency for fast-paced gameplay where timing and synchronization matter. The headset can also be used over a wired USB connection for users who prefer a direct connection or want to avoid wireless variables altogether.
edifier-g5-max-white
305-Hour Battery Life?
The G5 MAX includes a 2000mAh battery, with Edifier claiming up to 305 hours of playback on a single charge. That figure likely depends on the listening mode, volume level, codec, lighting, and whether the headset is being used over Bluetooth or 2.4GHz wireless. Still, even with real-world variation, that is a substantial battery-life claim for a wireless gaming headset and should reduce the need for frequent charging during long gaming sessions, travel, streaming, and daily entertainment use.
For gamers who prefer wireless freedom, the extended battery life also means less reliance on a wired connection, fewer cable-length issues, and a cleaner desk setup.
Wearing Comfort
The G5 MAX is also designed for longer listening and gaming sessions. At 305g, or 10.76 ounces, the headset is relatively light for a wireless gaming model, which should help reduce fatigue during extended use. Edifier also uses high-resilience memory foam and protein leather ear cushions, with a wider contact area across the ear pads and headband to distribute pressure more evenly.
The headband is also designed to be glasses-friendly, which matters for users who spend hours at a desk and do not want the headset turning their eyewear into a medieval torture device.
User Flexibility
With THX Spatial Audio+, low-latency wireless support, AI-assisted voice communication, and a very large battery-life claim, the HECATE G5 MAX is positioned as a versatile wireless gaming headset rather than a basic chat accessory. Edifier is targeting gamers, streamers, content creators, and listeners who want one headset for competitive play, music, movies, voice chat, and everyday use.
The G5 MAX is compatible with PCs, PlayStation consoles, and Xbox, although users should check the supported connection modes for each platform, since Bluetooth, 2.4GHz wireless, USB, and wired support can vary depending on the device.
Comparison
edifier-g5-max-vs-sony-pulse-elite
Brand/ModelEdifier G5 MAXSony Pulse Elite
Product Type Wireless Gaming HeadsetWireless Gaming Headset
Price $149.99$149.00
Driver53 mm PEN Diaphragm Dynamic DriverPlanar Magnetic
Frequency Response20Hz – 40kHz20Hz – 20kHz
Impedance64 ohms32 ohms
Sensitivity97dBNot Indicated
Signal-to-Noise Ratio (SNR)88dBNot indicated
THDLess than 1%Not Indicated
Audio Sampling Rate Support96kHz/24-bit (48kHz in 2.4 GHz mode)48kHz/16-bit (when using Sony Playstation Link)
Bluetooth Version6.05.0
Bluetooth ProfilesHFP / A2DP / AVRCPHSP / HFP /  A2DP / AVRCP
Effective Distance10m10m
Audio ProcessingTHX Spatial Audio+Sony Tempest 3D Audio
Audio CodingSBC, LHDC 5.0SBC, AAC
MicrophoneDual Built-In Mics + Detachable Boom MicFully retractable boom mic with AI-enhanced noise rejection
ConnectionBluetooth / 2.4G (USB-A & USB-C) / USB-ABluetooth
PlayStation Link™: via included USB-A dongle
Dual Connectivity: Simultaneous audio from PlayStation Link (games) and Bluetooth (calls/music)
PlaytimeAround119H / 305H (Bluetooth mode light on/off)
Around 104H / 227H (2.4G mode light on/off)
Up to 30 hours of continuous playtime
Charging PortUSB-CUSB-C
Charging Time6 HoursQuick Charge (10 mins provides up to 2 hours of play); includes a desktop/wall-mountable charging hanger
Power Input5V ⎓ 1A5V at 500mA to 2A (maximum 10W)
Control AppEDIFIER ConneX App None
In The BoxHeadset
USB cable
2.4G dongle (USB-A+USB-C)
User Manual
Headset
PlayStation Link™ USB adapter
PULSE Elite™ charging hanger
Mounting plate
USB cable
User manual
edifier-g5-max-black-dongle
The Bottom Line
At $149.99, the Edifier HECATE G5 MAX looks like a serious swing at the increasingly crowded wireless gaming headset category. The combination of THX Spatial Audio+, 2.4GHz low-latency wireless, Bluetooth 6.0 with LHDC 5.0 support, USB connectivity, AI-assisted microphone noise reduction, and a claimed 305-hour battery life gives Edifier a strong spec sheet against the Sony Pulse Elite and similarly priced models from Razer, ASUS, SteelSeries, Logitech, and others.
What makes the G5 MAX stand out is the feature mix. THX Spatial Audio+ and HECATE Driver software give PC users more control over surround processing and sound profiles, while the enormous battery-life claim could be a major advantage for gamers who hate charging yet another device. What is missing, at least for now, is real-world confirmation of the sound quality, microphone performance, comfort over longer sessions, and how well each connection mode works across PC, PlayStation, and Xbox.
This is clearly aimed at gamers who want one wireless headset for competitive play, streaming, music, movies, and everyday use without spending Audeze Maxwell money. If the G5 MAX performs anywhere close to what Edifier is promising, Sony’s Pulse Elite may not be the only headset in this price range that needs to start looking over its shoulder.
Price & Availability
2026 Audio-Technica ARH-AL5NC Wireless Headphones
Can open-back headphones work as everyday wireless cans? Audio-Technica’s ATH-AL5NC add LDAC, ANC, wired playback and up to 75 hours of battery life.
2026 Marantz MCR 60n CD Player and Streaming Amplifier in Black 2026 Marantz MCR 60n CD Player and Streaming Amplifier in Black
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
Sony Headphone Launch - September 2026 Sony Headphone Launch - September 2026
2026 Layer Audio Design Gen-300B Integrated Tube Amplifier Front 2026 Layer Audio Design Gen-300B Integrated Tube Amplifier Front
Layer's GEN-300B delivers 10 watts of Class A tube power for speakers and headphones from $1,499. Can it challenge far pricier 300B amps?
2026 Orchard Audio Starkrimson HT Ultra Front Angle 2026 Orchard Audio Starkrimson HT Ultra Front Angle
2026 TCL Q95K Soundbar System Lifestyle 2026 TCL Q95K Soundbar System Lifestyle
The TCL Q95K combines 11.1.4 channels, 22 drivers, wireless surrounds, dual 7-inch subwoofer drivers and Bang & Olufsen tuning.
At $499 per pair, the versatile Edifier R2750DB MKII wireless speakers feature three-way sound, HDMI eARC and LDAC Bluetooth for desktop, bookshelf or stand-mount...
OXS Storm A2 delivers budget-friendly wireless gaming headphones with 7.1 virtual surround, hybrid active noise cancellation, ultra-low latency, and versatile cross-platform support.
Gaming Headsets
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
At $369, the Edifier M90 are versatile wireless speakers that also include HDMI eARC for easy connectivity to PCs or TVs. Just make sure...
