Denon Introduces Affordable AVR-S980H 7.2-channel A/V Receiver With Convenience Upgrades
Denon AVR-S980H adds wireless surround support, 1440p pass-through, and channel level monitoriing offering a flexible step-up from soundbars under $1,000.
Denon AVR-S980H Home Theater A/V Receiver Lifestyle
Denon is doubling down on the sweet spot of the A/V receiver market with the new AVR-S980H, a 2026 update to its popular S-Series lineup that replaces the 2022 AVR-S970H. Positioned at the top of its affordable S-series range, the AVR-S980H builds on its predecessor with refinements aimed at easier setup, improved system control, and broader compatibility for modern home theater and gaming setups—all without pushing buyers into premium price territory.
“Denon has always believed that when you make something better, it sounds better, and that ethos has guided every first we’ve brought to the industry,” said Lyle Smith, President of Sound United at HARMAN. “Better sound is powerful, and it brings people closer to the stories, music, and moments they love. With the AVR-S980H, we’re giving families an easy way to make everyday experiences feel more engaging and far more enjoyable.”
denon-avr-s980h-av-receiver-angle
What’s New in the Denon AVR-S980H?
  • Improved performance through carefully selected internal components.
  • Channel Level Monitoring that provides real-time visibility into speaker levels, making it easier for users to fine-tune and troubleshoot their setup.
  • 1440p Video Pass-Through support for modern gaming setups
  • New Web UI that provides a more modern, browser-based interface for setup and control, improving ease of use for both consumers and installers.
Additional Feature Highlights
denon-avr-s980h-av-receiver-front-panel
Exterior Design: Starting with the basics, the AVR-S980H keeps things clean and functional, with a rectangular status display and a straightforward front panel. Essential controls are easy to access, so you’re not digging through menus just to get sound out of the thing.
Channel Configuration: The AVR-S980H incorporates a 7.2-channel configuration that can also be used in a 5.2.2 channel setup for Dolby Atmos.
Amplification: Incorporating Class A/B amplification, the S980H can deliver up to 90 watts per channel. This makes it suitable to handle all forms of content with a wide range of speaker systems in small-to-medium-sized rooms.
Surround Sound Support: The AVR-S980H provides support for several surround sound formats, including Dolby Atmos and DTS:X.
Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle
Wireless Surround Option: The AVR-S980H will support Denon Home 200, 400, and 600 speakers as wireless surrounds via a forthcoming firmware update. Once enabled, it offers a cleaner, more flexible home theater setup for rooms where running speaker wire isn’t practical.
Wireless Connectivity: Bluetooth. AirPlay 2 and Wi-Fi are also included.
HEOS Home App: The AVR-S980H features integrated HEOS, enabling streaming from multiple music services including Qobuz, with full multi-room control. HEOS-compatible wireless speakers can work alongside wired speakers, supporting up to 64 zones. You can play the same track throughout your home or select different music for each zone, creating a flexible, whole-home audio system.
HDR Support: For further video support, via HDMI, the AVR-S980H can pass through HDR10, Dolby Vision, HDR10+, and HLG HDR formats to a TV or video projector.
Two-sources with Two Zones: In addition to wireless multi-room audio, the AVR-S980H supports two-source, two-zone wired setups. This allows users to enjoy 5.1 channel surround sound in the main room and listen to a different source in
a second room in two-channel stereo, or play the same source in two rooms.
Room Correction: The AVR-S980H includes Audyssey MultEQ, Dynamic EQ, and Dynamic Volume for precise room calibration and consistent audio performance.
HDMI 2.1: The S980H provides HDMI 2.1 inputs with eARC, supporting 4K/120Hz and 8K/60Hz signals, VRR (Variable Refresh Rate), ALLM (Auto Low Latency Mode), and QFT (Quick Frame Transport), making them ideal for high-performance gaming and next-gen video sources. For added video and gaming support, the AVR-S980H provides 1440p resolution pass-through and is AMD FreeSync (TM) compatible.
Phono Input: For vinyl record fans, the AVR-S980H includes a dedicated phono input that supports MM (Moving Magnet) cartridges, making it easy to connect a traditional turntable. Turntables with built-in phono preamps can be connected to any standard analog input instead.
denon-avr-s980h-av-receiver-rear
Hi-Res Audio: High-resolution audio up to 24-bit/192kHz is supported. Compatible digital formats include MP3, WMA, WAV, MPEG-4/AAC, FLAC, and ALAC, as well as DSD playback at 2.8 and 5.6 MHz.
Compressed Audio Restorer: This feature improves compressed audio files such as MP3, WMA, and AAC by recalculating the frequency range to restore detail and clarity, making digital tracks sound more natural.
Voice Control: The AVR-S980H is compatible with Alexa Built-in, Google Assistant, and Siri for hands-free operation.
Smartphone App Control: Full control via iOS and Android apps allows easy access to all settings and features.
Denon AVR-S Series Onscreen Setup Assistant
The Denon AVR-S980H Series receiver comes with a built-in Setup Assistant that simplifies the installation process. When the AVR is powered on for the first time (with the TV on and the correct input selected), the guided setup menu launches automatically. If you exit the Setup Assistant using the BACK button on the remote, it can be reopened anytime from the main menu (GUI).
Denon AVR Setup menu
The Setup Assistant guides you through:
  • Language selection
  • Speaker setup and connections
  • Speaker calibration using Audyssey (when applicable)
  • Network connection setup (when applicable)
  • ARC/eARC HDMI configuration
  • Input assignment and labeling
  • Mobile control app download instructions
This process helps the AVR-S980H perform properly from the start, keeping setup straightforward for first-time home theater users.
Comparison
Denon ModelAVR-S980H (2026)AVR-S970H (2022)
Price$949$949
Product TypeHome Theater ReceiverHome Theater Receiver
Amplified Channels77
Power Output90 watts per channel (8 ohm, 20Hz-20kHz, 0.08% 2ch Drive)
125 watts per channel (6 ohm, 1kHz, 0.7% 2ch Drive)
185 watts per channel (6 ohm, 1kHz, 10% 1ch Drive)
Auto Speaker Setup via MicrophoneYes – Audyssey MultEQYes – Audyssey MultEQ XT 32
Front Display1-Line FLD1-Line FLD
GUI Languages3 (English, French, Japanese)3 (English, French, Japanese)
Setup AssistentYesYes
HDMI Inputs66
(3 support 4K/HDR 120Hz – pass-through)
(3 support up to 8K/50Hz pass-through and 4K to 8K upscaling)
HDMI Outputs22
HDMI ARC/eARC YesYes
Analog Video Inputs (Composite)00
Analog Video Outputs (Composite)00
Analog Audio Inputs44
Phono Input (MM)11
Analog Audio Outputs00
Digital Optical Inputs22
Digital Coaxial Inputs11
Subwoofer Output22
Headphones11
Speaker Terminals7 (Binding Posts)7 (Binding Posts)
Bi-Amp OptionYesYes
Zone 2 Speaker  OptionYesYes
Speaker A/B OptionYesYes
USB2 (1 front for audio/1 rear for power)2 (1 front for audio/1 rear for power)
AM/FM TunerYesYes
EthernetYesYes
Wi-FiYesYes
BluetoothYesYes
HEOSYesYes
Apple AirPlay 2YesYes
RoonYes (Roon Ready) Yes (Roon Tested)
Surround Sound SupportDolby Atmos
Dolby Height
Virtualization
Dolby Music
Dolby TrueHD
Dolby Surround
DTS:X
DTS Master Audio
DTS Neural:X
DTS Virtual:X
Dolby Atmos
Dolby Height Virtualization
Dolby Music
Dolby TrueHD
Dolby Surround
DTS:X
DTS Master Audio
DTS Neural:X
DTS Virtual:X
HDR Pass-Through HDR10, HDR10+, Dolby Vision, HLGHDR10, HDR10+, Dolby Vision, HLG
Color Gamut Support BT.2020BT.2020
3D Viewing SupportNot IndicatedYes
Gaming SupportVariable Refresh Rate (VRR)
Quick Frame Transport (QFT)
Auto Low Latency Mode (ALLM)
1440p Video Resolution Pass-Through
AMD FreeSync (TM) Compatible
System Remote ControlDenon AVR Remote (RC-1263)
Remote App
Web UI (Updated)
Denon AVR Remote (RC-1253)
Remote App
Web UI
Power Consumption430W400W
Power Consumption, No Sound (ECO On/Off)35W/75W35W/75W
Standby Power Consumption0.1W0.1W
CEC Standby Consumption0.5W0.5W
Dimensions (WDH)17.1 x 13.4 x 6.6 inches (Antenna Horizontal)
 17.1 x 13.4 x 9.3 inches (Antenna Vertical)
Weight (Lbs)21 21
What’s in the Box1 x AVR-S980H
1 x Denon AVR Remote (RC-1263)
Remote Control Batteries
AM/FM antennas
2 x Bluetooth/WiFi antennas
1 x Audyssey Calibration Microphone
Quick Start Guide
1 x AVR-S970H
1 x Denon AVR Remote (RC-1253)
AM/FM antennas
Microphone
Quick Start Guide
FinishBlackBlack
denon-avr-s980h-av-receiver-gaming
The Bottom Line
Denon isn’t rewriting the playbook with the AVR-S980H, but it is tightening the formula where it matters for buyers under $1,000. The updates focus on usability, system control, and broader compatibility for modern gaming and streaming setups—practical improvements that make day-to-day use less of a chore. The addition of wireless surround support (via firmware) is arguably the most forward-looking move here, offering a cleaner path for users who want surround sound without turning their living room into a wiring project.
What’s missing is just as telling. There’s still no sign of HDMI 2.2, although to be fair, nothing in the current ecosystem really demands it yet. The lack of detail around the new web interface is also a miss, especially as ease of control becomes a bigger selling point in this category. And for those expecting a major sonic or architectural leap over the AVR-S970H, this isn’t that moment.
The AVR-S980H is aimed squarely at buyers ready to move beyond a soundbar but not interested in the cost or complexity of higher-end separates or flagship AVRs. It’s a practical, incremental upgrade that keeps Denon competitive in the entry-level space—while leaving the door open for a more meaningful overhaul of the S, X, and A series down the line.
Pro Tip: Denon and Marantz are sister companies under Sound United and Harman International, which, in turn, is owned by Samsung.
Price & Availability
The Denon AVR-S980H is available for $949 at Crutchfield.
Tip: The Denon AVR-S970H is likely to go on sale while supplies last. Check Amazon.
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Can JBL Cove challenge Sonos, HEOS and Bluesound with Whole Home audio, Dolby Atmos and automatic room tuning?
The stalwart Japanese HiFi brand lives on with this, their latest nine-channel AV receiver. Does it offer the right blend of performance, features and...
Daily Deals
Can Denon’s DP-500BT bring wireless convenience to vinyl without sacrificing sound quality?
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Can Denon’s Home 200 and Home 400 wireless smart speakers challenge Sonos with HEOS multi-room audio, Dolby Atmos Music, and stronger sound at premium...
