Christie CP4415m RGBH 4K Projector Brings 15,000 Lumens to CEDIA 2026 and Your Ceiling Has Been Warned
Christie CP4415m RGBH 4K Projector Angle
Christie apparently has a different definition of “compact” than the rest of us.
The Christie CP4415m-RGBH weighs 132 pounds, consumes around 1,060 watts, uses a self-contained liquid cooling system, and can pump out as much as 15,000 lumens. Christie also says it is suitable for screens up to 52 feet wide.
You may want to reinforce the ceiling and buy a much larger home.
The CP4415m-RGBH is not actually making its product debut at CEDIA Expo 2026. Christie introduced the RGBH cinema projector family in late 2025, and the CP4415m-RGBH is already being deployed in commercial cinemas. What makes its appearance in Denver more interesting is that Christie is now explicitly positioning the projector as an option for premium residential home cinemas.
Christie is not taking a conventional home theater projector, adding more laser output, and calling it professional. The company is effectively moving in the opposite direction by taking technology designed for movie theaters, screening rooms, and post-production facilities and asking whether people building very large dedicated home cinemas might want some of it as well. Considering some of the theaters we saw at CEDIA 2025, the answer is probably yes.
Native 4K and Three Chip DLP
christie-cp4415-4420m-rgbh-front-low-right
The CP4415m-RGBH uses a 0.98-inch 4K SST three-chip DLP Cinema imaging system with native 4096 x 2160 resolution. Each primary color gets its own DMD, so there is no color wheel and no pixel shifting required to generate a 4K image.
Christie’s Phazer hybrid laser illumination system delivers up to 15,000 lumens with a high-brightness cinema lens, along with DCI-P3 color reproduction. The laser system is rated for more than 50,000 hours of operation, while a sealed optical path is designed to reduce dust contamination and long-term maintenance requirements.
For perspective, a JVC DLA-NZ500 is rated at 2,000 lumens, Sony’s BRAVIA Projector 7 at 2,200 lumens, and Epson’s QB1000 at 3,300 lumens. Even Sony’s much more expensive BRAVIA Projector 9 is rated at 3,400 lumens.
Even the Epson QL7000, which is specifically designed as a very high-output residential projector for large screens and rooms with ambient light, tops out at 10,000 lumens. The Christie still has another 50% on top of that.
Contrast is rated as high as 6,000:1 full-field on/off, although there is an important qualification. Christie specifies maximum brightness using its high-brightness cinema lens and maximum contrast with one of its UHC lenses, so those two maximum numbers should not be interpreted as something you necessarily get simultaneously.
Christie also incorporates Electronic Color Convergence, LiteLOC white-point tracking, a motorized Intelligent Lens System, and its CineLife+ electronics platform. LiteLOC is designed to maintain color balance and brightness as the laser light source ages, which matters considerably more when the projector is expected to stay installed for many years rather than being replaced when the next HDMI specification comes along.
4K at 120Hz? Read the Fine Print
Christie states that the CP4415m-RGBH platform can handle very high bitrate content at up to 4K/120Hz, but gamers should put the credit card back in the wallet for a moment.
The projector has two HDMI 2.0 inputs, two DisplayPort 1.2 connections, four 12G-SDI inputs, and Ethernet. Christie specifies 4K/120Hz operation when the projector is used with a GDC SR-6400 integrated media block, rather than through an HDMI 2.1 input from a PlayStation 5 or Xbox Series X.
In other words, this is a cinema projector capable of extremely high frame-rate professional playback. It is not a 132-pound gaming projector. Although that would certainly end the argument over who gets the television.
christie-cp4415-4420m-rgbh-right
Why Would You Put This in a House?
The obvious application is a large dedicated home theater with a very large projection screen, particularly installations using acoustically transparent material where substantial light output can be advantageous.
At 33.5 x 26.8 x 12 inches and 132 pounds, the CP4415m-RGBH is considerably more manageable than Christie’s truly extreme projection systems, but nobody should confuse manageable with something you casually bolt to the ceiling on Saturday afternoon. It requires professional installation, substantial power, careful ventilation planning, and potentially optional heat extraction depending on the room.
The internal cooling system is self-contained and Christie describes the projector as compact and quiet by cinema-projector standards. Again, context is everything. This is still a piece of commercial cinema hardware sitting in your house.
christie-cp4415-4420m-rgbh-electronic-panel
Where Does It Fit in Christie’s Home Theater Lineup?
Christie has been pushing harder into ultra-premium residential cinema.
At Audio Advice Live 2026, we covered the Christie Korus 4K1000A-KS, a much more conventional residential option delivering more than 10,000 lumens from a single-chip DLP design.
At the other end of sanity sits the $400,000 Christie Eclipse G3, which we selected as our cost-no-object projector and saw at CEDIA 2025. Eclipse uses a six-DLP architecture, produces up to 30,000 ANSI lumens, and is aimed at home theaters where both the screen and bank account have achieved industrial scale.
The CP4415m-RGBH offers something different: native 4K three-chip DLP Cinema architecture, enormous light output, commercial-grade processing, and a chassis that is at least realistic for a purpose-built residential projection room.
Christie currently lists the CP4415m-RGBH as $106,000, which could change subject to tariffs.
The Bottom Line
MicroLED and increasingly massive televisions continue to invade territory once owned exclusively by projectors, but there is still no practical substitute for projection when the screen becomes genuinely enormous.
Christie knows something about enormous screens.
The CP4415m-RGBH is interesting because it brings actual cinema hardware into a residential market where some customers are no longer satisfied with consumer projectors stretched to their limits. Native 4K three-chip DLP, 15,000 lumens, DCI-P3 color, commercial-grade processing, and a 50,000-hour laser light source make it a very different proposition from the typical home theater projector.
For more information: christiedigital.com
Splurge Audio Video Hi-Fi Tech Gifts 2026
Our favorite home theater projectors of 2026 deliver best-in-class performance across UST, lifestyle, and long throw categories.
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
NextLevel's Mantelbar hides a Sonos Arc soundbar or speakers inside the fireplace mantel. Clever architecture, or has the mantel finally earned its keep?
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
This episode covers the Best of CEDIA Expo 2026 with Caleb Denison, of CalebRated, including MicroLED video walls, 4K TVs and more.
Priced from $1,999 to $2,699, Epson's new line of 4K home theater projectors feature 120Hz gaming, laser light source, and brightness from 2500 to...
