In a headphone market crowded with plastic shells and predictable tuning, Dongguan-based brand SIVGA continues to carve out its niche the old-fashioned way with real wood and old-school wired design. The new SV021 Pro arrives at $179 with handcrafted wooden earcups, a closed-back architecture, and a promise of premium aesthetics without the usual boutique markup.
But in a category where looks can only get you so far, the real question is whether SIVGA’s latest budget-friendly over-ear delivers the sonic performance to match its striking build, or if it’s simply another pretty face in a very competitive field.
Driver Technology
Inside each earcup of the SV021 Pro sits a 50mm dynamic driver developed specifically for this model rather than pulled from a generic parts bin. SIVGA states that considerable in-house tuning and material research went into its design.
The diaphragm uses a five-layer aluminum composite construction, intended to balance rigidity with controlled damping. In practical terms, a stiffer diaphragm can improve transient response and clarity, while proper damping helps prevent unwanted resonance that can blur detail.
Driving the diaphragm is an ultra-fine black copper-clad aluminum voice coil. This type of voice coil is commonly used to reduce moving mass while maintaining conductivity, which can improve efficiency and responsiveness. SIVGA also claims benefits to perceived resolution and micro-detail retrieval.
The driver assembly itself is mounted within a six-layer reinforced composite housing, engineered to minimize unwanted vibration and reduce distortion by improving structural stability and energy transfer.
The technical story sounds promising on paper. Whether that engineering translates into real-world sonic performance is something best judged in listening — which we’ll dive into next.
Design & Comfort
Before getting to the sound, it’s worth spending a moment on design and comfort because this is an area where SIVGA has built a strong reputation. With the SV021 Pro, the brand continues that tradition. At $179, the overall build quality and material selection feel well above what you typically expect at this price point.
Our review sample came in the lighter beechwood finish. The fine grain pattern is clearly visible and gives the headphones an authentically handcrafted character rather than a synthetic “wood look.” For those who prefer something darker and more understated, SIVGA also offers a zebrawood version, which delivers a similarly premium aesthetic with a subtler visual impact. Whichever finish you choose, the attention to detail in the woodwork stands out immediately.
The structural components including the headband frame, yokes, and adjustment rails, are constructed from CNC-machined metal. This manufacturing process allows for tight tolerances and consistent precision, contributing to a solid, confidence-inspiring feel. The headphones never come across as fragile or delicate. While I didn’t test their durability with an accidental drop, they feel robust enough to handle normal daily use without anxiety.
Comfort is another area where the SV021 Pro performs well. At 289 grams, it’s relatively lightweight for a full-size closed-back design, and that lower mass pays dividends during longer listening sessions. The earpads are generously padded and notably soft, allowing the headphones to sit securely without creating pressure hotspots. On the head, they largely “disappear,” which is exactly what you want from a daily-use wired model.
The velour contact surfaces are also a smart choice. They feel gentle against the skin and do a good job of managing heat buildup, reducing that sweaty, sealed-in sensation that can occur with synthetic leather pads — especially in warmer environments.
There is one ergonomic limitation worth noting: the yokes do not swivel. For some listeners, a lack of horizontal articulation can affect how well the earcups conform to the jawline and head shape. In my case, the depth and plushness of the earpads compensated effectively, creating a consistent seal without issue. That said, fit is personal, and those with narrower or more angular head shapes may want to be aware of this design decision.
SIVGA includes a 1.6-meter detachable cable with the SV021 Pro, and it’s noticeably better than the generic rubber leads often bundled at this price. The supplied cable uses a quad-braided design with a fabric outer sheath, giving it a more premium feel while also helping to minimize microphonics. In daily use, it resists kinks and doesn’t retain awkward bends, which makes it easy to manage at a desk or in a portable setup.
The stock termination is 3.5mm single-ended, which will suit most users and devices. That said, those running balanced outputs from modern portable DAC/amps may wish SIVGA had offered a 4.4mm option in the box. Fortunately, the detachable design makes aftermarket upgrades straightforward.
Also included are a simple hemp storage pouch and a 6.35mm adapter for use with full-size amplifiers. With accessories covered, it’s time to focus on what matters most: how the SV021 Pro actually sounds.
Listening
On paper and certainly in the hand, the SV021 Pro checks a lot of boxes. It looks distinctive, feels premium for $179, and remains comfortable over long sessions.
Where things become more complicated is in its tuning.
In practice, the sonic presentation comes across as uneven, with balance issues that are immediately noticeable. Within the first few minutes of listening to familiar reference tracks, it became clear that something was not quite aligned. The frequency response does not feel cohesively voiced, and certain areas of the spectrum draw attention to themselves in ways that disrupt overall musicality.
That is somewhat surprising given SIVGA’s track record. The brand has demonstrated competent tuning before, and its sister company, Sendy Audio, recently impressed us with the Egret, a model that showed careful tonal balance and refinement. By comparison, the SV021 Pro feels less resolved in its final voicing decisions.
Let us break things down by frequency range, starting with the bass.
Bass
In the low frequencies, the SV021 Pro takes a decidedly heavy handed approach. The bass is elevated to the point where it becomes dominant, introducing bloom that spills into the lower midrange and softens overall clarity.
There is certainly an audience for this kind of presentation. Listeners who prioritize impact over precision may enjoy the added weight, especially with bass driven genres such as drum and bass or electronic music where a strong low end can create a more physical and immersive experience.
The trade off is control. The excess warmth masks finer details and reduces separation between instruments. Male vocals are particularly affected, often sounding pushed back in the mix. On tracks like “Papaoutai” by Stromae, his voice loses immediacy and presence, as if it is positioned behind the instrumental layer rather than anchored at the forefront where it belongs.
Midrange
By contrast, the midrange feels recessed. There is a noticeable dip through the central vocal region that robs instruments and voices of density and presence. As a result, guitars lack crunch, pianos lose harmonic richness, and vocals struggle to anchor the mix.
The overall impression is one of distance and diffusion. Instead of sounding centered and tangible, the mids come across as washed out, with reduced impact and body. The tonal imbalance between the elevated bass and pulled back midrange makes the presentation feel hollow rather than cohesive. Even casual listeners are likely to sense that the tuning does not sound quite right, as the core of the music lacks the weight and immediacy that define a natural sounding headphone.
Treble
The frequency response does recover somewhat as it moves into the upper midrange and lower treble. Female vocals cut through the mix with more clarity than male baritones, benefiting from the added energy in this region. There is a greater sense of articulation here, which helps prevent the presentation from sounding completely veiled.
However, that lift continues into the lower treble where it becomes problematic. A noticeable glare is introduced, adding sharpness that can turn strident at moderate to higher volumes. Over time, this emphasis contributes to listening fatigue rather than engagement.
Brass instruments in particular highlight the issue. On “Careless Whisper” by George Michael, the iconic saxophone line carries more bite than body, making the track sound harsher and more fatiguing than intended. Instead of smooth, sultry texture, the upper register leans toward edge and glare, which further reinforces the uneven tonal balance of the SV021 Pro.
Technicalities & Soundstaging
There is a sense that the underlying hardware in the SV021 Pro is capable of more than what its final tuning allows. The custom 50mm drivers appear technically competent, but the chosen sound signature limits their ability to showcase resolution and balance.
The elevated bass does more than just mask fine detail. It also compresses the perceived space, leading to a narrower soundstage and less precise imaging. Instruments tend to cluster rather than occupy clearly defined positions, which reduces layering and separation. While closed back headphones rarely deliver expansive staging, there is still a baseline expectation for coherence and placement that is not fully met here.
In direct comparison, models such as the FiiO FT1 and Beyerdynamic DT 700 Pro X present a more balanced frequency response with stronger spatial performance. Both offer better control in the low end and more convincing imaging, allowing them to sound more open and organized despite operating within the same closed back category.
Drivability
With a rated sensitivity of 106dB/mW and an impedance of 45 ohms, the SV021 Pro is very easy to drive. In practice, it reaches high listening levels straight from a standard smartphone headphone jack without strain. There is no requirement for a dedicated amplifier to achieve adequate volume.
Using external sources does bring incremental improvements. Paired with dongle DACs and a desktop chain consisting of the SMSL DO400 and Aune S17 Pro, the presentation gained slight refinement in control and clarity. However, the changes were subtle rather than transformative. Given the headphone’s accessible price point, investing in higher end source equipment does not materially alter its core tuning characteristics. The fundamental tonal imbalance remains, and additional amplification cannot meaningfully correct it.
The Bottom Line
The SV021 Pro is a frustrating release because so much of it is done right. The wood earcups look fantastic, the CNC machined metal frame feels durable and confidence inspiring, the cable is better than most at this price, and long term comfort is genuinely impressive. At 289 grams with plush velour pads, it is easy to wear for hours. From a design and build perspective, this is one of the more premium feeling options under $200.
Unfortunately, none of that offsets the tuning. The elevated and bloated bass, recessed midrange, and glare in the lower treble combine to create an uneven and fatiguing presentation. Detail retrieval is masked, vocals lack natural body, and spatial performance suffers as a result. No amount of better amplification meaningfully corrects the core imbalance. That is the deal breaker.
SIVGA has proven it can voice headphones well in the past, which makes this outcome more disappointing. At $179, there are closed back alternatives that deliver a more cohesive and accurate sound signature. When sound quality is the primary metric, as it should be with any headphone, the SV021 Pro falls short. For that reason, it is difficult to recommend despite its undeniable strengths in design and comfort.
Pros:
- Custom 50mm dynamic drivers with multi layer aluminum composite diaphragm and lightweight voice coil design
- Genuine beechwood or zebrawood earcups with solid CNC machined metal frame give a premium look and feel for the price
- Lightweight 289 g construction with plush velour pads delivers excellent long term comfort
- Elevated bass response adds strong impact for electronic, hip hop, and other bass driven genres
Cons:
- No swivel in the yokes may affect fit and seal for some head shapes
- Uneven tuning with boosted bass, recessed midrange, and pronounced lower treble glare reduces tonal balance and realism
- Congested staging and less precise imaging compared to similarly priced closed back competitors
Where to buy:
Related Reading:
- Meze Audio STRADA Review: Closed-Back Contender Or An EQ Dependent Gamble?
- Sendy Audio Egret Review: Do These $958 Planar Magnetic Headphones Challenge Far More Expensive Rivals?
- Best Audiophile Headphones (Wired): Editors’ Choice 2025
- Fosi Audio I5 Review: Planar Magic Or Headphone Misfire?
