Vertere Phono-1 LX MM/MC Phono Preamp Brings Lower Noise and Greater Control to Vinyl Playback
Vertere’s $2,399 Phono-1 LX phono preamp adds quieter power, flexible MM/MC loading, revised grounding, and serious competition for MoFi and Cyrus.
2026 Vertere Phono-1 LX Colors Front
Vertere has upgraded its Phono-1 phono preamp line with the $2,399 Phono-1 LX, a new MM/MC phono stage that replaces the Phono-1 MKII L. The core RIAA circuit remains intact, but the supporting hardware has been given serious attention: a revised gold-plated PCB, upgraded internal DC power supply, improved AC input filtering, and a simpler two-way earthing switch. None of that sounds especially glamorous until you remember that a phono cartridge produces a microscopic signal and every bit of hum, RF interference, or power-supply noise is waiting nearby with a sharpened knife.
Founded in the UK by Roksan co-founder Touraj Moghaddam, Vertere has built its reputation around treating analog playback as a chain of mechanical and electrical problems worth solving properly. eCoustics’ coverage of the Vertere DG-X turntable found the same approach in its motor drive, bearing, power supply, and resonance-control work. The Phono-1 LX applies that philosophy to the space between cartridge and amplifier, where quieter power, better grounding, and more careful filtering can matter as much as the turntable itself.
Related Reviews: Muarah MU-2 Phono Preamplifier Review: The Audiophile System Builder
vertere-phono-1-lx-rear
Vertere Phono-1 LX (rear)
Connections: The Phono-1 LX keeps connectivity relatively simple, with single-ended RCA inputs, stereo RCA line outputs, and grounding terminals. It supports both moving magnet and moving coil cartridges, but there are no balanced XLR outputs. At this price, that will feel like a missed opportunity for listeners whose preamplifiers or integrated amplifiers offer balanced inputs. Vertere has clearly prioritized cartridge matching and noise control over connection flexibility.
Earthing Switch: Vertere has replaced the previous grounding arrangement with a new two-way earthing switch that toggles between “Earth Lift” and “Earth Connection.” The company says the revised design is easier to operate and intended to provide a longer service life, while giving owners a straightforward way to address grounding issues within their own system.
Clean and Silent Power: The Phono-1 LX uses a revised AC input with additional filtering intended to prevent high-frequency and RF interference from entering the circuit. That works alongside an upgraded internal DC power supply designed to deliver cleaner, more consistent power to the phono stage. Vertere says the result is a quieter background and greater access to low-level detail buried in the groove.
Internal Circuitry: A new gold-plated PCB is intended to improve soldering consistency and long-term reliability across the circuit. Better construction and more careful grounding are exactly the kind of details that matter when a phono stage is amplifying an extremely low-level cartridge signal.
Cartridge Matching: The Phono-1 LX offers 10 gain settings, 15 resistance values, and nine capacitance options for more precise matching with moving magnet and moving coil cartridges. That gives owners meaningful flexibility when changing cartridges or dialing in an existing setup.
Power Indicator: The Phono-1 LX adds a blue-green power indicator LED that visually aligns it with the Vertere DG X, Tempo, Imperium, and CALON. It is a small detail, but it gives the phono stage a more consistent identity within the wider Vertere range.
Chassis and Cover: Vertere has fitted the Phono-1 LX with a new cover finished in fine-textured metallic silver. The update gives the unit a more refined appearance and a more tactile finish than the earlier model. Vertere has also eliminated the four top-mounted fixing screws, creating a cleaner, uninterrupted surface that brings the design closer to the company’s CALON phono preamplifier.
vertere-phono-1-lx-inside
Vertere Phono-1 LX (inside)
Comparison
Vertere Acoustic Model Phono-1 LXPhono-1 MKII / MKII L
Product Type Phono PreampPhono Preamp
Price$2,399$1,995
Circuitry Precision Components | Gold-Plated PCB Gold-plated, L-shaped circuit board that moves the linear power supply directly to the main PCB for vastly optimized grounding and lower impedance
Power Supply Linear, Int. Switchable
Ultra Low Noise | Encapsulated Transformer
Internal linear power supply
Gain Settings 40 dB to 63 dB in 12 Steps
High Gain version – Add 6.4 dB to all settings
40.2 dB to 62.8 dB in 12 Steps
Resistance 47k for MM;
78R to 47K for MC – In 14 Steps
47k for MM;
78R to 47K for MC in 14 Steps
Capacitance 100pF & 430pF for MM
100pF to 1.02uF for MC – In 9 Steps
Frequency Response 20Hz – 20kHz +/- 0.2dB 20Hz – 20kHz +/- 0.2dB
Noise <-78dB – AWD <-78dB – AWD
THD+N 0.009% – @ 1V < 0.03%
Finish Orange, Silver, Black & Black Acrylic DG Style Orange, Silver, Black
Idle Power Consumption 1.7 Watts Not Indicated
Dimensions (WHD)210 x 240 x 55 mm235 x 55 x 235 mm
Weight 2.2 kg (4.9 lbs)1.8 kg (4 lbs)
vertere-phono-1-lx-silver
Vertere Phono-1 LX
The Bottom Line
The Vertere Phono-1 LX is not aimed at casual vinyl listeners looking to replace the phono input inside an affordable integrated amplifier. At $2,399, it is intended for high performance analog systems with a turntable, tonearm, and cartridge capable of exposing the benefits of lower noise, more precise loading, and better system grounding.
Its strongest appeal will be to owners of Vertere turntables such as the DG X and DG-1S, particularly those using the company’s XtraX moving coil or Dark Sabre moving magnet cartridges. The broader adjustment range should also make it a credible option for listeners using cartridges from other manufacturers, provided the rest of the system is sufficiently revealing. The Phono-1 LX is less about adding a long list of headline features than refining the electrical environment around a very small cartridge signal.
The competition is not gentle. The $2,495 MoFi UltraPhono Pro offers front-panel gain and loading controls, balanced and single-ended outputs, a mono switch, subsonic filter, and a more overtly feature-rich approach. The $2,899 Cyrus 40 PPA goes further still with four configurable inputs, balanced and RCA outputs, remote control, level meters, a warp filter, and an optional external power-supply upgrade. Gold Note’s PH-10 is another serious rival for listeners who want balanced outputs, selectable EQ curves, and two independently configurable inputs.
The Muarah MU-2 remains the more characterful alternative for listeners who want tube-based circuitry, easy loading changes, and a fuller, warmer tonal balance. Its RCA-only connections and lower 56dB MC gain, however, make it a less natural fit for very low-output moving coil cartridges.
Price & Availability
The Vertere Phono-1 LX comes in four finishes: silver, orange, black, and black acrylic, with a price of $2,399 (£1650 / AU$3250) through Authorized Dealers.
For more information: vertereacoustics.com
2026 Triangle Borea BR05 Stand-mount Loudspeakers
Triangle’s Borea BR05 combines retro styling, an 8-inch woofer, and serious cabinet engineering. Who decided bookshelf speakers had to be so small?
Moon 341 Integrated Amplifier Black Angle Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
A new turntable, phono stage, cartridge or speaker could be the upgrade you've been looking for or the perfect gift for any vinyl lover.
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Musical Fidelity's new flagship M8x Vinyl Phono Stage is both fully discrete and fully balanced with improved gain stage and more.
