SIVGA Nightingale PRO IEM Debuts: Affordable Planar Performance Without the Premium Price
SIVGA’s Nightingale PRO is a $269 planar magnetic IEM with a multi-magnet driver, CNC-machined housing, low 16 ohms impedance, and wide 20Hz-40kHz response for versatile, source-friendly performance.
SIVGA Nightingale PRO IEMs Connected
SIVGA is coming back for another swing at the fiercely competitive wired IEM market with the Nightingale PRO — a next-gen planar magnetic design that takes the original 2023 Nightingale and gives it a serious upgrade. Built around a proprietary multi-magnet planar driver and wrapped in precision-machined aluminium-magnesium housings, the Nightingale PRO promises the kind of openness, balance, and clarity you usually have to pay a lot more for.
And like most of the more interesting overseas IEMs these days, North American listeners won’t find it at a local retailer — you’ll have to buy it online and take the leap, just like the rest of us.
Multi-Magnet Planar Driver: Enhanced Precision and Power
sivga-nightingale-pro-iem-interior
The Nightingale PRO uses a newly developed planar magnetic driver built for SIVGA, featuring a multi-magnet array paired with high-efficiency neodymium magnets. On paper, this design aims to improve control, responsiveness, and overall efficiency compared to the original model.
Its diaphragm combines an ultra-light 0.008mm composite base with a 0.006mm aluminum ribbon conductor, a configuration chosen to reduce mass and support more precise driver movement. The overall structure is engineered to provide a wide soundstage, solid separation, and strong dynamics, though final performance will depend on real-world listening.
Refined Acoustic Balance
The Nightingale PRO is designed to handle a wide range of material, from sparse acoustic recordings to dense electronic arrangements. Its planar driver and tuning approach are intended to highlight fine details while maintaining balance across the frequency range. SIVGA’s goal with this model is to provide an engaging, low-fatigue listening experience suitable for longer sessions, though actual results will come down to individual listening and system pairing.
sivga-nightingale-pro-iem-top
Comfort & Long-Wear Ergonomics
The Nightingale PRO’s acoustic housing is machined from an aviation-grade aluminum-magnesium alloy using a 5-axis CNC process, a choice aimed at improving structural consistency and controlling unwanted resonance. Each earpiece is finished with hand-polished solid wood faceplates, reflecting SIVGA’s ongoing use of wood elements across its product line.
For fit, the Nightingale PRO includes multiple eartip options to help users find a secure and comfortable seal. The design and accessory set are intended to support longer listening sessions, though comfort will naturally vary depending on ear shape and tip selection.
sivga-nightingale-pro-iem-accessories
Technical Specifications & What They Mean for Buyers
The Nightingale PRO lists a frequency response of 20Hz–40kHz, an impedance of 16Ω, and a sensitivity of 100dB ±3dB. These figures indicate that the IEM should be easy to drive from most portable sources, including smartphones with dongle DACs, portable players, and desktop headphone amps. The detachable 1.2m silver-plated OFC cable uses standard 0.78mm 2-pin connectors, making it compatible with a wide range of aftermarket cables.
At 27g per pair (without the cable), the weight falls within the typical range for metal-housed IEMs, suggesting they should be manageable for extended listening depending on fit and tip choice. The overall spec sheet positions the Nightingale PRO as a straightforward, source-friendly planar IEM that shouldn’t require specialized gear to perform as intended.
Comparison
sivga-nightingale-pro-vs-original
Nightingale PRO (2025)Nightingale (2023)
Product TypeIEM (In-Ear Monitor)IEM (In-Ear Monitor)
Price$269$229
Driver TypePlanar magnetic with multi-magnet structurePlanar magnetic
Diaphragm0.008mm composite film with 0.006mm aluminium ribbon conductorComposite film with aluminium coil conductor
HousingCNC-machined aluminium-magnesium alloy with hand-polished wood faceplatesCNC-machined aluminium-magnesium alloy with hand-polished wood faceplates
Frequency response20Hz – 40kHz20Hz – 40kHz
Impedance16Ω16Ω
Sensitivity100dB ±3dB100dB ±3dB
CableDetachable 1.2m silver-plated OFC with 0.78mm 2-pin connectorsDetachable 1.2m silver-plated OFC with 0.78mm 2-pin connectors
Weight27g (without cable)15g (without cable)
Package Contents1 x SIVGA Nightingale PRO IEMs
1 x Detachable Connector Cable (4.4mm)
1 x Hard carrying case
2 x Eartip size M
2 x Eartip size L
2 x Eartip size S
1 x Eartip case
1 x SIVGA Nightingale  IEMs
2 x Eartip size M
2 x Eartip size L
2 x Eartip size S
1 x Eartip case
sivga-nightingale-pro-iem-connections
The Bottom Line
SIVGA isn’t the first brand most listeners associate with IEMs, but they’ve built a solid track record on the headphone side. We reviewed their SV023 and Luan open-back headphones in 2022 and 2023, both of which showed the company’s ability to deliver thoughtful engineering and strong build quality at attainable prices. The Nightingale PRO feels like the natural next step in that evolution.
Sitting in the mid-$200 range, it enters a brutally competitive segment that includes the Campfire Audio Axion, Fosi Audio IM4 ($99), and Meze Audio Alba ($159). It also bumps shoulders with higher-tier planar offerings like the Noble Van Gogh ($699) and the Astell&Kern Luna ($2,700).
sivga-nightingale-pro-iem-cable
On paper, the Nightingale PRO aims for a practical sweet spot where engineering, materials, and pricing line up in a way that could appeal to a wide range of buyers. If it performs as designed, SIVGA may have added a genuinely compelling IEM to its growing lineup.
Price & Availability
The SIVGA Nightingale PRO IEM will be available to buy from November, 20, 2025 for $269 at Amazon and selected retailers across the UK, US, and Europe.
The original Nightingale IEM is available for $229 at Amazon.
2026 Technics Fritz Hansen Limited Edition SL-40CBT Turntable
Technics gives the SL-40CBT Bluetooth turntable a limited Fritz Hansen makeover, proving Danish design still knows how to shame a living room.
Wharfedale Elysian R Series Loudspeakers in Grey Wharfedale Elysian R Series Loudspeakers in Grey
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Noble Kronos flagship IEMs deliver cutting-edge 9-driver hybrid sound with titanium shells. Are these $4,500 earphones worth the hype and price?
Over-Ear Headphones
Can SIVGA’s $179 SV021 Pro turn premium wood build and comfort into great sound, or does its uneven tuning hold it back?
Is the SIVGA Nightingale Pro the planar IEM that finally gets linear tuning right, or is its warm, reference sound too niche to break...
Our picks for the best IEMs of 2025 include Beyerdynamic, Melody Wings, Campfire, 64 Audio, HiSenior and UE Pro.
In 2024, the best universal fit in-ear monitors (IEMs) at various price points are from Final, Campfire Audio and Noble Audio.
Daily Deals
Prime Days are here and now's a great time to pick up a pair of Apple's latest wireless earbuds with active noise cancellation.
The HiFiMan TWS800 wireless IEMs face some stiff competition from Sony, Bose, and Apple.
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
