CD Players
Shanling’s ECZero AKM Portable CD Player Swaps DAC, Costs Less
For $319, Shanling’s ECZero AKM delivers high-quality headphone listening, Bluetooth streaming to wireless headphones or speakers, and CD ripping—all in a sleek portable design.
Shanling ECZero AKM Portable CD Player
Streaming may rule the charts, but physical media clearly didn’t get the memo. Vinyl keeps spinning its comeback story, and now CDs—the format everyone supposedly buried a decade ago—are staging their own resurrection. With companies like FiiO and Shanling rolling out sleek new portable players, it’s clear that people still want to own their music, not just rent it from the cloud. The latest example? Shanling’s ECZero AKM portable CD player, now hitting the U.S. thanks to Forte Distribution, and giving disc diehards one more reason to keep those jewel cases within reach.
Following the Shanling ECZero T hybrid tube/solid-state portable CD player, the new ECZero AKM strips out the tubes for an all-solid-state design—without ditching the sound quality or core features that made the original interesting. It delivers much of the same sonic character and digital flexibility but at a lower price point, making it a more accessible entry into Shanling’s portable CD lineup. eCoustics Editor-in-Chief Ian White has the ECZero AKM inbound for review, so expect his unfiltered thoughts and listening impressions in the coming weeks.
The ECZero AKM is designed to be an audiophile-grade portable CD player at a real-world price,” said Roger Fortier, VP and Director of Sales at Forte Distribution, U.S. distributor of Shanling Electronics. “Its DAC brings out every detail of a well-recorded piece of music.”
Shanling ECZero AKM Portable CD Player Overview
shanling-ec-zero-akm-portabe-cd-player-open
The ECZero AKM keeps its mission simple—it plays CDs, and does it with clean, balanced sound whether you’re plugged in with headphones or running it through a desktop or main audio system. Inside, it uses an AKM DAC and dual SGM8262 amplifiers to keep the signal path tight and distortion low.
You get both unbalanced 3.5mm and balanced 4.4mm headphone outputs, so it’ll handle everything from efficient IEMs to power-hungry cans. The 3.5mm jack also doubles as a digital coax/optical SPDIF output for system integration, and Shanling includes a 100-step volume control to fine-tune output levels for just about any setup.
Bluetooth 5.3 support lets you stream directly from the ECZero AKM to wireless headphones or speakers that support aptX Adaptive, aptX, or SBC codecs. And for those who still like to archive their collections, the built-in CD ripping function lets you save tracks directly to a connected USB drive. It’s a thoughtful nod to convenience in a player that clearly wasn’t built for the Spotify generation.
shanling-ec-zero-akm-portabe-cd-player-views
The ECZero AKM keeps portability front and center with an internal 5500mAh rechargeable battery that delivers up to eight hours of playback on a full charge. When used at home, it can switch over to a USB-C power adapter for continuous operation without draining the battery.
All that hardware lives inside a compact, well-finished chassis that slips easily into a backpack or travel case. Shanling’s magnetic disc mechanism maintains consistent pressure on the CD, minimizing vibration and noise for stable playback—something every commuter or traveler will appreciate when the road gets bumpy.
The ECZero AKM’s metal body and tempered-glass lid give it a premium, durable feel. At 575g (1.27 lbs.) and measuring 158 x 150 x 28mm (6.2 x 5.9 x 1.1 in.), it’s solid but still travel-ready. Up front, a 1.68-inch color LCD display sits near the volume slider and control buttons, keeping essential playback info within easy view.
Comparison
shanling-fiio-cd-players
Brand/ModelShanling ECZero AKMShanling EC Zero TFiiO DM13
Product TypePortable CD PlayerPortable CD PlayerPortable CD Player
Price$319$589$164.99
Disc Playback FormatsCD, CD-R, CD-RWCD, CD-R, CD-RWCD, CD-R, CD-RW, CD layer of SACDs, and MQA CDs.
Dual JAN6418 Tube OutputNo (Solid State Only)Yes (Tube – Solid State Hybrid)No (Solid State Only)
Headphone AmplifierDual SGM8262 amplifiers.TPA6120Dual SGM8262 amplifiers.
DACAKM AK4493SR2R DAC ModuleCS43198 x 2
USB DAC Support768kHz/32-bit & DSD512768kHz/32-bit & DSD512N/A – USB is only used for ripping to an external drive, not as a source input.
External Power InputUSB-C 5V/2AUSB-C 5V/2AUSB-C 5V/2A
Headphone and Line Outputs3.5mm & 4.4mm3.5mm & 4.4mm3.5mm & 4.4mm
Digital Output3.5mm combined coaxial/optical SPDIFCoaxial and optical SPDIFCoaxial and optical SPDIF
Bluetooth Ver 5.3Ver 5.3Ver 5.2
Bluetooth CodecsaptX, aptX Adaptive, SBCaptX, aptX Adaptive, SBCSBC/aptX/aptX Low Latency/aptX HD
THD+N0.0004%0.02%≤0.0025% (1kHz/0dB@32Ω
Dynamic Range119dB117dBNot provided
Channel Separation103dB103dBNot Provided.
Signal-to-Noise Ratio (SNR)119dB117dB> 124dB (A-weighted)
USB DAC Frequency Response20Hz- 40kHz (+/-0.5dB)20Hz- 40kHz (+/-0.5dB)N/A
CD Player Response20Hz-20kHz (+/- 0.5dB)20Hz-20kHz (+/- 0.5dB)20Hz-20kHz (+/- 0.5dB)
3.5mm Line Out Frequency Response20Hz-40kHz (+/- 0.5dB)20Hz-40kHz (+/- 0.5dB)20Hz~20kHz: attenuation<2.3dB
4.4mm Line Out Frequency Response20Hz-40kHz (+/- 0.5dB)20Hz-40kHz (+/- 0.5dB)20Hz~20kHz: attenuation<2.3dB
Supported Audio FormatsDSD, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUSDSD, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUSFLAC, WAV, WMA, AAC, and MP3
Output Power (Transistor)Low Gain 211mW@32Ω
High Gain 525mW @32Ω
High Gain 836mW @32Ω (external power)
Low Gain: 57mW@32Ω
High Gain: 158mW@32Ω
High Gain: 330mW@32Ω (DC power)
3.5mm headphone output: L+R≥180mW+180mW (32Ω, THD+N<1%)
4.4mm balanced headphone output:L+R≥660mW+660mW (32Ω, THD+N<1%)
Output Power (Tube)N/A (Solid State Only)Low Gain: 47mW@32Ω
High Gain: 268mW@32Ω (DC power)
CD Ripping FunctionalityYes – Via USB OutputYes – Via USB OutputYes – Via USB Output
Active magnetic CD clamp and advanced anti-skip systemYesYesNot indicated
Aluminum chassis Yes (with Tempered Glass Panels)Yes (with Tempered Glass Panels)Yes
Status Display1.68-inch color screen1.68-inch color screen1.5-inch color screen
Hardware Buttons and Volume SliderYesYesYes
Battery5500mAh, up to 8 hours of playback5500mAh, up to 8 hours of playback3750mAh Cobalt-lithium, up to 8 hours
Dimensions (WDH)158 x 150 x 28mm
6.22 x 5.9 x 1.1 inches
158 x 150 x 28mm
137.5 x 144.7 x 28.7mm
5.41 x 5.7 x 1.13
·Weight575g / 1 lbs 4oz669g / 1 lbs 8oz450g / 15.9 oz
shanling-ec-zero-akm-portabe-cd-player-rear
The Bottom Line
The Shanling ECZero AKM proves that the humble CD still has some fight left in it. With its AKM DAC, dual headphone outputs, Bluetooth 5.3 streaming, and onboard CD ripping, it bridges the gap between analog nostalgia and digital convenience without feeling gimmicky. Add in the sturdy metal chassis, rechargeable battery, and travel-friendly size, and it’s clear Shanling designed this for listeners who still care about both fidelity and music ownership. Streaming might be easier, but the ECZero AKM makes the case that holding your music—and hearing it properly—still matters.
Price & Availability
The Shanling ECZero AKM is available for $319 at Amazon or $349 at Forte Distribution.
Also available:
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
CD Players
Shanling EC Play gives CDs a Gen Z reboot with Bluetooth 6.0, USB DAC support, balanced output, and a $199 price. Is this Discman...
CD Players
At $269, FiiO’s DM15 R2R portable CD player debuts with an in-house DAC, balanced and single-ended headphone outputs, Bluetooth transmit mode, and a high-voltage...
At $329, JBL’s Tour PRO 3 wireless earbuds combine dual drivers, adaptive noise cancellation, LDAC support, and a touchscreen Smart Charging Case to challenge...
At $299, the WiiM Sound features room correction, Wi-Fi 6E, stereo pairing and 5.1 setups, but lacks AirPlay, HDMI-ARC, and a phono input.
Mediterranean Summer 2025 brought brutal heat, tourist chaos, and locals who’ve officially had it. From Corfu’s charm to Dubrovnik’s GoT overload, here’s why Europe...
Portable CD players are back, but with better sound, Bluetooth, and DACs. FiiO and Shanling are leading the charge in 2025's retro revival.
CD Players
Shanling’s EC Zero T brings hybrid tube/solid-state sound to a portable CD player with R2R DAC, Bluetooth 5.3, and high-end headphone amp—CDs just got...
CD Players
Shanling will be demonstrating two disc players, DAC/Headphone Amp, DAC/Streamer, and HW-600 open-back headphones at High END.
