Sendy Audio Egret Headphones Debut with New Planar Drivers and Nano Fiber Diaphragm Tech
Sendy’s new Egret drops into the $799 arena with advanced planar tech and handcrafted woodwork, taking a clear shot at rivals like Meze and Dan Clark that now have real competition on their hands.
Sendy Egret Headphones
Sendy Audio, the upscale sibling under the SIVGA umbrella, is doubling down on its planar ambitions. We’ve had a strong track record with the models that have crossed our review desk, and the company clearly thinks it has another contender on its hands. The new Egret arrives as Sendy’s latest statement piece: an open back planar headphone built from the ground up with a new driver platform, a nano scale diaphragm, and the same handcrafted wooden housings that define the brand’s design language.
According to Sendy, Egret isn’t just another iteration. It’s the start of a new chapter in planar headphone engineering aimed at better accuracy, refinement, and long term listening comfort.
Exterior Design of the Sendy Audio Egret
On the outside, the Egret uses handcrafted solid wood housings that are finished by hand, giving every pair its own grain pattern and color tone. No two units look exactly the same, which adds a bit of personality and turns the headphones into a subtle fashion statement.
The open back design keeps the presentation spacious and transparent, while the contoured headband and soft leather earpads are shaped for long sessions without pressure points. It’s a practical blend of comfort and craftsmanship that reinforces what Sendy does best.
Planar Drivers & Composite Diaphragm
sendy-egret-headphones-lifestyle
The Egret uses Sendy’s most advanced planar magnetic driver yet, paired with a nano scale composite diaphragm. The driver measures 98 x 83 mm, and the diaphragm comes in under 800 nanometers, giving it very low mass and the ability to react quickly and cleanly. The goal here is simple: improve accuracy, speed, and dynamic range without introducing strain or harshness.
The diaphragm is produced using an Electron Beam Evaporation Deposition process, where ultra fine aluminum circuitry is applied directly onto the surface at the atomic level. This allows for tighter consistency across the diaphragm, lower distortion, and better control over how the driver behaves from bass through treble.
Sonically, Sendy tuned the Egret to offer a full, balanced presentation with solid low end reach, clear and natural mids, and treble that remains controlled rather than sharp. The intent wasn’t to chase sheer excitement or exaggerated detail, but to create a stable, resolving headphone that works for critical listening, studio evaluation, and long listening sessions at home.
The Cable They Actually Want You to Use
sendy-egret-cables
Sendy bundles a proper cable with the Egret instead of the usual afterthought. The detachable balanced cable uses a triple composite structure built for clean signal transfer: 30 strands of Furukawa oxygen free copper, 10 strands of silver plated copper, and 10 strands of enamelled gold plated copper. The mix is designed to keep resistance low and preserve detail without drifting into gimmick territory.
A graphene reinforced PVC jacket keeps the cable flexible and resilient, and Sendy includes both a 4.4 mm balanced plug and a 3.5 mm single ended adapter to cover most sources and headphone amps. It’s a practical, well engineered upgrade over the generic cables that usually ship with headphones in this price range.
These specs tell you exactly what lane the Egret is built for. The 8 Hz to 40 kHz bandwidth gives the driver plenty of room to breathe without relying on DSP tricks. The 38 ohm impedance and 103 dB sensitivity mean it should be reasonably easy to drive from most modern desktop amps and balanced portables, though it will still benefit from proper power to show what the new planar motor can really do.
The weight lands at about 420 grams, which is perfectly normal for a full size planar. Not light, not punishing—just enough mass to support a large driver without turning your neck into collateral damage. With the contoured headband and leather pads doing the heavy lifting, it should manage long listening sessions without turning comfort into a compromise.
Sendy Audio Egret Specifications
Sendy Audio ModelEgret
Product TypeHeadphones
Price$799
Wearing TypeFull-size Open Back
Driver TypePlanar Magnetic
Driver Size98 x 84mm
DiaphragmNano-scale composite (<800nm)
Frequency Response8Hz – 40kHz
Impedance38Ω
Sensitivity103dB ± 3dB
Cable1.8m detachable triple-composite (Furukawa OFC / Silver-plated Copper / Gold-plated Copper)
Connectors2.5mm balanced with 4.4mm and 3.5mm adapters
WeightApprox. 420 grams
FinishHandcrafted natural wood, open-back design
sendy-egret-headphones-travel-case
The Bottom Line
Planar magnetic headphones have been part of the landscape since Wharfedale brought them to market in 1972, and they’ve held their place thanks to speed, accuracy, and low distortion that dynamic drivers still struggle to match. They also tend to live at the higher end of the pricing ladder. Yes, you can spend nearly three grand on something like the HiFiMAN Isvarana, but there are also solid entry points like the Edition XV at $399 or the Monoprice M1070 at $349.
At $799, Sendy is clearly aiming for the middle of the market with the Egret. The goal is to deliver a more refined build, handcrafted woodwork, and a well executed planar driver without drifting into “mortgage payment” territory. Based on our experience with their previous models, it’s a smart lane for them. And while it’s not the only game in town at this price—competitors like the Meze Poet or the Dan Clark Audio models we recently reviewed offer their own takes on planar performance—the Egret brings a blend of style, comfort, and measured engineering that should resonate with listeners who want serious sound without crossing into four figure indulgence.
Price & Availability
The Sendy Audio Egret is priced at $799 / €879 / £799 from Sendy with availability on Amazon coming soon.
2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
Dan D'Agostino Momentum C2Z Preamplifier with Power Supply Dan D'Agostino Momentum C2Z Preamplifier with Power Supply
Dan D’Agostino Momentum C2Z preamplifier refines the C2 with Z circuitry and FET output stage. If you have to ask the price this is...
Musical Fidelity M6xi Integrated Amplifier Silver Musical Fidelity M6xi Integrated Amplifier Silver
At $3,799, Musical Fidelity’s M6xi delivers 230 WPC with an onboard DAC, HDMI ARC, and MM/MC phono stage, offering a powerful and flexible solution...
Denon AVR-S980H Home Theater A/V Receiver Lifestyle Denon AVR-S980H Home Theater A/V Receiver Lifestyle
Denon AVR-S980H adds wireless surround support, 1440p pass-through, and channel level monitoriing offering a flexible step-up from soundbars under $1,000.
2026 Samsung R85H Micro RGB TV Lifestyle 2026 Samsung R85H Micro RGB TV Lifestyle
Samsung reveals pricing and availability for its 2026 Micro RGB LED TV lineup, introducing a new approach to color accuracy and premium display performance.
Over-Ear Headphones
Can a $958 planar from Sendy Audio really challenge HiFiMAN, Audeze, and Dan Clark? The Egret delivers premium build, balance, and serious technical chops.
A year-end look at the biggest consumer A/V and media stories of 2025, from streaming wars and AI to vinyl, TV tech, and high-end...
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Over-Ear Headphones
At $599, Sendy Audio Aiva 2 open-back planar magnetic headphones deliver detailed treble, coherent soundstage, and premium design, but does it improve on the...
Podcasts
Apps for your ears are coming. Gary Spittle, Founder & CEO of Sonical is creating the next generation of headphones and earphones.
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
CanJam London 2025 showcased groundbreaking desktop DACs and Headphone Amplifiers with diverse sounds and innovation. North American audiophiles don’t want to miss these global...
Find out which audiophile headphones won Best in Show at CanJam London 2025, along with surprise launches from HiFiMAN and more first impressions.
