Samsung Reveals 2026 Micro RGB LED TV Pricing and Availability as It Pushes Premium TV Tech Into the Spotlight
Samsung reveals pricing and availability for its 2026 Micro RGB LED TV lineup, introducing a new approach to color accuracy and premium display performance.
2026 Samsung R85H Micro RGB TV Lifestyle
After rolling out its 2026 4K Mini LED, Neo QLED, OLED, and Frame TV lineups, Samsung is now going all-in on premium display tech with the debut of its first full 4K Micro RGB LED TV range anchored by eight models across three series and signaling a more aggressive push to bring next-generation panel technology into the mainstream.
The 2026 Micro RGB LED lineup spans eight models across three series, starting with the carryover MR95F anchored by a massive 115-inch screen, followed by the R95H Series in 85-, 75-, and 65-inch sizes, and the more accessible R85H Series offering 85-, 75-, 65-, and 55-inch options.
Pro tip: Samsung is expected to slot in a 100-inch model later in 2026, likely within the R85H or R95H range, to plug the gap between the current size tiers and hit that increasingly popular large-screen sweet spot.
You can read one of the first full reviews of the new R95H Micro RGB TVs today, right here.
2026 Samsung R95H Micro RGB TV Lifestyle
What Is Samsung Micro RGB LED TV Technology?
Samsung’s Micro RGB technology is built around sub-100-micron red, green, and blue LEDs that emit light independently, rather than relying on a white backlight with color filters. This approach enables more precise color reproduction at the pixel level and eliminates the inefficiencies associated with traditional backlighting systems.
Micro RGB LED Backlight Structure Angle
Also, instead of more traditional hardware-based Full Array Local Dimming, Samsung’s Ultimate Micro Dimming and Dimming Pro use software-based algorithms to achieve precise light control. For added support, Samsung incorporates advanced image processing tools such as, 4K AI Upscaling Pro, and AI Motion Enhancer Pro, which work in real time to refine brightness, motion handling, and overall image clarity across a wide range of content.
For a deeper technical breakdown of how Micro RGB works and how it differs from RGB Mini-LED, read our companion article, WTF Are RGB-MiniLED and Micro RGB LED TVs?
AI Engine Pro
Samsung Micro RGB AI Engine
To enable more precise, frame-by-frame image refinement, Samsung’s Micro RGB AI Engine Pro is driven by a next-generation AI chipset. The platform also integrates Micro RGB Color Booster Pro alongside either Micro RGB HDR Pro (R95H Series) or Micro RGB HDR+ (R85H Series and MR95F), working in concert to improve color depth, brightness control, and tonal balance for images that look more vivid without sacrificing overall naturalism.
Micro RGB Precision Color 100 (R95H series)
Samsung’s Micro RGB Precision Color 100 (R95H Series) features a refined Micro RGB light source with enhanced RGB color dimming precision, enabling more accurate color reproduction across a wide range of content. Certified by VDE, Micro RGB Precision Color 100 supports 100% of the BT.2020 wide color gamut, underscoring Samsung’s focus on color accuracy at the premium end of its TV lineup.
Glare Free (R95H and MR95F)
Samsung Glare Free Technology
This feature is designed to reduce on-screen reflections without compromising image quality, helping preserve contrast and color accuracy. It also improves real-world viewing conditions for users who don’t have full control over ambient lighting.
Vision AI Companion
Vision AI Companion is Samsung’s platform that combines large language model (LLM)–powered intelligence with natural, conversational interaction through Bixby. The system supports conversational search and interactive Q&A, delivers proactive content recommendations, and provides access to AI-driven features and apps, including Live Translate, Generative Wallpaper, and Perplexity.
Gaming
Gaming support is extensive, with Samsung’s Gaming Hub, AI Auto Game Mode, Cloud Gaming, and Motion Xceleration included on all Samsung 2026 RGB Micro LED TVs. The R95H series supports a 165Hz native refresh rate, the R85H series supports a native 144Hz refresh rate, and the MR95F supports a 120Hz native refresh rate with the ability to go up to 144Hz.
Samsung Gaming
Smart TV
Just as with all Samsung smart TVs, the Micro RGB models incorporate the Tizen OS for access to all major streaming services, as well as include Samsung’s TV Plus free Ad-supported TV service with access to hundreds of additional subscription-free channels and services.
Samsung Tizen OS
Audio Support
All new Micro RGB models support Dolby Atmos for multidimensional audio, Adaptive Sound Pro for optimizing clarity based on both room acoustics and content type, and Q-Symphony, which integrates the TV’s speakers with compatible Samsung audio products (soundbars and wireless speakers) to create a larger, more immersive soundstage. As an added bonus, all 2026 Samsung TVs include Eclipsa Audio, offering another immersive listening option in addition to Dolby Atmos.
Samsung Micro RGB LED TV Q-Symphony
Wireless One Connect Box Ready (R95H)
Samsung Micro RGB LED TVs provide the connections you would expect (refer to our comparison chart below), but one connection feature available for the R95H series TVs as an optional purchase is a Wireless One Connect Box. This allows you to bypass the connections located on the TV and provides access to them using the wireless connect box instead, if desired. The box wirelessly transmits up to 4K at 144Hz from as far as 10 meters (30 feet), which should be enough for most living rooms unless you’re trying to hide it in another zip code. The result is a much cleaner installation.
Samsung Wireless One-Connect Box
Samsung 2026 Micro RGB LED TVs Comparison
Keep in mind that while all Samsung MicroRGB TVs share many core features, there are some key differences. We’ve included a detailed comparison chart below to make those distinctions easier to see.
Samsung ModelR95H R85H MR95F
Product TypeMicro RGB LED TV (2026)Micro RGB LED TV (2026)Micro RGB LED TV (2025)
Screen Size (Inches)65, 75, 8555, 65, 75, 85115
Price85”: $6,499.99
75”: $4,499.99
65”: $3,199.99
85”: $3,999.99
75”: $2,799.99
65”: $2,099.99
55” $1,599.99
$29.999.99
Display TypeLCDLCDLCD
Lighting TechnologyMicro RGB LED Micro RGB LED Micro RGB LED
Refresh Rate165Hz (VRR Support)144Hz (VRR Support)120Hz (Up to 144Hz)
Display Resolution4K (3,840 x 2,160)4K (3,840 x 2,160)4K (3,840 x 2,160)
Anti ReflectionGlare FreeN/AGlare Free
Viewing AngleWide Viewing AngleWide Viewing AngleWide Viewing Angle
Dimming Technology(software-based)Ultimate Micro Dimming ProUltimate Micro DimmingUltimate Micro Dimming Pro
ProcessingMicro RGB AI Engine ProMicro RGB AI EngineMicro RGB AI Engine
Upscaling4K AI Upscaling Pro4K AI Upscaling4K AI Upscaling Pro
Variable Refresh Rate (VRR)YesYesYes
Motion HandlingMotion Xcelerator 165HzMotion Xcelerator 144HzMotion Xcelerator 144Hz
DLG (Dual Line Gate)240Hz240HzNot Indicated
Contrast EnhancerReal Depth EnhancerReal Depth EnhancerReal Depth Enhancer
Contrast BoosterYesYes
AI Motion EnhancerPro3N/APro
ColorMicro RGB Precision Color 100Micro RGB Precision ColorMicro RGB Precision Color
Micro RGB Color BoosterProProPro
HDR (High Dynamic Range)Micro RGB HDR ProMicro RGB HDR+Micro RGB HDR+
HDR10+Yes (Adaptive/Gaming/Advanced)Yes (Adaptive/Gaming/Advanced)Yes (Adaptive/Gaming)
Auto HDR RemasteringProYesPro
Adaptive PictureAI Optimized / AI CustomizationAI Optimized / AI CustomizationAI Optimized / AI Customization
Supersize Picture Enhancer85″ Only85″ & 100″ OnlyYes
AudioSpeaker Type: 4.2.2CH
Output
Power (W): 70W
Dolby Atmos
Object Tracking Sound (OTS): OTS+
Q-Symphony
Active Voice Amplifier (AVA): AVA Pro
Adaptive Sound: Pro
Bluetooth Audio
360 Audio
Speaker Type: 2CH
Output
Power (W): 30W
Dolby Atmos
Object Tracking Sound (OTS): OTS Lite
Q-Symphony
Adaptive Sound: Pro
Bluetooth Audio
360 Audio
Output
Power (W): 70W
Dolby Atmos
Q-Symphony
Adaptive Sound: Pro
Bluetooth Audio
360 Audio
TV DesignInfinity AirMonolith EdgeMetal SuperSlim
Bezel Type4 Bezel-less3 Bezel-less4 Bezel-less
Front ColorBlackTitan BlackRGB Cardon Silver
Stand TypeInfinity Air StandRound FeetMetal Linear Round
Stand ColorSpace GraphiteBlackRGB Cardon Silver
Adjustable StandN/AYesNot Indicated
ConnectivityWi-Fi: (Wi-Fi 6E)
Bluetooth: (BT5.3)
Wireless One Connect Box: Ready – Requires an optional purchase
HDMI Inputs: 4 Ports
HDMI Maximum Input Rate: 4K 165Hz (for HDMI 1/2/3/4)
HDMI Audio Return Channel: eARC
HDMI-CEC
USB Ports: 2 x USB-A
Ethernet (LAN)
Digital Audio Out (Optical)
RF Connection
RS-232C Input
Wi-Fi: (Wi-Fi 6E)
Bluetooth: (BT5.3)
One Connect Box: N/A
HDMI Inputs 4 Ports
HDMI Maximum Input Rate: 4K 144Hz (for HDMI 1/2/3/4)
HDMI-CEC
Ethernet (LAN)
RF Connection
RS-232C Input
Wi-Fi (Wi-Fi 5)
Bluetooth: (BT5.3)
HDMI-CEC
Ethernet (LAN)
RF Connection
RS-232C Input
Samsung Vision AIVision AI Companion
AI Soccer Mode
AI Sound Controller
Live Translate
Multi AI Agents (Copilot & Perplexity)
Pet & Family Care
Home Insight
Vision AI Companion
AI Soccer Mode
AI Sound Controller
Live Translate
Pet & Family Care
Home Insight
Vision AI Companion
AI Soccer Mode
AI Sound Controller
Live Translate
Pet & Family Care
Home Insight
TV Art FeaturesArt Mode: N/A
Art Store: Yes
Art Mode: N/A
Art Store: Yes
Art Mode: N/A
Art Store: Yes
Operating SystemOne UI TizenOne UI TizenOne UI Tizen
Free Ad Support TVSamsung TV PlusSamsung TV PlusSamsung TV Plus
Smart Home ConnectivitySmartThings, Matter, IoT-Sensor Functionality, Quick RemoteSmartThings, Matter, IoT-Sensor Functionality, Quick RemoteSmartThings, Matter, IoT-Sensor Functionality, Quick Remote
Smart Assistants (Built-In)Bixby, AlexaBixby, AlexaBixby, Alexa
Smart Assistants (Works with)Google AssistantGoogle AssistantGoogle Assistant
Far-Field Voice InteractionsYesYesYes
Web BrowserYesYesYes
Samsung HealthYes15Yes15Yes
Multi-Device ExperienceMobile to TV
TV initiates mirroring
Sound Mirroring
Wireless TV On
Mobile to TV
Sound Mirroring
Wireless TV On
Mobile to TV
Sound Mirroring
Wireless TV On
Multi-ViewUp to 2 videosUp to 2 videosUp to 2 videos
Buds Auto SwitchYesYesYes
Works with Apple AirPlayYesYesYes
Works with Google CastYesYesYes
Daily+YesYesYes
Now BriefYes Voice/User DetectionYes Voice/User DetectionYes Voice/User Detection
Workout TrackerYesYesYes
Karaoke MicYes16YesYes
Multi-ControlYesYesYes
Storage ShareYesYesYes
GamingGaming Hub
Cloud Gaming: – Xbox, NVIDIA GeForce Now, Luna, Blacknut, Antstream, Boosteroid
AI Auto Game Mode
ALLM (Auto Low Latency Mode)
Gaming Motion Plus
Super Ultra Wide Game View
Game Bar
Mini Map Zoom
AMD FreeSync: Freesync Premium™ Pro
HGiG
Hue Sync
Gaming Hub
AI Auto Game Mode
Gaming Motion Plus
Game Bar
Mini Map Zoom
HGiG
Hue Sync
Gaming Hub
AI Auto Game Mode
Gaming Motion Plus
Game Bar
Mini Map Zoom
HGiG
Hue Sync
Security Knox Vault: N/A
Knox Security: Yes
Knox Vault: N/A
Knox Security: Yes
Knox Vault: N/A
Knox Security: Yes
PowerPower Supply (V): AC110-120V~ 50/60Hz
Stand-by Power Consumption (W): 0.5
Typical Power Consumption (W): 75″: 208W 65″: 171W
Max Power Consumption (W): 75″: 370W 65″: 275W
 Eco Sensor
Auto Power Saving
Auto Power Off
Typical Power Consumption: Not Indicated
Eco Sensor
Auto Power Saving
Auto Power Off
Typical Power Consumption 410W
Max Power Consumption 800W
Eco Sensor
Auto Power Saving
Auto Power Off
Included AccessoriesRemote Control: BT SolarCell™ Remote TM2660H
Power Cable
Slim Fit Wall-mount Support:
Power Cable
Remote Control: BT SolarCell™ Remote TM2560H
Power Cable
The Bottom Line
Samsung has now moved beyond the early tease at CES 2026 and delivered a clearer picture of its Micro RGB strategy. By using independently controlled red, green, and blue LEDs, these TVs focus on more precise color reproduction and improved contrast without relying on traditional backlighting methods. That approach sets them apart from Mini LED and positions them as a more advanced option within Samsung’s premium lineup.
The competitive landscape is already taking shape. Hisense has introduced 4 RGB Mini LED models in the United States, LG has previewed its own Micro RGB direction, and TCL may expand its RGB Mini LED offerings beyond China. Sony could have the most impact once it announces full details for its RGB backlighting technology, which has already generated strong early impressions.
These TVs are aimed at buyers who prioritize color accuracy, large screen sizes, and the latest display technology. Pricing will likely keep them in the high end category, but the focus here is performance rather than value.
Samsung’s Micro RGB TVs introduce a different approach to premium display design and arrive at a time when multiple brands are exploring similar RGB based solutions.
Price and Availability
MR95F (2025 Carry Over)
R95H Series
  • 85” Class R95H: $6,499.99 at Samsung
  • 75” Class R95H: $4,499.99 at Samsung
  • 65” Class R95H: $3,199.99 at Samsung
R85H Series
  • 85” Class R85H: $3,999.99 at Samsung
  • 75” Class R85H: $2,799.99 at Samsung
  • 65” Class R85H: $2,099.99 at Samsung
  • 55” Class R85H: $1,599.99 at Samsung
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
After years of hands-on testing, these are the soundbars and speaker bar systems for home theater that impressed us most in 2026.
Roku’s $999 Pro Series OLED offers 120Hz, Dolby Vision and FreeSync Premium, while the $1,299 LX adds 144Hz VRR and higher brightness. Which is...
Microsoft ends Xbox Cloud Gaming support on 2020 Samsung TVs November 3. Here's which TVs are affected and how owners can keep playing.
Which TVs are worth buying in 2026? Our hands-on tested Editors’ Choice winners cut through the hype to reveal the best OLED, Mini LED...
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
