Revel is heading into AXPONA 2026 (April 10-12) with a clear focus: the debut of its new Performa4 speaker series, expected to fall between $2,000 and $7,000 per pair. Under the HARMAN Luxury Audio Group umbrella, which also includes Arcam, JBL Synthesis, Lexicon, and Mark Levinson, Revel isn’t going after statement pricing here. Performa4 is aimed at the part of the market where most serious systems are actually built, and where the competition is crowded, well established, and not particularly forgiving.
Revel Performa4 Speaker Series
Revel’s Performa4 Series is a new loudspeaker line built on the company’s established approach to acoustic design and measurement. It reflects three decades of engineering focused on controlled performance and consistent results in real-world listening environments.
Revel’s Performa4 Series consists of two floorstanding models (F346 and F345), two bookshelf speakers (M146 and M145), a center channel (C245), and a powered subwoofer (B140). With multiple configurations available, the Performa4 lineup can be used in both two-channel music systems and multichannel home theater setups.
“At Revel, science is at the heart of everything we do. The Performa4 series represents the culmination of thousands of hours of research, development, and real-world testing. With our new 7th-generation Acoustic Lens waveguide and advanced DCC and MCC transducers, we’ve raised the bar for what’s possible in this class,” said Jim Garrett, Senior Director of Product Strategy and Planning at HARMAN Luxury Audio.
Acoustic Lens Waveguide, DCC and MCC Transducers Explained
The Performa4 series uses Revel’s Deep Ceramic Composite (DCC) and Micro Ceramic Composite (MCC) drivers, developed to improve stiffness while keeping mass low and reducing unwanted coloration.
Woofer and midrange drivers are built on cast aluminum frames designed with Finite Element Analysis to optimize airflow, control resonance, and maintain structural stability. Each driver also uses an inverted surround and integrated trim ring, which simplifies the front baffle and keeps the layout clean.
Revel’s 7th-generation Acoustic Lens waveguide is paired with a 1-inch DCC dome tweeter to improve integration with the midrange driver. The waveguide is designed to control dispersion more consistently across the listening area, while also supporting higher efficiency and lower distortion, including at off-axis positions.
Revel Performa4 Industrial Design
The Performa4 series adopts a clean, modern design that builds on Revel’s established cabinet approach without adding unnecessary complexity.
All models use magnetically attached grilles for a flush, hardware-free front panel, along with black accent detailing that keeps the visual profile consistent across the range. Cabinets are internally cross-braced to improve rigidity and reduce unwanted vibration.
Curved side panels are finished in real wood veneers, available in Natural Walnut and Black Walnut, offering a straightforward aesthetic that fits into both traditional and contemporary spaces.
Revel Performa4 Models
F346
The F346 is a 3-way floorstanding loudspeaker and the top model in the Performa4 series.
It uses three 6.5-inch (165mm) MCC woofers, a 6.5-inch (165mm) DCC midrange driver, and a 1-inch (25mm) DCC dome tweeter paired with Revel’s 7th-generation Acoustic Lens waveguide.
Dual rear-firing ports provide low-frequency extension, while dual 5-way binding posts support bi-amping or bi-wiring. The cabinet is fitted with solid aluminum feet and includes optional floor spikes for added stability.
The F346 is rated for a frequency response of 30Hz to 40kHz (±6dB), with 88dB sensitivity and a nominal impedance of 6 ohms. Recommended amplifier power ranges from 20 to 250 watts.
F345
The F345 is a 3-way floorstanding loudspeaker that shares the same core design as the F346, using smaller drivers in a more compact cabinet.
It features three 5.25-inch (130mm) MCC woofers, a 5.25-inch (130mm) DCC midrange driver, and a 1-inch (25mm) DCC dome tweeter paired with Revel’s 7th-generation Acoustic Lens waveguide.
Dual rear-firing ports support low-frequency output, while dual 5-way binding posts allow for bi-amping or bi-wiring. The cabinet includes solid aluminum feet with optional spikes for placement flexibility.
The F345 is rated for a frequency response of 36Hz to 40kHz (±6dB), with 87dB sensitivity and a nominal impedance of 6 ohms. Recommended amplifier power ranges from 30 to 225 watts.
M146
The M146 is a 2-way bookshelf or standmount speaker positioned in the middle of the Performa4 lineup.
It uses a 6.5-inch (165mm) MCC woofer paired with a 1-inch (25mm) DCC dome tweeter and Revel’s 7th-generation Acoustic Lens waveguide.
The crossover network incorporates air-core inductors, and dual 5-way binding posts support bi-amping or bi-wiring. Optional MFS4 floor stands are available for proper placement and listening height.
The M146 is rated for a frequency response of 43Hz to 40kHz (±6dB), with 86dB sensitivity and a nominal impedance of 6 ohms. Recommended amplifier power ranges from 15 to 200 watts.
M145
The M145 is a compact 2-way bookshelf speaker and the smaller option in the Performa4 lineup.
It features a 5.25-inch (130mm) MCC woofer paired with a 1-inch (25mm) DCC dome tweeter and Revel’s 7th-generation Acoustic Lens waveguide.
Like the M146, it includes 5-way binding posts for flexible connectivity and is compatible with the optional MFS4 floor stands for proper positioning.
The M145 is rated for a frequency response of 54Hz to 40kHz (±6dB), with 85dB sensitivity and a nominal impedance of 6 ohms. Recommended amplifier power ranges from 15 to 150 watts.
C245
The C245 is a dedicated center channel speaker designed for use in multichannel systems with other Performa4 models.
It features dual 5.25-inch (130mm) MCC woofers flanking a 1-inch (25mm) DCC dome tweeter, paired with Revel’s 7th-generation Acoustic Lens waveguide for consistent dispersion across the front soundstage.
The C245 is rated for a frequency response of 55Hz to 40kHz (±6dB), with 86dB sensitivity and a nominal impedance of 6 ohms. Recommended amplifier power ranges from 15 to 200 watts.
B140
The B140 is a powered subwoofer designed to integrate with the Performa4 series in both two-channel and home theater systems.
It uses a 10-inch (250mm) fiber-composite woofer driven by a 750-watt RMS Class D amplifier, with up to 1,500 watts peak output. The design targets low-frequency extension down to 26Hz.
Rear-panel controls include a variable low-pass filter (50–150Hz), LFE input, phase adjustment, volume control, and auto on/off functionality. A rear-ported enclosure using Revel’s Constant Pressure Gradient design is intended to reduce turbulence and maintain cleaner low-frequency output.
MFS4 Floorstands
Revel also offers the optional MFS4 floor stands for the M146 and M145 bookshelf speakers.
Constructed from extruded aluminum and steel, the MFS4 stands are designed to position each speaker at an appropriate listening height. They include built-in cable management and optional spikes for use on carpeted surfaces. The stands are sold in pairs.
Revel Performa 4 Comparisons
| Revel Model | F346 | F345 | M146 | M145 | C245 |
| Speaker Type | Floorstanding | Floorstanding | Bookshelf | Bookshelf | Center |
| Price | $6,999/pair | $4,999/pair | $2,999/pair | $1,999/pair | $1,499/each |
| Speaker Configuration | 3-way | 3-way | 2-way | 2-way | 2-way |
| Tweeter | 1-inch (25mm) DCC Dome Tweeter with Acoustic Lens and 7th-Generation Waveguide | 1-inch (25mm) DCC Dome Tweeter with Acoustic Lens and Waveguide | 1-inch (25mm) DCC Dome Tweeter with Acoustic Lens and Waveguide | 1-inch (25mm) DCC Dome Tweeter with Acoustic Lens and Waveguide | 1-inch (25mm) DCC Dome Tweeter with Acoustic Lens and Waveguide |
| Midrange | 1 x 6.5 in (165 mm) Deep Ceramic Composite (DCC) Cone Driver | 1 x 5.25 in (135 mm) Deep Ceramic Composite (DCC) Cone Driver | N/A | N/A | N/A |
| Woofer | 3 x 6.5 in (165 mm) Micro Ceramic Composite (MCC) Cone Woofers | 3 x 5.25 in (135 mm) Micro Ceramic Composite (MCC) Cone Woofers | 1 x 6.5-inch (165 mm) Micro Ceramic Composite (MCC) Cone Woofer | 1 x 5.25 inch (130 mm) Micro Ceramic Composite (MCC) Cone Woofer | 2 x 5.25-inch (135 mm) Micro Ceramic Composite (MCC) Cone Woofers |
| Enclosure Tuning | Bass-Reflex via Dual Rear-Mounted Ports | Bass-Reflex via Dual Rear-Mounted Ports | Bass-Reflex via Rear-Mounted Port | Bass-Reflex via Rear-Mounted Port | Bass-Reflex via Rear-Mounted Port |
| Nominal Impedance | 6 Ohms | 6 Ohms | 6 Ohms | 6 Ohms | 6 Ohms |
| Sensitivity @ 1m, 2.83V | 88 dB | 87 dB | 85.5 dB | 85 dB | 86 dB |
| Recommended Amplifier Power | 20-250W | 30-225W | 15-200W | 15-150W | 15-200W |
| Frequency Response +/-6 dB | 30 Hz – 40 kHz | 36 Hz – 40 kHz | 43 Hz – 40 kHz | 54 Hz – 40 kHz | 55 Hz – 40 kHz |
| Crossover Frequency | 275 Hz / 1.7 kHz | 350 Hz / 2.1 kHz | 1.7 kHz | 1.8 kHz | 1.8 kHz |
| Dimensions | 44.4 x 14.1 x 16.3 inches 1127 x 357.33 x 414.48 mm | 40.9 x 11.9 x 13.9 inches 1038 x 301.86 x 352.46 mm | 14.1 x 9.7 x 12.7 inches 359 x 245.56 x 322.57mm | 11.6 x 7.9 x 9.6 inches 294 x 200 x 245mm | 7.1 x 23.4 x 10.9 inches 181 x 594.5 x 277 mm |
| Product Weight | 87.5 lbs / 39.7 kg | 64 lbs / 29.1 kg | 24.3 lbs / 11 kg | 15 lbs / 6.8 kg | 27.1 lbs / 12.3 kg |
Revel B140 Subwoofer
| Revel Model | B140 |
| Product Type | Powered Subwoofer |
| Price | $2,999/each |
| Driver | 250mm (10-inch) Coated Fibre Composite Cone Driver in a cast-Aluminum frame |
| Amplifier Type | Class D amplifier |
| Power Output | 750W RMS (1500W peak) |
| Enclosure Tuning | Bass-Reflex via Rear-Mounted Port |
| Controls | Auto Power, Crossover, Level, Phase |
| Inputs | RCA LFE/Line Level, 3.5mm, 12V Trigger |
| Frequency Response +/-6 dB | 26Hz – 150Hz |
| Crossover Frequency (Variable) | 50Hz – 150Hz |
| Dimensions | 14.8 x 16.9 x 17.2 inches (376.2 x 429.28 x 436.37 mm) |
| Weight | 61.3 lbs / 27.8 kg |
The Bottom Line
Revel’s Performa4 series is a calculated move into one of the most competitive segments in loudspeakers. The combination of DCC and MCC driver materials, the 7th-generation Acoustic Lens waveguide, and consistent cabinet engineering across the range points to a focus on controlled dispersion, tonal consistency, and predictable in-room performance; areas where Revel has historically been very disciplined.
The lineup is clearly built for flexibility. It can anchor a straightforward two-channel system or scale into a full home theater without mixing and matching across different voicings. That matters for buyers who want system coherence without overthinking every component swap.
What’s less clear is how much separation there is between models beyond size and output, and whether the subwoofer’s pricing will make sense for buyers building out a full system. There’s also no indication of built-in room correction or system-level integration features, which are becoming more common even in passive speaker ecosystems when paired with modern electronics.
This is for listeners who want a complete, measurement-driven speaker system in the $2,000 to $7,000 range without stepping into five-figure territory. Not entry-level, not cost-no-object—right in the middle where most serious systems live.
At AXPONA 2026, the F346 will be demonstrated with an Arcam SA45 integrated streaming amplifier and CD5 CD player, which should give a clear sense of how the top model performs with both streaming and physical sources.
Pricing & Availability
The Revel Performa4 series begins shipping in April through authorized Revel dealers and custom installation installers. All models are available in Natural Walnut and Black Walnut wood veneer finishes.
Suggested retail pricing is as follows:
- F346 Triple 6.5-inch Floorstanding Speaker – $6,999/pair
- F345 Triple 5.25-inch Floorstanding Speaker – $4,999/pair
- M146 6.5-inch Bookshelf Speaker – $2,999/pair
- M145 5.25” Bookshelf Speaker – $1,999/pair
- C245 Dual 5.25” Center Channel Speaker – $1,499/each
- B140 10-inch Powered Subwoofer – $2,999/each
- MFS4 Floor Stands – $699/pair
The Revel Performa4 series will make its official debut at AXPONA 2026, April 10-12, at the Schaumburg Convention Center in Chicago, IL.
For more information, visit www.revelspeakers.com
Related Reading:
- ARCAM Launches Radia Series Loudspeakers, Marking Its Return to Speakers at ISE 2026 Barcelona
- DALI’s New SONIK Series Brings Serious Hi-Fi Ambitions to Seven Affordable Speakers
- Perlisten A-Series: 4 New Entry-Level High-Performance Loudspeakers
- Elipson Drops 10 New Affordable Speakers — Proof the Oldest French Brand Still Has Taste
