Radiant Acoustics CLARITY 6.2 and 4.2 Bookshelf Speakers Deliver Compact Full Range Sound
Full range sound from bookshelf speakers? Check out the new Radiant Acoustics CLARITY 6.2 and 4.2 loudspeakers featuring PURIFI USHINDI woofers and custom AMT tweeters in an innovative cabinet design.
Radiant Acoustics Clarity 6.2 and 4.2 Bookshelf Speakers
Peter Lyngdorf’s fingerprints are all over the high-end audio world. He’s the driving force behind brands like DALI, Lyngdorf Audio, Steinway Lyngdorf, Purifi Audio, and the HiFi Klubben retail chain — all built around a no-nonsense obsession with sound quality and engineering. His latest venture, Radiant Acoustics, is pushing further into the spotlight with the launch of two new stand-mount speakers: the CLARITY 6.2 ($4,500/pair) and smaller CLARITY 4.2 ($3,000/pair).
From Peter Lyngdorf:Throughout my nearly 50 years in the audio industry, my goal has always been to redefine what great sound can be. Radiant Acoustics marks the latest chapter in this journey, and I’m thrilled to share it with you!… Radiant Acoustics delivers outstanding sound quality at an incredible value. Our Clarity 6.2 speakers, designed for discerning music lovers, offer a faithful reproduction of live music with truly outstanding dynamics—all in a compact, elegant design“.
Shared Technologies
Radiant Acoustics Bookshelf Speaker Cutaway Features
The CLARITY series isn’t just another pair of pretty cabinets in the high-end bookshelf crowd. Both the 6.2 and 4.2 models share a core set of technologies designed to deliver serious sonic performance — and to make Radiant Acoustics stand out in an already competitive category. Here’s what they have in common:
Purifi USHINDI Woofers
Both CLARITY models feature cutting-edge woofer technology sourced from PURIFI Audio — specifically, Radiant Acoustics uses PURIFI’s flagship USHINDI woofers, a high-performance design rarely seen in compact loudspeakers. These drivers are engineered to deliver low distortion, high efficiency, and deep bass that rivals much larger woofer designs.
radiant-clarity-4-2-woofer
What makes the USHINDI woofers special is their ability to extend lower in frequency without introducing audible distortion, all while preserving midrange clarity and precision. That means you get impactful low-end performance without sacrificing the detail and tonal accuracy needed for serious listening.
These woofers incorporate several patented PURIFI technologies, including the PureDrive ultra-linear motor systemNeutralSurround suspension, and a mathematically optimized cone geometry — all working together to eliminate nonlinearities and maintain control at all volumes. It’s the kind of engineering you’d expect in far more expensive loudspeakers, now packed into a bookshelf format.
  • Clarity 6.2 uses the PTT6.5X04-NLA-10 (6.5-inch) woofer
  • Clarity 4.2 uses the PTT4.0X04-NLC-02 (4-inch) woofer
AMT Tweeters
radiant-amt-tweeter
The CLARITY series also features a custom-designed AMT (Air Motion Transformer) tweeter that brings serious high-frequency performance to the table. Built by DALI specifically for Radiant Acoustics, this oversized AMT design uses an ultra-thin folded diaphragm with a large surface area to deliver high output, precise detail, and extended treble without harshness.
Compared to conventional dome tweeters, this AMT is a different beast entirely. It’s four times more efficient than a typical dome and significantly more powerful than smaller AMTs used in competing designs. That extra headroom means lower distortion, reduced risk of overload, and none of the thermal compression that can plague tweeters under dynamic load.
To further boost performance, the tweeter uses a dual-magnet symmetrical configuration, creating a stronger and more stable magnetic field than standard single-magnet AMTs. This helps maintain clarity and linearity across the entire frequency range.
Most importantly, the AMT’s voicing and dynamics are perfectly matched to the PURIFI USHINDI woofer, allowing the CLARITY speakers to operate as a cohesive, full-range system. Fast, clean, and efficient — the tweeter’s design lets the speaker take full advantage of the low-end muscle and midrange finesse the USHINDI drivers are known for.
High Frequency Beam Extension Waveguide
radiant-clarity-6-2-amt-waveguide
The CLARITY 6.2 takes things a step further with a custom-designed waveguide created by PURIFI specifically for this model. The design features five aluminum “fins,” or coherers, that play a critical role in controlling the AMT tweeter’s directivity and improving the integration between drivers.
At the crossover point — around 2400 Hz — the waveguide narrows the tweeter’s dispersion to closely match that of the woofer, creating a smoother, more cohesive handoff between the two. This alignment leads to a more accurate soundstage and better imaging across the listening area.
The waveguide also tackles room interaction. By restricting vertical dispersion, it minimizes reflections from the floor and ceiling that can muddy mid and high frequencies — especially in untreated rooms.
What sets this design apart, though, is its dual role: while the shape tightens dispersion around the crossover, the fins help expand high-frequency dispersion above that range. The result is a speaker that sounds focused and well-aligned when you’re in the “sweet spot,” but still delivers air and detail even when you’re not. It’s an elegant solution to a common problem in high-performance two-way designs.
Passive Radiators
ushindi-passive-radiators
To complete the acoustic package, CLARITY-series speakers use passive radiators — and not just any off-the-shelf solution. Radiant Acoustics opted for PURIFI USHINDI passive radiators instead of traditional bass reflex ports. These radiators are purpose-built to extend low-frequency performance while avoiding the downsides of ported enclosures.
The CLARITY 6.2 uses dual 6.5-inch radiators, and the CLARITY 4.2 features dual 4-inch radiators. Thanks to their large surface area, they can move more air with less excursion, which results in deeper bass and lower distortion — all while keeping the cabinet compact. Unlike ported designs that require more internal volume and often introduce chuffing or midrange bleed, this passive radiator system provides clean, tight bass without sacrificing clarity.
The radiators are mounted in a Dual Balanced Push-Pull configuration, meaning they sit back-to-back on a shared axis, perpendicular to the main driver’s axis. This setup cancels out reactive forces within the cabinet, resulting in zero net vibration — even at high output levels. The benefit? No cabinet resonance, no added distortion, and a more faithful reproduction of the original signal.
The CLARITY 4.2’s radiators have been specifically tweaked by PURIFI for Radiant Acoustics, including extra mass to lower the resonant frequency, allowing the smaller model to hit harder in the bass than you’d expect from its footprint. It’s a clever engineering move that helps both speakers punch well outside their size class — without sounding bloated or boomy.
  • The Clarity 6.2 uses the PTT6.5PR-NL2-02 (6.5-inch) PURIFI passive radiators.
  • The Clarity 4.2 uses the PTT4.0PR-NL2-03 (4-inch) PURIFI passive radiators.
Crossover
The CLARITY series crossover has been engineered with one clear goal: minimize distortion while maximizing synergy between the drivers and radiators. Every component in the signal path is selected for performance, not just cost or convenience.
radiant-clarity-crossover
Air-core inductors are used throughout the design to maintain linearity and avoid core saturation. These coils feature thick wire windings to reduce DC resistance, which helps preserve dynamic range and optimize sensitivity — key for revealing subtle musical details without coloration.
Capacitors are chosen based on hard measurements, prioritizing low internal resistance and high self-resonance frequency. This ensures minimal energy loss, low distortion, and reliable high-power handling even during complex musical passages. The resistors follow suit, offering low self-inductance and rock-solid linearity across the operating range.
But it’s not just about low distortion. The crossover is carefully tuned to align the woofer, AMT tweeter, and passive radiators for a coherent, unified response. It controls the horizontal directivity across the frequency spectrum, widening the effective listening area and making the system less position-dependent — a key win in real-world rooms where not everyone sits in the “perfect” spot.
The result? A speaker that sounds focused and natural whether you’re dead center or off to the side — with crossover voicing that avoids the phase issues or tonal gaps that plague lesser designs.
The Front Baffle
The CLARITY series front baffle is a serious piece of engineering — and not just for looks. It’s machined from a solid block of aluminum and then bonded to an MDF front panel to create a rigid sandwich structure. This hybrid approach dramatically reduces vibration, cabinet flex, and unwanted resonance — all of which can smear detail and muddy imaging.
radiant-clarity-baffle
Most speakers in this category stick with MDF-only front baffles to keep costs down. Radiant Acoustics clearly didn’t take that route. The aluminum faceplate is heavy, inert, and expensive to produce — but it provides a rock-solid foundation for the PURIFI USHINDI woofers, allowing them to work under ideal mechanical conditions.
The baffle’s chamfered edges serve both form and function. Visually, they soften the speaker’s industrial lines, but more importantly, they reduce edge diffraction, helping to maintain clarity and focus in the upper midrange and treble.
Bottom line: the front baffle isn’t just another material choice — it’s a performance-driven decision that supports the entire acoustic architecture of the speaker.
BASOTECT Dampened Cabinet
Hailing straight from Peter Lyngdorf’s personal woodshop, the CLARITY series cabinet is built tough with thick MDF panels reinforced by horizontal bracing to maximize rigidity and kill unwanted cabinet noise. Inside, a dedicated support pad surrounds the woofers, giving them room to breathe and optimizing their mechanical environment.
basotect-dampening
The woofer magnets get special treatment too — a brace plug channels energy directly into the cabinet’s core, reducing flex in both the front and rear baffles. This structural reinforcement keeps distortion from creeping in where it matters most.
For internal damping, Radiant Acoustics uses Basotect, a melamine-based open-cell foam known for its top-tier sound absorption. This isn’t just any filler—it’s specifically effective at taming the backward radiation from the AMT tweeter, keeping the cabinet acoustically quiet and preserving the speaker’s clarity and precision.
Bottom line: every detail of the cabinet’s design is geared toward minimizing distortion and maximizing sonic purity, a hallmark of Lyngdorf’s obsessive approach to audio engineering.
radiant-clarify-6-2-colors
The CLARITY 6.2 is the larger model in the CLARITY series, yet it maintains a compact footprint. This two-way speaker is engineered to deliver deep, controlled bass along with clear midrange and high frequencies, all with minimal distortion. It handles the dynamic range required for live recordings while preserving the accuracy of original material.
Despite its two-driver design, the CLARITY 6.2 produces a seamless and spacious soundstage that can fill a typical listening room. It’s designed to compete with larger three-way systems by providing balanced and detailed sound in a smaller package.
Radiant Acoustics CLARITY 4.2
radiant-clarity-4-2-speakers-lifestyle
Sharing much of the advanced technology found in the 6.2, the CLARITY 4.2 is engineered to maintain exceptionally low distortion for a speaker of its size. The clarity and power it delivers exceed typical expectations for a compact design.
Smaller than the 6.2, the CLARITY 4.2 offers an expansive, full-bodied, and immersive soundstage. Its ultra-low distortion architecture ensures that what you hear is pure music, free from coloration or interference. While its sensitivity numbers may look modest on paper, the CLARITY 4.2 still provides enough output to fill most listening rooms without strain.
This speaker is a solid option for anyone seeking high-end performance in a compact package, without the premium price tag.
Comparison
CLARITY 4.2CLARITY 6.2
Product TypeCompact 2-Way SpeakerCompact 2-Way Speaker
Price (pair)$2,998$4,498
Frequency Response40-22,000 Hz (±3dB)35-20,000 Hz (±3dB)
Sensitivity78 dB @ 2.83 VRMS ~ 1 W @ 8 ohm82 dB @ 2.00 VRMS ~ 1 W @ 4 ohm
85 dB @ 2.83 VRMS ~ 1 W @ 8 ohm
Impedance4 ohm 4 ohm
TweeterCustom AMT (Air Motion Transformer)Custom AMT (Air Motion Transformer)
Midrange/woofer4-inch PURIFI USHINDI (PTT4.0X04-NLC-02)6.5-inch PURIFI USHINDI (PTT6.5X04-NLA-10)
Passive radiators2 x 4-inch PURIFI USHINDI (PTT40PR-NL2-03)2 x 6.5-inch PURIFI USHINDI (PTT6.5PR-NL2-02)
Enclosure typeDual Balanced Passive RadiatorsDual Balanced Passive Radiators
Crossover frequency2300 Hz 2400 Hz
Crossover componentsLow-iron composition, air coilsLow-iron composition, air coils
Recommended  amplifier powerMin. 60WMin. 100W
Power handling200W250W
ConnectionsGold-plated banana connectors Gold-plated banana connectors
Cabinet15 mm MDF, 12 mm aluminum front baffle21 mm MDF, 15 mm aluminum front baffle
Internal dampeningBasotectBasotect
Front grillNoNo
Dimensions (WHD)164 x 260 x 194 mm
6.46 x 10.24 x 7.64 inches
222 x 364 x 266 mm
8.74 x 14.33 x 10.47 inches
WeightNet weight: 5.6 kg / 12.35 lbs. each.
Gross weight: 13 kg / 28.66 lbs. pair
Net weight: 10.8 kg / 23.8 lbs. each
Gross weight: 12.5 kg / 27.5 lbs. each
FinishesBlack, White (6-layer lacquer)
Walnut (Veneer)
Walnut (Veneer)
Custom Speaker Stands
To pair perfectly with the speakers, Radiant Acoustics offers custom-built, sturdy speaker stands designed primarily for the CLARITY 6.2 but flexible enough to support most compact speakers on the market. Made with solid steel plinths, these stands weigh a substantial 22 kilograms each, providing a stable and vibration-free foundation.
radiant-clarity-speaker-stand
For the smaller CLARITY 4.2, Radiant Acoustics sells a dedicated top plate separately that replaces the standard one to ensure a precise fit. If you buy the stands bundled with the 4.2 speakers, these custom top plates come included at no extra charge.
The stands feature adjustable upward tilt options for optimal vertical dispersion and offer built-in cable management to keep your setup clean. Additional touches include interchangeable top plates, secure mounting points, compartments for sand filling to add mass, and height-adjustable spikes with floor-protecting pads for stability and surface protection.
radiant-clarity-4-rear-input
The Bottom Line
Peter Lyngdorf’s Radiant Acoustics CLARITY series steps into a crowded bookshelf speaker market with a distinct approach that’s hard to ignore. Priced at just under $5,000 for the 6.2 and $3,000 for the 4.2, these speakers are positioned against heavy hitters like the Castle Windsor Earl and Duke ($5,000–$6,000), the Monitor Audio Studio 89 ($2,599), the Buchardt E50 ($4,000), and even the budget-friendly ELAC BS312.2 ($2,000).
What sets the CLARITY speakers apart isn’t flashy styling but a combination of unique driver tech—including the advanced PURIFI USHINDI woofers and custom AMT tweeters—and a carefully engineered, rigid aluminum baffle paired with a braced MDF cabinet. Despite a relatively low sensitivity rating, these speakers deliver detailed, distortion-free sound with surprisingly good output.
If you’re looking for bookshelf speakers that bring serious engineering muscle and a fresh take on driver and enclosure design, the CLARITY series deserves a serious listen — especially given Lyngdorf’s track record and pedigree. They won’t be for everyone, but audiophiles seeking precision and innovation will find plenty to consider here.
Price & Availability
2 Comments
2 Comments
  1. Anton
    July 13, 2025 at 5:15 pm
    As much as I don’t like the industrial design, the drivers, cabinet, construction, and materials are indeed impressive. Do you think these will sound more like a DALI or Lyngdorf? They are not inexpensive When you consider the size, stands, and the amount of power you might need.
    • Ian White
      July 13, 2025 at 6:24 pm
      Anton,
      I suspect that they will not sound like DALI. Probably more analytical with deeper bass.
      IW
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Starting at 3950 EUR per pair, the Buchardt Audio E50 Passive Bookshelf Speakers Deliver Danish Flair with a Healthy Appetite for Power.
Questyle’s QMS system pairs the iXStreamer with E5/E4 wireless speakers, SEAS drivers, Wi-Fi 6, LDAC, aptX, HDMI ARC/eARC, and lossless streaming.
Klipsch Rebellion debuts at High End Vienna 2026 as the first compact Heritage speaker, based on PWK’s rare 1958 H8 design.
Acoustic Energy AE Active debuts at High End Vienna 2026 with analog Class A/B amplification, RCA/XLR inputs, and no wireless clutter.
Fyne Audio Cubitt 5 active speakers bring IsoFlare driver tech, HDMI ARC, MM phono, and aptX HD Bluetooth for $749. But what’s missing?
Wharfedale Denton 1S brings coaxial point source design, wall mounting, Brilliance EQ, and Heritage Series style for $999. Is this the smarter small speaker?
Can one system do it all? Elipson’s Prestige Facet II 6 Active BT adds HDMI ARC, aptX HD, and a phono stage to simplify...
Daily Deals
Focal Omada bookshelf, floorstanding, and center speakers are on sale through June 21, 2026. Save up to 35% while supplies last.
