PMC Unveils Prophecy Speakers at High End Munich 2025: As Subtle as a Cannon in a Confessional
Discover PMC’s latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
PMC prophecy9 Speakers Lifestyle
PMC (Professional Monitor Company) has crossed the Channel and stormed the halls of High End Munich 2025, armed with their latest sonic weapon: the prophecy loudspeaker line. First unveiled in February, these British-engineered marvels are making their trade show debut in front of the toughest crowd in hi-fi. With a name like prophecy, you’d expect divine revelations — or at the very least, speakers that can peel the varnish off your musical expectations without breaking a sweat.
The prophecy speaker line consists of five models:
  • prophecy1: Bookshelf/Standmount speaker
  • prophecy5: Floorstanding Speaker
  • prophecy7: Floorstanding Speaker
  • prophecy9: Floorstanding Speaker
  • prophecyC: Center Channel Speaker
Note: As of this time, there are no prophecy 2, 3, 4, or 8 model designations.
pmc-prophecy-loudspeakers
The Prophecy speakers feature advanced technologies and a refreshed aesthetic that PMC believes represents the future of sound. Audiophiles and music enthusiasts attending High End Munich will have the chance to experience a new level of scale, realism, transparency, and musicality, all wrapped in a design that reflects current trends.
From Oliver Thomas, PMC co-CEO: “The response to prophecy has been phenomenal. I’m delighted that everyone gets’ what we were going for. Our new speakers feature elegant design with a sound that is bold, immersive, and far bigger than their size should allow…We’re proud to showcase the full range at the most important hi-fi event of the year. Come find us, say hello, and we will play you a few great tracks so you can experience just how powerful great design can sound.
Oliver Thomas and Elliott Whyte, the lead engineer behind the Prophecy series, will offer in-depth presentations on the technologies driving the Prophecy speakers at scheduled intervals throughout the show.
ATL & LaminairX
pmc-atl
The Prophecy line features a significant upgrade to PMC’s Laminair technology, working in conjunction with the Advanced Transmission Line (ATL). The patent-pending* LaminairX has been completely redesigned, unlocking the full potential of the ATL by reducing turbulence, which in turn lowers resistance and harmonic distortion by up to 3 dB. The result is clearer bass with improved timing and dynamic range, free from air noise. Additionally, the newly developed aerodynamic vent is integrated into the heavy extruded aluminum base of the cabinet, which also helps ground the speaker for enhanced control.
laminair-x
The unique holistic design approach takes into account every element — from the drive units and crossover components to the ATL, LaminairX vent, waveguides, and cabinet — all working in harmony to eliminate anything that detracts from the ideal musical experience. Each component has been designed to function together, with all parts being entirely interdependent.
Woofer
The long-throw bass drive units, developed specifically for the Prophecy line, are perfectly matched to the ATL. Their exceptionally linear design delivers deep bass frequencies without coloring the midrange, thanks to the combined effects of LaminairX and the ATL. The ultra-light, mica-filled cone material offers the ideal balance of rigidity, damping, and weight, allowing it to respond quickly to both the most powerful and the most subtle audio signals.
Tweeter
The tweeter used in the Prophecy line is the same one found in professional nearfield and midfield studio monitors. This 27mm soft dome, featuring Ferrofluid cooling, is equipped with a specially designed dispersion grille that ensures ultra-controlled directivity, extending up to 180 degrees.
3-Way Models
The three-way models (prophecy7 and prophecy9) feature a 55mm soft dome midrange, also used in professional studio monitors and the Ci series — the industry standard for Dolby Atmos Music mixing and a favorite in high-end home cinema installations. Its distinctive ‘n-compass™’ sculptured profile surrounds both the high-frequency and midrange drivers, improving their response and integration, ensuring they work as a unified system with an ultra-wide and stable soundstage.
The drive units are connected via PMC’s well-known high-order, steep roll-off crossover design. Its military-grade circuit board with ultra-thick copper tracks and gold through plating supports non-inhibited current flow and greater reliability. Careful component selection, precision matching, and optimised positioning provide low component interaction and low coloration. The steep filter slopes ensure that each drive unit works within its optimum range and presents a superb off-axis response for a wide listening window.
PMC Manufacturing Approach
The Prophecy series also introduces a new manufacturing approach for PMC, focusing on greater sustainability. The cabinet finishes highlight the natural tactile qualities of Walnut, Mediterranean Oak, and Black, using minimally invasive techniques. This not only enhances the speakers’ aesthetic but also aligns with modern interior design trends. The veneers are sourced from sustainable suppliers.
The grilles are secured with concealed magnets, and the open-weave, textured fabric complements the overall Prophecy aesthetic.
PMC prophecy Comparison
pmc-phophecy-series
PMC Modelprophecy1prophecy5prophecy7prophecy9prophecyC
Product TypeTwo-Way Bookshelf/Standmount SpeakerTwo-Way Floor Standing SpeakerThree-Way Floor Standing SpeakerThree-Way Floor Standing SpeakerTwo-way Center Channel Speaker
Price$4,299/pair$6,499/pair$9,499/pair$12,999/pair$3,299/each
Frequency Response (-3dB)50Hz-20kHz 40Hz – 20kHz40Hz – 20kHz35Hz – 20kHz 50Hz – 20kHz
Sensitivity (SPL 1w @ 1m)85dB  87dB 88dB91.5dB91.5dB
Peak SPL  120dB 121dB123dB125dB124dB
Recommended Amp Power20 – 200W20 – 200W25 – 250W30 – 300W20 – 200W
Effective ATL™ Length1.79m/5.8ft1.79m/5.8ft1.91m/6.3ft2.57m/8.4ft1.79m/5.8ft
Impedance6 Ohm6 Ohm6 Ohm4 Ohm4 Ohm
Tweeter (HF)PMC 1”/27mm soft dome PMC 1”/27mm soft domePMC 1”/27mm soft domePMC 1”/27mm soft domePMC 1”/27mm soft dome
Midrange (MF)Not ApplicableNot ApplicablePMC 2”/55mm soft dome PMC 2”/55mm soft dome precision midrange Not Applicable
Woofer (LF)PMC 5”/125mm LTXL mineral cone with cast alloy chassisPMC 5”/125mm LTXL mineral cone with cast alloy chassisPMC 5”/125mm LTXL mineral cone with cast alloy chassis2 x PMC 5”/125mm LTXL mineral cone with cast alloy chassis2 x PMC 5”/125mm LTXL mineral cone with cast alloy chassis
Horizontal Directivity80 degrees 90 degrees90 degrees90 degrees90 degrees
Vertical Directivity90 degrees110 degrees 110 degrees 100 degrees 90 degrees
Crossover Frequency1.5kHz1.6kHz0.6kHz
 3.1kHz
0.6kHz
3.2kHz
1.6kHz
Input ConnectionsOne pair 4mm binding posts finished in satin nickelOne pair 4mm binding posts finished in satin nickelOne pair 4mm binding posts finished in satin nickelOne pair 4mm binding posts finished in satin nickelOne pair 4mm binding posts finished in satin nickel
DimensionsH 400mm/15.7”
W 165mm/ 6.5″
D 260mm/10.2” (+ 23mm terminals and +10mm grille)
H 900mm/35.4” (+20mm spikes)
W 165mm /6.5”
D 260mm/ 10.2” (+ 23mm terminals and +10mm grille)
H  965mm/ 37.9” (+20mm spikes)
W 165mm/6.5”
D 310mm/ 12.3” (+ 23mm terminals and +10mm grille)
H 1030mm/40.5” (+20mm spikes)
W 165mm/6.5”
D 360mm/14.2”  (+ 23mm terminals and +10mm grille)
H
165mm/6.5”
W 575mm/22.6”
D 260mm/10.2” (+ 25mm terminals and +10mm grille)
Weight (each)10.3 kg
22.7 lbs
17.7 kg
39 lbs
23.7 kg
52 lbs
28.1kg
62 lbs
16.3 kg
36 lbs
Finish OptionsMediterranean oak
Natural alnut
Blackened walnut
Mediterranean oak
Natural walnut
Blackened walnut
Mediterranean oak
Natural walnut
Blackened walnut
Mediterranean oak
Natural walnut
Blackened walnut
Mediterranean oak
Natural walnut
Blackened walnut
pmc-cor-front
The Prophecy speaker setup at High End Munich 2025 is powered by the PMC cor integrated amplifier. Featuring an analog design, the cor adds no sonic character of its own, allowing the music to speak for itself. Following the same design principles that guide the creation of PMC loudspeakers—musicality, transparency, and neutrality—it ensures that nothing is added or taken away from the listening experience.
Visually, the cor embraces a minimalist industrial design, inspired by the work of Dieter Rams and a nod to Raymond Loewy, the “father of streamlining.” Crafted from extruded aluminum and available in a subtle black or silver finish, its understated appearance perfectly complements the pure, uncolored sound it delivers.
PMC cor Specifications
pmc-cor-rear
PMC ModelCor Integrated
Product TypeIntegrated Ampifier
Price$9,999
General Specifications
Amplifier TypePure analogue Class A/B
Inputs1 x balanced, 4 x single-ended, direct in
Outputs4mm binding posts, preamp out
Dimensions (WHD- including feet)432mm x 87.5mm x 401mm
17.01 x 3.445 x 15.79 inches
Weight12kg
Pre-Amplifier Specifications
Frequency response20Hz – 20kHz (+0/-0.2dB)
5Hz – 80kHz (+0/-1dB)
Maximum gain15dB
Tone controls+/- 10dB
Input impedance25kOhms, unbalanced >14kOhms, balanced
THD (Total Harmonic Distortion)0.001% at 1kHz <0.005%, 20Hz – 20kHz, 80kHz measurement bandwidth
Noise<0.001% SMPTE
Maximum input5.5Vrms
Maximum output10Vrms
Power Amplifier Specifications
Rated output power 230V mains95W into 8 Ohms,
140W into 4 Ohms
Frequency response20Hz – 20kHz +0/-0.2dB
5Hz – 80kHz +0/-1dB
Input impedance23.5kOhms
Sensitivity1V = 100W into 8Ohms
Gain28.9dB
THD (Rated output power into 8 Ohms)0.001% at 1kHz <0.01%, 20Hz – 20kHz, 80kHz measurement bandwidth
Noise-101dB A-weighted re. rated output
Output Impedance<0.05Ohms, 20Hz – 20kHz
Damping factor>160 into 8Ohms, 20Hz – 20kHz
pmc-prophecy9-loudspeaker
PMC prophecy9 Loudspeaker (flagship model)
The Bottom Line
PMC prophecy loudspeakers offer a step up from the Twenty5i series launched in 2020. Although both can be used for hi-fi or home theater, the prophecy series brings even greater musicality, transparency and lifelike dynamics.
For those attending, PMC is a must-visit at High End Munich 2025  in Room D106, Atrium 3.1.
Pricing & Availability
PMC speakers can be purchased through Authorized Dealers worldwide.
  • prophecy1 Bookshelf/Standmount Speaker: $4,299 (pair)
  • prophecy5 Floorstanding Speaker: $6,499 (pair)
  • prophecy7 Floorstanding Speaker: $9,499 (pair)
  • prophecy9 Floorstanding Speaker: $12,999 (pair)
  • prophecyC Center Channel Speaker: $3,299 (each)
  • cor Integrated Ampifier: $9,999
Fezz Audio Luna Integrated Amplifier Big Calm Maroon Front Angle
Fezz Audio Luna brings Polish tube engineering, Toroidy transformers, bold finishes, and modern flexibility to U.S. hi-fi customers.
iFi Audio ZEN Air Phono 2 MM MC Preamplifier Lifestyle Stack iFi Audio ZEN Air Phono 2 MM MC Preamplifier Lifestyle Stack
iFi's ZEN Air Phono 2 adds MM and MC support with accurate RIAA playback and low noise, offering a flexible $129 upgrade for turntables...
Garmin JL Audio Primacy System Lifestyle Garmin JL Audio Primacy System Lifestyle
Garmin’s JL Audio Primacy system combines streaming, room correction, MM/MC phono, Dante, and active speakers from $50,000. Is this the new luxury hi-fi formula?
YG Acoustics Titan Loudspeakers Pair YG Acoustics Titan Loudspeakers Pair
7 feet tall and and weighing 1,000 pounds, YG Acoustics flagship 5-way loudspeakers come in fully active, semi-active or passive versions.
Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash Devialet Phantom Ultimate 98 dB Roland-Garros Wireless Speaker Clay Splash
Devialet’s Roland Garros Phantom Ultimate serves clay court style, deep bass, and French attitude in a limited edition wireless speaker. Voilà.
2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle 2026 Jamo Concert Legacy 11 Loudspeakers Heritage Finish Lifestyle
Priced from $1,099 to $7,999 per pair, Jamo Concert Legacy and Element Series Loudspeakers preview August 2026 launch.
Mother's Day Tech Gift Ideas 2026
Upgrade Mom's audio experiences this Mother's Day with gift ideas she'll absolutely love -- and you might too.
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Only 25 numbered pairs will ever be made, finished in piano-gloss rosewood with satin-black detailing, engraved plaques and certificates of authenticity.
Wisdom Audio’s Sage Series outdoor speakers feature premium planar magnetic technology delivering audiophile-quality sound with advanced DSP and durable design for luxury outdoor and...
WiiM Amp Ultra merges the brains of the Ultra and the brawn of the Amp Pro—now with a touchscreen and HDMI ARC for your...
Estelon unveils the AURELLE stand-mount and Centre speaker, and AURUS subwoofer at High End Munich 2025, celebrating its 15th anniversary. Prices start at €7,500...
Qobuz Connect launches this week, bringing seamless high-res audio streaming to HEOS and a wide range of devices, outshining TIDAL with smoother integration.
AVID HIFI celebrates 30 years with the EVO TWO, a $40K 3.5-way loudspeaker built in the UK to rival Focal, Wilson, and Sonus faber...
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
