Hsu D15-Chimera SC: The World’s First Supercharged Dual 15″ Sub Debuts at T.H.E. Show 2025
Hsu Research D15-Chimera SC Subwoofer in satin black
Meet the new apex predator of home theater bass: the Hsu Research D15-Chimera SC, a modular, dual 15-inch subwoofer that just made its explosive debut at T.H.E. Show SoCal 2025 in California. This beast doesn’t just move air—it moves walls. Starting as a sealed dual 15-inch sub (a first for Hsu), the D15-Chimera transforms into a supercharged ported juggernaut with the addition of the SC module, making it the first-ever supercharged dual 15-inch ported subwoofer on the planet.
Fueled by a 1200W RMS amplifier, the D15-Chimera SC delivers seismic low-end with surgical control. Hsu’s two-piece design isn’t just smart—it’s practical. It’s the only subwoofer in its class that won’t make you swear during setup. Once you snap on the SC, you unlock dual and triple-port configurations that rival Hsu’s legendary VTF-TN1 subwoofer—but with less port noise and deeper tuning.
Need more drama? You can even customize the port direction, choosing forward-facing for visual intimidation or rear-firing for a stealthy rumble that hits like an aftershock. The D15-Chimera SC isn’t just loud—it’s strategic warfare in subwoofer form.
Brace your drywall. The age of supercharged bass has officially arrived.
hsu-d15-chimera-sc-subwoofer-the-show-2025
D15-Chimera SC in satin black at T.H.E. Show SoCal 2025
How the D15-Chimera SC Works — And Why It Sounds Like Thunder on Command
Hsu’s D15-Chimera SC might sound like a mythical beast, but converting it from sealed to ported is surprisingly straightforward—and smartly designed for real-world setups.
You start with the top sealed subwoofer unit—a standalone dual 15-inch sealed beast that’s more than capable on its own. When you’re ready to unleash full Beast Mode, you add the SC (Supercharger) module, which acts as the ported lower half of the stack.
Here’s the clever part: The amplifier is mounted underneath the sealed sub. To combine both units, you simply unscrew the amp, stack the SC module underneath, and then remount the amp to the side of the cabinet. This opens up an internal connection between the two enclosures, effectively transforming the sealed D15 into a fully ported system with your choice of port configurations.
The result? A dual-15-inch supercharged ported subwoofer that delivers crushing low-end extension and output—but in a modular, manageable form that you can actually install without a forklift or a buddy named Thor.
No fancy tools. No drama. Just smart Hsu engineering that gives you massive bass when you want it, and refined sealed performance when you don’t.
hsu-d15-chimera-the-show-2025
Hsu D15-Chimera (vertical) with MFL-6 stand-mount speaker as left rear surround speaker.
Comparison
D15-ChimeraD15-Chimera SC
PerformanceBest Performance; Pro AudioUnparalleled Performance; Pro Audio
MSRP$1,799
+shipping
$2,298
+shipping
Woofer Dual 15-inchDual 15-inch
Low-End Extension 25 Hz (sealed)14 Hz (2 ports)
15 Hz (3 ports)
17 Hz (4 ports)
Low Bass Output 117.6 dB125.7 dB (2 port)
126.4 dB (3 port)
126.9 dB (4 port)
Mid Bass Output 132.0 dB131.6 dB (2 port)
132.1 dB (3 port)
132.7 dB (4 port)
Type SealedPorted (VTF)
Modular DesignOptionalIncluded
XLR Inputs Yes Yes
hsu-d15-chimera-sc-subwoofer-angle
Hsu D15-Chimera SC
Analysis: Why the D15-Chimera SC Is Hsu’s Most Ambitious Sub Yet
The D15-Chimera SC isn’t just Hsu’s largest subwoofer—it’s a thoughtful blend of engineering and practicality. The base D15-Chimera starts as a sealed dual 15-inch design capable of strong low-end extension down to 25 Hz and output levels that approach 118 dB. Add the Supercharger (SC) module, and the system transitions into a ported configuration that significantly boosts output and extension—down to 14 Hz with up to 126.9 dB of low bass.
This isn’t just about adding more power or drivers—it’s about flexibility. The modular approach makes it easier to handle and install compared to traditional one-box designs at this performance level. You get sealed precision when space or control matters, and ported depth and scale when you want maximum low-end impact.
With 2 to 4 ports active, the SC configuration drops the extension down to as low as 14 Hz and boosts output to 126.9 dB. That’s 2x the performance of Hsu’s already formidable TN1 tower in both mid and low bass—without the same cabinet bulk or footprint.
What makes it smarter than brute-force solutions is the modular design: easier to move, install, and tailor to your room. You can run it sealed in a tighter space, then supercharge it when you’re ready to shake the slab foundation. The real-world upgrade process (unscrew amp, stack SC, remount amp on side) is surprisingly intuitive for a setup this powerful.
hsu-home-theater-the-show-2025
Hsu’s 5.1 home theater system at T.H.E. Show SoCal used 5 identical MFL-6 stand-mount speakers with D15-Chimera SC subwoofer and Onkyo TX-NR686 and the thinnest speaker cables ever spotted at a high-end audio show.
Listening
We experienced the Hsu D15-Chimera SC at T.H.E. Show SoCal 2025 in Costa Mesa, CA, and while a hotel room is arguably one of the worst places to judge a subwoofer—thin walls, questionable acoustics, and a layout that likely has nothing in common with your home setup—what we experienced was hard to ignore.
Anchoring a full Hsu 5.1 speaker system, the D15-Chimera SC didn’t just fill the room—it pressurized it. It uses its own built-in amplifier, and it’s clear that the pairing is more than up to the task. During the ocean battle in Godzilla vs. Kong, the D15 unloaded a tidal wave of infrasonic bass. Every punch felt like it landed in your chest, and the depth charges didn’t just rock the ship—they shook the entire room.
For the audiophiles chasing that elusive 16Hz organ note, the D15 delivers it without flinching. No need to plan a trip to Boardwalk Hall when this thing can summon subterranean frequencies right in your listening room—assuming your walls can take it.
Price & Availability
Pre-orders for the Hsu D15-Chimera SC open Monday, June 9th at 9 AM PT and run through July 11, 2025. Pre-order pricing is set at $2,149 plus $198 for shipping, which reflects a $150 discount compared to purchasing the sealed D15-Chimera and Supercharger module separately. A non-refundable $400 deposit is required to secure your order.
Important Note: While the D15-Chimera (sealed) will be available as a standalone model later on, pre-orders are exclusively for the full supercharged ported version (D15-Chimera SC).
2 Comments
2 Comments
  1. Anton Yelchin
    June 10, 2025 at 11:27 am
    Not doubting your experience, but the finish looks very dated and as you guys have correctly pointed out recently — color matters. Even in a large and innovative looking subwoofer.
    Not sure I need to feel bass down to 17Hz in my den.
  2. Andy P
    June 12, 2025 at 3:25 am
    HSU Rules. My VTF3-MK5 thunders the foundation of our home. The Chimara SC specs are shocking.. incredible performance for the $. Blows away SVS and everything but perhaps Tonewinner in terms of performance per dollar
Monitor Audio Creator Series C2L-A Angled In-Ceiling Speakers Lifestyle
In-Ceiling Speakers
The $750 Monitor Audio C2L-A angled in-ceiling speaker offers improved directional clarity and placement flexibility, especially for Dolby Atmos height channels.
2026 NAD C 589 CD Player Drawer Open Above 2026 NAD C 589 CD Player Drawer Open Above
CD Players
At $1,399, the NAD C 589 CD player promises improved playback with MQA's QRONO d2a processing and ESS ES9039PRO DAC.
Innuos Nazare Digital Music Streamer Innuos Nazare Digital Music Streamer
Can Innuos Nazaré justify its $100K+ price? We compare it to ZENith NG at AXPONA 2026 and ask who actually needs this level of...
Wharfedale Heritage Centre Speaker in cabinet Wharfedale Heritage Centre Speaker in cabinet
Center Speakers
Wharfedale Heritage Centre Channel finally delivers a matching center speaker for Linton, Super Denton, and Heritage Series home theater systems.
Kanto Audio Tuk Grand Lifestyle Kanto Audio Tuk Grand Lifestyle
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV. LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV.
LG’s Micro RGB evo TVs aim to boost brightness and color beyond OLED, but can they justify a premium over models like the G6...
Podcasts
Gary Yacoubian (SVS CEO) and Nicholas Brown (SVS VP of Marketing) reveal details about the company's latest subwoofers and future products.
Can the SVS 3000 Micro R|Evolution deliver deep bass from dual 9-inch drivers, 1,200 watts power, and advanced DSP without taking over your room?
At $2,749, can PS Audio’s Foundry F12 justify its price against SVS, REL, and MartinLogan by delivering cleaner, more controlled bass where it actually...
Just days after CES 2026, SVS’s 3000 R|Evolution subwoofers are now available—but do they raise the bar for output and control?
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
From budget-friendly upgrades to room-shaking reference bass, these subwoofer picks deliver accurate low-end performance, smart features, and real value at every price tier.
