Head(amame) Debuts 3D Printed Sustainable Headphones at AXPONA 2026 You Can Build Yourself
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Head(amame) Pro Headphones
Most audio brands guard their designs like trade secrets, but Head(amame) showed up at AXPONA 2026 and did the exact opposite. The Vancouver-based company is handing over schematics, specs, and build plans for its 3D printed headphones, inviting users to print and assemble their own at home with a parts kit for what cannot be fabricated on a desktop printer. While 3D printed speakers have been circulating in DIY circles for years, this is the first time I have seen the concept executed this openly and completely in the headphone space.
Morgan Andreychuk explained that Head(amame) gives away the files to 3D print the cups, yoke, and headband whether you buy the finished headphone or build it yourself. The price difference is a big part of the appeal: the completed Head(amame) Pro starts at $369 for Kickstarter backers, while the Head(amame) parts kit sells for $130 through the company’s site. That means buyers can pay more for a finished product with QC and warranty coverage, or spend a lot less on the kit and print most of the structure themselves.
Either way, the open design is the real hook. Owners have the files needed to recreate most of the structural parts if something breaks, wears out, or if they want to tweak the design later. The tradeoff is straightforward: choose the DIY route and you give up the company’s finished-product QC process and warranty, but not its support. Andreychuk and the team were clearly willing to discuss materials, printing options, and possible improvements, which makes this feel less like a sealed consumer product and more like a headphone platform built for people who actually want to tinker.
Head(amame) Pro 3D Printed Headphones
The Head(amame) Pro uses a semi closed back design that will feel familiar in concept to the Fostex T50RP, even if it looks nothing like it. The structure is unmistakably its own. The headband and yoke form a plus shaped frame that dominates the face of the cup, while a series of radial baffles wrap around the perimeter, giving it an almost floral appearance. You do not see the driver from the rear, but each “petal” hides a vent that becomes visible from the side.
Head(amame) Pro Headphones at AXPONA 2026
Even the cable placement refuses to follow convention, mounted vertically on the rear face but closer to the front. My first instinct was that I had them on backwards. Morgan acknowledged that clearer left and right markings are still a work in progress.
The first real surprise comes when you pick them up. For something this large, the Head(amame) Pro is extremely light. That is not by accident. The goal is to go even further, with plans to swap a brass pin for aluminum and replace another internal component with carbon fiber. It is already more than 100 grams lighter than the AirPods Max and still trending downward.
That kind of weight reduction changes the equation. A non padded headband might raise eyebrows on paper, but here it is not the liability you would expect because there simply is not enough mass to make it one.
The Head(amame) Pro uses dynamic drivers with a glass diaphragm intended to improve speed and clarity, but the platform is not locked down. Builders can experiment with a range of 40 mm dynamic drivers as long as the specifications line up, which reinforces the open, modular nature of the design. Head(amame) shared a booth with Capra Audio, who assisted with tuning the Pro.
That collaboration came after some disagreement over the voicing of an earlier model, prompting Morgan to bring Capra into the process for this revision. Given Capra Audio’s presence in the DIY space with aftermarket parts and headbands, the partnership makes sense and will likely resonate with the community this product is aimed at.
Sound, at least in that environment, leaned close to reference with a slight roll off in the lowest octaves and a bit of lift up top. It is an easy signature to listen to and, more importantly, one that invites experimentation. That matters here because the entire premise is that you are not stuck with a fixed outcome. The reality of a busy show floor limits how far I am willing to go with sonic conclusions, but the early impression was positive enough to warrant a deeper look. If I can get a set printed for review, there is clearly more to unpack.
As a concept, Head(amame) is doing something few others are willing to try. It is a more sustainable approach than most full size headphones, and at roughly 280 grams with plans to go even lighter, it is also one of the more comfortable options for listeners who usually tap out early because of weight.
Where to order: $589 $399 at Head(amame)
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
A/V Furniture & Accessories
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Magico A3 2027 Loudspeakers Lifestyle Magico A3 2027 Loudspeakers Lifestyle
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle 2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle
The $1,800 JBL PartyBox Ultimate 2 packs 1,500 watts, Wi-Fi 6, Roon, AI karaoke and a touchscreen into a light show speaker that isn't...
2026 TDM Neo Headphone Speaker Black in hand 2026 TDM Neo Headphone Speaker Black in hand
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
Headphones
Help Capra Audio rebuild after devastating West Virginia floods. Donate or share the GoFundMe, now at about $19,000 of its $30,000 goal.
Podcasts
Hi-Fi Bear reveals what makes T10 Bespoke's in-ear computers so special with eCoustics Podcast Producer Mitch Anderson who tries them for the first time.
Podcasts
Loewe returns to the U.S. with Stellar TVs and Leo headphones. At AXPONA 2026, its team explains the brand’s premium design and engineering strategy.
Headphones
At AXPONA 2026, Sr. eCoustics Personal Audio Reviewer, W. Jennings, reveals his favorite headphones, portable gear, and high-end audio systems, along with an exciting...
Podcasts
At AXPONA 2026, Lenny Coco of MoFi shares his lifelong passion for music and system building, whether analog or digital, and his perspective may...
At AXPONA 2026, eCoustics Editor-in-Chief, Ian White, reveals some of his favorite products at North America's largest high-end audio show.
Focal Crafts, Mu-so Hekla, and CI-Uniti 102 headline AXPONA 2026 with new finishes, wireless performance, and CI flexibility
At $13,000, the Esoteric N-05XE combines streaming, DAC, preamp, and headphone amp duties into a Tokyo-built hub that impressed at AXPONA 2026.
