Fosi Audio Launches BT20A MAX 2.1 Bluetooth Class D Amplifier for High-Power Desktop and Compact Systems
Fosi Audio’s $229.99 BT20A MAX packs a TI TPA3255 amp, real 2.1 power, and unusually robust Bluetooth codec support—does it deliver where it counts?
Fosi Audio BT20A MAX Desktop Amplifier with Bluetooth
Fosi Audio has built a formidable presence in affordable hi-fi, and the launch of the BT20A MAX underscores just how far the brand has come. Priced at $229.99, the BT20A MAX is the company’s most advanced BT20A-series amplifier to date, combining high-output Class D amplification, upgraded internal components, and next-generation Bluetooth connectivity in a compact chassis aimed squarely at desktop and small-room systems.
Backed by strong sales momentum and consistently high visibility on Amazon, Fosi Audio has evolved well beyond “budget amp specialist,” now offering one of the broadest product lineups in its category—spanning a turntable, passive loudspeakers, DACs, planar magnetic headphones, IEMs, dongle DACs, subwoofers, and an expanding range of Bluetooth and power amplifiers.
High-Power Class D Performance in a Compact Design
fosi-bt20a-max-angle
The Fosi Audio BT20A MAX is a compact 2.1-channel Class D integrated amplifier designed to deliver serious output and modern wireless flexibility without the bulk or complexity of a traditional hi-fi amp. At its core is Texas Instruments’ TPA3255 amplifier chipset, paired with NE5532 op-amps, delivering up to 300 watts per channel peak and 180 watts per channel RMS into 4 ohms, with stable operation across 2–8Ω speaker loads.
Fosi Audio’s use of post-filter feedback (PFFB) helps keep distortion extremely low (≤0.003% THD+N) while maintaining a high signal-to-noise ratio of ≥112 dB, ensuring consistent performance even as speaker impedance varies. Independent digital and analog power supplies, along with ELNA capacitors, are employed to preserve clarity, dynamics, and tonal balance.
Designed for flexible system integration, the BT20A MAX offers dual RCA inputs, Bluetooth connectivity, binding posts for passive loudspeakers, and a dedicated subwoofer output for true 2.1-channel operation. A selectable 80 Hz high-pass filter improves midrange and vocal clarity when used with a subwoofer, while bass and treble controls allow for system tuning. An EQ bypass mode is included for listeners who prefer a cleaner, more direct signal path.
fosi-bt20a-max-features
Wireless playback is a major strength at this price point. The BT20A MAX uses a Qualcomm QCC3095 Bluetooth SoC with Bluetooth 6.0, supporting an unusually broad range of codecs for a $229.99 amplifier, including SBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Lossless, and LDAC.
This ensures stable, low-latency connections and high-resolution wireless streaming from smartphones, tablets, and computers, whether used at a desk or in a compact living-room setup. Wireless range is rated at up to 15 meters (50 feet).
Additional features include a motorized analog volume potentiometer controlled by the included remote, 12V trigger support for system automation, and an active cooling system with a newly engineered low-noise fan and optimized ventilation that improves thermal efficiency by up to 30% during extended listening sessions.
fosi-bt20a-max-remote
fosi-bt20a-max-rear
The amplifier is housed in an all-aluminum chassis and operates on a DC voltage range of 32V–48V, making it suitable for a wide range of power supplies and use cases. Overall, the BT20A MAX is aimed squarely at desktop audiophiles, apartment dwellers, and budget-minded hi-fi listeners who want high output, subwoofer integration, and unusually robust Bluetooth codec support in a compact, affordable amplifier.
Comparison
BT20A MAX
(2026)
BT20A PRO
(2023)
BT20A
(2020)
Product TypeBluetooth AmplifierBluetooth AmplifierBluetooth Amplifier
Price$229.99$99.99$79.99
Channel Configuration2.12.0 2.0
Amplifier ChipsetTI TPA3255, NE5532TI TPA3255, NE5532TI TPA3116, NE5532
Max Output Power300W x 2 @ 4Ω300W x 2 @ 4Ω200W x 2 @ 4Ω
RMS Output Power180W x 2 @ 4ΩNot Indicated Not Indicated
Input2 x RCA
Bluetooth
1 x RCA
Bluetooth
1 X RCA
Bluetooth
OutputSpeaker Out
Sub Out
Speaker Out Speaker Out
SNR≥ 112 dB≥108dB≥ 98dB
THD+N≤ 0.003%≤0.005%≤ 0.5%
Terminal Impedance2-8Ω2-8Ω2-8Ω
Bluetooth SoCQualcomm QCC3095ATS2853ATS2853
Bluetooth Version6.05.05.0
Bluetooth Connection Range50′ / 15m50′ / 15m28′ / 8.5m
Bluetooth Audio CodecsSBC / AAC / aptX / aptX HD / aptX Adaptive / aptX Lossless / LDACSBC/AACSBC/AAC
Frequency Response20 Hz–20 kHz (±0.5 dB)20Hz – 20kHz (±1 dB)20Hz – 20kHz (±1 dB)
Package ContentsBT20A Max x 1
Bluetooth Antenna x 1
User’s Manual x 1
IR Remote x 1
Power Adapter x 1
BT20A PRO x 1
32V/5A or48V/5A Power Adapter x 1
User’s Manual x 1
BT20A x 1
Power supply x 1
AC power cord x 1
User’s Manual x 1
fosi-bt20a-max-front
The Bottom Line
If the sonics live up to the spec sheet, the Fosi Audio BT20A MAX makes a strong case at $229.99 by focusing on the things that actually matter in a compact 2.1 amp: a proven TI TPA3255 Class D platform, very low measured distortion, real output power into 4 ohms, proper subwoofer integration with a high-pass filter, and one of the most complete Bluetooth codec lineups you’ll find anywhere near this price. Add independent power supplies, quality internal components, and practical touches like a remote-controlled analog volume pot and 12V trigger, and this is clearly aimed at listeners who want performance and flexibility—not a feature bingo card.
What’s missing is just as telling. There’s no HDMI, no phono stage, and no headphone amplifier, which means this is not an all-in-one lifestyle hub or a vinyl-first integrated amp. And that’s fine. This is for desktop audiophiles, apartment dwellers, and budget-conscious hi-fi listeners who already live in the world of streaming, powered subwoofers, and passive bookshelf speakers—and who don’t feel the need to pay extra for features they won’t use. If you want TV eARC, a turntable input, or late-night headphone listening, look elsewhere. If you want a compact, high-power 2.1 amplifier with unusually strong Bluetooth support and the right core tech at the right price, the BT20A MAX is very much in the conversation.
Where to buy:
Monitor Audio Creator Series C2L-A Angled In-Ceiling Speakers Lifestyle
In-Ceiling Speakers
The $750 Monitor Audio C2L-A angled in-ceiling speaker offers improved directional clarity and placement flexibility, especially for Dolby Atmos height channels.
2026 NAD C 589 CD Player Drawer Open Above 2026 NAD C 589 CD Player Drawer Open Above
CD Players
At $1,399, the NAD C 589 CD player promises improved playback with MQA's QRONO d2a processing and ESS ES9039PRO DAC.
Innuos Nazare Digital Music Streamer Innuos Nazare Digital Music Streamer
Can Innuos Nazaré justify its $100K+ price? We compare it to ZENith NG at AXPONA 2026 and ask who actually needs this level of...
Wharfedale Heritage Centre Speaker in cabinet Wharfedale Heritage Centre Speaker in cabinet
Center Speakers
Wharfedale Heritage Centre Channel finally delivers a matching center speaker for Linton, Super Denton, and Heritage Series home theater systems.
Kanto Audio Tuk Grand Lifestyle Kanto Audio Tuk Grand Lifestyle
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV. LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV.
LG’s Micro RGB evo TVs aim to boost brightness and color beyond OLED, but can they justify a premium over models like the G6...
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
Dongle DACs
Can a $149 MagSafe compatible DAC/amp deliver clean, neutral sound and fix the cable chaos of dongle DACs for iPhone users? The Fosi MD3...
Fosi Audio debuts the C3 AI Gaming Sound Card and MD3 Magnetic DAC/Amp at CanJam NYC 2026, expanding into gaming audio and portable hi-fi.
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Can Fosi Audio’s $199 K7 deliver truly audiophile-grade sound with balanced power, EQ, and broad connectivity—or does value finally meet its limits?
Dongle DACs
Fosi Audio debuts the MD3 Magnetic and DS3 portable DAC/headphone amplifiers at CanJam Dubai 2026, focusing on compact design, XMOS processing, and IEM-friendly performance—not...
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
