FiiO Expands Active Speaker Line With New SP5 Hi-Fi Desktop Monitors
FiiO expands its desktop audio lineup with the new SP5 active speakers, featuring upgraded amplification, premium drivers, and wide-format connectivity for under $750.
FiiO SP5 Desktop Speaker
FiiO has been on a tear in 2025. With the launch of the S15 music streamer, FT7 planar magnetic headphones, FX17 IEMs, M21 digital audio player, K17 headphone amp, SA1 active speakers, and the K15 DAC/amp, they’ve hit just about every corner of the desktop and portable audio market.
Now they’re adding another powered speaker to the mix: the new FiiO SP5. It builds on FiiO’s existing lineup of active speakers — including the SP3, SP3BT, and SA1 — with upgrades aimed at both desktop audio setups and more demanding studio environments. According to FiiO, the SP5 delivers improvements in sound quality and performance that push it further into reference territory while keeping things compact and desk-friendly.
fiio-sp5-speaker
FiiO SP5
FiiO SP5 Features: Desktop-Friendly Powered Speakers With Studio-Grade Performance
As with most compact active speaker systems — and consistent with FiiO’s previous designs — the SP5 follows the familiar primary/secondary setup. The primary speaker houses all of the amplification and inputs, while the secondary connects via the included speaker cable. It’s a clean, functional layout that keeps your desktop looking less like a recording studio exploded.
Under the hood, the SP5 features a completely reworked dual power supply system. Each speaker gets its own dedicated 120W power supply — not shared — which helps eliminate cross-channel interference and keeps power delivery stable. This setup is more in line with what you’d expect from a traditional component system than from a typical powered desktop pair.
FiiO also fitted the SP5 with a true 4-channel amplifier design, delivering 60W + 20W per speaker. That means each driver gets its own dedicated power: 60 watts for the 5.25-inch Rohacell-cone woofer and 20 watts for the 1-inch composite silk dome tweeter. It’s a more surgical approach to amplification — not just louder, but more controlled.
The Rohacell woofer is engineered for ultra-low distortion and quick, tight bass response. Meanwhile, the tweeter benefits from a rear cavity design and internal magnet structure, which gives the highs a smooth, detailed character without smearing or harshness. According to FiiO, this combo is all about delivering clarity, balance, and full-range performance in a speaker system that doesn’t eat your entire desk.
To fine-tune what you actually hear, the SP5 comes equipped with a built-in 3-band EQ system for bass and treble adjustments, plus dual-frequency bass extension. It’s designed to give users quick, hands-on control — whether you’re taming boom in a small room or adding some low-end punch for casual listening.
But if you want more surgical precision, pairing the SP5 with the FiiO Control App (available on iOS and Android) unlocks a full 10-band parametric EQ (PEQ) along with complete speaker configuration from your phone, tablet, or laptop. Whether you’re dialing in your personal desktop setup or prepping a mix in a small studio space, the tuning flexibility is there.
In terms of connectivity, the SP5 covers both wireless and wired needs. On the wireless side, it supports high-resolution Bluetooth codecs like LDAC and aptX Adaptive. For wired connections, you get analog AUX and RCA inputs, balanced XLR, and USB-C — making it versatile enough to slot into everything from laptop setups to more serious desktop rigs.
fiio-sp5-rear
For added input flexibility, the SP5 features independent volume memory for each source. That means every input — whether it’s Bluetooth, USB-C, RCA, or XLR — retains its own volume level, so you’re not constantly readjusting when switching between devices.
Volume control is handled by a low-noise, high-precision encoder, allowing for stepless, electronic adjustments via the front-mounted knob. It’s not just smooth — it preserves resolution across the entire frequency range, so you don’t lose detail when listening at lower levels.
The SP5 also includes a 12-volt trigger input, allowing it to sync power-on with external gear — handy if you’re integrating it into a larger setup and want everything to fire up with one switch.
Additional controls include a custom IR remote, RGB LED indicators (color-coded for input selection), and that front-facing volume knob — tactile, responsive, and exactly where it should be for desktop use.
The SP5 includes two Furukawa oxygen-free copper power cables, ensuring clean power delivery and maximum electrical conductivity.
Comparison
fiio-sp5-comparison
SP5 (2025)SA1 (2025)SP3BT (2024)SP3 (2023)
Product TypeActive SpeakerActive SpeakerActive SpeakerActive Speaker
Price $749.99$199.99$369.99$299.99
AmplificationIndependent 4-channel power  amplification (60W x 2 + 20W x 2 per speaker)
Total Output Power: 160W RMS (80W per speaker)
20W x 2 (woofers)
 5W x 2 (tweeters)
30W x 2 (woofer)
10W x 2 (tweeter)
30W x 2 (woofer)
10W x 2 (tweeter)
Frequency ResponseNot Indicated65-20kHz65-20kHz65-20kHz
DriversWoofer: 5.25-inch Rohacell cone bass driver
Tweeter: 1-inch composite silk dome with rear cavity and internal magnet
Woofer: 3.5 inches
Tweeter: 3/4 inches
3.5-inch carbon fiber mid-woofer
1-inch silk dome tweeter
InputsAnalog: AUX, RCA, XLR
Digital: Type-C USB
Analog: RCA/PHONO IN, AUX IN,
Digital: USB IN, COAX IN, OPTICAL IN
Analog: RCA/AUX/Type-C/
Digital: COAX/OPT
Analog: RCA/AUX
Subwoofer OutputNoYesNoNo
Bluetooth Ver 5.1 with LDAC/aptX Adaptive/SBC /AACVer 5.4 with LDAC/AAC/SBCLDAC/aptX Adaptive/aptX HD/aptX LL/aptX/AAC/SBCNo
Bluetooth ChipQualcomm (model not specified)Qualcomm (model not specified)Qualcomm QCC5124No
Adjustability3-band bass EQ
3-band treble EQ
Dual-frequency bass extension control
10-band PEQ via FiiO Control App
31-Band PEQ via FiiO Control App
Adjustable bass gain
Adjustable LED lighting effect
Switchable left and right channels.
Power SupplyDual independent 120W power supplies (one per speaker)Not SpecifiedNot SpecifiedNot Specified
Volume ControlLow-noise high-precision encoder with stepless electronic volume adjustmentStandardStandardStandard
​ControlPhysical volume knob
RGB indicator ring
IR Remote control
FiiO Control App (iOS/Android)
RGB indicator ring
IR Remote control
RGB indicator ring
IR Remote control
RGB indicator ring
IR Remote control
Trigger InputYes (for synchronized power with compatible devices)NoNoNo
DimensionsNot ProvidedMain unit: About 135.5×155.6x185mm (including feet)
Secondary unit: About 129×141.6x185mm (including feet)
About 163x120x132mm (excluding base) About 170x120x132mm (including 0° flat base) About 182x120x132mm (including 7° angled base)About 163x120x132mm (excluding base) About 170x120x132mm (including 0° flat base) About 182x120x132mm (including 7° angled base)
WeightNot ProvidedMain unit: About 1750g
Secondary unit: About 1660g
Primary speaker weight 1950g
secondary speaker weight 1660g
Primary speaker weight 1840g        secondary speaker weight 1660g
Included AccessoriesTwo Furukawa oxygen-free copper power cables
Custom IR remote and batteries
Input cables RCA
Primary and Secondary speaker connection cable
Remote Control with Batteries
Power Adapter
AC Power Cable
RCA to 3.5mm audio cable
Quick Start Guide
Power Adapter
AC Power Cable
Instruction Manual
Rubber Base
Power Adapter
AC Power Cable
Instruction Manual
Rubber Base
fiio-sp5-front-pair
The Bottom Line
FiiO has been on a serious product tear in 2025, and the launch of the SP5 marks at least the seventh new release by mid-July. It’s the fourth entry in their active speaker lineup, joining the SP3, SP3BT, and SA1 — and based on its specs, the SP5 clearly takes the flagship position.
It builds on FiiO’s prior efforts with more refined drivers and higher-output amplification, aimed at desktop users and even small studio applications. But just like the earlier models, the SP5 skips HDMI ARC/eARC and—oddly—leaves out a dedicated phono input. That’s a bit of a head-scratcher considering the less expensive SA1 includes one.
In terms of market positioning, FiiO seems to be angling squarely at brands like Audioengine. While Audioengine has a wider catalog and longer history in this space, FiiO’s aggressive release schedule suggests they’re serious about catching up. Four speaker models in two years isn’t nothing — but they’ve still got some ground to cover.
And FiiO’s not just competing with Audioengine. Other strong players in the compact powered speaker market include ELAC, Kanto, and Monoprice — all offering solid performance at competitive price points. KEF’s offerings sit at the premium end of the spectrum, but they bring top-tier sound quality, extensive connectivity, and that signature design polish. FiiO may not be playing at KEF’s level just yet, but the SP5 shows they’re aiming higher with each release.
Price & Availability
The FiiO SP5 will be available in August 2025, for an expected price of $749 / £709.
2 Comments
2 Comments
  1. Anton
    July 13, 2025 at 5:10 pm
    $750 is not completely out of line when you consider what KEF charges and those Alpha iQ from PSB are over $1,000 USD.
    They need to make it in red and yellow. Like the connectivity options.
    • Ian White
      July 13, 2025 at 6:26 pm
      FiiO has done a rather good job with their speakers and I like the design. I agree that “black” is a very boring option. We plan on reviewing these.
      IW
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Can Onkyo's MUSE Y-50 with Class D power, HDMI ARC, phono, streaming, and CREATOR powered monitors reset its hi-fi direction?
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
At $369, the Edifier M90 are versatile wireless speakers that also include HDMI eARC for easy connectivity to PCs or TVs. Just make sure...
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Fosi Audio’s $229.99 BT20A MAX packs a TI TPA3255 amp, real 2.1 power, and unusually robust Bluetooth codec support—does it deliver where it counts?
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
