FiiO Jade Audio LEVEL 1 Desktop Amp Debuts at High End Vienna 2026 with 300 Watts for $139
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO came to High End Vienna 2026 with three new desktop hi-fi products, and the most traffic-friendly one is almost certainly the Jade Audio LEVEL 1 desktop amplifier. Why? Because FiiO is claiming up to 2 x 300 watts of output from a compact desktop amp priced at $139.
That is either one of the more interesting budget hi-fi announcements of the show, or someone at FiiO found the “make forum threads explode” button and pressed it with both thumbs. Probably a little of both. Hopefully it came with schnitzel.
The new lineup also includes the FiiO JT9 open-back planar magnetic headphones and a fully discrete Class A headphone amplifier, giving FiiO a broader desktop ecosystem aimed at listeners who want more than another dongle DAC dangling from a laptop.
FiiO LEVEL 1: A $139 Desktop Amp With Real Ambition
fiio-jade-audio-level-1-black-angle
The FiiO Jade Audio LEVEL 1 is a compact desktop stereo amplifier built around the Texas Instruments TPA3255 amplifier chip, which uses TI’s PurePath Ultra-HD technology. FiiO claims output up to 2 x 300 watts, but that number needs proper context: the headline rating is into 4 ohms at under 10% THD+N with a 53V/12A power supply.
That does not make the figure fake, but it does mean readers should not assume the LEVEL 1 will deliver 300 clean watts per channel into every speaker under normal conditions while also making espresso. FiiO’s own specifications also list 240W + 240W into 4 ohms and 135W + 135W into 8 ohms at under 1% THD+N, which are still very serious numbers for a compact amplifier at this price.
Can we also retire “giant killer” while we’re here? It gets tossed around far too often in hi-fi, usually before anyone has measured the thing, listened to it properly, or explained what giant was allegedly slain. And we’re not referring to some French kid playing basketball in Texas.
Connectivity Is the Real Story
fiio-jade-audio-level-1-back-connections
FiiO Jade Audio LEVEL 1 (back)
Connectivity is stronger than expected for the money. The LEVEL 1 includes RCA line input, USB DAC input, coaxial digital input, and Bluetooth 6.0 reception with SBC and LDAC codec support. FiiO has also included a single-ended line output, subwoofer output, speaker outputs, physical bass and treble controls, and support through the FiiO Control app.
The USB DAC input supports up to 96kHz/24-bit playback, while the coaxial input supports up to 192kHz/24-bit. That gives the LEVEL 1 enough flexibility for desktop systems, small-room loudspeaker setups, CD transports, streamers, computers, and Bluetooth playback from a phone or tablet.
That matters because this is not being pitched as a minimalist purist amplifier. This is a compact, flexible desktop or small-room amplifier for listeners who want wired digital input, analog input, wireless playback, tone controls, subwoofer output, and enough claimed power to make people start arguing on Head-Fi and Audio Science Review before mother makes their breakfast.
Retro Styling, Modern Inputs, Very FiiO Pricing
The LEVEL 1 uses an aluminum alloy chassis with wood side panels, giving it the retro desktop look FiiO clearly wants. FiiO says the amplifier uses a six-layer immersion gold thick copper PCB and capacitors sourced from Germany and Japan.
The unit measures about 181 x 133 x 36mm, excluding feet, and weighs about 676g. It is available in black with walnut side panels or silver with maple side panels.
At $139, the LEVEL 1 lands directly in the value-fi combat zone where Fosi Audio, SMSL, Topping, Loxjie, WiiM, and Dayton Audio have been making life uncomfortable for traditional entry-level integrated amplifiers.
The big question is not whether the LEVEL 1 is inexpensive. It is. The question is whether it sounds composed, stable, and clean enough at real-world listening levels to be more than another spec-sheet stunt that ends up in the hi-fi dustbin of history.
FiiO JT9: Open-Back Planar Headphones Join the Desktop Push
fiio-jt9-headphones
FiiO JT9
FiiO also used High End Vienna 2026 to preview the JT9, an open-back planar magnetic headphone built around a custom 95 x 86mm planar driver and ultra-thin diaphragm. FiiO says the JT9 uses its dual-coating driver technology and a uniform magnetic field design, with the goal of improving transient response and tonal accuracy.
The JT9 is also designed to be more portable than its large planar driver might suggest. Current show information lists the headphones at a claimed 365 grams, with a foldable design for easier storage. Sensitivity is listed at 95dB/mW, and FiiO is including both 3.5mm single-ended and 4.4mm balanced cables.
Pricing has not been confirmed yet, and that matters. The JT9 enters a very crowded planar headphone category where FiiO already competes with models like the FT1 Pro and JT7, while brands such as HiFiMAN, Audeze, Moondrop, Sendy Audio, and others have made life rather interesting at multiple price points. If FiiO prices the JT9 aggressively, it could become one of the more interesting open-back planar headphones to watch. If not, it becomes another planar headphone looking for room at the Waffle House counter and we know how that usually ends up at 3 in the morning.
FiiO CLASS A Headphone Amplifier Rounds Out the Desktop System
fiio-class-a-front
FiiO CLASS A
The third product in FiiO’s High End Vienna 2026 desktop lineup is the FiiO CLASS A, which appears to be the actual product name. Subtle? Not exactly. Accurate? Apparently.
Current show information describes the CLASS A as a fully discrete pure Class A headphone amplifier rated at 1000mW + 1000mW. FiiO is also listing a 60W toroidal transformer, discrete regulated power supply, five selectable gain settings, bass and treble controls, and 12V trigger input/output.
Connectivity includes 3.5mm, 4.4mm balanced, and XLR headphone outputs, along with RCA input and RCA output connections.
The CLASS A also does not appear to include a built-in DAC, which fits the concept. This is being positioned as a standalone headphone amplifier for listeners who already have a DAC or desktop source and want FiiO’s take on pure Class A amplification, complete with the usual trade-offs: more heat, lower efficiency, and hopefully the smoother, richer presentation people expect from this type of circuit.
That suggests FiiO is not just throwing one inexpensive desktop amp at the wall. The company is building out a broader desktop ecosystem aimed at both loudspeaker and headphone listeners. Between the Jade Audio LEVEL 1, JT9 planar headphones, and CLASS A headphone amplifier, FiiO clearly wants more desk space. Given the pricing history, it may get it.
The Bottom Line
fiio-jade-audio-level-1-angle-silver
The FiiO Jade Audio LEVEL 1 is the key product here: a $139 desktop amplifier with TPA3255 amplification, USB DAC, coaxial, RCA, Bluetooth 6.0 with LDAC, tone controls, pre-out, subwoofer output, and high claimed power output that needs independent testing. Alongside the JT9 planar headphones and FiiO CLASS A headphone amplifier, it shows FiiO expanding its desktop hi-fi lineup beyond portable DACs and headphone amps.
Readers should care because the LEVEL 1 offers an unusual mix of power, inputs, outputs, and price. If it performs well in real systems, it could be a useful option for desktop setups, small rooms, powered subwoofer integration, and affordable two-channel systems.
Where to buy:
Edifier Hecate G5 MAX Wireless Gaming Headset
Can Edifier’s $149 HECATE G5 MAX challenge Sony Pulse Elite with THX Spatial Audio+, low-latency wireless, and 305-hour battery life?
Ferrum Broen Streaming Transport under WANDLA DAC Ferrum Broen Streaming Transport under WANDLA DAC
Can Ferrum BROEN turn Volumio, SFP networking, and WANDLA integration into a serious high-end streaming transport for external DACs?
Noble Audio Iris IEMs back with tips Noble Audio Iris IEMs back with tips
Noble Audio's $699 Iris IEM combines a custom 10.2mm dynamic driver, three-layer diaphragm, Micarta housing, and modular cable connectivity.
2026 Noble Vanguard IEMs 2026 Noble Vanguard IEMs
Is the Noble Audio Vanguard the strongest sub-$350 hybrid IEM for listeners who want premium shells, 1DD + 2BA drivers, balanced connectivity, and USB-C...
Luxsin X8 and X9 Desktop DAC headphones amplifiers Luxsin X8 and X9 Desktop DAC headphones amplifiers
Luxsin X8 and X9 desktop DAC and headphone amps arrive in North America with HP-EQ, touchscreens, serious output power, and AI-assisted EQ on the...
2026 Vertere Phono-1 LX Colors Front 2026 Vertere Phono-1 LX Colors Front
Vertere’s $2,399 Phono-1 LX phono preamp adds quieter power, flexible MM/MC loading, revised grounding, and serious competition for MoFi and Cyrus.
Daily Deals
FiiO EH13 wireless headphones deliver ANC, LDAC, Bluetooth 6.0, wired listening, and up to 75 hours of battery life for under $50.
We give Dynaudio's new Opus One all-in-1 soundbar solution a look (and a listen) at its debut at High End 2026.
Trinnov, dCS, and Perlisten delivered a massive 15.8.8 immersive audio demo at HIGH END Vienna 2026, showcasing the music of Justin Gray, who was...
The 11 High End Vienna 2026 products we most want to review, from Ruark and Cambridge to Meze, Eversolo, Questyle, and Klipsch.
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
Clearaudio N2 MM cartridge uses a carbon fibre PETG body, 8.5g weight and $290 price to challenge Audio-Technica, Grado, Ortofon and Sumiko.
Walking the floor at the world’s largest high end audio show, HIGH END, in Vienna last week, it was easy to get jaded. Hey,...
