FiiO FG3 Gaming Headset Launches With Dual Driver Audio Virtual 7.1 Surround and Cross Platform Support
Can FiiO’s $69 FG3 gaming headset deliver Hi-Fi dual-driver sound, virtual 7.1 surround, and browser EQ for budget gamers?
FiiO FG3 Gaming Headset Lifestyle
The gaming headset category has become as bloody as your favorite FPS, with every brand now promising cinematic immersion, pinpoint positional audio, marathon battery life, and the kind of microphone clarity that allegedly turns chaos into strategy. FiiO has decided to enter that firefight with the new $69.99 FG3, an over-ear gaming headset that brings the company’s Hi-Fi audio background into the entry-level gaming space.
The timing is interesting. FiiO’s FG3 lands in the same week that Edifier introduced its own Hecate G5 MAX wireless gaming headset, giving gamers another reason to rethink what $150 and under can buy in 2026. The FG3 takes a different approach, built around a coaxial dual dynamic driver design with integrated DSP processing, virtual 7.1 surround sound, browser-based audio customization, and cross-platform support for PCs and consoles. Wireless gameplay is not part of the package here at the asking price.
FiiO is clearly betting that gamers are ready for headsets that sound less like plastic explosions in a shoebox and more like properly engineered audio products. The FG3 is designed to deliver accurate positional cues, cleaner voice communication, and a more customizable listening experience without forcing buyers into premium pricing territory.
Hi-Fi Engineering Meets Gaming
fiio-fg3-gaming-headset-with-boom-mic
FiiO FG3
The FG3 is FiiO’s first dedicated gaming headset, and the company has not entered the category with a conventional single-driver design. Instead, the FG3 uses a coaxial dual dynamic driver arrangement that combines a 50 mm dynamic driver with a smaller 16 mm dynamic driver.
The goal is to have both drivers radiate from a more unified acoustic point, which can help preserve phase consistency and improve directionality. For gaming, that matters because positional cues are not just marketing language; hearing where footsteps, reloads, voices, and environmental effects are coming from can change how quickly players react.
FiiO uses an electronic two-way crossover to divide the workload between the two drivers. The 50 mm driver handles low and midrange frequencies, while the 16 mm driver is assigned to the higher frequencies. FiiO claims a frequency response of 10 Hz to 40 kHz, which places the FG3 well beyond the range of human hearing on paper, but the more relevant question is whether that driver arrangement delivers better clarity, separation, and spatial information in actual gameplay.
Dedicated DSP Processing
The FG3 also includes a dual-core DSP chip designed to manage gaming audio with low latency and fast signal processing. That matters because gaming headsets have to do more than play music loudly. They need to keep dialogue intelligible, effects clean, and positional information stable when the screen gets busy.
FiiO has also integrated a DAC that supports audio up to 192 kHz/24-bit, along with a built-in headphone amplifier rated at up to 80 mW of output power. Those specifications are unusual for an entry-level gaming headset and reflect FiiO’s attempt to bring more of its Hi-Fi hardware approach into a category that has not always prioritized sound quality.
The combination of DSP, DAC, amplifier, and dual-driver architecture is clearly intended to help the FG3 handle both competitive gaming and general media playback. Subtle environmental sounds, teammate voices, explosions, and soundtrack cues all place different demands on a headset. FiiO’s argument is that the FG3 can handle those demands with greater precision than most budget gaming headsets.
Virtual Surround Sound
The FG3 includes FiiO’s specially tuned virtual 7.1 surround sound processing, with two available modes: Cinema and Action. The goal is to create a more spacious 360-degree presentation that helps with directional awareness in games while adding more scale to films and other media.
Virtual surround sound is always implementation-dependent, and not every gamer wants extra processing layered over the original mix. But for players who want a larger soundfield and clearer directional cues without moving to a full speaker system, the FG3 gives them that option directly from the headset.
fiio-fg3-gaming-headset-side
Clear Communication
FiiO has also fitted the FG3 with a detachable microphone that uses an Environmental Noise Cancellation algorithm to reduce background noise. That includes common desk-level distractions such as keyboard and mouse sounds, which can make online team communication harder than it needs to be.
The FG3 also supports hardware-based sidetone monitoring, allowing users to hear their own voice with low latency while speaking. Sidetone can be enabled or disabled through the web-based FiiO Control interface, and users can also adjust the monitoring level. That is a practical feature for longer gaming sessions, especially for anyone who dislikes the sealed-off feeling of closed-back headsets.
Browser-Based EQ
One of the more useful FG3 features is that it does not require dedicated desktop software for setup. Configuration is handled through FiiO Control WEB, a browser-based platform that allows users to create and save custom 10-band EQ settings directly to the headset.
That matters because gaming headset software is often where good intentions go to die. FiiO’s approach should make it easier to adjust the FG3 across different devices, create separate listening profiles, and avoid installing another bloated control app just to change EQ.
fiio-fg3-gaming-headset-controller-usb
Designed for Every Platform
The FG3 is designed as a driver-free, plug-and-play gaming headset with support for Windows 7, 8, 10, and 11, along with smartphones and laptops. FiiO also lists adaptive UAC 1.0 and UAC 2.0 compatibility for PlayStation 4, PlayStation 5, Xbox Series consoles, and Nintendo Switch 2.
The headset uses a foldable design for easier transport, with breathable woven mesh ear pads, memory foam cushions, a closed-back acoustic structure, and a stainless steel headband. Inline controls provide quick access to volume, microphone mute, and audio mode selection without forcing players to leave the game or dig through menus.
Key Specifications Compared
Edifier G5 MAXFiiO FG3
Product Type Wireless Gaming HeadsetWired Over-ear Gaming Headset
Price $149.99$69.99
Driver53 mm PEN Diaphragm Dynamic Driver50 mm dynamic driver + 16 mm dynamic driver
Frequency Response20Hz – 40kHz10Hz – 40kHz
Impedance64 ohms32 ohms
Sensitivity97 dB100 dB
Signal-to-Noise Ratio (SNR)88 dBNot indicated
THDLess than 1%Not Indicated
Audio Sampling Rate Support192 kHz / 24-bit (48 kHz in 2.4 GHz mode)Up to 192 kHz / 24-bit
BluetoothVersion 6.0–
Audio ProcessingTHX 7.1.4 Spatial AudioVirtual 7.1 surround sound
MicrophoneDual Built-In Mics + Detachable Boom MicDetachable microphone with ENC noise reduction
ControlEDIFIER ConneX App FiiO Control WEB browser-based interface
Weight305g (10.8 oz)315g (11.1 oz)
fiio-fg3-package
FiiO FG3 headset, Inline control cable, USB-A to USB-C female adapter, Detachable microphone, and Quick start guide
The Bottom Line
The FiiO FG3 is not just another inexpensive gaming headset with RGB lights and a microphone attached as an afterthought. Its most unusual feature is the coaxial dual dynamic driver layout, which combines a 50 mm driver for bass and midrange with a 16 mm titanium-plated driver for higher frequencies. Add in dual-core DSP, 192 kHz/24-bit USB audio support, a built-in amplifier, browser-based 10-band EQ, virtual 7.1 surround, hardware sidetone, and a detachable ENC microphone, and FiiO is clearly trying to bring more of its Hi-Fi DNA into the entry-level gaming category.
At $69.99, the FG3 is aggressively priced. That is the story. FiiO is offering a wired gaming headset with more audio engineering behind it than most models at this level, especially for players who care about positional cues, dialogue clarity, EQ control, and a cleaner microphone setup.
What is missing? Wireless connectivity. There is no Bluetooth, no 2.4 GHz dongle, no battery life claim, and no active noise cancellation for listening. Compared to some newer rivals, including Edifier’s Hecate G5 MAX, the FG3 is less about all-day wireless convenience and more about wired stability, USB audio quality, and price-to-performance value. It also does not appear to offer the higher-end planar magnetic approach found in more expensive gaming headsets from brands like Audeze.
The FG3 is for gamers who want better sound without spending $150 to $300, PC and console users who do not mind a wired connection, and listeners who want EQ control without installing another bloated desktop app. It is not for players who want wireless freedom, ANC, or premium materials at any cost. FiiO has entered a very crowded category, but at this price, the FG3 gives budget gaming headsets something new to worry about.
Where to Buy:
2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica’s $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
FiiO's $380 CLASS A headphone amp can switch to Class AB with low-impedance headphones. Here's what FiiO says and why the distinction matters.
Over-Ear Headphones
The $160 FiiO JadeAudio JT9 planar headphones deliver deep bass and spacious sound, but can their bright treble spoil an otherwise excellent value?
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
FiiO’s $499 FT15 gets a bigger planar driver, thinner diaphragm and lighter chassis, and we already have first impressions from CanJam London.
Gaming Headsets
Sony’s new PlayStation Pulse and Pulse Edge headsets add larger planar magnetic drivers, PlayStation Link, Bluetooth and ANC.
Can SMSL’s new R100 and D400 MK2 compete with FiiO, Schiit and Topping in the increasingly crowded DAC market below $1,000?
