DALI’s New SONIK Series Brings Serious Hi-Fi Ambitions to Seven Affordable Speakers
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home cinema.
DALI SONIK Loudspeaker Series in walnut
Danish Audiophile Loudspeaker Industries (DALI) is taking another calculated swing at the affordable end of the hi-fi market with SONIK, a new loudspeaker series aimed squarely at listeners who want real performance without the usual audiophile toll booth. Positioned as DALI’s most significant step forward since the OBERON series arrived in 2018, SONIK is designed to reset expectations for both music and home cinema fans—again. That’s not chest-thumping marketing bravado; OBERON legitimately became a global benchmark in its class, and DALI clearly believes lightning can strike twice with its successor.
SONIK also lands at a moment when DALI has been quietly reminding the industry how to do accessible hi-fi properly. The recently released DALI KUPID, which just earned one of our Editors’ Choice Awards for Best Bookshelf Speakers, proved that “entry-level” doesn’t have to mean compromised, dull, or designed by the accounting department. If KUPID was the polite but pointed warning shot, SONIK looks like the full Danish follow-through—clean design, sensible engineering, and a refreshing refusal to overcomplicate things just to sound expensive.
dali-sonik-7-lifestyle
DALI SONIK 7 loudspeakers in walnut
DALI makes loudspeakers for everyone, from KUPID to KORE and everything in-between, covering hi-fi, home cinema, wireless speakers and headphones. Our sound and design principles have always been most visible to music fans at the price point that SONIK hits and we believe the range sets a new benchmark in performance for the price. We’re excited to launch SONIK worldwide and look forward to attracting even more DALI fans in 2026” says Krestian Pedersen, DALI Head of Product Management.
THE SONIK EVOLUTION
DALI SONIK arrives as the company’s most ambitious and carefully structured loudspeaker lineup to date, spanning seven models designed to cover everything from compact two-channel systems to fully realized home cinema setups. The brief is refreshingly pragmatic: satisfy the seasoned audiophile who actually listens, while remaining approachable enough for design-conscious newcomers who want serious sound without a crash course in speaker lore. That balancing act has always been a DALI specialty, and SONIK leans hard into it.
What separates SONIK from the usual “trickle-down tech” rhetoric is how directly it pulls from DALI’s own top tier. Engineering cues from KORE, EPIKORE, and EPICON including refined transducer geometry, advanced magnet systems, and more rigid, better-controlled cabinet construction—have been methodically distilled into a range that’s easier to place, easier to drive, and easier to live with. Just as important, SONIK reflects one of DALI’s enduring advantages in this market: vertical integration.
DALI designs and builds almost everything in-house—drivers, cabinets, finishes, and even the proprietary hardware that holds it all together. In a category increasingly dependent on outsourced parts and shared components, that level of control isn’t just a point of pride; it’s how DALI keeps performance, consistency, and cost exactly where they need it to be.
SONIK Technology Stack: Trickle-Down Engineering Without the Trickle-Down Compromises
Ultra-Light 29mm Soft Dome Tweeter: At the core of the SONIK high-frequency design is a newly developed 29mm soft dome tweeter, engineered for low mass and low mechanical loss. Its wide dispersion characteristics support a smooth and coherent transition through the upper midrange, while a new aluminium faceplate improves bandwidth, stability, and thermal performance—contributing to cleaner highs without added edge or glare.
dali-sonik-7-tweeter-closeup
DALI Hybrid Tweeter System is only on the SONIK 7 and SONIK 9
DALI Hybrid Tweeter System (SONIK 7 and SONIK 9): Select models feature DALI’s well-established Hybrid Tweeter System, combining the 29mm dome with a 17 × 45mm planar magnetostatic tweeter. This dual-driver configuration pairs the dynamic impact of a dome with the air and extension of a planar element, resulting in broader dispersion and greater high-frequency resolution—particularly beneficial in larger rooms and multi-seat listening environments.
Low-Loss Bass & Midrange Drivers: SONIK employs 5¼-inch and 7-inch bass/midrange drivers built around DALI’s Clarity Cone™ technology. Constructed from a proprietary blend of paper and wood fibre, the cone structure balances stiffness and damping to reduce coloration while preserving natural midrange texture and transient speed. The result is controlled bass response and a midband that remains articulate and unforced.
SMC Essential Magnet System: Derived from the EPICON platform, SMC Essential plays a key role in SONIK’s low-distortion performance. By incorporating a hybrid iron/SMC pole-piece design, this patented magnet system significantly reduces third-order harmonic distortion, particularly in the midrange. The benefit is greater clarity and composure at higher playback levels—performance traits more commonly associated with far costlier loudspeakers.
Dual-Flare Bass Reflex Port Design: SONIK’s Dual Flare bass reflex ports are engineered to minimise turbulence while maintaining accurate timing and clean low-frequency extension. Models designed for wall-mounting or home cinema use incorporate front-firing or placement-specific port geometries, ensuring consistent performance even in space-constrained installations.
Modern Scandinavian Design
dali-sonik-1-speaker-walnut-grille-on
DALI SONIK 1 with grilles
Each SONIK model features custom-designed magnetic grilles for a clean, uninterrupted front profile, paired with sleek aluminium tweeter faceplates that reinforce both rigidity and visual precision. DALI has also introduced new in-house–developed speaker terminals, designed for long-term durability and flexible connectivity without resorting to oversized or decorative hardware.
Updated logo badges and baffle treatments take direct inspiration from DALI’s flagship EPIKORE series, subtly elevating the visual language while maintaining SONIK’s accessible positioning. Floorstanding models benefit from aluminium spike outriggers, which provide improved mechanical stability while adding a grounded, purposeful aesthetic.
Behind the clean lines, SONIK cabinets are built from CNC-machined MDF with rigid internal bracing to control resonance. High-grade vinyl finishes ensure consistency and durability, while separate internal chambers for bass drivers improve timing accuracy and reduce unwanted interaction between drivers—design choices driven by acoustics rather than appearance.
SONIK is offered in four restrained, room-friendly finishes: Black Ash, Walnut, Natural Oak, and White. In classic Scandinavian fashion, the palette is designed to complement modern interiors rather than compete with them—quietly confident, functional, and very much on brand for DALI.
Standmount Models:
DALI SONIK 1 — Key Specifications
dali-sonik-1-oak
DALI SONIK 1 (natural oak)
  • Type: 2-way bass reflex standmount / shelf speaker
  • Frequency Response: 51 Hz – 26 kHz (±3 dB)
  • Sensitivity: 86 dB (2.83 V / 1 m)
  • Impedance: 6 ohms
  • Max SPL: 106 dB
  • Crossover: 2-way, 2,800 Hz
  • Recommended Power: 25 – 100 W
  • Placement: 1 – 50 cm from rear wall on stand or shelf
  • Included: 2× grilles, rubber feet & pads, documentation
Drivers
  • Tweeter: 29 mm low-loss soft dome (soft woven fabric)
  • Woofer: 5¼-inch Clarity Cone™ (paper & wood fibre)
Cabinet / Connectivity
  • Bass reflex enclosure (51 Hz tuning)
  • Single-wire terminals
  • Integrated wall bracket
Size & Weight
  • Dimensions (H × W × D): 274 × 162 × 231 mm (10.8 × 6.4 × 9.1 in)
  • Weight: 4.1 kg / 9.03 lb (each)
  • Shipping: 10 kg / 22.04 lb (pair)
DALI SONIK 3 — Key Specifications
dali-sonik-3-walnut
DALI SONIK 3 (walnut)
  • Frequency Response: 47 Hz – 26 kHz (±3 dB)
  • Sensitivity: 87 dB (2.83 V / 1 m)
  • Impedance: 6 ohms
  • Max SPL: 108 dB
  • Crossover: 2-way, 2,300 Hz
  • Recommended Power: 25 – 150 W
  • Placement: 5 – 50 cm from rear wall on stand or shelf
  • Included: 2× front grilles, rubber pads, documentation
Drivers
  • Woofer: 7-inch Clarity Cone™ (paper & wood fibre)
  • Bass reflex enclosure (46 Hz tuning)
Size & Weight
  • Dimensions (H × W × D): 350 × 200 × 306 mm (13.7 × 7.8 × 12.1 in)
  • Weight: 6.5 kg / 14.13 lb (each)
  • Shipping: 15.1 kg / 33.28 lb (pair)
Floorstanding Models:
DALI SONIK 5 — Key Specifications
dali-sonik-5-oak
DALI SONIK 5 (natural oak)
  • Type: 2-way bass reflex floorstanding speaker
  • Frequency Response: 39 Hz – 26 kHz (±3 dB)
  • Sensitivity: 88 dB (2.83 V / 1 m)
  • Impedance: 6 ohms
  • Max SPL: 108 dB
  • Crossover: 2-way, 2,200 Hz
  • Recommended Power: 30 – 150 W
  • Placement: 15 – 100 cm from rear wall
  • Included: Toolkit, documentation, 2× front grilles, spikes, lock nuts, hemispherical rubber feet, spike outriggers & mounting hardware
Drivers
  • Woofers: 2 × 5¼-inch Clarity Cone™ (paper & wood fibre)
  • Bass reflex enclosure (43 Hz tuning)
Size & Weight
  • Dimensions (H × W × D): 826 × 249 × 270 mm (32.5 × 9.8 × 10.6 in)
  • Weight: 10.8 kg / 23.80 lb (each)
  • Shipping: 26.6 kg / 58.64 lb (pair)
DALI SONIK 7 — Key Specifications
dali-sonik-7-white
DALI SONIK 7 (white)
  • Type: 2½-way bass reflex floorstanding speaker
  • Frequency Response: 36 Hz – 30 kHz (±3 dB)
  • Sensitivity: 88.5 dB (2.83 V / 1 m)
  • Impedance: 6 ohms
  • Max SPL: 110 dB
  • Crossover: 2½-way, 2,300 Hz / 14,000 Hz
  • Recommended Power: 30 – 180 W
  • Placement: 20 – 100 cm from rear wall
  • Included: Toolkit, documentation, front grille, spikes, lock nuts, hemispherical rubber feet, spike outriggers & mounting hardware
Drivers
  • Tweeter System: DALI Hybrid Tweeter
    • 17 × 45 mm planar magnetostatic
    • 29 mm low-loss soft dome (soft woven fabric)
  • Woofers: 2 × 7-inch Clarity Cone™ (paper & wood fibre)
  • Bass reflex enclosure (39 Hz tuning)
Size & Weight
  • Dimensions (H × W × D): 1,006 × 304 × 330 mm (39.6 × 12.0 × 13.0 in)
  • Weight: 16.2 kg / 35.71 lb (each)
  • Shipping: 19.7 kg / 43.43 lb (each)
DALI SONIK 9 — Key Specifications
dali-sonik-9-black-cutaway
DALI SONIK 9 (black)
  • Type: 2½ + ½-way bass reflex floorstanding speaker
  • Frequency Response: 34 Hz – 30 kHz (±3 dB)
  • Sensitivity: 90 dB (2.83 V / 1 m)
  • Impedance: 4 ohms
  • Max SPL: 111 dB
  • Crossover: 400 Hz / 2,100 Hz / 14,000 Hz
  • Recommended Power: 50 – 300 W
  • Placement: 20 – 120 cm from rear wall
  • Included: Front grille, spikes, lock nuts, hemispherical rubber feet, spike outriggers & mounting hardware, toolkit, documentation
Drivers
  • Woofers: 3 × 7-inch Clarity Cone™ (paper & wood fibre)
  • Bass reflex enclosure (35 Hz tuning)
Size & Weight
  • Dimensions (H × W × D): 1,126 × 318 × 376 mm (44.3 × 12.5 × 14.8 in)
  • Weight: 24.6 kg / 54.23 lb (each)
  • Shipping: 30.1 kg / 66.35 lb (each)
On-Wall & Home Cinema Models:
DALI SONIK ON-WALL — Key Specifications
dali-sonik-on-wall-oak
DALI SONIK ON-WALL (natural oak)
  • Type: 2-way bass reflex on-wall speaker (LCRS capable)
  • Frequency Response: 55 Hz – 26 kHz (±3 dB)
  • Impedance: 6 ohms
  • Max SPL: 107 dB
  • Crossover: 2-way, 2,400 Hz
  • Placement: 0 – 10 cm from wall or wall-mounted (LCRS use)
Drivers
  • Bass reflex enclosure (50 Hz tuning)
Size & Weight
  • Dimensions (H × W × D): 385 × 245 × 123 mm (15.2 × 9.7 × 4.8 in)
  • Weight: 4.9 kg / 10.80 lb (each)
  • Shipping: 10.9 kg / 24.03 lb (pair)
DALI SONIK CINEMA — Key Specifications
dali-sonik-cinema-oak
DALI SONIK CINEMA (natural oak)
  • Type: 2-way bass reflex LCR speaker (stand/shelf)
  • Frequency Response: 46 Hz – 26 kHz (±3 dB)
  • Sensitivity: 89.5 dB (2.83 V / 1 m)
  • Impedance: 6 ohms
  • Max SPL: 109 dB
  • Placement: 0 – 50 cm from rear wall on stand or shelf (LCRS use)
  • Included: Front grille, rubber pads, documentation
Drivers
Size & Weight
  • Dimensions (H × W × D): 170 × 571 × 214 mm (6.7 × 22.5 × 18.4 in)
  • Weight: 7.9 kg / 17.41 lb (each)
  • Shipping: 9.6 kg / 21.16 lb (each)
dali-sonik-loudspeakers-series-natural-oak-2025
DALI SONIK Loudspeaker Series (natural oak)
The Bottom Line
With SONIK, DALI isn’t reinventing loudspeakers so much as reasserting what accessible hi-fi is supposed to sound like. This seven-model lineup covers real-world needs—from compact stereo systems to full home-cinema builds—while staying true to DALI’s core strengths: low distortion, wide dispersion, tonal neutrality, and easy room integration. The meaningful trickle-down of technologies from KORE, EPIKORE, and EPICON, combined with DALI’s rare end-to-end in-house manufacturing, gives SONIK a level of consistency and engineering integrity that most competitors at these prices simply can’t match.
Just as OBERON reset expectations in 2018, SONIK is positioned to do the same in 2026—this time with broader system flexibility, cleaner design, and more refined performance across the board. Add sensible pricing, placement-friendly designs, and a lineup that scales cleanly with room size and budget, and SONIK makes a very Danish argument: good sound doesn’t need drama, exclusivity, or a second mortgage—just smart engineering and restraint.
dali-sonik-5-cinema-home-theater-lifestyle-black
DALI SONIK 5 and SONIK CINEMA
Pricing & Availability
The DALI SONIK series will launch globally on February 2, 2026. Pricing is listed per pair across all territories, with the exception of SONIK CINEMA, which is sold as a single speaker.
  • SONIK 1 – $900 (€498 | £449 AUS$849)
  • SONIK 3 – $1,200 (€698 | £599 | AUS$1,199)
  • SONIK 5 – $1,800 (€998 | £899 | AUS$1,749)
  • SONIK 7 – $2,800 (€1,498 | £1,299 | AUS$2,549)
  • SONIK 9 – $4,500 (€2,398 | £2,199 | AUS$4,099)
  • SONIK ON-WALL – $1,200 (€650 | £599 | AUS$1,149)
  • SONIK CINEMA (single speaker) – $900 (€499 | £449 | AUS$859)
All models are available in Black Ash, White, Walnut, or Natural Oak finishes.
1 Comment
1 Comment
  1. Acenk
    December 21, 2025 at 7:13 am
    Dali’s habit when releasing new speakers for the bookshelf variant is not to provide a planar tweeter 😌
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Questyle’s QMS system pairs the iXStreamer with E5/E4 wireless speakers, SEAS drivers, Wi-Fi 6, LDAC, aptX, HDMI ARC/eARC, and lossless streaming.
The new generation Summit Everest and K2 join the previously released Makalu, Pumori, and Ama in an ultimate high-end JBL speaker line-up.
JBL's Summit Series audiophile loudspeakers, the Makalu, Pumori, and Ama, honor 80 years of acoustic precision and emotional power.
Acoustic Energy AE Active debuts at High End Vienna 2026 with analog Class A/B amplification, RCA/XLR inputs, and no wireless clutter.
Neat Vito Classic packs an AMT tweeter, dual bass drivers, claimed 22Hz bass, and slim British manners.
Does your giant TV or projector screen make your soundbar look puny? Sony is here for you with their new powered speaker system which...
Tannoy is celebrating its 100th Anniversary with the production of 45 pairs of special edition floorstanding loudspeakers.
