In late 2024, Technics unveiled their EAH-AZ100 in-ear TWS earphones and they were an overnight sensation. Using a newly developed magnetic fluid driver to maintain linearity and eliminate distortion, the AZ100 offered (and still offers) an excellent combination of accurate, musical sound and effective noise cancellation at a competitive price. But not everyone likes to jam a pair of buds into their ear canals, no matter how great the sound.
Many music lovers prefer the feel and sound of over-ear headphones. So Technics applied everything they learned in the development of the EAH-AZ100 to create a new flagship pair of over-ear headphones, the EAH-A1000. Can they pull off another coup and disrupt the over-ear market as they did with in-ears? Stay tuned to find out.
What Are They?
The Technics EAH-A1000 are a pair of over-ear, noise cancelling wireless headphones intended to provide audiophile quality sound in a convenient, portable form factor. They sell for $449 (MSRP) which puts them squarely up against the established leaders in the premium ANC wireless headphones field, including the Bose Quiet Comfort Ultra and Sony WH-1000XM6. The earcups can be folded for portability and they come with a slim zippered case for transportation. They feature an elegant aluminum and faux leather design, with sleek curves and tasteful metallic accents.
The AZ1000 comes in two colors: basic black and “Platinum Greige.” You heard me: GREIGE. It’s somewhere between gray and beige, but it could also be called “off white.” Thinking that this was just a marketing team going off the deep end trying to differentiate themselves, I looked up the word. It’s French and has actually been in use since the 19th century, originally to describe unfinished raw textiles. The word morphed in the early twentieth century into its current use as a color that blends gray and beige. Today, the word “greige” is mostly used in interior design for paint and fabric colors, but we wouldn’t be surprised if more headphone makers adopt the term in today’s fashion-conscious marketplace where the look is (almost) as important as the sound.
The AZ1000 battery life is the best we’ve seen in the premium wireless headphone segment, but play time varies, depending on which codec you use. With the audiophile-quality LDAC codec (Android), you’ll get up to 40 hours of use out of a full charge, with noise cancellation enabled, and up to 80 hours with noise cancellation turned off. Using Apple’s AAC codec, you can squeeze up to 45 hours of play time out a single charge, with noise cancellation on, and up to a whopping 90 hours of use with noise cancellation off. If you use a hard-wired connection via the USB cable (with no source of power), you’ll still get a respectable 30 hours of use with ANC enabled and 60 hours with ANC off. While a full charge takes up to 3.5 hours, a 15-minute quick charge will get you around 4 hours of use with noise cancellation engaged (AAC).
The EAH-A1000 features a brand new 40mm carbon fiber driver design which uses a new formulation of the company’s magnetic fluid to ensure high linearity of excursion with low distortion. The driver features an “SST” (Symmetrical Surround Technology) Edge surround, inspired by the company’s audiophile loudspeakers. Carbon fiber was selected for the cone material due to its high rigidity and low mass.
The magnetic fluid ensures that the driver radiates precisely without the “wobble” or “tumbling” that can occur with traditional drivers, which can lead to audible distortion. The company first developed this fluid for its audiophile wired TZ700 IEMs and used it again in the drivers in the AZ100 wireless earbuds. Technics developed a new formulation optimized for the larger driver in the A1000.
While there is no 3.5mm (1/8 inch) analog jack, the company does provide a 3.5mm to USB-C cable, allowing you to plug into a plane’s in-flight entertainment system or any other analog headphone jack. Be advised that this type of usage will result in the analog signal being internally converted to digital, and then back to analog for output to the internal amplifiers and drivers. In actual practice, this process did not seem to introduce any significant audible artifacts.
That USB-C input also allows direct playback of lossless or high resolution audio from a compatible iPhone, iPad, Android phone, PC or tablet. A USB-C to USB-C cable is provided for charging or direct USB audio playback.
For wireless connectivity, the A1000 supports Bluetooth 6.0, including Bluetooth LE (Low Energy) with Auracast. This allows multiple sets of headphones (or speakers) to receive the same audio signal from a compatible phone, tablet or PC with Auracast broadcast capability. However, if you choose to enable LE, then you won’t be able to use use the spatial audio or voice assistant features. You can adjust these preferences in the app (more on that later).
With Auracast, we were able to use the A1000s for a “silent disco” at a pre-release press event in Tokyo. The DJ was spinning tunes and broadcasting them out to the crowd via Auracast and those of us in the audience were rocking out together. Switching over to “Ambient mode” you could still hear the music clearly but also maintain a conversation with others on the dance floor. But taking off the headphones, you could hear a pin drop. Kind of an eerie experience and a really cool way to enjoy music or movies together in a small or large group without annoying the neighbors.
Adapts To Your Environment
The noise cancellation included on the A1000 is Technics’ latest version of their Adaptive Noise Cancellation (ANC). This allows effective cancellation, not just of steady state noise like a plane engine or HVAC, but also dynamic noises like traffic and human voices. Ambient Mode is also available in case you want to maintain some situational awareness while still enjoying your music. Call quality is maintained via the use of AI-enhanced beam forming microphones. In our testing, this tech worked really well to clear up voices in noisy environments. I took and placed several calls and, network connectivity issues aside (“CAN YOU HEAR ME NOW?!”), call quality was quite good.
Technics says that the A1000 is “optimized for Dolby Atmos” and does offer optional head-tracking, which is useful for VR and gaming. The A1000 can be connected to up to three devices concurrently and switches automatically among them as each device becomes active. You can also set priorities in the Technics Audio Connect app, to always give priority to your laptop during a Zoom call (for example), so your virtual meeting isn’t disrupted by an incoming call on your cell phone.
There’s an App for That
As with most headphone makers, Technics offers a dedicated app called “Technics Audio Connect” for Android and iOS (appearing as simply “Audio Connect” in your app list). Here is where you can access the 8-band EQ, adjust the level of noise cancellation, enable Dolby Atmos (with or without head tracking), and set device priority if necessary. The app isn’t essential, of course – you can simply pair the A1000s like any other Bluetooth wireless headphone – but the app does enable more advanced features like spatial audio and allows you to customize the sound and operation of the headphones for your personal tastes.
Ergonomically Speaking
While many wireless headphones require some time to get familiar with the operation of the controls on the unit itself, Technics keeps things simple with just two buttons – one for power/pairing and one for ANC to toggle among ANC on, Ambient mode, or ANC off. Between these buttons is a multi-purpose slider that acts as a volume control or track navigation. I’m used to controls being on the left earcup on other brands, but these are on the right earcup. It was easy to get used to the controls and I really like the feel and operation of the slider as opposed to the swipe controls of other wireless headphones.
The ear pads and headband use high-density memory foam designed to “balance durability and comfort during extended listening.” I found the clamping force to be just enough to provide a tight seal and stay firmly on my head, without feeling tight or uncomfortable. I did notice that if I leaned all the way back in my chair with my head titled back precipitously, the headphones could slide off my head. Solution? Don’t lean back so damn far without some sort of head support.
I wore the A1000s for nearly 14 hours straight on a trip back from Japan and found them to be quite comfortable for extended listening. The folding mechanism was smooth – bordering on feeling slightly loose – but we will see how well they hold up over extended use over the coming months.
I will admit one unexpected quirk of the EAH-A1000. With most premium over-ear wireless headphones, an integrated motion detector senses when you have taken them off your head and the headphones go into a standby mode to conserve battery life. By default, the A1000 seems to stay powered on, even when you take them off your head, fold them up and put them in the case. I kept getting notices on my phone that the headphones I had previously paired with were available, hours after I had stopped using them and folded them up in the case. I understand that this may make it quicker to resume play when you take a short break, but it was unexpected behavior.
It turns out this power-off behavior can be adjusted in the Technics app (thanks to my buddy Tony Ware from PopSci for pointing this out). The default for “auto power off” is to always stay on, even when the headphones are not actively receiving an audio signal. This is handy if you want to just use the headphones for ANC, without listening to audio, but it can also lead to a slow unintentional decay of the charge when not in active use.
There’s also a separate “Wear Detection” feature in the app which will automatically pause playback if you remove the headphones from your head, and can be set to automatically resume playback if you put them back on within a minute. But having the headphones stay powered up even when they’re folded and tucked away doesn’t seem like the best choice to me. Fortunately the battery life on the A1000 is so good that this power drain never actually impacted my use or enjoyment of the headphones.
Listening Notes
Over the course of my review, I listened to a wide sampling of music and video programming from a number of different sources. I used local 2-channel 24-bit/96KHz high res audio files stored on my phone connected both via LDAC wireless and via direct USB wired connection. I also listened to an extensive selection of Dolby Atmos spatial audio tracks on Amazon Music, connected both wirelessly and via a hard-wired USB-C cable.
On high quality stereo tracks, like Daft Punk’s “Give Life Back to Music” and “Get Lucky” in 24-bit/88.2 KHz high res PCM (connected via USB cable), minute details of the drums, synth and guitar were readily audible and the overall dynamics of the track were well conveyed by the headphones. Compressed tracks like 256 kbps MP3 rips of Adele’s “Someone Like You” and Alice in Chains “Down in a Hole” also came through smoothly and clearly, though with some compression artifacts audible in stringed instruments and drums. This is not the fault of the headphones but the source material. If you’ve got lower quality rips, don’t expect perfect sound.
Moving onto spatial audio tracks, Fleetwood Mac “Dreams” in Dolby Atmos sounded better on the A1000 than I’ve heard it in quite some time with deep extended low notes emanating from the electric bass and kick drums with nice articulation and impact. The mix offered excellent spatiality with harmony vocals all precisely placed in distinct points in space and snappy attack on the toms and snare drums.
Billie Eilish has a number of tracks mastered in Dolby Atmos, including the Oscar-winning “No Time to Die” track for the Bond film of the same name. On the A1000, I might as well have been back in the theater watching the film, with the layers unfolding into three dimensional space as the song built to its inevitable orchestral crescendo. On the simpler side, her track “The 30th” builds from a simple, casual lead vocal and guitar strum to a layered, but controlled tension-filled climax that will take your breath away. The A1000 reproduced this with ample power and finesse.
On mellow singer/songwriter fare like Aoife O’Donovan’s “Prodigal Daughter,” the delicate strumming and picking of guitar strings was presented with exquisite detail and a palpable presence, and harmony vocals were easy to identify in space but blended nicely together.
Switching over to EDM, the track “Alive” by Kx5, a collaboration between Deadmau5 and Kaskade, features wonderful use of space and a deep sonic thrust when the bass drops around 28 seconds into the song. About 4 minutes in when the synth snare roll moves in a circle from front center around the room and back to where it started, the A1000 presented this with a palpable sense of three dimensional space and sound truly seeming to move around my head, not just from left to right.
Overall, the A1000’s handling of Dolby Atmos spatial audio tracks is about the best I’ve heard from headphones. But Dolby Atmos music tracks can sometimes be mastered at a lower overall audio level, compared to stereo tracks. On some Dolby Atmos cuts, like KX5 “Alive” and the remastered Dolby Atmos tracks from Roxy Music, I feel like the A1000 could have used a bit more volume range. With the volume maxed out, there was no audible distortion, but the level didn’t quite peak out where I would have liked it to. This did not happen with stereo music tracks which are generally mastered with a higher peak level.
Technics EAH-1000 Technical Specifications
| GENERAL | Driver Unit (mm) | 40 mm (1-9/16 in) | |
| Noise Reduction for Calls | AI Beamforming | ||
| Talk Time | Approx. 30 hours | ||
| Playback Time with Battery (LDAC) | Approx. 40 hours (NC ON) Approx. 80 hours (NC OFF) | ||
| Playback Time with Battery (AAC) | Approx. 45 hours (NC ON) Approx. 90 hours (NC OFF) | ||
| Playback Time with Battery (Hard-wired USB) | Approx. 30 hours (NC ON) Approx. 60 hours (NC OFF) | ||
| Charging Time (25°C/ 77°F) | Approx. 3.5 hours (Using 500 mA power source or higher) | ||
| Quick Charge (15 minutes, AAC) | 4 hours (NC ON) | ||
| Dimensions (W x H x D) | Approx. 165 mm x 206 mm x 88 mm | ||
| Weight | Approx. 306 g (10.8 oz) | ||
| Supplied Accessories | USB cable: Approx. 1.2 m (USB-C to USB-C) Audio cable: Approx. 1.2 m (USB-C to 3.5 mm) Carrying case | ||
| Advanced Functions | Bluetooth® Wireless Technology | Frequency Band | 2400 MHz~2483.5 MHz |
| Codec | SBC, AAC, LDAC, LC3 | ||
| Full Adaptive Digital Hybrid Noise Canceling | Yes | ||
| Bluetooth® Multipoint Pairing | Yes |
The Bottom Line
With solid Adaptive Noise Cancellation, nice staging, a natural sonic signature and extended battery life, I’d say Technics has another winner on their hands with the EAH-A1000. Those who enjoy spatial audio will appreciate the robust, three dimensional soundscape, but may be annoyed by the lack of dynamics on some Dolby Atmos mixes. On stereo tracks, the A1000’s ability to support raw lossless and high resolution audio from a hard-wired USB connection, as well as audiophile grade LDAC wireless should appeal to those who value sound quality as much as they love their music. Recommended.
Pros
- Neutral and natural sonic signature with good staging and firm precise bass
- USB input supports hard-wired connection to phone or player for highest possible sound quality
- Extended battery life – up to 90 hours with ANC disabled
- Simple, but effective controls on right earcup
- Solid ANC works well to reduce noise in chaotic environments
- 8-band EQ allows personalization of sound
- Excellent spatial treatment of Dolby Atmos (spatial audio) content
Cons
- Volume is a bit limited on some Dolby Atmos music tracks
- Power stays on by default when not in use
- ANC slightly outmatched by some competitors (e.g. Sony XM6)
Our Ratings:
★★★★★★★★★★ Sound Quality
★★★★★★★★★★ Build Quality
★★★★★★★★★★ Comfort
★★★★★★★★★★ Features
★★★★★★★★★★ Value
Where to Buy:
Available October 1, 2026 in black or platinum greige.
Related Reading
ORT
September 29, 2026 at 4:54 pm
Hail and well met, Chris!!
“GREIGE”?! How quaint of Technics to create such a flaccid portmanteau for this “colorway”…I am showing considerable restraint on this. “SIGH”…Gray or beige both work fine for me. I don’t think I could tell people whilst maintaining my trademark straight face that I am wearing ‘phones that are “greige in colour”. Would this cultural colloquialism of a faux pas prevent me from buying these headphones? Nah. I understand Technics desire to be different, to stand out if you will from the rest of the herd but I already do so by myself. I like these phones for what they do for me as evidenced by your thoughts on them and I thank you for that, my brother!!
I can hear some call for the weeping vase into which they will cry their cuckodile tears of (f)artificial indignation, LOL!
“Greige”?! Nigerian, puhleeeeeze! Oh how I cry for the spirit of my arbiter of wit and wisdom, Gaius Petronius Arbiter.
ORTacles of Thebes
Ian White
September 29, 2026 at 7:16 pm
ORT,
Could be worse. Could be Pepto Pink.
IANUS IV
