Orange Amplifiers Launches the “O” Turntable: Because What the World Really Needed Was Another Minimalist Record Player
With a $699 tag, the O Turntable is belt-driven and comes with a pre-installed MM cartridge and a built-in phono preamp for easy connection with almost any amp or receiver
Orange Amplifiers O Turntable Angle Lifestyle
Orange Amplifiers (yes, that Orange—makers of loud, proud guitar and bass amps since 1968) have built a reputation on rock-solid gear with serious attitude and attention to detail.
Now, they’re continuing their march into consumer audio. After surprising everyone in 2024 with the oddly compelling Pyramid Audio System, Orange is back at it for 2025 with something even more unexpected: a turntable.
Dubbed the O Turntable (because apparently the alphabet starts and ends with “O” now), this UK-built deck is aimed squarely at serious vinyl heads and music lovers who want audiophile performance—along with a dash of Orange’s signature flair.
O Turntable Features: Orange Amplifiers’ Audiophile-Grade Vinyl Spinner
orange-amps-o-turntable-corner
24V Low-Noise Synchronous Motor
The O Turntable features a custom PCB and aluminum pulley system that minimizes vibration while maintaining consistent platter speed. This steady rotation supports accurate groove tracking and overall playback precision.
23mm High-Mass Phenolic Platter with Flywheel Effect
The 23mm phenolic platter adds mass and stability, helping to smooth out rotation and enhance speed consistency thanks to its natural flywheel effect.
Pre-Installed MM Cartridge and Phono Preamplifier
For easy integration into a variety of setups, the O Turntable comes with a built-in moving magnet (MM) phono preamp and a pre-installed cartridge with a replaceable carbon stylus. You don’t need a dedicated phono input—just plug it into any available RCA analog line input on your amp, receiver, or AVR.
orange-amps-o-turntable-tonearm
Auto-Bias Tonearm with Ultra-Low-Friction Bearings
The tonearm is fitted with ultra-low-friction bearings and a pre-set anti-skating bias. With a push-fit counterweight and no alignment tools required, setup is truly plug-and-play—ideal for those who want audiophile sound without the setup headache.
Sleek White Gloss Plinth and Signature Styling
The O Turntable sports a minimalist white gloss plinth with an underside power switch to keep the surface clean. Orange’s iconic branding appears on the plinth, tonearm, and cartridge. It also ships with a clear dust cover and a custom “Voice of the World” slipmat, because branding is forever.
Designed to Complement the Orange Pyramid Audio System
While the O Turntable pairs effortlessly with Orange’s own Pyramid Audio System, it’s compatible with virtually any setup. It’s simple enough for beginners, but built well enough to satisfy seasoned vinyl junkies.
orange-amps-o-turntable-speaker-system
From Cliff Cooper, Founder & CEO of Orange Amplifiers: “The O Turntable delivers pure, uncompromised vinyl sound with the simplicity and style our customers expect.”
Specifications
O Turntable
Product Type Belt-Drive Turntable
Price £499 / $699
MAX Output Level(3.54 CM/S RMS 45” cbs STR100 Band 6A amd 7A) 370-420MV
Output Impedance1KΩ
Frequency Response (Preamp Only)14Hz (-3dB) to 100Hz (-0.6dB)
RIAA Accuracy (Preamp Only)100Hz to 20KHZ +/- 4dB Typically better than +/- 0.25   dB
Preamp Gain4dB
Preamp Input Loading47K ohms in parallel with 220PF
Signal-to-Noise Radio (SNR)75dB A Weighted Ref Max Output
Dimensions (Lid Closed)447 x 117 x 360mm
17.6 x 4.6 x 14.2 inches
Weight 4.35 Kg/9.5 lbs
Power Supply (UK/EU)Input: 230V AC 50Hz 0/07 Amps
Output: 24 Volts AC 350 MA AC
Power Requirements (UK/EU)50 Hz AC 0.142MA 3.4 Watts
Power Supply (US)Input: 115V AC 60Hz
Output:: 24V AC 350MA AC
Power Requirements (US)60 Hz AC 0.142MA 3.1 Watts
The Bottom Line
The O Turntable marks a bold, if slightly unconventional, entry into the crowded vinyl market from Orange Amplifiers. With its eye-catching design, built-in phono stage, and pre-installed cartridge, it offers a plug-and-play experience at a midrange $699 price point—clearly aimed at style-conscious, younger listeners and fans of the Orange brand.
But competition is fierce. Pro-Ject’s AUTOMAT 1.2 and T1 EVO series offer strong performance and pedigree at lower price points, while Lenco’s sub-$500 lineup adds built-in Bluetooth for extra convenience. Meanwhile, Victrola’s Hi-Res Carbon and Onyx ($599 / $399) bring advanced wireless streaming to the table—literally.
Orange may face a tough climb in a saturated segment, but when paired with its Pyramid Audio System, the O Turntable becomes more than just a novelty—it’s a distinctive system play that could win over design-focused vinyl newcomers and longtime Orange loyalists alike.
orange-amps-o-turntable-top
Price & Availability
The O Turntable is priced at £499 (inc VAT) / €599 / $699.
The Pyramid Audio System is priced at £795 and $995.
Both products are available directly online from Orange (O Turntable from late July in the USA), and in-store through authorized dealers.
ViewSonic LX60HD smart LED 1080p projector angle
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
HiBy W4 Portable HiFi Bluetooth Headphone Amplifier HiBy W4 Portable HiFi Bluetooth Headphone Amplifier
HiBy W4 packs aptX Lossless, LDAC, 475mW balanced output, and a touchscreen into a $99 portable Bluetooth DAC Amplifier.
Pro-Ject Debut Reference 10 Turntable Lid Open Pro-Ject Debut Reference 10 Turntable Lid Open
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Sennheiser CX 80U Wired Earbuds and HD 400U Headphones Sennheiser CX 80U Wired Earbuds and HD 400U Headphones
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Creek Audio Cymatics 6 Stand-mount Speaker Front Creek Audio Cymatics 6 Stand-mount Speaker Front
Can Creek Audio stand out in 2026 as it enters the crowded speaker market and rethinks its amplifier strategy?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
Andover Audio’s SpinPlay is a brutally well-executed all-in-one record player that sounds far better than it should at its price—and may be the company’s...
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Editors’ Choice 2025 turntables show prices are up and cheap decks still disappoint. Choosing a long-term table now takes more thought—but pays off in...
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
