Meze Audio Unveils ARTA at High End Vienna 2026: Is This the New Reference That Pushes ELITE and Empyrean II Aside?
At $6,000, Meze Audio ARTA open-back planar magnetic headphones feature a new high impedance 225-ohm Rinaro driver.
2026 Meze Audio ARTA Headphones
Meze Audio has not been in any great hurry to replace its top headphones, and that restraint has worked rather well. The ELITE and Empyrean II have spent the past few years doing exactly what flagship headphones are supposed to do: stay relevant, collect awards, earn loyal listeners, and avoid becoming yesterday’s expensive mistake in a nicer box.
That matters because Meze has never treated its upper-tier models like disposable fashion accessories for audiophiles with restless credit cards. The company’s best headphones are handmade in Baia Mare, Romania, built around long-term serviceability, and designed to feel like objects you keep rather than trade away the moment the next shiny thing slithers out of a CNC machine.
The new ARTA changes the conversation.
Unveiled ahead of High End Vienna 2026, ARTA is being positioned by Meze Audio as a new reference headphone and one of the company’s most ambitious designs to date. It will make its first public appearance at the show on June 4, with consumer availability expected later this summer.
At $6,000 USD / €6,000, ARTA sits well above the Empyrean II and enters a tier where the source chain, DAC, headphone amplifier, cables, and even your beverage selection require more careful consideration.
meze-audio-arta-outer-earcup
New Rinaro MZ5 HΩ Driver: ARTA’s High-Impedance Planar Engine
At the heart of ARTA is the new Rinaro High Impedance Isodynamic Hybrid Array MZ5 HΩ driver. Meze describes it as the highest-impedance planar magnetic headphone driver to date, with an average impedance of 225 ohms. That is the first real clue that ARTA is not being aimed at casual desktop listening through whatever USB dongle survived the junk drawer. This is a high-voltage, low-current design intended to reward better amplification and cleaner source components.
That should not surprise anyone who has spent meaningful time with Meze’s top headphones. The Empyrean II remains my personal reference headphone because it does not force me to choose between resolution, tone, comfort, and musicality. It has enough detail to satisfy the audiophile side of the brain, but it never turns listening into a clinical exercise. Any headphone hoping to replace it has to do more than impress for 15 minutes at a show. It has to disappear for hours.
But the Empyrean II also benefits from better electronics. So does ELITE. These headphones do not need brute force, but they absolutely respond to better DACs, headphone amplifiers, and source components. Feed them properly and they open up. Starve them and you are leaving a lot of Romania on the table.
ARTA appears to push that idea further.
Meze lists ARTA at 495g, with a claimed frequency range of 3 Hz to 115 kHz and total harmonic distortion below 0.05%. That makes it heavier than the ELITE, Empyrean II, LCD-5, and even the newer LCD-5s, but not by enough to make comfort a non-starter. Meze has earned some trust on ergonomics, and 495g is still manageable for a full-size open-back reference headphone if the headband distributes the weight properly.
What it is not, however, is a commuting headphone. ARTA is open-back, which means everyone around you gets a partial listening session whether they asked for one or not. It also looks expensive enough to attract the wrong kind of attention on the subway. Maybe Metro-North after White Plains. The A train? Absolutely not.
Sculpture, Serviceability, and a Very Romanian Sense of Purpose
ARTA looks unmistakably like a Meze headphone, but the design moves in a more assertive direction. The materials are what one would expect at this level: precision-machined metal, carbon fiber, and leather, all used with a clear focus on durability, weight control, and long-term serviceability. Meze also deserves credit for continuing to build headphones that look distinctive without drifting into costume jewelry.
The acoustic grille is more than a styling detail. Meze says ARTA uses angled acoustic blades to reduce internal soundwave reflections, which should help with transient clarity and openness. The company is describing the tuning as warm-neutral with a more spacious, speaker-like presentation, but that part will need to wait until we hear it under controlled conditions.
That is the kind of claim that needs to survive actual listening, because the high-end headphone category is already littered with models that promise speaker-like presentation and then deliver an expensive clamp with excellent treble anxiety. Still, Meze has a strong track record here.The Empyrean II already does space, texture, and tonal density better than most of its rivals, and it does so without making weaker recordings feel like a punishment.
The serviceability story remains one of Meze’s strongest advantages. ARTA is designed so that every major component, including the earpads, headband, drivers, and earcups, can be disassembled, serviced, or replaced. That matters at $6,000. A headphone at this level should not become landfill because one part fails or one material ages badly. Meze has understood this for years, and ARTA continues that approach.
Comparison
ELITEEMPYREAN IIARTA
MSRP$4,000$2,999$6,000
Driver TypeRinaro Isodynamic Hybrid Array®Rinaro Isodynamic Hybrid Array®Rinaro High Impedance Isodynamic® Hybrid Array
Diaphragm TypeRinaro Parus® [MZ3SE]Rinaro Isoplanar® [MZ3]MZ5 HΩ
Impedance32 Ω32 Ω225 Ω average
Frequency Range3 Hz – 112 kHz8 Hz – 110 kHz3 Hz – 115 kHz
Total Harmonic Distortion (THD)<0.05%<0.05%<0.05%
Headphone Weight433 g449 g495 g
The Bottom Line
ARTA is unique because it is not just a more expensive version of the ELITE or Empyrean II. The new MZ5 HΩ driver, 225-ohm impedance, angled acoustic-blade grille, 495g weight, full serviceability, and $6,000 USD / €6,000 price point all suggest that Meze is building a new reference tier rather than simply refreshing the lineup.
The key question is not whether ARTA looks more advanced on paper. It does. The real question is whether the high-impedance Rinaro driver delivers a clear improvement in spatial presentation, transient clarity, tonal accuracy, and control when paired with the right DAC and headphone amplifier. At this level, different is not enough. Audeze, Dan Clark Audio, and HiFiMAN all have established planar magnetic models in this price range, which means ARTA enters a category with no shortage of credible competition.
ELITE and Empyrean II are not being shown the door, and they should not be. Both remain outstanding open-back planar headphones, and the Empyrean II remains my personal reference for good reason. ARTA may become Meze’s new summit model, but it still has to prove that the climb was worth it.
For more information: Meze Audio
Blok Axis 700 Speaker Stands in white with Stax 2G Modular Equipment Rack
A/V Furniture & Accessories
Can better speaker placement start with the right stand? Blok Axis offers three heights, IsoFill damping, isolation pads, and multiple finishes.
NAD CI S2 Angle NAD CI S2 Angle
NAD expands Dirac Live Room Correction to its CI SA2-120 and CI S2, adding automated acoustic optimization to its BluOS custom install lineup.
2026 SMSL D400 MK2 and R100 DACs 2026 SMSL D400 MK2 and R100 DACs
Can SMSL’s new R100 and D400 MK2 compete with FiiO, Schiit and Topping in the increasingly crowded DAC market below $1,000?
2026 Schiit Audio Bifrost 3 DAC Black 2026 Schiit Audio Bifrost 3 DAC Black
Did Schiit improve Bifrost by moving beyond True Multibit? Bifrost 3 adds Mesh, EQ, 32/384 USB and drops the price to $699.
iFi Audio Phantom 1.5 Headphone Amplifier Angle iFi Audio Phantom 1.5 Headphone Amplifier Angle
Can one headphone amp drive IEMs, planars and electrostatics? The $3,749 iFi iCAN PHANTOM 1.5 delivers up to 15W plus a 640V energizer.
2026 iFi Go Cable Lifestyle 2026 iFi Go Cable Lifestyle
Dongle DACs
Can iFi eliminate the dongle DAC? The $79 GO cable builds an ESS DAC and headphone amp directly into a USB C cable for...
What were the best headphone systems at CanJam SoCal 2026? We heard standout rigs from RAAL, Chord, Meze, Grado, HiFiMAN, SJY and more.
Meze Audio’s ALBA S keeps the original driver, tuning and metal shell but drops the bundled USB-C DAC adapter to cut the price.
Over-Ear Headphones
These 8 new headphones and IEMs have us curious in 2026, from Sony’s 1000X ANC flagship to Final, Meze, HiFiMAN, Audeze and Noble.
Can Final’s $8,499 DX10000 CL justify its True Diamond driver and closed-back flagship design, or is the price the real headline?
Can HIFIMAN’s $1,899 HE6 Remastered revive a planar icon with a lighter headband and the same serious amplifier demands?
