MartinLogan Depth Series Subwoofers Plunge Into the Lower Depths — Down to a Bone-Rattling 18Hz
MartinLogan dives deeper with the new Depth Series subwoofers—more power, pricier, and ready to rattle floors in a market already stacked with bass-heavy contenders.
MartinLogan Depth Series Subwoofer LIfestyle
Just two weeks after dropping the Grotto Series home theater subwoofers priced at $2,300 and $2,800, MartinLogan clearly didn’t get the memo about inflation fatigue—because they’re already back with the new Depth Series, which somehow manages to climb even higher up the price ladder. Before you roll your eyes at another “premium” bass box, let’s take a closer look at what the Depth lineup actually brings to the table—and how it stacks up in a market where SVS, REL, and Hsu Research are all locked in a race to the bottom to deliver maximum low-end for minimum cash.
When asked about replacing MartinLogan’s flagship BalancedForce Subwoofers, Allan Tarrant, Senior Vice President of MartinLogan, said: “Replacing our flagship BalancedForce Subwoofers was no easy task. We decided to start from scratch and design something totally original in order to take bass performance to the next level. I am happy to report that this new Depth Series has exceeded our expectations in every way. From the overall look and feel, fit and finish, feature set, and most importantly, the sound quality, they really are something truly special.”
martin-logan-depth-215-212
Depth 215 (left) and Depth 212 (right)
Key Features and Benefits of the MartinLogan Depth Series Subwoofers
Balanced Force Design: The goal of a subwoofer is to reproduce low frequencies with both control and accuracy. MartinLogan’s Balanced Force technology uses dual active 12-inch (Depth 212) or 15-inch (Depth 215) drivers mounted in opposing positions to cancel cabinet vibration and reduce distortion. The result is more stable, detailed bass performance that avoids the boominess often caused by enclosure resonance.
Carbon Aerocore Woofers: Each woofer cone features MartinLogan’s new Carbon Aerocore design, built from Carbon Fiber, PMI Structural Foam, and Fiberglass layers. This tri-layer structure offers a high strength-to-weight ratio, maintaining rigidity under heavy load. Triple venting beneath the spider, through the voice coils, and pole pieces improves airflow and minimizes heat, while dual copper shorting rings reduce distortion for consistent, well-controlled low-frequency output.
High-Power Amplification: The Depth Series relies on reference-grade Class-D amplifiers optimized for efficiency and low distortion. The Depth 212 delivers 2,200W Dynamic Peak (1,100W RMS), while the Depth 215 uses dual amplifiers for 4,400W Dynamic Peak (2,200W RMS). These amps maintain linear performance across volume levels, ensuring accurate bass reproduction whether you’re listening quietly or pushing your system harder.
Advanced DSP Control: Both models are powered by MartinLogan’s proprietary 500MHz 64-bit Vojtko DSP Engine, which continuously monitors and adjusts performance in real time. This system manages crossover points, phase alignment, and output levels with precision, ensuring accurate, balanced bass response that integrates cleanly with main speakers in both music and home theater systems.
Efficient Thermal Management: To sustain that level of power and digital processing, the Depth 212 and 215 are built to stay cool under pressure. MartinLogan’s Convection-Cooled Concealed Amplifier Design hides the amplifier and connections within a streamlined rear trim assembly featuring dual aluminum heatsinks. This setup promotes effective passive airflow, maintaining amplifier stability during extended listening sessions while keeping cable management tidy and the overall look refined.
Anthem Room Correction (ARC): As part of the Anthem/Paradigm/MartinLogan (PML Sound International)family, the Depth Series includes Anthem Room Correction (ARC Genesis) for accurate room equalization and calibration. Using the included premium calibration microphone kit, users can quickly measure and adjust the subwoofer’s response to match their room acoustics, improving bass integration and overall system balance.
Pro Tip: Anthem ARC is not the same as HDMI-ARC. The former is a room correction system, while HDMI-ARC is a connection protocol for sending audio from a TV to compatible equipment.
Touch Control Interface: Once setup is complete, users can fine-tune performance using MartinLogan’s Concealed Touch Control Interface (TCI). Located on the rear panel, six backlit touch points and an LED display provide direct access to all key settings. The backlighting can also be customized—or turned off entirely—for a clean, discreet appearance.
Pro Tip: Prefer using your phone? The MartinLogan Control App offers full wireless access to tuning and configuration options for even easier adjustments.
martin-logan-depth-215-rear-inputs
Comprehensive Connectivity: The Depth Series subwoofers are designed to integrate easily into a wide range of systems, from two-channel setups to full-scale home theaters. Connection options include XLR Left and Right, XLR LFE (Right XLR), dedicated RCA LFE, RCA Left and Right, Speaker Level inputs (via banana plugs), and an RCA Sub Out for daisy-chaining or multi-sub configurations.
As an added convenience, both the Depth 212 and Depth 215 feature built-in lossless wireless connectivity, allowing for flexible placement without the clutter of additional cables while maintaining full-resolution signal integrity.
Integrated Anti-Vibration Feet: Often overlooked but essential, the anti-vibration feet on the Depth Series subwoofers are engineered to isolate the cabinet from the floor—whether on hardwood, tile, or carpet. This design minimizes energy transfer and resonance, reducing room rattles and unwanted vibrations. The result is tighter, cleaner bass with improved overall clarity and system dynamics, allowing the subwoofer to perform at its best without shaking the rest of the room.
When asked about the technology behind the new subwoofers, Andrew Lindsey, Product Manager at MartinLogan, replied that “The BalancedForce woofer configuration has been a key part of our subwoofer technologies for decades, ever since it was first used in the Statement E2 sub-bass towers. Depth 212 and Depth 215 utilize this balanced, dual-opposed design to great effect, using an all-new woofer cone material we call Carbon Aerocore. These cutting-edge woofer cones use a tri-layer, unibody construction composed of a Carbon Fiber layer, a PMI structural foam layer, and finally a fiberglass layer. This combination provides an extreme strength-to-weight ratio with incredible self-dampening properties—leaving nothing but clean, detailed, articulate bass.”
Comparison
martinlogan-depth-vs-grotto
MartinLogan Model Depth 212Depth 215Grotto 12Grotto 15
Product Type Powered Wireless SubwooferPowered Wireless SubwooferPowered Wireless Subwoofer Powered Wireless Subwoofer
Price $5,499$6,999$2,299$2,799
Frequency Response18–120 Hz ±3 dB (Anechoic via LFE input)18–120 Hz ±3 dB (Anechoic via LFE input)22-120 Hz ±3 dB (Anechoic via LFE input)20-120 Hz ±3 dB (Anechoic via LFE input)
Low Frequency Transducer Dual Active 12″ cast-aluminum basket, high excursion, Carbon Aerocore cone woofers in a BalancedForce configuration with under spider, voice coil, and pole piece venting, plus dual copper shorting ringsDual Active 15″ cast-aluminum basket, high excursion, Carbon Aerocore cone woofers in a BalancedForce configuration with under spider, voice coil, and pole piece venting, plus dual copper shorting rings.Triple 12″ (25.4cm) Hybrid Woofer System consisting of 1x high-excursion, aluminum cone in a cast aluminum basket with 2x aluminum cone passive radiators for enhanced low frequency output.Triple 15″ (25.4cm) Hybrid Woofer System consisting of 1x high-excursion, aluminum cone in a cast aluminum basket with 2x aluminum cone passive radiators for enhanced low frequency output.
Amplifier Reference Grade Class-D Amplifier: 2,200W Dynamic Peak (1,100W RMS)Dual Reference Grade Class-D Amplifiers: 4,400W Dynamic Peak (2,200W RMS)MartinLogan Magnitude MT 2kW Amplifier: 2000W peak (1000W continuous)MartinLogan Magnitude MT-2kW Amplifier: 2000W peak (1000W continuous)
Digital Signal Processing UltraHigh-Resolution 500MHz Vojtko DSP Engine with 64bit processingUltra High-Resolution 500MHz Vojtko DSP Engine with 64bit processingUltra High-Resolution 500MHz Vojtko DSP Engine with 64bit processingUltra High-Resolution 500MHz Vojtko DSP Engine with 64bit processing
Cabinet Extensively braced and reinforced variable thickness (1-3″) cabinetExtensively braced and reinforced variable thickness (1-3″) cabinetSealed 1″ thick MDF cabinet with center brace and reinforced MDF woofer bafflesSealed 1″ thick MDF cabinet with center brace and reinforced MDF woofer baffles
Controls (Touch Control Interface)Level Adjustment
Tone Sweep
Low Pass Filter
Phase/Polarity
Listening Mode
20-30Hz Level
ARC On/Off
Wireless On/Off
Passcode Lock
Logo Color
Information
Factory Reset
Language Selection
Owner’s Manual QR Code
Control APP QR Code
Level Adjustment
Tone Sweep
Low Pass Filter
Phase/Polarity
Listening Mode
20-30Hz Level
ARC On/Off
Wireless On/Off
Passcode Lock
Logo Color
Information
Factory Reset
Language Selection
Control APP QR Code
Level: Interactive LED Backlit Knob, Min–Max
Tone Sweep: Sweep Start and Pause (with status light)
Power Mode: On, 12v Trigger
Auto Wireless
Audio Pairing Button (for included MartinLogan wireless transmitter)
Auto Wireless
Controls (via Bluetooth)Level: -40 to 12dB (Min-Max)
Low-Pass Filter (Frequency): 35–120Hz (1° Increments)
Low-Pass Filter (Order): Bypass, Third, Fourth
Phase: 0–180° (1° Increments)
Phase (Polarity): Normal, Inverted
Preset Listening Modes: Movie, Music, Night
20–30Hz Level: ±10dB
Anthem Room Correction (ARC Genesis): On, Off
Tone Sweep (120-20Hz): On, Off, Pause (Frequency)
Inputs Line Level: Left, Right, and LFE XLR: Left, Right or LFE (Right In)
Speaker Level: Left and Right (requires banana plugs)
Line Level: Left, Right, and LFE XLR: LFE
OutputRCA Sub Out (Outputs the sum of all connected inputs)RCA Sub Out (Outputs the sum of all connected inputs)RCA Sub Out (combines and repeats all incoming signals to an additional subwoofer)RCA Sub Out (combines and repeats all incoming signals to an additional subwoofer)
Wireless Input Integrated Wireless Receiver, Wireless Transmitter IncludedIntegrated Wireless Receiver, Wireless Transmitter IncludedIntegrated Wireless Receiver Wireless Transmitter IncludedIntegrated Wireless Receiver Wireless Transmitter Included
Power Draw Standby (Wireless Disabled): 0.5W
Standby (Wireless Enabled): <2W *Transmitter and Subwoofer combined
Max: 1000W
 Standby (Wireless Enabled): < 2W (Transmitter and Subwoofer combined)
Max: 1000W
Feet Integrated Anti-Vibration Feet (carpet spikes included)Integrated Anti-Vibration Feet (carpet spikes included)Integrated Anti-Vibration Feet (carpet spikes included)Integrated Anti-Vibration Feet (carpet spikes included)
Weight  127 lbs (57.6kg)173 lbs (78.5kg) 82.5 lbs (37.4 kg)118 lbs (53.5 kg)
Dimensions (HxWxD)
Product height is without carpet spikes but includes the feet.
21 x 19.8″ x 20.4 inches
53.3 x 50.3 x 51.8cm
22.5 x 22.8 x 23.4 inches
57.2 x 58 x 59.5cm
17.8 x 17.9 x 17.9 inches
45.2 x 45. x 45.4cm
20.5 x 21.8 x 21.8 inches
52.2 x 55.4 x 55.4cm
Finish Gloss BlackGloss BlackGloss BlackGloss Black
martin-logan-depth-212-rear-angle
MartinLogan Depth 212
The Bottom Line
MartinLogan didn’t waste any time following up the Grotto Series with the new Depth Series, and this move feels like a clear signal that they’re coming for the high-end home theater crowd with some serious intent. The Depth 212 and Depth 215 bring plenty of substance to justify their price hike — from Balanced Force dual-opposed drivers and Carbon Aerocore woofer cones to Anthem Room Correction (ARC Genesis) and a 500MHz 64-bit Vojtko DSP engine that keeps everything in check.
The reference-grade Class-D amplification delivers between 2,200W and 4,400W Dynamic Peak power, backed by lossless wireless connectivity, convection cooling, and anti-vibration feet that help keep the bass tight, controlled, and floor-friendly.
That said, MartinLogan isn’t operating in a vacuum. SVS continues to redefine performance per dollar with its SB 17-Ultra R|Evolution and SB-5000 R|Evolution subs, while REL’s Serie SDALI’s SUB V-16 F, and Raidho’s TD8 and TD10 all compete in the same sandbox with their own design philosophies and sonic signatures.
How the Depth Series and Grotto Series stack up in real-world listening rooms remains to be seen—but one thing’s for sure: MartinLogan isn’t shying away from flexing its engineering muscle in a market that’s already loaded with heavy hitters. And if you somehow think this still isn’t enough bass, there’s always the $30,000 Wilson Audio Submerge or the $35,000 McIntosh PS1K, because nothing says “I like low end” quite like shaking the foundation—literally.
martin-logan-depth-215-subwoofer-front-angle
MartinLogan Depth 215 (front angle)
Pricing & Availability
Available Models and Pricing: Launching in Gloss Black with a variety of color options coming in 2026 – available through MartinLogan Authorized Dealers.
  • Depth 212: $5,499.99 USD | $7,249.99 CAD
  • Depth 215: $6,999.99 USD | $8,999.99 CAD
Also available:
  • Grotto 12: $2,299.99 USD | $2,599.99 CAD
  • Grotto 15: $2,799.99 USD | $3,199.99 CAD
Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
iFi GO Link 2 Dongle DAC connected to laptops iFi GO Link 2 Dongle DAC connected to laptops
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Q Acoustics Easyfit In-ceiling Speakers Lifestyle Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Technics SL-1500CS Turntable Silver Technics SL-1500CS Turntable Silver
Technics SL-1500CS upgrades the popular SL-1500C with Delta Sigma Drive motor control. Does this precision boost make it the new direct drive leader in...
Rega Aos MC Phono Preamplifier Angle Left Rega Aos MC Phono Preamplifier Angle Left
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
At $2,749, can PS Audio’s Foundry F12 justify its price against SVS, REL, and MartinLogan by delivering cleaner, more controlled bass where it actually...
Just days after CES 2026, SVS’s 3000 R|Evolution subwoofers are now available—but do they raise the bar for output and control?
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
From budget-friendly upgrades to room-shaking reference bass, these subwoofer picks deliver accurate low-end performance, smart features, and real value at every price tier.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
The Anthem MRX SLM delivers high-end performance in an ultra-slim AVR built for CI installs and small rooms, though limited power and inputs may...
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
