Lyngdorf SB-75 Passive Soundbar Announced: High-End Audio Upgrade for 75″ and 77″ TVs
What makes Lyngdorf’s $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
Lyngdorf Audio has introduced the SB-75, a high-end passive soundbar designed to complement 75- and 77-inch televisions, with wider cabinet sizes available by special order. Expected to arrive in the U.S. by Summer 2026, the SB-75 continues the company’s push into luxury home theater solutions alongside its FR-2 loudspeakers, Cue-100 speaker system, and the TDAI-2210 integrated streaming amplifier.
Unlike the $500 all-in-one soundbars stacked by the pallet at big-box retailers, passive soundbars like the SB-75 target a very different audience. These are buyers who already own serious amplification, care about room correction and system matching, and expect a soundbar to deliver the same level of fidelity they demand from their two-channel music systems. In other words, this is for the listener who wants one elegant LCR solution beneath the TV without sacrificing the kind of clarity, dynamics, and scale normally associated with a dedicated speaker system.
That places the SB-75 in a niche but growing category occupied by brands such as Theory Audio Design, which specializes in custom-width passive LCR soundbars designed for 65- to 85-inch displays. Like those systems, Lyngdorf’s approach assumes the use of external amplification, advanced room setup software, and higher-end A/V processors, creating a performance-first alternative to the convenience-driven soundbars that dominate the mainstream market.
SB-75 Overview: Bring Your Own Power
lyngdorf-audio-sb-75-passive-soundbar-gray-angle
Lyngdorf SB-75 passive soundbar in gray
The SB-75 combines two high-end stereo speakers within a single cabinet, giving it the form factor of a soundbar but the design philosophy of a traditional hi-fi loudspeaker. Intended to be wall mounted below a TV or projection screen, the SB-75 is engineered to deliver a wide soundstage and powerful output for both movies and music.
Unlike most soundbars, however, the SB-75 does not include built in amplification. Instead, it uses standard speaker connections, allowing owners to pair it with the external amplifier or amplifiers of their choice, whether that means a high quality two channel amplifier or a pair of monoblocks. This approach provides far greater flexibility for system matching and performance tuning than the typical all in one soundbar design.
High-End Soundbar Design Built Like Real Speakers
The Lyngdorf SB-75 may look like a soundbar, but under the hood it’s closer to a pair of serious hi fi loudspeakers housed in a single cabinet. Designed for on wall installation below a TV or projection screen, the SB-75 combines a slim, space saving footprint with the engineering approach Lyngdorf typically applies to its high end speakers.
Inside the rigid MDF cabinet are six drivers arranged in a stereo configuration. The SB-75 uses four 180 mm (6.5 inch) aluminum cone midrange woofers with 35 mm voice coils, die cast baskets, and vented magnets, paired with two 28 mm (1.1 inch) fabric soft dome tweeters. This configuration allows the SB-75 to function as a full range passive stereo speaker capable of delivering both music and movie soundtracks with convincing scale and clarity.
The cabinet itself is shallow but carefully tuned for placement close to a wall, which improves efficiency and overall output. With a rated sensitivity of 92 dB and a nominal impedance of 4 ohms, the SB-75 is designed to deliver high output levels when paired with quality external amplification.
Lyngdorf lists the SB-75 with a frequency response of 57 Hz to 20 kHz (±3 dB), making it capable of substantial bass performance on its own while still integrating easily with a subwoofer for home theater systems. The soundbar measures 168 x 20 x 11 cm (66 x 7.9 x 4.3 inches), or 11.6 cm (4.6 inches) deep when mounted with the included wall bracket, allowing it to sit discreetly below large flat panel displays while delivering the soundstage of a traditional stereo speaker setup.
Designed for Clean Wall Installation
lyngdorf-audio-sb-75-passive-soundbar-lifestyle-front
The Lyngdorf SB-75 is engineered for simple wall mounting and ships with an integrated wall mount bracket for straightforward installation below a TV or projection screen. Its shallow cabinet profile makes placement easy while maintaining a low visual impact in both dedicated home theaters and everyday living spaces.
Finished in an extra matte black, the SB-75 is designed to visually disappear in dark cinema rooms or when placed behind an acoustically transparent projection screen. For more traditional media rooms and living rooms, the speaker features rounded cabinet edges and an elegant midnight gray fabric grille that helps it blend seamlessly with modern interior design.
Pro Tip: The SB-75 is sized to match 75 inch and 77 inch televisions, creating a clean, proportional look beneath large displays. Lyngdorf also offers custom cabinet widths by special order, allowing integrators and homeowners to match the soundbar precisely to other screen sizes.
Steinway Lyngdorf Model S
Steinway Lyngdorf Model S Soundbar Under TV Lifestyle
In addition to the SB-75, Lyndorf Audio’s sister company, Steinway Lyngdorf, offers an integrated powered soundbar system, the Steinway & Sons Model S (originally released in 2024).
Instead of a passive design, the Model S incorporates a high-end speaker speaker assembly, but also provides Room Perfect technology for performance optimization in different room acoustic properties and size, and also includes an externally connected Steinway Lyngdorf amplification system.
Comparison
Lyngdorf SB-75Steinway & Sons Model S
Product TypePassive SoundbarPowered Soundbar
Price$5,000$17,000
Description2 x 2-way speaker (stereo soundbar)Full-range on-wall loudspeaker
EnclosureMDF construction, closed cabinetAluminum front and back, MDF frame
Tweeter2 x 28mm (1.1″) Fabric soft dome3 x Air Motion Transformer, Kapton foil, neodymium magnet
Midrange4 x 180 mm (6.5″), 35mm voice coil, cone material: aluminum, die-cast basket, vented magnet 3 x 5.25″ anodized aluminum cone, neodymium magnet
Woofer2 x 10″ aluminum cone, 4-layer voice coil, neodymium magnet
Nominal Impedance4 OhmsN/A
Frequency Response (-3dB)57 – 20,000 Hz40 Hz – 20 kHz
Power Handling250 Watts1,600 Watts
AmplificationExternal A1 or A2 amplifiers, 4 x 400 watt  (left channel, right channel, center channel, dual woofers)
Max SPL@1m117 dB113 dB
Sensitivity (2.83V/1m)92 dBN/A
Crossover2,200 HzWoofer/midrange: Digital, stored in processor (200 Hz, 4th order)
Midrange/tweeter: (2,500 Hz, 4th order)
ConnectionsBinding posts (2 pairs; one for left and one for right channel)2 x Neutrik speakON NL4
PlacementOn-wall with supplied wall-mount bracketOn-wall
Dimension (WHD)168 x 20 x 11 cm (11.6 cm with wall mount bracket)
66 x 7.9 x 4.3 inches (4.6 inches with wall mount bracket)
Custom Width available by special order
189 x 30 x 10.4 cm
74.4 x 11.8 x 4.1 inches (incl. base plinth)
Weight28 kg / 62 lbs48 kg / 106 lbs
FinishUltra matte black, detachable fabric grille in midnight greyMatte black and high-gloss black with gold accents. Customized lacquers and finishes are available on request.
lyngdorf-audio-sb-75-passive-soundbar-front
Lyngdorf SB-75
The Bottom Line
The Lyngdorf SB-75 isn’t meant for shoppers comparing $300 soundbars at the local electronics store. It’s aimed squarely at enthusiasts and custom installers who want the clean look of a soundbar but refuse to give up the performance of real loudspeakers. By using a fully passive design with external amplification, Lyngdorf offers far more flexibility and system matching than the typical all in one soundbar.
For listeners who value both music fidelity and cinematic impact and already own high quality amplification or plan to build a serious home theater system, the SB-75 delivers something unique: the sound of high end stereo speakers in a single, elegant cabinet designed to sit seamlessly beneath a large screen.
lyngdorf-audio-sb-75-grill-logo-closeup
Lyngdorf logo on SB-75 grille
Price & Availability
The Lyngdorf SB-75 is expected to become available by Summer 2026 via Authorized Dealers for an approximate price of $5,000 USD (that does not include required amplification).
Note: The Steinway Lyngdorf Model S is currently available at Authorized Dealers for $17,000.
Silent Angel H1
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
2026 FiiO FT15 Headphones 2026 FiiO FT15 Headphones
FiiO’s $499 FT15 gets a bigger planar driver, thinner diaphragm and lighter chassis, and we already have first impressions from CanJam London.
2026 Bose Ultra Open 2nd Gen and Sport Open Earbuds in Black 2026 Bose Ultra Open 2nd Gen and Sport Open Earbuds in Black
Is Bose trying to make open ear audio mainstream? The $199 Sport Open Earbuds and $299 Ultra Open Earbuds 2nd Gen target fitness and...
2026 Hisense Boom Portable Bluetooth Speakers 2026 Hisense Boom Portable Bluetooth Speakers
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
2026 IKEA BADRUKA Bluetooth Speaker in pink on desktop 2026 IKEA BADRUKA Bluetooth Speaker in pink on desktop
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
Sony PlayStation Pulse and Pulse Edge Wireless Gaming Headsets Sony PlayStation Pulse and Pulse Edge Wireless Gaming Headsets
Gaming Headsets
Sony’s new PlayStation Pulse and Pulse Edge headsets add larger planar magnetic drivers, PlayStation Link, Bluetooth and ANC.
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
The compact Yamaha B200A adds Dolby Atmos and built in bass for under $300, but can you live without external surrounds or a subwoofer?
Can serious home theater disappear into the room? Sonance pairs an 82.7-inch soundbar with redesigned PowerPipe X hidden subwoofers.
The TCL Q95K combines 11.1.4 channels, 22 drivers, wireless surrounds, dual 7-inch subwoofer drivers and Bang & Olufsen tuning.
The $699 Sonos Beam Ultra packs nine drivers, dedicated Atmos height channels and Sonos 27, but still skips DTS:X. Is it worth the premium?
Can the $1,500 Bluesound Pulse Cinema justify its price with BluOS, strong music performance, and flexible connectivity despite limited Atmos immersion?
