A/V Furniture & Accessories
GIK Acoustics Launches Sound Block StackPack Acoustic Treatment — But at $976, It Better Sound Like God Whispering
GIK Acoustics’ Sound Block StackPack includes a trio of modular acoustic panels that can be free standing or wall mounted.
GIK Acoustics Sound Block StackPack Promo Image
The room is the most overlooked — and most important — component in any stereo or home theater setup. You can throw all the money in the world at exotic cables and power conditioners, but if your room sounds like a tiled bathroom or a slap echo chamber, you’re sunk.
Sure, room correction software built into AVRs and processors tries to save the day — but let’s be honest, it’s more band-aid than cure depending on the room. Onkyo’s AccuEQ, Anthem Room Correction (ARC), Audyssey (Denon/Marantz), Dirac (ARCAM, Onkyo, Integra, Pioneer Elite, select Denon/Marantz), Pioneer’s MCACC, and Yamaha’s YPAO all promise digital salvation. But when those DSP wizards can’t fix boomy bass or flutter echo in your converted guest bedroom, it’s time for the grown-up solution: physical acoustic treatment.
What Is Acoustic Treatment and Why It Matters
Acoustic treatment refers to the use of specialized materials and products designed to control sound behavior within a room. Unlike soundproofing—which blocks sound from entering or escaping a space—acoustic treatment improves the sound inside the room itself.
There are three primary types of acoustic treatment products: absorption panels, bass traps, and diffusers. Absorption panels reduce mid- and high-frequency reflections that cause echo and muddiness. Bass traps focus on controlling low-frequency energy buildup, which often causes boomy or uneven bass. Diffusers scatter sound waves to maintain natural ambiance without unwanted reflections.
Strategically placed acoustic treatment can significantly reduce reverberation, control flutter echo, and smooth out frequency response. Whether you’re dealing with a dedicated listening room, home theater, podcast studio, or even a conference space, proper treatment is critical for achieving accurate, intelligible sound.
GIK Acoustics is a leading manufacturer of acoustic treatment products designed to improve sound quality in a wide range of environments—from home theaters and recording studios to two-channel listening rooms. Their product lineup includes absorption panels, bass traps, and diffusers in a variety of sizes, finishes, and configurations.
For 2025, GIK Acoustics has introduced the Sound Block StackPack, a bundled solution aimed at simplifying the acoustic treatment process. The StackPack offers a modular, scalable approach to taming problematic reflections, reverb, and low-frequency buildup. Designed for audiophiles, content creators, and engineers, the StackPack delivers pro-level performance for rooms that demand precision and control.
gik-sound-block-stackpack
The StackPack combines three GIK Sound Blocks into a single, space-efficient vertical stack, making it ideal for professional studios, home listening spaces, and multi-purpose rooms. This modular tower format provides focused acoustic control without taking up excessive floor space, offering a clean, streamlined alternative to scattered panels or bulky traps.
By reducing room reflections and low-frequency buildup, the StackPack helps improve imaging, tonal balance, and clarity—especially in untreated or asymmetrical rooms. Its design also adds a polished visual element, blending form and function in one tidy package.
Each StackPack kit includes the following parts:
  • Two scattering Sound Blocks fitted with wooden accent plates, designed specifically for high-frequency diffusion.
  • One Sound Block featuring GIK’s patented FlexRange Technology for powerful low-frequency absorption, effective down to 50Hz.
The Sound Blocks are wrapped in premium Camira acoustically transparent fabric and come in three distinct styles, allowing them to blend seamlessly into a wide range of room aesthetics—from minimalist studios to more eclectic home environments.
gik-sound-block-stackpack-slide
The Sound Block StackPack offers a modular design that adds serious flexibility to the equation. Users can position the units behind speakers, along side walls, on the rear wall, or in any acoustically strategic location depending on the room’s needs. Whether you’re fine-tuning a dedicated two-channel setup or taming reflections in a home theater, the StackPack adapts to fit the space without compromising performance or style.
From Paul Bishop, GIK Designer: “The Sound Block Stack Pack is a super efficient way to drop serious freestanding coverage into your room without overthinking it,…With these three striking finishes, you’ve got a ready-to-go solution that looks sharp and performs even better – no need to configure a custom stack, and the discount makes it even easier to say yes.
The Sound Block StackPack makes it easy to implement in your room space.
A set of three modular Sound Blocks is designed to provide superior acoustic treatment, crafted to elevate both the sound quality and aesthetic appeal of your room.
Key features of the Sound Block StackPack include:
  • Space-saving vertical layout.
  • The StackPack combines broadband absorption, precise bass control, and targeted sound diffusion.
  • Modular and pre-configured for easy setup.
  • Effective full-range acoustic treatment for compact spaces.
The Sound Block StackPack is available in 3 colors:
  • Beech Noir: A sophisticated blend of dark tones and light wood accents.
  • White Hot: A crisp, modern aesthetic with sleek white finishes.
  • Dusky Fawn: A warm, earthy palette that complements various interior designs.
The Bottom Line
Acoustic treatment isn’t just an add-on—it’s often the final piece in turning a good audio or home theater system into a great one. GIK Acoustics’ Sound Block StackPack stands out by delivering serious room control in a sleek, modular package that actually looks good—no more ugly foam panels ruining your décor. It’s designed to tame problematic reflections and bass build-up with style and precision, making it a solid choice for critical listening environments.
That said, this level of performance doesn’t come cheap—at nearly $1,000, treating a large room can get expensive fast. And remember, acoustic treatment works best when balanced with natural room elements like carpets, furniture, bookshelves, and plants. Too much of either can suck the life out of your sound or leave you chasing dead echoes. If you’re unsure, bring in a pro to help avoid turning your listening room into an acoustic cave.
Price & Availability
Each SoundBlock StackPack includes 3-pack of panels for $976.97 at GIK Acoustics, which represents a 22% saving compared to individual Sound Blocks, offering an efficient and cost-effective acoustic treatment solution.
GIK Acoustics also provides complimentary acoustic consultation services for personalized room analysis and recommendations. Online tools to get you started include Acoustic Advice, Acoustics Visualizer, Acoustic Panels Calculator, and Acoustic Products Comparison Tool.
1 Comment
1 Comment
  1. ORT
    July 20, 2025 at 8:06 pm
    Hello the house!
    I have decided to cash in on the frAudiophilian inability to think rather than feeeeeel…My first (Lawdy I HATE this term) “merch” shall be dubbed “The Accoustic Maze – Sound goes in but gets lost!”
    I have prepared nifty names for the (British word ALERT!) “colourways”
    “Shrubbery Noir” – If you do not buy this, we shall say…Ni!! to you!
    “Non-Colour Privilège” – Let the Turd World know you are not only sensitive but oh so much more woke than Greta!
    “Dusky Springsteen” – Guaranteed to absorb the noise of even the most self serving of supposed Rock “legends”.
    Thee ORTacle at HelFi
Luxman L-100 Centennial Class A Integrated Amplifier
Luxman's CENTENNIAL series D-100 SACD/CD player and L-100 Class A Integrated Amplifier aim to end your desire to upgrade.
TEAC TN-400BT X/TB Turntable Lifestyle TEAC TN-400BT X/TB Turntable Lifestyle
Can a Bluetooth turntable make vinyl practical for wireless headphone users? TEAC’s TN 400BT X/TB bets that convenience matters more than purism.
Toneoptic CAN Record Storage System stacked with mixed colors Toneoptic CAN Record Storage System stacked with mixed colors
Toneoptic’s CAN record storage system offers modular stackable vinyl storage made in Los Angeles starting at $195 and designed to replace milk crates for...
Arendal Sound 1610 Loudspeaker Series Arendal Sound 1610 Loudspeaker Series
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
Okki Nokki One DV Record Cleaning Machine Front Okki Nokki One DV Record Cleaning Machine Front
Can the $749 Okki Nokki ONE built in the Netherlands set a new standard for quieter and more reliable record cleaning machines?
Optoma UHZ36 4K Laser Projector Lifestyle Optoma UHZ36 4K Laser Projector Lifestyle
Does Optoma's $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Acoustic Room Treatment
GIK Acoustics debuts its new Amplitude line featuring patented recessed plate technology, premium finishes, and modern design for superior room acoustics and refined visual...
At $299, the WiiM Sound features room correction, Wi-Fi 6E, stereo pairing and 5.1 setups, but lacks AirPlay, HDMI-ARC, and a phono input.
Dirac Live Active Room Correction for select Denon and Marantz A/V Receivers and Preamp/Processors is now available for $299 extra.
The CANVAS HiFi Soundbar has already gotten good reviews, but it may get even better with the implementation of Organic Master Tuning
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
At $6,000, the McIntosh MX200 delivers 11.2 channels of surround sound with higher resolution video pass-thru up to 8K.
Ask an Expert
Do your new pair of loudspeakers not sound like you envisioned after reading that super positive review? You may have a room acoustics issue.
