FiiO K15 DAC Headphone Amp: The Affordable Desktop Option Schiit Hopes You Ignore
Discover the FiiO K15 DAC Headphone Amp: A powerful, affordable desktop solution offering balanced audio, Wi-Fi, and Bluetooth, all for $549. Compare with top contenders like Schiit Asgard X and Shanling EH2.
FiiO K15 Desktop DAC and Headphone Amp Front View Angle
FiiO has quickly become a major force in the headphones and desktop audio space, consistently churning out products that are both practical and well-received. We’re barely halfway through 2025, and they’ve already launched a slew of gear—including the S15 music streamer, FT7 planar magnetic headphones, FX17 IEMs, M21 DAP, K17 headphone amplifier, and the new FiiO K15 DAC/Headphone Amplifier.
With this many products hitting the market, you’d think they’d be ready to call it a year. But despite the announced price hikes, FiiO’s not slowing down. Instead, they’re pushing forward, continuing to meet demand and expand their lineup, even in the face of tariffs and rising costs.
The K15 Desktop DAC and Headphone Amp: Affordable Power in a Compact Package
FiiO has launched the K15 Desktop DAC and Headphone Amplifier, offering a more affordable alternative to the higher-end K17, which is priced just shy of $1,000. The K15 retains much of what makes the K17 a strong performer but comes in at a more approachable $600.
This full-system desktop DAC/amp is tailored for music lovers and works seamlessly with the FiiO FT7 headphones or powered speakers like the FiiO SP3. While it’s optimized for these products, it’s versatile enough to pair with any headphones or powered speakers of your choice. But if you’re considering an upgrade, FiiO’s own suggestions could be worth a look.
At its core, the K15 features dual AKM AK4497S DAC chips from AKM’s ‘VELVET SOUND’ series. These high-end chips are designed to deliver precise digital-to-analog conversion, maintaining clarity from low to high frequencies with minimal distortion and a broad dynamic range. The K15 is one of the first products to implement these flagship AKM chips in a dual configuration, resulting in a rich, immersive sound signature. Plus, for those who like to fine-tune, a 10-band parametric EQ via the FiiO Control app allows users to adjust the sound to their personal preferences.
Amplification
The K15 features a discrete Class A/B amplifier circuit that delivers up to 3000mW per channel through its balanced output. This allows it to effortlessly drive both sensitive IEMs and high-impedance over-ear headphones, providing low-noise, high-current performance across the board.
Playback
The K15 provides several input modes for playback.
  • USB DAC (XMOS XU316, supporting 768kHz/32-bit, DSD512, MQA)
  • Bluetooth decoding (LDAC, AptX HD, AAC)
  • Streaming (Roon Ready, AirPlay)
  • Local playback via USB storage
  • Audio decoding via Optical and coaxial Audio Connections
  • Single-ended and balanced analog inputs – single-ended input ideal for turntables (the K15 has a ground connection for traditional turntable phono outputs).
Whether you’re playing back your personal library or streaming high-resolution music wirelessly, the K15 adapts effortlessly to your preferred ecosystem.
fiio-k15-rear
Fully Balanced
From the DACs to the amplifier stage, the K15’s audio path is fully balanced and differential. This design improves channel separation, minimizes distortion and noise, and maximizes overall fidelity.
For added signal stability, the K15 incorporates a tri-board design, which isolates the digital, analog, and power supply sections into separate PCBs (Printed Circuit Boards). This layout helps reduce crosstalk and electrical interference, resulting in a noticeably cleaner sound.
Precision Power
The K15 features a high-efficiency 30W internal AC power supply, with an additional 12V DC input for users looking to upgrade to an external linear power supply. It also incorporates independent digital and analog power rails, along with a multi-stage analog supply that uses multiple dropout regulators. This ensures a consistent flow of ultra-clean current to each audio stage, maintaining optimal performance throughout.
Touchscreen
To facilitate easy operation, the K15 features a 3.93-inch color LCD touchscreen. The screen supports intuitive visual control, while tactile knobs provide quick access to key functions. For hands-free operation, an infrared remote and FiiO Control App (Android, iOS) connectivity are included.
Wired or Wireless Network Connectivity
The K15 is equipped with Gigabit Ethernet and 2.4G/5G dual-band Wi-Fi for seamless network streaming, ensuring high-speed, stable connections for your music sources.
Comparison
fiio-k15-k17
K15K17
Product Type Desktop DAC and Headphone AmpDesktop DAC and Headphone Amp
Price$549$989.99
Remote ControlSupports IR remote (only the included accessory) Supports IR remote (only the included accessory)
DAC2 x AK4497SAKM flagship DAC chips (AK4191 + 2 x  AK4499EX)
USBXU316XU316
Headphone amplifier transistorMJE243G/253G MJE243G/253G
Display3.93-inch LCD 3.93-inch LCD
Bluetooth Version5.15.1
Bluetooth CodecsSBC/AAC/aptX/aptX LL/aptX HD/aptX Adaptive/LDAC SBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
MQAYesYes
Equalization10-band parametric EQ accessible through the FiiO Control app.Global 31-band professional-grade high-precision lossless parametric EQ
USB DAC768kHz/32bit; DSD512 (Native) Up to 768kHz/32bit, DSD512 (Native)
Coaxial input192kHz/24bit; DSD64 Up to 192kHz/24bit, DSD64
Optical input96kHz/24bit Up to 96kHz/24bit
Local playback384kHz/32bit; DSD256 Up to 384kHz/32bit, DSD256 (DOP)
Streaming playback384kHz/32bit; DSD256 (DOP) Up to 384kHz/32bit, DSD256
Gain Setting ModesUltra high gain
Super high gain
High gain
Medium gain
Low gain
Ultra high gain
Super high gain
High gain
Medium gain
Low gain
Headphone Output (Ultra High Gain Mode) Output Power 1: L+R≥1400mW+1400mW (32Ω SE, THD+N<1%)
Output Power 2: L+R≥3000mW+3000mW (32Ω BAL, THD+N<1%)
Output Power 3: L+R≥180mW+180mW (300Ω SE, THD+N<1%)
 Output Power 4: L+R≥700mW+700mW (300Ω BAL, THD+N<1%,)
Output power 1 L+R≥1800mW+1800mW (16Ω, THD+N<1%)
Output power 2 L+R≥1850mW+1850mW (32Ω, THD+N<1%)
Output power 3 L+R≥240mW+240mW (300Ω, THD+N<1%)
RCA Output LevelL+R=2.4Vrms+2.4Vrms (1kHz@10kΩ) – Gain Mode Not Specified2.5Vrms (1kHz@10k)
XLR Output LevelL+R=4.8Vrms+4.8Vrms (1kHz@10kΩ)  – Gain Mode not SpecifiedUltra High Gain Mode
Output power 2 L+R≥4000mW+4000mW (32Ω, THD+N<1%)
Output power 3 L+R≥950mW+950mW (300Ω, THD+N<1%)
Frequency Response (All Outputs)20Hz~80kHz, attenuation<2.8dB20Hz~20kHz: attenuation<0.05dB
20Hz~90kHz: attenuation<3dB
SNR≥122dB (A-weighted)Gain Mode Dependent
Noise Floor<5.3μV (A-weighted)Gain Mode Dependent
THD+N<0.00054% (1kHz/-12dB@32Ω) Gain Mode Dependent
ColorBlack/Silver Black/Silver
Dimensions244.6x213x66.8mm 244.6 x 213 x 66.8 mm
Weight2100g 2750g
The Bottom Line
The K15 DAC/Headphone Amp is a solid addition to the FiiO product lineup, offering much of what the flagship K17 provides but at about half the price. With a reasonable $549 price tag, it faces some interesting competition. For example, the newly released Schiit Audio Asgard X, priced at $399, offers a great headphone amp solution but lacks features like a touchscreen display, balanced audio connectivity, Wi-Fi, and Bluetooth. For $200 less, it could be a solid choice, depending on your priorities.
Another competitor at $399 is the Shanling EH2, which provides balanced headphone output via a 4.4mm connection and Bluetooth. However, it lacks a screen and Wi-Fi.
For those who want to keep things “bare-bones,” FiiO also offers the K11R2R, priced under $200. It skips Bluetooth and the touchscreen but still delivers 4.4mm balanced, 6.3mm unbalanced, and line outputs.
All things considered, the K15 strikes a strong balance between price, audio decoding and processing, connectivity, and the added bonus of a front display—making it an excellent option for music enthusiasts.
Price & Availability
The FiiO K15 will be released on August 1, 2025 for $549.
Update: The FiiO K15 price has increased, now selling for $599 at Amazon.
The K15 will be shown at CanJam London on July 19th, 2025. Attendees and press will be able to listen to the K15 with FiiO FT7 headphones.
The K17 is available for $989.99 at Amazon.
Grell OAE2 Open-Back Headphones Flat
Axel Grell’s OAE2 open-back headphones debut at CanJam NYC 2026 with a speaker-like soundstage concept. Can the $599 design change how we listen to...
Grado Labs Signature S550 Open-back Headphones Lifestyle Woman Grado Labs Signature S550 Open-back Headphones Lifestyle Woman
At $995, Grado's most affordable Signature Series open-back headphones feature new S2 drivers and cushion design with a Brazilian Walnut housing. Is this the...
Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
iFi GO Link 2 Dongle DAC connected to laptops iFi GO Link 2 Dongle DAC connected to laptops
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Q Acoustics Easyfit In-ceiling Speakers Lifestyle Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
The Burson Conductor GT4 is a $3K audio sledgehammer—insanely powerful, deadly neutral, and hot enough to fry eggs. Upgradeable, versatile, and built like a...
Bowers & Wilkins brings its McLaren partnership back for 2025 with the Px8 S2 McLaren Edition, pairing the updated S2 acoustic platform with clean...
Creative Labs reinvents the iconic Sound Blaster with the Re:Imagine, a modular high-resolution audio hub combining PC, gaming, and pro audio control with open...
At $699, Noble Audio’s FoKus Prestige Encore elevates luxury wireless listening with a four-driver hybrid design, Audiodo sound calibration, Bluetooth 5.4 with aptX Lossless...
At $1,980, Eversolo’s DAC-Z10 combines dual AKM DACs, R2R volume control, balanced preamp design, and HDMI I2S connectivity in a refined, touchscreen-equipped chassis built...
Compare Denon and Marantz AVRs for 2025—explore features, performance, and prices to find the best home theater receiver for your setup, from budget to...
At $349, Bluesound's new PULSE FLEX delivers hi-res audio, BluOS streaming, and flexible multi-room or home theater use.
