Dangbei MP1 Max 4K Lifestyle Projector: Half Laser, Half LED, All Out to Replace Your TV
At under $2,000, the Dangbei MP1 Max is a compact 4K lifestyle projector with Google TV, AI setup, and hybrid laser-LED tech for screens up to 150-inches.
Dangbei MP1 Max 4K Projector Lifestyle
Following up on the 2024 DBOX02 portable laser projector, Dangbei is back for 2025 with the MP1 Max—a sleeker, more powerful unit aimed at viewers who want big-screen 4K without taking out a second mortgage. But like most “affordable” 4K projectors in this space, the MP1 Max plays it smart (and a little shifty) by skipping a native 4K chip. Instead, it uses pixel-shifting tech to deliver a 4K UHD image—good enough to fool your eyes, if not your microscope.
DLP 4K Pixel Shifting
The MP1 Max incorporates a 0.47-inch 1080p DLP chip (DMD) from Texas Instruments, packed with 2.1 million micromirrors. To achieve 4K (8.3 million pixels), the projector uses pixel-shifting technology. This means that it rapidly shifts the 1080p image both vertically and horizontally at 240Hz. This is so fast (240 times per second), the viewer’s eyes perceive it as a full 4K UHD image. It’s not native 4K, but it’s close enough for most people to never notice the difference, especially at typical viewing distances.
Hybrid Laser and LED Light Source: What Powers the Dangbei MP1 Max?
The MP1 Max features an advanced Triple Laser plus LED hybrid light source, providing higher brightness, improved color accuracy, and a more comfortable viewing experience.
dangbei-dual-light
Light Output
With 3100 ISO lumens of brightness, the MP1 Max delivers vivid, lifelike images that hold up well in rooms with ambient light—and even in some outdoor settings where light control is limited.
Screen Size Options
The MP1 can project images from 40 to 300 inches, but for best results, Dangbei recommends a screen size from 80 to 150 inches. Some example projector to screen distances are:
  • 80-inch screen – 6.9 ft (2.1 m)
  • 100-inch screen – 8.9 ft (2.7 m)
  • 120-inch screen – 10.5 ft (3.2 m)
  • 150-inch screen – 13.1 ft (4 m)
Color
The 110% BT.2020 wide color gamut expands the spectrum for richer, more vibrant visuals, while the ΔE<1 color accuracy brings a more realistic viewing experience. Its advanced 4K Ultra HD Triple Laser + LED technology enhances color vibrancy and visual depth while ensuring long-lasting reliability.
HDR
The MP1 also provides HDR support with the inclusion of HDR10+ for more realistic presentation of the bright and dark scenes.
3D
The MP1 also provides a 3D viewing option with compatible content and optional 3D glasses.
Eye Comfort
In addition to picture quality, the MP1 Max also recognizes the importance of eye comfort by providing source-level protection, filtering 400-445 nm harmful blue light to reduce eye strain.
Audio
Audio is not neglected as Dolby Audio and DTS Virtual X are supported through its built-in 2 x 12-watt audio system, which incorporates a 750cc Bass Chamber that is capable of delivering frequencies down to 45Hz.
Entertainment Right Out Of The Box
dangbei-mp1-max-google-tv
The MP1 Max incorporates Google TV with licensed Netflix integration and over 10,000 apps, including YouTube, Disney+, Prime Video, and Hulu. With over 700,000+ movies and shows and smart recommendations, your entertainment options are virtually endless. Google Assistant voice control makes navigation simple and intuitive.
AI Image Setup
InstantPro AI Image Setup technology simplifies setup by automating image optimization with features like Auto Focus, Auto Keystone Correction, Screen Fit, Obstacle Avoidance, Eye Protection, Real-time Keystone Correction, and AI Brightness Adjustment. If you want more control, you can easily fine-tune the settings with minimal manual effort.
Remote Convenience
For added convenience, the remote includes One-Click Wake & Play to instantly launch Netflix, YouTube, or Prime Video—even from sleep mode. Smart Shortcuts offer quick access to Auto Focus and Auto Keystone Correction, delivering a perfectly adjusted image in seconds.
Intelligent Cooling System
dangbei-mp1-max-cooling
The Dangbei MP1 Max incorporates an advanced Modular Cooling Technology that supports efficient performance. With Zoned Thermal Insulation (cold and heat isolation), High-Capacity Heat Pipes, and Dual Turbo Fans, the system runs silently yet provides efficient heat dissipation.
Practical Design
dangbei-mp1-max-side-lifestyle
The MP1 Max has an increasingly popular design that incorporates a built-in stand with 360° horizontal rotation and 135° vertical tilt. This supports easy placements on tables, shelves, or mounted setups. This type of design is also featured on several other Brands/Models of projectors, such as the Hisense M2 Pro and Leica Cine Play 1.
The MP1 Max features a sculpted, curved exterior that is designed to blend into any space. The fabric finish enhances acoustics while resisting dust and fingerprints, and the eco-friendly EPP case offers stylish portability with a sleek, minimalist design.
Comparison
dangbei-mp1-max-comparison
Note: Projector image sizes are not to scale.
Dangbei MP1 Max Dangbei DBOX02 (aka Mars Pro 2)Hisense M2 ProLeica Cine Play 1
Release Year2025202420252025
Product Type 4K Laser/LED Hybrid Projector4K Laser Projector4K Laser Projector4K Laser Projector
MSRP$1,999$1,899$1,299$3,795
Display TechnologyDLPDLPDLPDLP
Display Chip0.47” DMD0.47” DMD0.47” DMD0.47” DMD
Light SourceTriple Laser + LEDALPD® Laser Tri-Color LaserDirect Triple RBG-Laser
Brightness3100 ISO Lumens2450 ISO Lumens1200 ANSI LumensUp to 3000 Lumens (Ultra Mode)
Native Contrast Ratio100,000:1 (not verified)5,000:11,000:11,500:1
Resolution3840 × 2160 pixels (via pixel shifting)3840 × 2160 pixels (via pixel shifting)3840 × 2160 pixels (via pixel shifting)3840 × 2160 pixels (via pixel shifting)
Throw Ratio1.2:11.27:11.0-1.3:1 (D:W)(0.9-1.5):1
Aspect Ratio16:9 /4:316:9 /4:316:9 /4:316:9 /4:3
Projection Size40” – 300”   (Recommended 80”~150”)60″~200″ (Recommended 80”~120”)65 to 200-inches65 – 300”
Color Gamut110% BT.202076.25% DCI-P3110% BT.2020> 100%  BT 2020
Color AccuracyΔE<1ΔE<1ΔE<.9Not Provided
HDR SupportHDR10+, HDR10, HLGHDR 10+, HDR 10, HLGHDR10, Dolby Vision, HLGDolby Vision® / HDR10+ / HLG
3D Yes (Optional Glasses Required)Yes (Optional Glasses Required)Yes (Optional Glasses Required)Yes (Optional Glasses Required)
MEMC (Motion Estimation/Motion Compensation)YesYesYesYes
Setup FeaturesInstanPro AI Image Setup
Auto Focus
Auto Keystone
Correction
Screen Fit
Obstacle Avoidance
Eye Protection:
Real-Time Keystone Correction
Auto Focus
Auto Keystone
Correction
Screen Fit
Obstacle Avoidance
Eye Protection
Easy Setup Features
Auto Focus
Auto-Obstacle Avoidance
Auto Screen Adaptation
Wall Color Adaptation
Setup Features
Auto Focus
Manual Focus
Auto Keystone Correction/Auto Screen Alignment
Audio System 2-Channel2-Channel2-Channel2-Channel
Power Output12W × 212W × 210W × 210W × 2
Surround Sound Support DTS Virtual:X
DTS-HD
Dolby Audio
Dolby Digital
Dolby Digital Plus
Dolby Digital
Dolby Digital Plus
DTS:X
Dolby Digital
DTS Virtual:X
DTS Virtual:X
Dolby Audio
CPUQuad-Core ARM Cortex-A55Not IndicatedNot IndicatedNot Indicated
GPUMali-G52Not IndicatedNot IndicatedNot Indicated
Operating SystemGoogle TVGoogle TVVIDAA OSVIDAA OS
RAM2 GB2GB DDR3Not IndicatedNot Indicated
ROM32 GB 32GB eMMC5.1 Not IndicatedNot Indicated
Fast BootYes (STR)Not IndicatedNot IndicatedNot Indicated
Screen MirroringGoogle CastChromecast built-inApple AirPlay 2, MiracastYes
RemoteRemote Control
Bluetooth Remote
App Control
Remote ControlBacklit Voice RemoteBluetooth / IR in Aluminum Housing with Microphone
Streaming ServicesNetflix, YouTube, Prime Video, Hulu, Disney+, and moreNetflix, YouTube, Prime Video, Hulu, Disney+, and moreNetflix, Disney+, HBO MAX, Hulu, Prime Video, SHOWTIME, YouTube, Apple TV +, and moreNetflix, Prime, Disney, YouTube, and more
Voice ControlGoogle AssistantGoogle AssistantVIDAA VoiceVIDAA Voice, Alexa
Wired ConnectivityHDMI eARC,
HDMI 2.1,
USB 2.0,
3.5 mm
HDMI eARC,
HDMI 2.1
USB 2.0 (×2)
HDMI ARC,
HDMI 2.1
USB 3.0
HDMI eARC
HDMI 2.1
S/PDIF,
Optical (Toslink)
USB 3.0 (×2)
Wi-FiWi-Fi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/axWi-Fi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/axWi-F 6 (802.11a/b/g/n/ac)
Wi-Fi 6 (IEEE 802.11 a/b/g/n/ac/ax)
BluetoothVersion 5.2/BLEVersion 5.2/BLEVersion 5.0Version 5.2
Noise LevelStandard Mode <24dB Standard Mode <24dB Not Indicated< 29dB (A) @ 1m distance
DC-IN×1×1×1×1
Power Consumption190W150W100W180W
Dimensions (HWD)9.71 x 11.65 x 9.1 inches9.29 × 7.93 × 6.43 Inches9.10 x 7.60 x 8.60 inches10.3 x 9.5 x 9.0 inches
Weight12.3 lbs8.8 lbs8.6 lbs14.7 lbs
ColorDark GreyBlack WhiteMetal Grey
In the BoxEPP Carrying Case
Power Plug
Remote
User Manual
AAA Batteries(×2)
Power Plug
Remote Control
Wiping Cloth
User Manual
Voice remote with backlight
Quick Start Guide / Manual
Power Cable
Remote control
AAA batteries(×2)
Power cable
Power supply unit
Accessory bag
Operating instructions & Warranty
dangbei-mp1-max-accessories
The Bottom Line
With growing competition from extra-large screen TVs, the projector landscape is shifting. One clear trend is the rise of compact “lifestyle” projectors designed to fit a variety of home setups—from living rooms and bedrooms to outdoor spaces and even on-the-go use.
Building on the success of its DBOX02, Dangbei’s MP1 Max brings solid performance to this segment while embracing the trend of built-in tilt and swivel stands for flexible display positioning.
When compared to competitors like the Hisense and Leica Play 1, the MP1 Max sits in the middle price-wise. The Hisense is slightly smaller, the Leica a bit larger. The MP1 Max leads in brightness with about 3,100 ISO lumens, though the Leica isn’t far behind. All three projectors offer easy setup, but Dangbei’s AI-assisted auto setup is the most comprehensive.
Pro Tip: Leica’s premium price is partly due to its brand name and higher-end lenses, which may justify the cost for some buyers.
A standout feature on the Dangbei MP1 Max, not prominently mentioned by its competitors, is its innovative cooling system that supports stable operation in various environments and may extend the light engine’s lifespan.
Speaking of the light engine, the MP1 Max takes a hybrid approach—combining laser and LED technology—to enhance color accuracy, diverging slightly from the pure laser trend.
While Dangbei and its rivals target a step above the sea of cheap, low-brightness projectors, their higher price tags reflect their elevated performance. If you’re looking for a compact projector that can challenge larger standard models and ultra-short-throw projectors, these options deserve serious consideration.
dangbei-mp1-max-with-lights
Price & Availability
The Dangbei MP1 Max is available for $300 off, now $1,999 $1,699 at Amazon and the Dangbei Website. However, launch discounted pricing is only expected to last until July 7, 2025.
HiFi Rose RW800 Rose Air Lite Streaming Expansion Module Lifestyle Closeup
2026 Volumio Primo V3 Music Streamer with Tablet 2026 Volumio Primo V3 Music Streamer with Tablet
Volumio’s third-generation Primo V3 adds a faster processing platform, ESS ES9039Q2M DAC, NOS mode, eight DAC filters, selectable RCA and XLR output levels, and...
Daily Deals
Movies
THX Deep Note returns with “Spark,” a new trailer that updates a 42-year cinema ritual for today’s immersive moviegoing experience.
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
JMGO N3 Ultimate delivers triple laser color, a 3-in-1 optical system, and up to 5,800 ISO lumens for screen sizes from 40 to 300...
3D never died, it evolved. Today’s high output home theater projectors bring Blu-ray 3D films to life with sharper detail, deeper immersion, and a...
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
XGIMI’s TITAN Noir Max aims to bridge lifestyle design and premium projection, but pricing, final specs, and Q1 2026 availability will determine where it...
Epson brings Google Gemini AI to its Lifestudio projectors, adding smarter content discovery, voice control, and smart home features ahead of CES 2026.
