Cleer Audio to Unveil THX-Certified ARC 4 Wireless Earbuds at CES 2026
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES 2026.
Cleer ARC 4 white on-ear bud
In the run-up to CES 2026, Cleer Audio is doubling down on open-ear listening with the launch of the ARC 4 and ARC 4+ wireless earphones. Building on what made the ARC series popular in the first place, the new models retain Cleer’s open-ear hook design—no ear-canal seal, no isolation guilt—while refining the shape and hinge for better fit, comfort, and long-term wear.
The idea remains refreshingly practical: deliver engaging sound without shutting out the world, making the ARC 4 Series a natural fit for commuting, office use, and workouts where situational awareness isn’t optional, it’s common sense.
cleer-arc-4-around-ear
THX Certification
What actually makes this announcement matter, however, is not the revised ergonomics or the open-ear positioning—it’s the badge on the spec sheet. Cleer Audio’s ARC 4 Series is the first pair of wireless earphones to earn THX Certification, a distinction rarely associated with open-ear designs, let alone hook-style wireless models.
That certification signals a measurable standard for tuning, consistency, and performance, and it suggests Cleer isn’t just chasing lifestyle users this time—it’s aiming to bring a level of audio credibility to a category that usually settles for “good enough.”
thx-certification-process
With THX Headphone Certification in play, the Cleer ARC 4 Series isn’t treating open-ear audio like a compromise. The goal here is measurable sound accuracy—balanced frequency response, low distortion, and precise left/right channel matching for stable imaging—while preserving the clarity that open designs often struggle to maintain at higher volumes. THX’s specialized open-ear standards also address the usual weak spot, delivering controlled, believable low-end performance without turning the soundstage into mush.
Both the ARC 4 and ARC 4+ (aka ARC 4 Plus) are tuned directly by THX engineers to align with the THX optimal frequency response curve, prioritizing natural tonality, clean vocals, and detailed highs. The result isn’t a hyped “fitness earbud” sound, but a more disciplined, high-fidelity presentation that aims to stay honest to the source—something the open-ear category has historically been terrible at.
Cleer also splits the lineup cleanly by features. The ARC 4 supports Dolby Audio alongside Snapdragon Sound by Qualcomm, delivering stable, low-latency wireless performance with an emphasis on clarity and consistency rather than gimmicks. It’s a sensible foundation that prioritizes reliable connection quality and natural sound—two things open-ear designs don’t always get right.
Step up to the ARC 4+ and the focus shifts toward immersion. It adds Dolby Atmos optimization and Dolby Sensor-based Head Tracking, using onboard sensors to detect head movement and keep the soundstage anchored in place. Dolby Atmos tuning enables more accurate rendering of height and spatial cues for compatible content, while Dolby Audio continues to handle stereo and multichannel material with low distortion and controlled dynamics. In short, ARC 4 keeps things grounded; ARC 4+ leans into spatial audio without pretending it’s a home theater strapped to your ears.
On the hardware side, the ARC 4 Series checks the right technical boxes for a serious open-ear design. Cleer rates the earbuds for Hi-Res Audio with a 65Hz–40kHz frequency range, an ambitious spec for a category that usually taps out well before that.
To compensate for the inherent bass challenges of open-ear listening, Cleer leans on its DBE 4.0 (Dynamic Bass Enhancement) processing, which is designed to add weight and depth to the low end without smearing the mids or turning the presentation into a bloated mess.
cleer-arc-4-black-in-case
Cleer ARC 4
Cleer ARC 4 Series: Shared Features and Core Technologies
Beyond the headline audio features, the ARC 4 Series is built on a modern wireless foundation. Bluetooth 5.4Snapdragon SoundBluetooth multipoint, and support for aptX Lossless give both models the bandwidth and stability needed for high-quality, low-latency playback, while integrated voice control keeps things hands-free. It’s a feature set aimed squarely at daily use, not just spec-sheet flexing.
Call quality gets equal attention. Qualcomm cVc (Clear Voice Capture) microphones reduce background noise and suppress echo, while aptX Voice further improves intelligibility during calls. The emphasis here is clear conversations without sacrificing audio performance—something open-ear designs can easily fumble.
Physically, the ARC 4 earbuds are 10% lighter than their predecessors, tipping the scales at just 10.8 grams per earbud. A redesigned ergonomic hinge and softer materials improve long-term comfort and stability, while the slimmer, more pocket-friendly charging case makes the whole package easier to live with day to day.
Battery life is competitive for the category. The ARC 4 delivers up to 32 hours of total playback (approximately 7–9 hours per charge plus 25 hours from the case), while the ARC 4+ stretches that to 34 hours. Both models integrate with the Cleer+ app for Android and iOS, offering EQ adjustments, ambient and noise-control settings, firmware updates, battery status, and access to the user manual—all the practical tools you actually end up using.
Cleer ARC 4 vs. ARC 4+
cleer-arc4-vs-arc4-plus
ARC 4ARC 4+
Product TypeOpen EarphonesOpen Earphones
Price $99.99$129.99
Driver16.2mm Driver16.2mm Driver
BluetoothVer 5.4Ver 5.4
Qualcomm Snapdragon SoundYesYes
Bluetooth Codec SupportAptX Adaptive, AptX Lossless, SBC, AAC, LC3AptX Adaptive, AptX Lossless, SBC, AAC, LC3
Bluetooth Multipoint Connection YesYes
THX® CertifiedYesYes
Dolby®™Dolby Audio™Optimized for Dolby Atmos™
HeadtackingYes
Hi-Res Audio®YesYes
Frequency Response65Hz-40kHz65Hz-40kHz
Microphones2-mic Qualcomm cVc ENC (Environmental Noise Cancelling)2-mic Qualcomm cVc ENC (Environmental Noise Cancelling)
6-Axis Motion SensorYes
Adaptive Volume Control (AVC)YesYes
On/Off Button (Earbuds)Yes
MFi® (Made for iOS Devices)Yes
Cleer+ App | EQYesYes
Key FeaturesSound EQ, Touch ControlSound EQ, Touch Control
IPX7 Water & Sweat ResistanceYesYes
Battery LifeUp to 7 hours, in total 32 hours with the charging caseUp to 9 hours, in total 34 hours with the charging case
Charge MethodsUSB-CUSB-C
Quick ChargeA 10-minute charge provides 2 hoursA 10-minute charge provides 3 hours
ColorsBlack, WhiteBlack, White, Pink
Weight10.8g (per earbud)
76g (both earbuds and case)
10.8g (per earbud)
cleer-arc-4-plus-white
Cleer Arc 4+
The Bottom Line
After spending time with every generation of Cleer’s open-ear lineup—from the original ARC through ARC IIARC 3ARC 3 Gaming Edition, and ARC 3 Sport Pro—it’s clear that the ARC 4 and ARC 4+ are the most mature and technically credible versions yet. Previous models focused on comfort, durability, and use-case specialization (gaming latency, sports stability), but the ARC 4 Series shifts the emphasis toward measurable audio performance, with THX Headphone Certification as the defining upgrade. That certification doesn’t magically outperform non-THX products, but it does confirm that Cleer is now applying tighter tuning standards, lower distortion targets, and better channel matching than any prior ARC model.
Compared to the ARC 3 variants, the ARC 4 Series adds improved ergonomics, lighter earpieces, longer battery life, broader codec support, and a more refined sound profile—while giving up the ARC 3’s LED touchscreen case, which remains the only real regression. The ARC 4 is the logical successor for existing ARC and ARC II users who want better sound and modern wireless performance without gimmicks, while the ARC 4+ will appeal to listeners coming from the ARC 3 Gaming Edition who want spatial audio and head tracking without sacrificing open-ear awareness.
These are for listeners who value situational awareness, comfort, and credible sound quality, not noise cancellation or sealed-ear bass theatrics. If you’ve followed the ARC series from the start, the ARC 4 models feel less like another iteration and more like Cleer finally locking in what open-ear wireless is supposed to be.
Price & Availability
2026 Bose Lifestyle Ultra Wireless Speaker Colors
Bose Lifestyle Ultra Speaker debuts at $299 with AirPlay, Spotify Connect, Google Cast, TrueSpatial audio, and a clear shot at Sonos.
2026 Bose Lifestyle Ultra Soundbar White 2026 Bose Lifestyle Ultra Soundbar White
Can Bose make home theater easier? The Lifestyle Ultra Soundbar and Subwoofer add Dolby Atmos, SpeechClarity, AirPlay, and Google Cast.
REL Acoustics Planar PL-2 On-Wall Subwoofer White Lifestyle REL Acoustics Planar PL-2 On-Wall Subwoofer White Lifestyle
Can REL’s on-wall Planar PL-1 and PL-2 subwoofers deliver serious bass without putting a big box on the floor?
Esoteric N-05XE Network DAC Preamplifier Esoteric N-05XE Network DAC Preamplifier
At $13,000, the Esoteric N-05XE combines streaming, DAC, preamp, and headphone amp duties into a Tokyo-built hub that impressed at AXPONA 2026.
IFi Zen Air Blue 2 IFi Zen Air Blue 2
At $129, the iFi Audio ZEN Air Blue 2 adds aptX Lossless Bluetooth streaming to any amp or speakers, making it ideal for upgrading...
Bumpboxx BB-777 Boombox Lifestyle Carry on Shoulder Bumpboxx BB-777 Boombox Lifestyle Carry on Shoulder
Is the Bumpboxx BB-777 the ultimate all-format boombox? AM/FM, Dual cassette, CD, Bluetooth, USB and 270W output for $649?
Mother's Day Tech Gift Ideas 2026
Upgrade Mom's audio experiences this Mother's Day with gift ideas she'll absolutely love -- and you might too.
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
THX opens Shenzhen and Taipei labs for HDR10+ and Eclipsa Audio certification, expanding testing where most AV gear is built.
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
At $219, Cleer ARC 5 open ear earbuds add THX Spatial Audio, Dolby Atmos, Snapdragon Sound, aptX Lossless, a touchscreen smart case, and up...
LG announces pricing and availability for its 2026 OLED evo G6 and C6 TVs, featuring brighter panels, new processing, and enhanced gaming performance.
ASUS launches the ROG Cetra Open Wireless gaming earbuds with cross platform support for PC, Mac, PlayStation, Switch, iOS, and Android. Are open earbuds...
Exclusive Videos
Find out what the Focal Mu-so Hekla all-in-one speaker can actually do, and why the company doesn't want to call it a soundbar.
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
