Cambridge Audio CXN100 SE Network Streamer Debuts with HDMI eARC and New Black Finish
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
2026 Cambridge Audio CXN100 SE Music Streamer Black
Cambridge Audio isn’t reinventing the wheel with the CXN100 SE, it’s merely tightening the bolts where it actually matters.
The new CXN100 SE keeps the same core platform, DAC architecture, and sonic performance that made the original CXN100 one of the more credible network streamers under $1,000, but adds something the category has been slow to embrace: HDMI eARC. That single addition turns it from a pure music component into a far more useful hub for modern systems, letting your TV feed directly into your hi-fi without extra boxes or workarounds.
Just as important, Cambridge isn’t messing with the part that already works. The StreamMagic app remains one of the more stable and genuinely usable control platforms in this space, with native support for TIDAL Connect, Qobuz Connect, and Spotify Connect, which means you’re not locked into a clunky proprietary interface when you just want to press play and get on with your life.
CXN100 SE Adds HDMI eARC for TV Audio Integration
HDMI eARC (and ARC) allows the CXN100 SE to receive digital audio from your TV — including sound from built-in apps, gaming consoles, and any devices connected to the TV itself. Setup is straightforward: connect a single HDMI cable between the TV’s eARC port and the CXN100 SE. From there, the streamer handles TV audio just like any other source, passing it along to your hi-fi system, powered speakers, or AV receiver without additional boxes or signal juggling.
cxn100se-hdmi-arc
Beyond the addition of HDMI eARC and ARC, the CXN100 SE otherwise retains the full feature set of the original CXN100, including:
StreamMagic: The CXN100 SE continues to use Cambridge Audio’s fourth generation StreamMagic platform, available on iOS and Android.
Streaming Support: Services include Spotify Connect, TIDAL Connect, Qobuz Connect, Amazon Music, Deezer, and Internet radio. The CXN100 SE remains Roon Ready and also supports AirPlay 2, Google Cast, and Bluetooth. MQA support is retained as well, although we are hard pressed to find too many people who are still using it now that TIDAL no longer supports it.
Wired Connectivity: In addition to HDMI, inputs include USB, coaxial, and TOSLINK digital connections, while outputs are provided via balanced XLR and unbalanced RCA. That range of digital inputs also makes the CXN100 SE a practical hub for legacy sources; if you’re running an older CD player or transport, you can upgrade the DAC section here and simplify your system without stacking more boxes.
cambridge-audio-cxn100-se-black-rear
DAC: Digital audio support is comprehensive across all inputs. TOSLINK optical handles 16 and 24-bit PCM from 32 to 96 kHz along with DoP64, while S/PDIF coaxial extends support up to 24-bit/192 kHz PCM with DoP64. Local USB media and USB audio inputs both support PCM up to 32-bit/768 kHz and DSD up to DSD512, and UPnP streaming reaches the same 32-bit/768 kHz ceiling. At the core, the ESS ES9028Q2M SABRE32 Reference DAC anchors the design, delivering low distortion, strong timing, and a wide dynamic range.
EQ: A 7 band equalizer allows users to fine tune the sound to suit their preferences and room acoustics.
Display: A large 4.76-inch high-resolution color display shows album artwork, playback information, and selectable VU meters, keeping the experience focused, simple, and immersive.
Design and Engineering: The CXN100 SE is designed, engineered, and tuned by ear at Cambridge Audio’s London office and live music venue, Melomania
Comparison
cxn100-cxn100se-exn100
Cambridge Audio ModelCXN100 / CXN100 SEEXN100
Product Type Network StreamerNetwork Streamer
Price$1,099$1,799
Stream Magic Gen 4 PlatformYesYes
Display Screen4.76″ IPS TFT
1280 x 569
4.76″ IPS TFT
1280 x 720
DAC ESS ES9028Q2MESS ES9028Q2M (supported by different op amps and analog output stage for improved clarity over the CXN100 or CXN100 SE)
HDMI eARC (ARC)Only SE modelYes
USB Audio InputYes – Type B with USB Audio 2.0 Support1 x USB 2.0
Digital Audio InputsUSB Drive, Bluetooth (5.1), S/PDIF Coaxial, TOSLINK OpticalUSB Drive, Bluetooth (5.1), S/PDIF Coaxial, TOSLINK Optical
Digital Audio OutputsS/PDIF Coaxial and TOSLINK OpticalS/PDIF Coaxial and TOSLINK Optical
Analog Audio OutputsBalanced XLR and unbalanced RCA analogBalanced XLR and unbalanced RCA analog
CompatibilityTOSLINK optical: 16/24-bit 32-96kHz PCM, DoP64
S/PDIF coaxial: 16/24-bit 32-192kHz PCM, DoP64
Local USB media: PCM up to 32-bit 768kHz, DSD up to x512
USB audio: PCM up to 32-bit 768kHz, DSD up to x512
UPnP: up to 32bit, 768kHz
TOSLink Optical6/24bit 32-96kHz PCM, DoP64
S/PDIF coaxial: 16/24bit 32-192kHz PCM, DoP64
PCM up to 32bit/768kHz
ConnectivityBluetooth (SBC, AAC), AirPlay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL Connect, MQA, Qobuz, Deezer, Roon Ready.Bluetooth (SBC, AptX, AptX HD), AirPlay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL Connect, MQA, Qobuz, Deezer, Roon Ready.
Audio Formats ALAC, WAV, FLAC, AIFF, DSD (x512), WMA, MP3, AAC, HE AAC, AAC+, OGG VorbisALAC, WAV, FLAC, AIFF, DSD (x512), WMA, MP3, AAC, HE AAC, AAC+, OGG Vorbis
Ethernet 10/100MbitIEEE 802.3, 10 Base-T or 100 Base-T
WI-FIIEEE 802.11 ac (2.4GHz / 5GHz)IEEE 802.11 a/b/g/n/ac (2.4GHz / 5GHz)
RS232 Yes – Service OnlyYes – Control
Power Consumption (Max)30W30W
Power Consumption (Standby)<0.5W (eco), <2W (network standby)<0.5W (eco), <2W (network standby)
Dimensions 430 x 85 x 305mm
(6.9 x 3.4 x 12.2″)
430 x 85 x 305mm
(6.9 x 3.4 x 12.2″)
Weight3.55kg
(7.83 lbs)
4.1kg
(9 lbs)
Colors Lunar Gray
Black (SE only)
Lunar Gray
cambridge-audio-cxn100-se-black-front
The Bottom Line
The Cambridge Audio CXN100 SE doesn’t try to be a reinvention; it’s a targeted upgrade that makes an already strong streamer more useful in the real world. HDMI eARC is the headline, and it matters. It turns the CXN100 SE into something closer to a system hub, letting you pull TV audio into a proper hi-fi setup without adding another box. Add the new black finish and cleaner front panel, and it’s easier to integrate visually and functionally into modern systems.
What hasn’t changed is just as important. Same DAC, same streaming platform, same performance, same $1,099 price. No internal power supply overhaul, no new DAC topology, no leap in sound quality. If you already own the CXN100, this isn’t a must-upgrade.
What’s missing? Still no analog inputs, no built-in amplification, and no real attempt to compete with all-in-one network streaming amplifiers. This remains a dedicated digital front end.
Who is it for? Anyone building a clean, modern two-channel system who wants fewer boxes and better TV integration without sacrificing sound quality. It also makes more sense now for buyers who were considering the step-up EXN100 but don’t actually need everything it offers.
cambridge-audio-cxn100-se-black-front-angle
Price & Availability
Cambridge Audio’s CXN100 SE Black (new color) will be available beginning April 2026, followed by Lunar Grey (carry over from CXN100) from June 2026 for $1,099 (£899 / €1049).
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Eversolo’s DMP-A8 Gen 2 adds AKM DAC architecture, SFP fiber networking, Wi-Fi 6, SSD storage, and Master Edition CD playback.
Can Innuos take digital streaming further? New NET switches and FLOW reclocker bring NAZARÉ tech to ZEN and STREAM systems.
Cambridge Audio Evo 300 delivers 300Wpc, Hypex NCOREx power, StreamMagic Gen 4, HDMI eARC, MM phono, and big Evo ambition.
Can MOON’s 491 Network Player/Preamplifier and 461 Power Amplifier deliver streaming, vinyl, DAC flexibility and real power in two boxes?
Can Innuos Nazaré justify its $100K+ price? We compare it to ZENith NG at AXPONA 2026 and ask who actually needs this level of...
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
