Bose QuietComfort 15 Acoustic Noise Cancelling Headphones (2009)
The Quietest, Best-performing Bose Headphones Ever
The new QuietComfort 15 headphones, introduced today, are the result of more than 30 years of continuous Bose research in noise reduction technology — research that pioneered the category and has since led to breakthroughs for military applications, pilots and consumers.
Through significant engineering advancements in active and passive noise reduction technologies, the QC 15 headphones offer more attenuation in louder environments and across a wider range of frequencies — without compromising the audio quality and comfortable fit of the acclaimed QuietComfort headphone line.
“We believe the QuietComfort 15 headphones offer a combination of benefits unmatched in the industry,” said Sean Garrett, general manager of the Bose Noise Reduction Technology Group. “We’ve applied our research in noise reduction using an integrated systems approach — an approach as proprietary as our technologies. It requires meticulous engineering to ensure all elements of the headphone work together to achieve our very ambitious performance requirements.”
New Noise Reduction Technology: Only From Bose
The QuietComfort 15 headphones debut a more sophisticated, proprietary electronics approach to active noise reduction, placing microphones both inside and outside the earcup. This electronics system better senses the sound in almost any environment and then more effectively measures, compares and reacts to the noise — instant by instant — to produce an opposing cancellation signal.
New proprietary ear cushion technology provides additional passive attenuation. It features a new mechanical design and uses materials selected for specific acoustic properties to block more noise from entering the earcup.
Through research in user testing, the QC15 headphones overcome the inherent challenge of all headphones — the performance variation from user to user, caused by the difference in head shape and size. Bose engineers used a proprietary acoustic design to deliver a consistent experience for all owners.
The resulting performance is demonstrable. The engine roar fades further away, there is less distraction at work or at home, and when music is preferred, it is heard more clearly: within a quieter environment, more definition and detail are revealed.
The QC15 headphones benefit from decades of research in on-head audio. Proprietary active equalization technology electronically tunes the frequency response of the headphones, ensuring the accurate reproduction of instruments and vocals. Bose TriPort acoustic headphone structure is incorporated, a technology featuring small ports in the earcups that dramatically increase the low-frequency output of the system. Deep low notes are delivered naturally, without a manufactured “boost” and without increasing headphone size or weight.
The QuietComfort 15 headphones feature an around-ear design that maintains the renowned comfort of its predecessors. A single earcup cable can be detached for untethered noise reduction. Once the cable is removed, listeners need only flip a switch on the right earcup to activate the proprietary technology.
A single AAA battery powers the QC15 headphones for approximately 35 hours of use. The green on/off indicator light flashes when there is approximately five hours of battery life remaining. For compact storage, the earcups rotate to a flat resting position and fit easily into the provided newly designed carrying case.
The new QuietComfort 15 Acoustic Noise Cancelling headphones replace the QuietComfort 2 Acoustic Noise Cancelling headphones. They are available in silver, beginning August 20, 2009 from Bose for the same price as their predecessor: $299.95. The QuietComfort 3 Acoustic Noise Cancelling headphones (featuring an on-ear design) are available for $349.95. Bose QuietComfort headphones are sold at select authorized Bose dealers, Bose retail stores, or toll free at 1-800-444-BOSE (2673).
FiiO FG3 Gaming Headset Lifestyle
Can FiiO’s $69 FG3 gaming headset deliver Hi-Fi dual-driver sound, virtual 7.1 surround, and browser EQ for budget gamers?
CableRated HDMI cables. CableRated HDMI cables.
A/V Furniture & Accessories
Frustrated by the unreliability of cheap cables and the empty promises of expensive ones, the founder of CalebRated just launched his own value-oriented line...
2026 Sony IER-M500 IEM Colors 2026 Sony IER-M500 IEM Colors
Sony’s $119 IER-M500 wired IEMs target musicians with secure fit, stage-grade isolation, and compact single-driver sound.
Edifier Hecate G5 MAX Wireless Gaming Headset Edifier Hecate G5 MAX Wireless Gaming Headset
Can Edifier’s $149 HECATE G5 MAX challenge Sony Pulse Elite with THX Spatial Audio+, low-latency wireless, and 305-hour battery life?
Ferrum Broen Streaming Transport under WANDLA DAC Ferrum Broen Streaming Transport under WANDLA DAC
Can Ferrum BROEN turn Volumio, SFP networking, and WANDLA integration into a serious high-end streaming transport for external DACs?
Noble Audio Iris IEMs back with tips Noble Audio Iris IEMs back with tips
Noble Audio's $699 Iris IEM combines a custom 10.2mm dynamic driver, three-layer diaphragm, Micarta housing, and modular cable connectivity.
Daily Deals
Bose acquires StreamUnlimited to build a broader connected audio platform across streaming, AI, licensing, McIntosh, and Sonus faber.
Bose QuietComfort Ultra Earbuds Gen 2 refine a classic with Bluetooth 5.4, wireless charging, better call quality, and top-tier ANC. Sony is likely to...
Apple AirPods Max 2 face the original Max and Bose QuietComfort Ultra 2 in this ANC headphone showdown. Better enough, or just safer?
At $1,998, Bose Lifestyle Ultra pairs Dolby Atmos, PhaseGuide, SpeechClarity, and a wireless subwoofer, but skips support for DTS:X.
Bose Lifestyle Ultra Wireless Speaker makes Sonos and Bluesound sweat with bigger than expected sound, AirPlay, Google Cast, Spotify Connect, and one baffling subwoofer...
Can Bose make home theater easier? The Lifestyle Ultra Soundbar and Subwoofer add Dolby Atmos, SpeechClarity, AirPlay, and Google Cast.
Bose Lifestyle Ultra Speaker debuts at $299 with AirPlay, Spotify Connect, Google Cast, TrueSpatial audio, and a clear shot at Sonos.
Our Best of 2022 Soundbar picks feature some great options from Sony, Polk, Sonos, Samsung, and Vizio for every budget.
