Dongle DACs
Fosi Audio MD3 Review: Can a $149 MagSafe DAC/Amp Fix Your Phone’s Sound?
Can a $149 MagSafe compatible DAC/amp deliver clean, neutral sound and fix the cable chaos of dongle DACs for iPhone users? The Fosi MD3 might surprise you.
Fosi Audo Portable Magnetic DAC Angle
Dongle DACs are everywhere. Scroll through Amazon or any audio retailer and you will find dozens of tiny USB DAC/amps promising better sound from your phone. Most solve one problem while creating another: a cable dangling from your handset and one more gadget rattling around in your pocket.
The Fosi Audio MD3 tries to clean up that mess in a manner that will work for some.
Priced at $149.99, this compact DAC/amp attaches directly to the back of your phone using 16 high strength N52 magnets, making it MagSafe compatible with modern iPhones. Instead of a dongle hanging off the bottom of your device, the MD3 sticks flush to the rear panel, turning the DAC into something closer to an integrated mobile audio upgrade than yet another accessory.
While affordable, it is entering one of the most crowded categories in portable audio. The difference is that very few of those competitors try to physically integrate with your phone the way the MD3 does. The question is whether the concept works in practice and more importantly, whether the sound quality justifies sticking it to the back of your phone.
Fosi Audio M3 Portable Magnetic DAC back of smartphone
Fosi Audio MD3 Specifications and Technology Explained
At the heart of the Fosi Audio MD3 is the ESS ES9039Q2M DAC, the chip responsible for converting digital data into analog sound. It’s a highly regarded converter with impressive specifications, including a 116dB signal to noise ratio and total harmonic distortion plus noise of roughly 0.00075%. The chip also supports PCM up to 384kHz/32-bit and native DSD256, so those with a library of hi-res FLAC or DSD files will have plenty of headroom.
Another advantage of the ES9039Q2M is its low power consumption, which is important in a portable device. In theory, that should allow the MD3 to deliver better sound without draining your phone’s battery as quickly as some other portable DAC/amp designs.
Amplification duties are handled by four ESS ES9063Q op amps, which together deliver up to 180mW of output at 32 ohms. That is a respectable amount of power for a compact mobile device and should be more than adequate for most in-ear monitors and an acceptable range of high-sensitivity headphones.
One of the MD3’s more unusual design choices is its MagSafe compatible magnetic backplate, which uses 16 high-strength N52 neodymium magnets. The idea is simple: instead of dangling from your phone like a traditional dongle DAC, the MD3 can snap directly onto the back of compatible iPhones, keeping the setup compact and eliminating cable clutter.
I wasn’t able to test that feature personally because I use an Android phone, but Editor in-Chief Ian White tried the MD3 with his iPhone 14 at CanJam NYC 2026 last weekend and confirmed that the magnetic attachment works as intended. It’s a clever approach that separates the MD3 from the dozens of conventional dongle DACs currently competing for attention in the portable audio space.
fosi-audio-md3-portablele-magnetic-dac-side
Design & Build Quality
Despite the budget friendly nature of the Fosi Audio MD3, the chassis is made from aluminium alloy, something you do not always see on dongle DACs priced under $200.
Even with its all metal construction, the MD3 remains extremely portable. It weighs just 50 grams (1.76 ounces) and measures 70 x 45 x 12 mm (2.76 x 1.77 x 0.47 inches), making it about as unobtrusive as a portable DAC/amp can be.
That 12 mm (0.47 inch) thickness is not accidental. According to Fosi Audio, the dimension was carefully chosen so that most headphone plugs will not lift the unit away from the back of the phone when connected. That detail is important because the MagSafe magnetic attachment relies on the MD3 sitting flush against the device.
I was also surprised to find hand stitched leather covering the rear panel. It is a small touch, but one that adds a bit of tactile refinement to an otherwise utilitarian product and likely costs Fosi Audio more than you would expect at this price point.
fosi-audio-md3-portablele-magnetic-dac-back-leather
Moving to the front of the Fosi Audio MD3, you’re greeted by a 1.28 inch circular LCD display. It doesn’t get especially bright, but visibility is perfectly adequate in most lighting conditions and the colors are surprisingly vibrant for such a small screen.
The default volume display is particularly clever. It mimics the look of a classic VU meter, giving the interface a bit of retro flair while still presenting useful information such as gain level, sample rate, and the selected digital filter.
The screen can also do more than simply display playback data. Fosi has included a selection of images and preloaded animations, including a spinning vinyl record, a cartoon dog, and even an anime character. None of it is essential to the MD3’s function as a DAC/amp, but it adds a bit of personality to a category that is usually very utilitarian.
There are even a few built-in mini games, including dice rolling, spin the bottle, and rock paper scissors, which make use of the display. I didn’t spend much time with them, but someone out there will inevitably appreciate the novelty.
Just below the screen sits what Fosi calls the Vista button, which cycles through the available images and animations.
On the right side of the MD3 are three physical buttons. From top to bottom they handle volume up, volume down, and menu or confirm, with the volume buttons also doubling as navigation controls when scrolling through the menu.
Connectivity is straightforward. The top panel features a USB Type-C port for connection to your phone or source device. The bottom panel includes a second USB-C port, along with both 4.4 mm Pentaconn balanced and 3.5 mm single ended headphone outputs.
That’s really all there is to it. The MD3 is a refreshingly simple device to operate.
But features and design only get you so far. The real question is how it performs where it matters most: sound quality.
fosi-audio-md3-portablele-magnetic-dac-black-silver
Listening & Headphone Synergy
To evaluate the sonic performance of the Fosi Audio MD3, I connected it to both my mobile phone and laptop, feeding it a mix of Spotify streams and hi res FLAC files.
On the output side, I rotated through a range of over-ear headphones to see how well the MD3 would pair with different designs and whether it could handle more demanding loads. Headphones including the HiFiMAN HE1000 Unveiled, Thieaudio Cypher, Sendy Audio Egret, and Beyerdynamic DT880 Edition 600 Ohm were plugged in to see how far the little DAC/amp could be pushed.
After a few months of listening, my overall impression of the MD3’s sound quality is fairly straightforward. It presents music with a neutral, largely coloration free tonal balance that walks a careful line between analytical clarity and musical engagement. Fosi Audio has managed to maintain good balance across the audible spectrum without tipping into the sterile or overly clinical presentation that sometimes plagues affordable DAC/amps.
fosi-audio-md3-portablele-magnetic-dac-kit
Included: Two braided USB-C to C cables, USB-C to A adapter, instruction manual
Starting with the bass, the MD3 reaches deep into the sub bass without obvious roll off and delivers satisfying texture and dynamic impact. Electronic music and drum heavy tracks carry the right sense of weight and physicality, so you never feel like the low end is being shortchanged. A good example is the infamous sub bass swell around the three and a half minute mark in Hans Zimmer and James Newton Howard’s “Why So Serious?”. Through the HiFiMAN HE1000 Unveiled, the MD3 reproduced that moment with convincing rumble and control.
The midrange maintains the same level of clarity and composure as the lower frequencies. Vocals and instruments come across with a natural timbre and a sense of intimacy when the recording calls for it. Listening to Sade’s “Smooth Operator,” the presentation placed her voice front and center with the kind of effortless smoothness that suits the track perfectly.
Up top, the treble extends cleanly with a healthy amount of sparkle, but without drifting into sharpness or glare that could lead to listening fatigue. “La Lune” by L’Impératrice sounded particularly engaging through the Thieaudio Cypher, with the delicate triangle strikes rendered clearly and with impressive nuance despite their relatively low level in the mix.
Overall, the MD3 paired well with most of the headphones in my collection, largely thanks to its neutral and balanced sound signature. In practice, that means any reasonably well tuned pair of headphones will likely perform well with the little Fosi.
There are limits, however. Extremely power hungry headphones such as the Modhouse Tungsten or HiFiMAN HE6se V2 are simply asking too much of a compact device like this. While the MD3 could push the HE6se V2 to my preferred listening level of around 65 dB, the bass became noticeably thin and some of the finer details were lost. Headphones with very high impedance or low sensitivity typically need several watts of power to perform at their best, which is well beyond the intended use case of a portable DAC/amp like the MD3.
fosi-audio-md3-portablele-magnetic-dac-ports
The Bottom Line
The Fosi Audio MD3 takes a different approach in a category crowded with tiny USB dongle DACs. Instead of dangling from your phone with a short cable, the $149.99 MD3 magnetically attaches to the back of compatible iPhones, turning it into a compact all in one mobile audio upgrade. Combined with a capable ESS ES9039Q2M DAC, clean amplification, and a neutral, well balanced sound signature, the MD3 delivers a natural listening experience that pairs well with the vast majority of headphones.
It also stands out with thoughtful design touches such as an aluminium chassis, hand stitched leather backing, and a customizable circular display that adds some personality to what is usually a very utilitarian product category.
Where the MD3 faces pressure is on value and raw power. Competitors like the HiBy W4 offer more output power and Bluetooth connectivity for roughly $50 less, which may matter more to some listeners than magnetic convenience. And while the MD3 has more than enough power for most headphones and IEMs, it will struggle with extremely demanding models that require several watts to perform at their best.
For iPhone users who want a cleaner, cable free portable setup, the MD3 solves a problem that few dongle DACs even attempt to address. If MagSafe integration and tidy pocket ergonomics matter to you, the MD3 is a clever and enjoyable mobile audio companion. If raw power and features are the priority, there are stronger values elsewhere.
Pros:
  • MagSafe compatible design attaches directly to the back of newer iPhones
  • Aluminium chassis with hand stitched leather gives it a premium feel
  • Interactive circular LCD display with customizable visuals and animations
  • Neutral yet musical sound signature that works well with most headphones
  • Enough power for the vast majority of IEMs and portable headphones
Cons:
  • $149.99 price feels slightly high compared to competing dongle DACs
  • Less output power and fewer features than some cheaper rivals like the HiBy W4
  • Not suitable for extremely power hungry headphones like HE6 class designs
For more information: fosiaudio.com
Fosi Audio debuts the C3 AI Gaming Sound Card and MD3 Magnetic DAC/Amp at CanJam NYC 2026, expanding into gaming audio and portable hi-fi.
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Dongle DACs
Can the $199 FiiO BTR17 still compete in 2026? With dual ESS DACs, THX power, and LDAC support, this pocket DAC/amp aims close to...
Dongle DACs
Is the Astell&Kern HC5 worth its premium price, or are you just paying for the logo on a balanced portable USB DAC?
Can Fosi Audio’s $199 K7 deliver truly audiophile-grade sound with balanced power, EQ, and broad connectivity—or does value finally meet its limits?
Fosi Audio’s $229.99 BT20A MAX packs a TI TPA3255 amp, real 2.1 power, and unusually robust Bluetooth codec support—does it deliver where it counts?
Dongle DACs
Fosi Audio debuts the MD3 Magnetic and DS3 portable DAC/headphone amplifiers at CanJam Dubai 2026, focusing on compact design, XMOS processing, and IEM-friendly performance—not...
Dongle DACs
Can a $349 dongle DAC really deliver true tube sound and serious power? The ONIX Beta Xi2 aims to prove portable tubes aren’t a...
