XGIMI Horizon 20 Series 4K Home Theater Projectors: Pre-order 30% Off
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
XGIMI Horizon 20 Series Projectors 2025
XGIMI is expanding beyond lifestyle and portable projectors into serious home theater territory with the debut of its new HORIZON 20 Series at IFA 2025 in Berlin, signaling a push toward enthusiast-grade performance.
XGIMI calls the HORIZON 20 Series its most advanced home projectors yet, touting cinema-level brightness, faster gaming chops, and more customization knobs to twist. The lineup includes the Horizon S, Horizon Ultra, and Horizon Max—familiar shells with upgraded guts powered by MediaTek. In short: same design language, bigger bragging rights.
mediatek-9679-soc
xgimi-horizon-20-lenses
Advanced Lenses and Laser Technology Explained
The flagship HORIZON 20 Max pushes 5,700 ISO lumens through its new X-Master Red Ring Lens and RGB triple-laser engine. Translation: it’s built for people who refuse to draw the curtains and still expect daylight-proof cinematic visuals.
Setup
The HORIZON 20 Series features XGIMI’s ISA 5.0 (Intelligent Screen Adaptation) system, offering Autofocus, uninterrupted Keystone Correction, Obstacle Avoidance, Intelligent Screen Alignment, Wall Color Adaptation, and Intelligent Eye Protection for a seamless setup experience.
HDR & Picture Enhancements
All models in the line-up (HORIZON 20, HORIZON 20 Pro, HORIZON 20 Max) support Dolby Vision, HDR10+, Filmmaker Mode, IMAX Enhanced, and Lens Shift with optical zoom functions.
Google TV Support
The HORIZON 20 Series includes Google TV, providing access to thousands of streaming apps and native Netflix support. Built-in Wi-Fi 6 enables reliable wireless connectivity.
Gaming
The HORIZON 20 Series offers gaming support with 1ms input lag, 240Hz refresh rate, and VRR. It also introduces a partnership with Assassin’s Creed: Shadows to provide an integrated gaming experience.
Audio Support
The HORIZON 20 Series features Harman/Kardon speaker drivers tuned for balanced sound with low distortion and clear dynamics. Supported audio formats include Dolby Audio, DTS-HD, and others.
XGIMI Horizon 20 Series Projector Front Angle
Comparison
Pro Tip: The main differences between the HORIZON 20, 20 Pro, and 20 Max are brightness levels and price; all other features remain consistent across the series.
Horizon 20Horizon 20 ProHorizon 20 MAX
MSRP$1,699$2,499$2,999
Display TechnologyDLPDLPDLP
Imaging Chip0.47 DMD0.47 DMD0.47 DMD
Light SourceRGB Triple LaserRGB Triple LaserRGB Triple Laser
LensHigh Light Transmission Coated LensHigh Light Transmission Coated LensHigh Light Transmission Coated Lens
Projection MethodFront, Rear, Front Ceiling, Rear CeilingFront, Rear, Front Ceiling, Rear CeilingFront, Rear, Front Ceiling, Rear Ceiling
Image Size40” – 300”40” – 300”40” – 300”
Aspect Ratio16:916:916:9
Resolution (via Pixel Shifting)4K UHD (3840 x 2160 pixels)4K UHD (3840 x 2160 pixels)4K UHD (3840 x 2160 pixels)
Brightness 3200 ISO Lumens4100 ISO Lumens5700 ISO Lumens
Contrast Ratio20,000:1 (DBLE On)20,000:1 (DBLE On)20,000:1 (DBLE On)
Color GamutBT.2020 110%BT.2020 110%BT.2020 110%
HDR SupportHDR10, Dolby VisionHDR10, Dolby VisionHDR10+, Dolby Vision
IMAX EnhancedYesYesYes
Gaming Support(Game Mode, VRR on, AK off)
Latency
1ms at 1080P@240Hz
2.2ms at 1080P@120Hz
3ms at 4K @60Hz
Latency
1ms at 1080P@240Hz
3ms at 4K @60Hz
Latency
1ms at 1080P@240Hz
3ms at 4K @60Hz
MEMCYesYesYes
3D Viewing OptionYesYesYes
Eye ProtectionYesYesYes
Setup SystemUninterrupted Auto Keystone
Auto Focus
Intelligent Obstacle Avoidance
Auto Focus
Auto Focus
Les ShiftV±120%/H±45%V±120%/H±45%V±120%/H±45%
Optical ZoomYesYesYes
Digital ZoomYesYesYes
Throw Ratio1.2-1.5:11.2-1.5:11.2-1.5:1
System CPUMT9679MT9679MT9679
GPUMali-G52Mali-G52Mali-G52
RAM4GB4GB4GB
Storage128GB128GB128GB
Google TVYesYesYes
Fast BootYes (STR)Yes (STR)Yes (STR)
Mirroring DisplayDLNA/GoogleCastDLNA/GoogleCastDLNA/GoogleCast
Audio SupportDTS-Virtual:X
DTS-HD
Dolby Audio
Dolby Digital (DD)
Dolby Digital Plus (DD+)
DTS-Virtual:X
DTS-HD
Dolby Audio
Dolby Digital (DD)
DTS-Virtual:X
DTS-HD
Dolby Audio
Dolby Digital (DD)
Audio System2 x 12W Harman/Kardon2 x 12W Harman/Kardon2 x 12W Harman/Kardon
WiFiWiFi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/ax10WiFi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/ax10WiFi 6 Dual-band 2.4/5GHz, 802.11a/b/g/n/ac/ax10
BluetoothVer 5.2Ver 5.2Ver 5.2
Wired Connectivity (Inputs)DC × 1
HDMI × 2 (HDMI1 supports eARC)
1 x USB 3.0
1 x  USB 2.0
DC × 1
1 x USB 3.0
1 x  USB 2.0
DC × 1
1 x USB 3.0
1 x  USB 2.0
Wired Connectivity (Outputs)Optical × 1
Audio × 1
Optical × 1
Audio × 1
Optical × 1
Audio × 1
Noise Level≤28dB@1m12≤28dB@1m12≤28dB@1m12
PowerAC100-240V, 50/60HzAC200-240V, 50HzAC100-240V, 50/60Hz
Dimensions (HWD)249 × 298 × 190 mm
9.8 × 11.7 × 7.5 In
249 × 298 × 190 mm
9.8 × 11.7 × 7.5
249 × 298 × 190 mm
9.8 × 11.7 × 7.5
Weight4.8 kg / 10.6 lbs4.9 kg / 10.8 lbs5.4 kg / 11.9 lbs
What’s in the BoxPower Plug x 1
Manual x 1
Warranty Card x 1
Backlight Bluetooth Remote Control x1
AAA Batteries x2
Power Plug x 1
Manual x 1
Warranty Card x 1
AAA Batteries x2
Power Plug x 1
Manual x 1
Warranty Card x 1
AAA Batteries x2
XGIMI Horizon 20 Series connections
The Bottom Line
Since its founding in 2013, XGIMI has grown from a small startup into a notable player in the video projector market, thanks to partnerships with Google, Harman/Kardon, and Texas Instruments. The HORIZON 20 Series builds on this track record, offering versatile features and performance that signal a strategic move into dedicated home theater projectors for both enthusiasts and general users.
Price & Availability
The XGIMI Horizon 20 Series projectors are available for pre-order now for 30% off through XGIMI until October 14th, 2025.
Grell OAE2 Open-Back Headphones Flat
Axel Grell’s OAE2 open-back headphones debut at CanJam NYC 2026 with a speaker-like soundstage concept. Can the $599 design change how we listen to...
Grado Labs Signature S550 Open-back Headphones Lifestyle Woman Grado Labs Signature S550 Open-back Headphones Lifestyle Woman
At $995, Grado's most affordable Signature Series open-back headphones feature new S2 drivers and cushion design with a Brazilian Walnut housing. Is this the...
Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
iFi GO Link 2 Dongle DAC connected to laptops iFi GO Link 2 Dongle DAC connected to laptops
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Q Acoustics Easyfit In-ceiling Speakers Lifestyle Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Does Optoma's $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
BenQ’s W5850 targets serious home theater enthusiasts with laser brightness, factory calibration, and film-first features—but at a higher price and with notable omissions.
XGIMI’s TITAN Noir Max aims to bridge lifestyle design and premium projection, but pricing, final specs, and Q1 2026 availability will determine where it...
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Projectors & Screens
Sony's VPL-VW6100ES BRAVIA Projector 8 offers stunning big screen home theater performance at a hefty price.
Podcasts
Find out who won and what happened at the 2025 UST Projector Showdown where 8 projectors were compared side-by-side.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Priced from under $2,700 to $6,000, this year's top eight UST projectors faced off against each other for the title of Best UST Projector...
