Triangle Unveils CAPELLA 2 Wireless Speakers with Signature Horn Tweeters
The Triangle CAPELLA 2 delivers flexible home audio with WiSA wireless, Bluetooth, and multiple wired inputs, including a new subwoofer output, combining French design with high-performance powered speakers.
Triangle Capella 2 Wireless Speakers in Black Lifestyle
Triangle Hi-Fi has expanded its wireless lineup with the CAPELLA 2, the successor to the original CAPELLA powered speakers. Designed and built in France, the CAPELLA 2 continues the brand’s use of horn tweeters and integrated amplification, offering a straightforward wireless hi-fi solution for modern systems.
The CAPELLA 2 builds on the strengths of the original CAPELLA system with several key updates. The new Stereo Hub 2 now features a more powerful ARM Cortex-A53 processor, a dedicated subwoofer output, and an Ethernet port for improved network stability.
Like the original, the CAPELLA 2 system consists of a pair of powered wireless speakers paired with a central stereo hub and companion app for connectivity and control. Each speaker connects wirelessly to the hub, requiring only a single AC power cable per speaker.
Triangle CAPELLA 2 Wireless Speakers: Design, Drivers, and Performance
triangle-capella-2-tweeter
Tweeter: The CAPELLA 2 speakers use Triangle’s TZ2530MG horn tweeters, a signature design element for the brand. The optimized phase plug at the horn’s output improves off-axis sound dispersion, while the 25mm magnesium-aluminum alloy dome delivers accurate high-frequency detail and extended top-end response.
triangle-capella-2-woofer
Midwoofer: The CAPELLA 2 features a 165mm (6.5″) mid-woofer with Triangle’s proprietary natural cellulose pulp diaphragm, a hallmark of the brand’s acoustic design. The driver includes a ventilated aluminum chassis and a hybrid half-roll suspension made of foam and treated rubber, enabling natural vocal reproduction, detailed instrument presentation, and controlled low-end response.
DVAS: The CAPELLA 2 continues to use Triangle’s DVAS (Driver Vibration Absorption System) to enhance driver performance and cabinet stability. This system uses high-density perforated bracing bonded to each driver with a damping layer, reinforcing the driver-to-cabinet connection. High-density DVA foam at the ends of internal reinforcements helps reduce vibration from membrane movement for cleaner sound reproduction.
Downfiring Vents: The cabinet sits on an elevated aluminum base that allows unobstructed airflow around the downfiring bass reflex port. Low frequencies are evenly dispersed around the base, while midrange frequencies project from the front.
The flared dual-ended port design minimizes airflow noise and reduces harmonic distortion. This configuration supports flexible placement — whether the speakers are in open space or near a wall — without sacrificing performance.
triangle-capella-2-wireless-speakers-oak-lifestyle
Cabinet Design: The CAPELLA 2’s rounded cabinet edges serve both aesthetic and acoustic purposes. The front panel supports the drivers and aids in diffracting sound waves, helping to minimize distortion. Rubber rings around the tweeter and mid-woofer feature an angular, geometric structure to reduce edge effects. The curved edges also deflect reflected waves outward, lowering unwanted reflections and enhancing overall clarity.
CAPELLA 2 Amplification, DSP, and Digital Crossover
Amplification & DSP: The CAPELLA 2 active speakers deliver a total of 2 × 100 watts, with each driver powered by its own 50-watt amplifier and dedicated digital-to-analog converter. A built-in DSP continuously monitors driver performance, optimizing output and ensuring consistent response across the full frequency range.
Crossover: The system uses a digitally controlled crossover designed for linear frequency response. This results in tighter, more controlled bass, a clearer and balanced soundstage, and improved vocal detail, allowing the speakers to maintain precision and clarity across the spectrum.
CAPELLA 2 Stereo Hub Version 2
triangle-capella-2-hub-rear-angle
Processor & Connectivity: The Stereo Hub 2 features an upgraded ARM Cortex-A53 processor for faster, more reliable performance. It includes an Ethernet port for stable network connections, supporting seamless streaming and multi-room setups.
Subwoofer Output: A dedicated subwoofer output has been added, allowing easy integration of a separate low-frequency module to extend bass performance.
System Integration: Like the original hub, the Stereo Hub 2 connects wirelessly to both CAPELLA 2 speakers, with a single AC power cable required per speaker, and is controlled via the companion app for simplified system management.
triangle-capella-2-hub-rear-white
Connectivity: The CAPELLA 2 supports a range of wireless inputs, including Bluetooth and Wi-Fi, along with AirPlay, Google Chromecast, and Roon for versatile streaming options.
Wired Inputs: Physical connections include HDMI ARC, optical, USB, RCA, and 3.5mm analog stereo. The system also features a dedicated subwoofer output for easy integration of an external bass module.
WiSA Technology
Wireless Speaker Connection: Like the original CAPELLA, the CAPELLA 2 uses WiSA technology to transmit audio from the Stereo Hub to the speakers. This wireless system supports high-resolution audio (24-bit/96kHz) with virtually no latency. WiSA also allows flexible speaker placement, as no physical cables are required between the hub and the speakers.
The CAPELLA App
triangle-capella-2-app
For ease of setup and control, a free CAPELLA App (iOS/Android) is provided. This provides users with Room EQ and Manual EQ setting options, as well as working with the Stereo Hub for setup and input selection.
Automatic Calibration
Triangle Capella 2 Wireless Speakers Room EQ
CAPELLA App & Automatic Calibration: The CAPELLA App includes Automatic Calibration Technology, which adjusts the system to match the acoustic characteristics of your listening space. This step helps ensure optimal performance from the CAPELLA 2 in any environment.
Pro Tip: Calibration works with Apple devices using the built-in microphone. Android phones or tablets require the optional Zen microphone ($149) for the same functionality.
Comparison
triangle-capella-2-speaker-comparison
Triangle ModelCAPELLA 2CAPELLABorea BR03  BT (aka BRO3 Connect)
Price (US)US pricing not confirmed$2,999 $750
Speaker TypeActive, Bi-Ampfied, Bass Reflex (down-firing port)Active, Bi-Ampfied, Bass Reflex (down-firing port)Active, Bass Reflex (rear ports)
Power Output2 x 100 watts (4 x 50 watts)2 x 100 watts (4 x 50 watts)2 x 60 Watts RMS Class D
Tweeter 1 x Horn tweeter with 25mm magnesium alloy dome1 x Horn tweeter with 25mm magnesium alloy dome1 x 25mm EFS silk dome tweeter
Mid-Woofer1 x 16.5 cm natural cellulose pulp membrane1 x 16 cm Mid-woofer half-roll suspension with natural cellulose pulp membrane1 x 16cm cellulose pulp Midwoofer
Frequency Response (+/- 3db )42 Hz – 22 kHz 42 Hz – 22 kHz 47 Hz – 22 kHz
Stereo HubYesYesNo
Wireless ConnectivityWi-Fi, WiSA, BluetoothWi-Fi, WiSA, BluetoothBluetooth
Wired Connectivity1 x HDMI (ARC/eARC)
1 x USB-A
3 x Optical / SPDIF
1 x Coaxial
1 x RCA Stereo
1 x Aux / Optical 3.5mm
1 x Subwoofer Output
1 x HDMI (ARC)
1 x USB-B
3 x Optical / SPDIF
1 x Coaxial
1 x RCA Stereo
1 x HDMI ARC (Newly Added)
1 x USB-B: PC / MAC (New Added)
1 x OPTICAL
1 x  COAX
1  RCA / 3.5mm jack
1 x PHONO Turntable
t x Subwoofer Output
BluetoothYesYes Yes
Apple AirplayYesYesNo
ChromecastYesYesNo
RoonYesYesNo
Sampling FrequenciesAnalog sources: up to 24-bit/96kHz
Bluetooth: up to 16 bit/192 kHz
WiSA: 24-bit/96kHz, latency 2.6 ms
Digital sources: up to 24bit/192kHz
Bluetooth: up to 16- bit/48 kHz
Bluetooth HD:16- bit/44 kHz
Audio Format SupportAPE
FLAC
WMA
WAV
Apple Lossless (ALAC)
AAC
AAC-LC
HE-AAC
HE-AAC v2
MP3
APE
FLAC
WMA
WAV
AAC
AAC-LC
HE-AAC
HE-AAC v2
MP3
EPA
WMA
WAV
MP3
Capella App (Setup and Control)YesYesNo
Automatic CalibrationYesYesNo
Speaker Dimensions (each)Width: 200mm (8 in)
Height: 380 mm (15 in)
Depth: 315 mm (12.4 in)
Width: 200mm (8 in)
Width: 206 mm (8.1 in)
Height: 360 mm (14.2 in)
Depth: 314 mm (12.4 in)
Speaker Weight (each) 8.5 kg (18.75 lbs)8.5 kg (18.75  lbs)Master speaker net weight: 7.3kg (16 lbs)
Slave speaker net weight: 6.6kg (14.6 lbs)
Stereo Hub DimensionsWidth: 70mm (2.8 in)
Height: 45 mm (1.77 in)
Depth: 170 mm (6.7 in)
Depth: 100 mm (4 in)
Not Applicable
Stereo Hub Weight0.8 kg (1.76 lbs)0.5 kg (approx 1 lb)Not Applicable
Finish OptionsSpace Black
Oak
English Green
Space White
Astral Blue
Black Star
Brown Nebula
Space White
Astral Blue
Black Ash
Light Oak
Light Oak Blue
Oak Green
Cream
Included Accessories1 x Wi-Fi antenna for Stereo Hub
2 x Magnetic protective grilles
for speakers.
1 x Power cable for Stereo Hub (3 adapters supplied EU, UK, USA).
2 x Power cables for speakers.
1 x Aluminium radio frequency remote control
2 x AAA batteries for the remote control.
1 x Allen key for remote control battery change.
1 x Registration coupon.
1 x Speaker cleaning cloth.
for speakers.
1 x 3-meter speaker cable to connect the speakers together.
1 x  Power cable
1 x Radio frequency remote control
2 x Magnetic fabric protection grid
8x Rubber pad
Triangle Capella 2 Wireless Speaker Finishes and Colors
The Bottom Line
The Triangle CAPELLA 2 builds on the original with practical upgrades like a subwoofer outputEthernet connectivity, and enhanced hub features, making it a more versatile compact wireless system. While a dedicated phono input would have improved turntable integration, the CAPELLA 2 remains a strong option for those seeking French-designed, high-performance wireless speakers.
It competes in a crowded sub-$2,000 market that includes Audioengine, ELAC, Kanto Audio, PSB, and KEF, but Triangle’s reputation and design appeal give it an edge for buyers willing to invest in quality.
Price & Availability
The CAPELLA 2 system has been previewed worldwide at the Warsaw Hi-Fi Show held on October 25 and 26, 2025. Product availability is expected to begin early in 2026. The European price is expected to €2499 – US pricing has not been announced.
Kanto Audio Tuk Grand Lifestyle
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV. LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV.
LG’s Micro RGB evo TVs aim to boost brightness and color beyond OLED, but can they justify a premium over models like the G6...
2026 LG W6 Wallpaper TV Lifestyle Angle 2026 LG W6 Wallpaper TV Lifestyle Angle
LG’s 2026 OLED evo W6 Wallpaper TVs bring ultra thin design, Zero Connect, and 165Hz support in either 77-inch or 83-inch screen sizes.
Sennheiser HD 480 Pro Headphones in the Studio Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
At $329, WiiM Ultra is the company's top-of-the-line digital music streamer which adds a touchscreen, HDMI ARC and a subwoofer out.
Dutch & Dutch’s new 6c wireless speaker brings compact design, BACCH3D audio, RoomMatching, and high-end engineering to a smaller, more flexible footprint.
Creative Labs reinvents the iconic Sound Blaster with the Re:Imagine, a modular high-resolution audio hub combining PC, gaming, and pro audio control with open...
