CD Players
Shanling CT90 CD Transport Adds High-Res Bluetooth Streaming with aptX HD & LDAC
Shanling’s $999 CT90 CD transport targets modern CD collectors with digital-only outputs and Bluetooth, but skips SACD, analog outs, and compact rack-friendly design.
Shanling CT90 CD Transport Silver Angle Large
Streaming may dominate the way most people listen to music in 2026, but physical media refuses to go quietly into the cloud. Vinyl is still spinning on turntables everywhere, and CDs—once written off as obsolete—have been slowly clawing back relevance with listeners who value ownership, reliability, and sound quality without subscription fatigue.
Shanling has been one of the more aggressive players in that resurgence, rolling out a steady stream of CD-focused products across multiple categories. In just the past few years, the company has launched portable CD players, full-size players, and dedicated transports including the ECZero AKM, CD80 II, EC Zero T, CR60, and others—clearly betting that discs still matter to a meaningful slice of the hi-fi audience. That strategy continues with the newly announced $999.99 Shanling CT90 CD Transport, distributed in the U.S. by Forte Distribution.
What makes the CT90 especially interesting isn’t just another spin on disc playback, but Shanling’s decision to blur the line between old-school and modern by adding Bluetooth connectivity with high-resolution codec support. Including Bluetooth on a CD transport—particularly with aptX HD and LDAC—signals that Shanling understands how people actually listen today: sometimes wired, sometimes wireless, and often somewhere in between.
Shanling CT90 Overview
shanling-ct90-cd-transport-black-angle
The Shanling CT90 CD Transport represents a clear step up from Shanling’s earlier Shanling ET3 ($899 at Amazon), bringing with it a revised digital architecture, expanded digital output options, and a more modern hi-fi design language. The industrial aesthetic takes cues from the Shanling SCD3.3 SACD player ($3,899), highlighted by a large rectangular front-panel display that makes playback information and system status easy to see from across the room.
Where the ET3 leaned heavily into network features—offering Wi-Fi, AirPlay, and DLNA alongside CD playback and USB support—the CT90 takes a more focused approach. It retains Bluetooth connectivity, including high-resolution codec support, but drops AirPlay and DLNA, positioning the CT90 squarely as a disc-first CD transport with modern wireless flexibility rather than a full network streamer.
The interest in compact discs from audiophiles and casual listeners alike is driving innovators like Shanling to create new products that bring out the best in digital physical media,” said Roger Fortier, VP and Director of Sales, Forte Distribution, U.S. distributor of Shanling Electronics. “The CT90 is the perfect match for high-performance DACs that maximize the pure, distortion-free digital signal streaming from the transport.”
Similar to the Shanling SCD3.3, the Shanling CT90 uses a top-loading CD mechanism and is clearly aimed at higher-end audio systems than Shanling’s more entry-level Shanling ET3. At its core is the widely used SAA7824 servo chip, an industry-standard solution responsible for disc decoding accuracy and precise control of data retrieval—critical factors for minimizing read errors and jitter before the signal ever reaches an external DAC.
shanling-ct90-cd-transport-black-front
shanling-ct90-cd-transport-black-rear
True to its role as a dedicated transport, the CT90 is strictly digital-only and omits any internal DAC or analog output stage. Digital connectivity includes dual USB ports—one for playback of high-resolution files from USB storage via Shanling’s Eddict app (iOS and Android), and another dedicated USB digital output for direct connection to a computer-based audio system.
Additional outputs include I²S, coaxial, optical, and AES/EBU, with both I²S and SPDIF/AES paths benefiting from dedicated upsampling circuitry. The result is a disc-first transport designed to feed high-performance external DACs with the cleanest possible digital signal.
The CT90 handles standard CD formats, including CD-R and CD-RW playback, as well as MQA-CD and Bluetooth (LDAC, aptX HD, aptX, and AAC).
Comparison
shanling-ct90-et3
Shanling ModelCT90 (2025)ET3 (2024)
Product TypeCD Transport CD TRansport
Price$999$899
Exterior DesignModern Shanling Hi-Fi design inspired by SCD3.3CNC-machined metal body
Servo and Disc DrivePhilips SAA7824 servo and DA11 disc drivePhilips SAA7824 servo & Sanyo HD850 Laser
Loading MechanismTop-loading with puck and tiltable coverTop Loading
Disc Format SupportCD, CD-R, CD-RW, and MQA-CDCD, CD-R, CD-RW, and MQA-CD
UpsamplingDedicated upsampling circuit (not active on USB output)CT7302CL Upsampling chipAll-to-DSD or All-to-PCM Upsampling function
Physical Outputs 1 x I2S output with FPGA and 10 selectable modes
2 x AES/EBU outputs
1 x Coaxial
1 x Optical SPDIF
1 x USB Audio output
I2S output
1 x AES output
1 x Coaxial
1 x Optical SPDIF
Physical Inputs1 x Clock input for external 44.1 kHz / 10 MHz master clock
1 x  USB input for use as a USB digital transport –  USB drive playback (controlled via Eddict player)
WiFiNo2.4G/5G
AirPlayNoYes
DLNANoYes
Bluetooth Bluetooth with LDAC, aptX HD, aptX, AACBluetooth 5.0  with LDAC, AAC, and SBC Codec Support
Power SupplyLinear power supply with 30W transformer15W
Front Display 4.8″ elongated display (294 x 1024)IPS 320 x 290
Onboard ControlsHardware buttons and control wheelHardware buttons and control wheel
I2S Output Sampling RatesPCM up to 768 kHz
DSD512 Native
PCM 768kHz / 32-bit,
DSD 512
SPDIF / AES OutputPCM up to 192 kHz
DSD64 DoP
PCM 192 kHz / 32-bit
DSD 64
USB Outputup to PCM 768kHz / 32-bit
DSD 512 (no upsampling)
DSD 512
Dimensions (WDH)280 x 230 x 91 mm188 x 255 x 68mm
Weight~3.5 kg (7.72 lbs)2.5 kg
Included AccessoriesPower Cable
Remote control
CD Puck
Quick Start Guide
Power Cable
Remote control
CD Puck
Quick Start Guide
The Bottom Line
The Shanling CT90 is a $999, disc-only CD transport designed for listeners who still buy and own CDs and already have digital inputs available in their system. It offers a top-loading mechanism, a modern industrial design, multiple digital output options (USB, I²S, coaxial, optical, and AES/EBU), and Bluetooth with high-resolution codec support—an uncommon but interesting addition for a dedicated CD transport.
What it does not include is equally important. There is no built-in DAC, no analog outputs, no headphone output, and no SACD compatibility, meaning an external DAC or a preamp/receiver with digital inputs is required. The top-loading design also requires vertical clearance, which may complicate installation in racks or tight shelving. It’s also notable that Shanling supports SACD playback on higher-priced models while limiting the CT90 to CD and MQA-CD.
The CT90 is for CD collectors who want a dedicated transport with flexible digital connectivity and already own the rest of the signal chain. It’s not an all-in-one player, and it’s not designed for systems that rely solely on analog inputs.
Price & Availability
The Shanling CT90 is priced at $999 at Forte Distribution
Burchardt S400 MKIII Bookshelf Loudspeaker Natural Oak Front 2026
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Audio Note Oto SE 35 Audio Note Oto SE 35
Audio Note ignores trends again. The Oto SE 35 brings new transformers and PSU to the cult EL84 amp. Low power, big attitude. Hear...
Magico S7 2026 Loudspeaker Views Magico S7 2026 Loudspeaker Views
Magico previews the $200,000 S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Emotiva BasX TA2+ Integrated Amplifier Emotiva BasX TA2+ Integrated Amplifier
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
CD Players
Mission completes its 778 Series with the 778CDT CD transport, a practical, affordable addition that reflects the quiet return of CD playback in modern...
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Shanling’s M3 Plus, iBasso’s DX340, and Astell&Kern’s SP4000 show why DAPs still matter: better power, better sound, and a distraction-free experience no smartphone with...
DAPs
Shanling's M3 Plus portable DAP delivers a sleek design, warm sound, Android 13, and balanced output for under $500.
CD Players
Shanling’s SCD3.3 treats SACD like it never died—true DSD output, a 212-resistor R2R DAC, tube stage, and enough engineering muscle to shame most “modern”...
CD Players
Only for Varèse owners: dCS’s new Transport delivers reference-level CD and SACD playback with ultra-low vibration and ACTUS bit-perfect transmission.
CD Players
TEAC's Reference 500 Series PD-507T CD Transport is engineered for audiophiles pairing external DACs with a growing CD resurgence.
