Sennheiser Unveils CX 80U Wired Earbuds and HD 400U Headphones with USB-C Digital Audio
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Sennheiser CX 80U Wired Earbuds and HD 400U Headphones
Sennheiser isn’t chasing trends here. With the new CX 80U earphones and HD 400U headphones, the company is doing something far more practical: updating two of its most accessible wired models for a world that no longer has headphone jacks.
Both products replace the long-running CX 80S and HD 400S, swapping the 3.5mm plug for USB-C and adding integrated digital audio support. The result is a direct, low-latency signal path that works with modern phones, tablets, laptops, handheld gaming devices, and PCs—no dongles required. Both models support up to 24-bit / 96 kHz playback and are class-compliant for plug-and-play use across iOS, Android, Windows, macOS, ChromeOS, and SteamOS devices.
Sennheiser’s pitch is straightforward: wired still matters, especially for people who want consistent sound quality, zero pairing drama, and something that doesn’t need charging.
According to Christian Ern, Senior Product Manager at Sennheiser, the goal was simplicity without compromise. These are products designed to plug in, work immediately, and stay out of the way while you get on with your day—whether that’s calls, gaming, studying, or music listening.
Sennheiser HD 400U Headphones
sennheiser-hd-400u-headphones
The Sennheiser HD 400U ($99.95 at Amazon) is a closed-back, over-ear design that sticks closely to the formula that made the HD 400S popular. It’s compact, folds flat, and leans toward a bass-forward tuning that works well for everyday listening. Passive isolation helps block out background noise in shared spaces, making it a sensible option for home offices, school environments, and travel.
Sennheiser includes a detachable USB-C cable and a storage pouch, which keeps things practical rather than precious. This is not a studio headphone and doesn’t pretend to be one—it’s built for portability, durability, and predictable performance across devices.
What the HD 400U Is Doing Under the Hood
At its core, the Sennheiser HD 400U is a closed-back, over-ear dynamic headphone built for everyday listening rather than studio theatrics. The closed design keeps sound in and outside noise out, which immediately makes it more useful for shared spaces, commuting, and work environments where open-back headphones would be a liability.
The 18-ohm impedance tells you this headphone is easy to drive. Phones, laptops, tablets, and handheld gaming devices don’t have to work hard to get it loud, and there’s no requirement for an external amplifier. Pair that with a 217-gram weight, and you get something that’s comfortable enough for long sessions without feeling flimsy or toy-like.
sennheiser-hd400u-headphones-black
Sennheiser uses a 9.7mm dynamic driver, tuned to cover the full audible range from 18 Hz to 20 kHz. Translation: you’ll get usable low-end extension without exaggerated sub-bass theatrics, and clean enough treble to keep vocals and dialogue intelligible without fatigue. The low total harmonic distortion (<0.5% at 100 dB) means the sound stays composed even when you turn things up; no strident edges or obvious breakup at higher volumes.
Built for Calls, Meetings, and Everyday Use
The integrated microphone is tuned for practicality, not podcast stardom. With a 100 Hz to 10 kHz frequency range and an omnidirectional pickup pattern, it’s designed to capture your voice clearly during calls and meetings without requiring precise positioning. It won’t isolate your voice like a boom mic, but it does the job reliably for work, gaming chat, and video calls.
CX 80U Earphones
sennheiser-cx-80u-earphones
For listeners who prefer something lighter and more discreet, the Sennheiser CX 80U ($39.95 at Amazon) takes the familiar CX 80S in-ear design and gives it the same USB-C digital treatment. The tuning is balanced with a touch of low-end weight, and passive isolation does most of the work when it comes to blocking outside noise.
Three sizes of silicone ear tips are included to help with fit and comfort, whether the earphones are being used for music, calls, or gaming sessions. Like the HD 400U, the CX 80U includes an in-line remote with an integrated MEMS microphone for voice calls and meetings.
What the CX 80U Is Doing Under the Hood
The Sennheiser CX 80U is a wired, in-ear dynamic earphone designed for simplicity, isolation, and consistency across modern devices. Like its predecessor, the CX 80S, it focuses on balanced tuning with enough low-end presence to keep things engaging without smothering vocals or dialogue.
Because this is a USB-C digital earphone, traditional specs like impedance and sensitivity don’t apply in the same way they do with analog models. The digital signal is handled internally, which means volume behavior and power delivery are controlled by the source device rather than varying wildly depending on headphone jacks or dongles.
The stated 17 Hz to 20 kHz frequency response covers the full audible range, delivering usable low-end weight and clean treble without pushing into exaggerated extremes. This tuning works well for music, video, podcasts, and gaming—especially in environments where background noise would otherwise get in the way.
There’s no active noise cancelling here, and that’s intentional. The CX 80U relies on its in-ear fit to passively block outside noise. Three sizes of ear tips are included to help achieve a proper seal, which is critical for both comfort and bass response. Get the fit right, and the earphones do a respectable job of keeping distractions out without introducing digital artifacts or battery requirements.
The Bottom Line
The Sennheiser CX 80U and HD 400U aren’t designed to compete with wireless headphones. They’re built for people who want affordable, wired audio that connects directly to modern USB-C devices without adapters, apps, or batteries. For students, commuters, gamers, and anyone tired of managing dongles, Sennheiser’s USB-C update is about reliability and convenience, not trends.
Pricing & Availability
Both models are available now:
ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path finally a DAC...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Clarus Concerto MKII Power Conditioner Angle Clarus Concerto MKII Power Conditioner Angle
Clarus Concerto MKII targets noise and power stability for high-end systems, but at $12,000 it raises the question: who really needs it?
SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle
Can the SVS 3000 Micro R|Evolution deliver deep bass from dual 9-inch drivers, 1,200 watts power, and advanced DSP without taking over your room?
Opening Day optimism, Sennheiser in limbo, Kaleidescape at 25, and a study that questions how we hear. Think you’re paying attention? Think again.
Headphones
Sennheiser’s consumer division is for sale again as Sonova exits. What happens next could reshape one of audio’s most recognizable brands.
ACTIVO Scoop feature a single 8mm dynamic driver, dual 6mm dynamic drivers, and dual balanced armatures, bringing Astell&Kern tech to an accessible price.
Are wired IEMs making a comeback? CanJam NYC 2026 suggests growing demand as audiophiles chase better sound beyond wireless earbuds.
Can the Sennheiser RS 275 finally fix late night TV listening and dialogue clarity without disturbing others through Auracast and low latency wireless audio?
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
