Samsung Announces The Freestyle+ AI Portable Projector Ahead of CES 2026
Samsung unveils the Freestyle+ ahead of CES 2026, adding AI features and higher brightness to its lifestyle projector—still best suited for dark rooms.
Samsung Freestyle+ Portable Projector Lifestyle
Just ahead of CES 2026, Samsung has officially unveiled The Freestyle+, an AI-powered portable projector that underscores just how serious this category has become. Building on the compact, cylindrical design language of the original Freestyle and Freestyle (2nd Gen), the Freestyle+ focuses less on gimmicks and more on practical upgrades; smarter AI-assisted setup, higher brightness, and broader entertainment support—aimed at making projection genuinely flexible rather than situational.
This isn’t about turning every wall into an IMAX screen; it’s about reliable, low-friction viewing that works in apartments, bedrooms, dorms, and temporary spaces without a calibration headache.
More importantly, Samsung’s timing says a lot about where the market is headed. Portable and lifestyle projectors are no longer fringe products—they’re a fast-growing category with real momentum, as brands like XGIMIHisense, and others continue to roll out brighter, smarter, and more user-friendly models year after year. As screen sizes keep creeping up and TVs get less portable, projectors like the Freestyle+ are carving out a clear role: adaptable, space-conscious displays that meet modern viewing habits head-on; no mounts, no installers, no drama.
samsung-the-freestyle-plus
Samsung The Freestyle+
The Freestyle+ reflects Samsung’s vision to create displays that adapt naturally to how people live and move between spaces,” said Hun Lee, Executive Vice President of the Visual Display Business at Samsung Electronics. “By combining true portability with intelligent AI that optimizes both the viewing environment and the content itself, The Freestyle+ makes it easier to enjoy a consistent, high-quality experience wherever you are.”
AI OptiScreen
At the core of The Freestyle+ is AI OptiScreen, Samsung’s umbrella term for a suite of AI-powered screen optimization technologies designed to remove friction from setup. Rather than asking users to manually tweak focus, keystone, or alignment, AI OptiScreen automatically adapts the image to different room sizes, surfaces, and viewing angles. The idea is simple—and overdue: point it where you want, place it where it fits, and start watching.
  • 3D Auto Keystone: This feature automatically corrects distortion even when projecting onto uneven or non-flat surfaces, such as corners, curtains or angled walls.
  • Real-time Focus: This feature continuously adjusts focus as the projector moves or rotates, helping maintain clear, stable images without blurring or visual noise.
  • Screen Fit: This automatically adjusts the image to match the screen area when used with a compatible projector screen accessory.
  • Wall Calibration: This is a very practical feature that analyzes the color or pattern of the projection surface (including a bedsheet placed on a wall) and minimizes visual distractions for clear viewing
Samsung Vision AI
In addition to AI Optiscreen, the Freestyle+ also supports Samsung’s Vision AI Companion. This personalized AI platform, designed for Samsung screens, integrates enhanced Bixby with AI services from global partners to enable more natural, conversational interaction with on-screen content.
Take It Almost Anywhere
The Freestyle+ doubles down on portability by retaining the compact, cylindrical design that has defined the Freestyle line from the start—small enough to move easily from room to room or toss into a bag without planning your day around it. With a rated light output of 430 ISO lumens, the Freestyle+ delivers close to twice the brightness of the previous generation, making it far more usable in real-world living spaces where ambient light is a fact of life, not a controllable variable. It’s still very much a lifestyle projector, but one that’s better equipped to hold its own outside of a pitch-black room (more on that in the Bottom Line).
Everyday Viewing
The Freestyle+ is built for everyday casual viewing, and you can move it around without worrying about whether the space is “right” for projection. Its 180-degree rotating design supports projection at virtually any angle—including walls, floors, and ceilings—without additional mounts or accessories, enabling flexible viewing setups that adapt naturally to different rooms and moments throughout the day.
samsung-the-freestyle-plus-angle
Samsung TV Plus & Game Hub
The Freestyle+ brings entertainment with you—without relying on external devices or fixed setups. Built-in access to Samsung TV Plus and various streaming services is included.
Samsung Gaming Hub allows users to stream, play, and explore content directly from the projector without the need for external game consoles.
Audio
Audio is handled by a built-in 360-degree speaker, designed to provide even sound coverage from the projector’s compact enclosure without requiring external speakers for casual viewing. The Freestyle+ also supports Samsung Q-Symphony, allowing it to play in sync with compatible Samsung soundbars rather than replacing them—useful if you want a fuller, more directional soundstage without disabling the projector’s internal audio. It’s a practical approach that keeps setup simple while giving users an upgrade path if better sound is a priority.
The Bottom Line
The Samsung Freestyle+ is a sensible update to Samsung’s original lifestyle-projector concept, adding more modern processing and convenience features—but it still runs into the same hard limit as its predecessors: brightness. At 430 ISO lumens, it’s not built to overpower daylight or compete with brighter home-theater or “portable laser” models. If you want the image to look its best, plan on using it in a dark room or outside at night where ambient light isn’t washing out the picture.
That said, the category Samsung helped popularize has moved fast. Since the first Freestyle launched, “lifestyle” and portable projectors have exploded into a crowded field spanning entry-level minis to much brighter (and larger) portable units. Brands like XGIMIHisense, and others have been aggressive, and some of the newer designs are starting to look…familiar. XGIMI’s Vibe, in particular, echoes the Freestyle’s form factor closely—clear proof that Samsung’s design and product idea landed, even if the brightness ceiling still defines what these compact projectors can realistically deliver.
Price & Availability
Samsung will be showing the Freestyle+ at CES 2026, with a phased global rollout planned for the first half of the year. Full specifications and pricing have not yet been announced and are expected closer to launch.
Denon AVR-S980H Home Theater A/V Receiver Lifestyle
Denon AVR-S980H adds wireless surround support, 1440p pass-through, and channel level monitoriing offering a flexible step-up from soundbars under $1,000.
2026 Samsung R85H Micro RGB TV Lifestyle 2026 Samsung R85H Micro RGB TV Lifestyle
Samsung reveals pricing and availability for its 2026 Micro RGB LED TV lineup, introducing a new approach to color accuracy and premium display performance.
Western Acoustics Type 2.1 Bookshelf Speakers at AXPONA 2026 Western Acoustics Type 2.1 Bookshelf Speakers at AXPONA 2026
Western Acoustics Type 2.1 lands at AXPONA 2026 with Purifi driver, horn design, and a Brooklyn apartment sensibility that trades flash for texture and...
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026 QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Samsung's Micro RGB TV tech arrives in real-world screen sizes
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
