Perlisten A-Series: 4 New Entry-Level High-Performance Loudspeakers
Perlisten A-Series loudspeakers are designed for stereo or home theater. Choose between two towers, a stand-mount and on-wall surround.
Perlisten A-Series Loudspeakers for 2025
Perlisten has long been synonymous with uncompromising performance—and a price tag to match. With the new A-Series, the brand is finally offering a more accessible entry point without sacrificing the sonic signature that made its high-end models legendary.
The lineup—A4t and A3t tower speakers, A3m monitor speaker, and A2s surround speaker—delivers the brand’s signature dynamic, natural sound, premium build quality, and custom-engineered drivers, bringing a taste of Perlisten’s top-tier performance to a wider audience.
A4t Tower: The Flagship of the A-Series
perlisten-a4t
The A4t ($6,990/pair) sits at the top of the A-Series lineup. Its third woofer helps manage bass more efficiently, making it well-suited for larger rooms or setups that demand deeper low-end performance. Distortion is kept low, and the speaker works effectively for both music and home theater applications. It pairs naturally with the other A-Series models for a consistent, balanced sound across a full system.
The A4t is a floor-standing speaker designed to bring the A-Series’ performance closer to the brand’s high-end models. At its core is a bespoke 35mm composite Teteron dome tweeter mounted in a unique waveguide, which helps control dispersion and improves imaging across the listening area.
The low end is handled by three 215mm carbon fiber woofers arranged in a bass reflex enclosure, which balances punch and extension while keeping distortion low.
Perlisten has also engineered a custom crossover and cabinet specifically for this design, ensuring smooth integration between drivers and a controlled acoustic response. The A4t is capable of maintaining linear frequency response from 100Hz to 10kHz within ±2dB and extends down to 28Hz in typical listening environments (–6dB).
With a nominal impedance of 4Ω and a recommended amplifier range of 50–350 watts, the speaker is flexible enough to pair with a variety of high-quality amplification without overtaxing the system.
The result is a speaker that performs reliably in both music and home theater applications, delivering clean, natural sound across its range with low distortion even at higher SPL levels.
Perlisten A4t Specifications
  • Type: Floor-standing tower speaker
  • Enclosure: 2½-way acoustic suspension, bass reflex
  • Drivers:
    • Tweeter: 35mm composite Teteron dome with waveguide
    • Woofers: 3 × 215mm carbon fiber diaphragms
  • Frequency Response:
    • Full range: 36Hz – 24kHz (–6dB)
    • Extended: 27Hz – 27kHz (–10dB)
    • Typical in-room bass extension: 28Hz (–6dB), 19Hz (–10dB)
  • Sensitivity: 88.5 dB / 2.83V / 1m
  • Impedance: 4Ω nominal / 3.1Ω minimum
  • Response Linearity: 100Hz – 10kHz ±2dB
  • Amplifier Requirements: 50 – 350W
  • Maximum SPL @1m (100–20kHz):
    • Peak: 113.9 dB
    • <3% 2nd/3rd harmonics: 111.0 dB
  • Dimensions (H × W × D): 50.6″ × 11.0″ × 17.7″ (1285 × 280 × 450 mm)
Perlisten A3t: Entry-Level Tower with Full-Range Performance
perlisten-a3t
The Perlisten A3t ($4,990/pair) is a floor-standing, entry-level tower speaker in the A-Series, designed to deliver the brand’s signature sound in a more accessible format. It features a 35mm composite Teteron dome tweeter mounted in a custom waveguide, which helps control dispersion and improve imaging across the listening area.
Low frequencies are handled by two 215mm carbon fiber woofers housed in a 2-way acoustic suspension bass reflex cabinet, providing balanced, controlled bass with typical in-room extension down to 26Hz (–6dB) and 17Hz (–10dB).
The A3t maintains linear frequency response from 100Hz to 10kHz within ±2dB, with a nominal impedance of 4Ω and sensitivity of 88.4dB, allowing it to work effectively with amplifiers rated between 50 and 300 watts. The speaker is capable of producing peak sound pressure levels of 113.2dB, or 111dB at <3% second and third harmonic distortion.
Measuring 50.6″ high, 11.0″ wide, and 15.4″ deep (1285 × 280 × 390 mm), the A3t combines Perlisten’s custom-engineered drivers, crossover, and cabinet design to deliver controlled, natural sound for both stereo and multi-channel applications.
Perlisten A3t Specifications
  • Enclosure: 2-way acoustic suspension, bass reflex
  • Drivers:
    • Tweeter: 35mm composite Teteron dome with custom waveguide
    • Woofers: 2 × 215mm carbon fiber diaphragms
    • Full range: 33Hz – 27kHz (–6dB)
    • Extended: 24Hz – 27kHz (–10dB)
    • Typical in-room bass extension: 26Hz (–6dB), 17Hz (–10dB)
  • Sensitivity: 88.4 dB / 2.83V / 1m
  • Impedance: 4Ω nominal / 3.0Ω minimum
  • Amplifier Requirements: 50 – 300W
    • Peak: 113.2 dB
  • Dimensions (H × W × D): 50.6″ × 11.0″ × 15.4″ (1285 × 280 × 390 mm)
Perlisten A3m Mini-Monitor: Compact Speaker with Full-Range Performance for Stereo and Home Theater
perlisten-a3m
The Perlisten A3m ($3,590/pair) is a compact tower mini-monitor designed to deliver the brand’s signature performance in a versatile, space-saving package. It features a 35mm composite Teteron dome tweeter mounted in Perlisten’s custom waveguide to control dispersion and imaging, paired with a single 215mm carbon fiber woofer in a 2-way acoustic suspension cabinet.
The A3m provides linear frequency response from 100Hz to 10kHz within ±2dB and extends from 44Hz to 24kHz (–6dB) with in-room bass extension down to 40Hz (–6dB) and 31Hz (–10dB).
With a nominal impedance of 4Ω, sensitivity of 88.1dB, and recommended amplifier power between 50 and 250 watts, it offers efficient operation and clean output. The speaker can achieve peak SPL levels of 112.1dB, or 111dB at <3% second and third harmonic distortion.
Measuring 26.6″ high, 11.0″ wide, and 13.8″ deep (675 × 280 × 350 mm), the A3m works well as a two-channel speaker with sufficient bass extension, as the core of a reference-level 2.1 system, or as part of a home theater setup for LCR or surround applications. It can be wall-mounted or ceiling-mounted using Perlisten’s tilt swivel bracket, offering flexible placement without compromising performance.
Perlisten A3m Specifications
  • Type: Compact tower mini-monitor
  • Drivers:
    • Woofer: 1 × 215mm carbon fiber diaphragm
    • Full range: 44Hz – 24kHz (–6dB)
    • Extended: 37Hz – 27kHz (–10dB)
    • Typical in-room bass extension: 40Hz (–6dB), 31Hz (–10dB)
  • Sensitivity: 88.1 dB / 2.83V / 1m
  • Amplifier Requirements: 50 – 250W
    • Peak: 112.1 dB
  • Dimensions (H × W × D): 26.6″ × 11.0″ × 13.8″ (675 × 280 × 350 mm)
  • Mounting Options: Wall or ceiling mount using Perlisten tilt swivel bracket
Perlisten A2s On-Wall Surround Speaker: Flexible Performance for Cinema and Immersive Audio
perlisten-a2s
The Perlisten A2s ($995/each) is a versatile on-wall surround speaker designed for multi-channel applications, including home theater and immersive audio setups. It features a 35mm composite Teteron dome tweeter mounted in Perlisten’s custom waveguide for controlled dispersion and clear imaging, paired with a single 215mm carbon fiber woofer.
The A2s delivers linear frequency response from 100Hz to 10kHz within ±2.5dB, with a full range of 58Hz – 30kHz (–6dB) and in-room bass extension down to 50Hz (–6dB).
With a nominal impedance of 6Ω, sensitivity of 86.8dB, and recommended amplifier power of 50–200 watts, it provides clean output and works efficiently with a range of amplifiers. The speaker can achieve peak SPL of 109.8dB, or 109dB at <3% second and third harmonic distortion.
Compact and adaptable, the A2s can be mounted on walls or ceilings using Perlisten’s tilt swivel bracket, making it suitable for side, rear, or top surround channels, and pairs seamlessly with other A-Series products.
Perlisten A2s Specifications
  • Type: On-wall surround speaker
  • Enclosure: Acoustic suspension
  • Drivers:
    • Full range: 58Hz – 30kHz (–6dB)
    • Extended: 49Hz – 33kHz (–10dB)
    • Typical in-room bass extension: 50Hz (–6dB), 41Hz (–10dB)
  • Sensitivity: 86.8 dB / 2.83V / 1m
  • Impedance: 6Ω nominal / 4.5Ω minimum
  • Response Linearity: 100Hz – 10kHz ±2.5dB
  • Amplifier Requirements: 50 – 200W
    • Peak: 109.8 dB
    • <3% 2nd/3rd harmonics: 109.0 dB
  • Dimensions (H × W × D): 17.7″ × 11.0″ × 8.7″ (450 × 280 × 221 mm)
  • Mounting Options: Wall or ceiling using Perlisten tilt swivel bracket
The Bottom Line
The Perlisten A-Series represents the brand’s most accessible entry into its high-end performance world, offering a carefully engineered set of speakers that bring Perlisten’s signature sound closer to a wider audience. Across the lineup—from the full-sized A4t to the compact A2s on-wall surround—these speakers are designed for both stereo and multi-channel setups, making them equally at home in music systems or immersive home theaters. While the A-Series delivers controlled dispersion, low distortion, and deep bass relative to size, larger rooms or more demanding low-frequency content may benefit from pairing with a subwoofer for a fully extended low end.
Perlisten’s A-Series also reflects a growing trend in high-performance on-wall speakers, with flexibility for side, rear, or height channels, and easy wall or ceiling mounting. Compared with competitors such as Theory Audio Design, Sonus faber, DALI, and Acoustic Energy, the A-Series occupies the higher end of “accessible,” offering the technology and engineering of premium models without the extreme price of Perlisten’s flagship lines. These are far from inexpensive, but they represent the most affordable way to experience the brand’s custom drivers, waveguides, and cabinet engineering in a full system configuration.
For more information: perlistenaudio.com
Where to buy:
Note: Pricing is for each speaker, so prices double per pair.
1 Comment
1 Comment
  1. KC
    September 9, 2025 at 6:52 pm
    What’s an acoustic suspension bass reflex cabinet? Seems a bit contradictory.
Kanto Audio Tuk Grand Lifestyle
Kanto debuts TUK Grand and updates TUK, YU6, and YU4 at AXPONA 2026. Can affordable speakers stand out in a high-priced show?
LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV. LG Enters RGB LCD TV market with MRG95 Micro RGB evo TV.
While LG doesn’t seem to be giving up on OLED TV technology any time soon, the company is also hopping on the RGB bandwagon...
2026 LG W6 Wallpaper TV Lifestyle Angle 2026 LG W6 Wallpaper TV Lifestyle Angle
LG’s 2026 OLED evo W6 Wallpaper TVs bring ultra thin design, Zero Connect, and 165Hz support in either 77-inch or 83-inch screen sizes.
Sennheiser HD 480 Pro Headphones in the Studio Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
James and Kornelijus of IAG's Hi-Fi Division join us at AXPONA 2026 to discuss the latest versions of QUAD's iconic Electrostatic Speakers and Amplifiers.
Chesky Audio LC2 debuts at AXPONA 2026 with a $1,995 per pair price, unique 3D printed cabinet design, and a clear focus on affordable...
Western Acoustics Type 2.1 lands at AXPONA 2026 with Purifi driver, horn design, and a Brooklyn apartment sensibility that trades flash for texture and...
Andrew Jones to debut Jones and Cerreta Troubadour at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how...
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Magico previews the S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
At $899, the Technics SL-40CBT Bluetooth Direct Drive Turntable features aptX Adaptive, built-in MM phono stage and three finishes.
