McIntosh MA2375 Vacuum Tube Integrated Amplifier Debuts as Binghamton Keeps the Blue Meters Glowing
McIntosh MA2375 debuts as a $15,000 all-tube integrated amplifier with 75-watts per channel, MM/MC phono, headphone amp, and no digital extras.
McIntosh MA2375 Tube Integrated Amplifier Front and Back Angle
When Bose acquired McIntosh Group in November 2024, bringing both McIntosh and Sonus faber under the same corporate roof, the high-end audio world reacted with the calm restraint of villagers spotting smoke over the castle. Would McIntosh still build unapologetically high-end American amplifiers in Binghamton? Would Sonus faber still make loudspeakers with Italian craft and not Bluetooth conference-room energy?
With the new McIntosh MA2375 Vacuum Tube Integrated Amplifier, the answer appears to be yes. Very much yes.
The MA2375 is a 75-watt-per-channel, all-analog vacuum tube integrated amplifier with KT88 output tubes, 12AT7 driver tubes, Unity Coupled Circuit output transformers, and the familiar blue-meter glow that tells loyalists the lights in Binghamton are still on. Bose may own the house now, but based on recent McIntosh and Sonus faber product activity, nobody has painted over the family crest.
McIntosh MA2375 Overview
The latest example of McIntosh’s traditional design approach is the new McIntosh MA2375 Vacuum Tube Integrated Amplifier, the company’s first vacuum tube integrated amplifier in more than a decade. Vacuum tube amplification has long been part of McIntosh’s high-performance audio heritage, and the MA2375 continues that lineage in a modern integrated amplifier.
The MA2375 combines a vacuum tube preamplifier and vacuum tube power amplifier in a single all-analog component. It does not include a built-in DAC, network streaming, or wireless functionality, keeping the design focused on analog source components and loudspeaker amplification.
mcintosh-ma2375-kt88-tubes
The power amplifier section uses four KT88 output tubes and four 12AT7 driver tubes, delivering 75 watts per channel. The preamplifier section uses two 12AX7A tubes and two additional 12AT7 tubes.
McIntosh’s Unity Coupled Circuit Output Transformers allow the MA2375 to deliver its rated output into 4-, 8-, or 16-ohm loudspeakers, giving owners flexibility when matching the amplifier with different speaker loads.
The MA2375 follows McIntosh’s established industrial design language, with a polished stainless-steel chassis, exposed tubes, protective tube cage, tube illumination, and the company’s signature blue watt meters.
The MA2375 includes a 5-band analog equalizer for fine-tuning the integrated amp’s sound in relation to the room environment and listening preferences. The included High Drive headphone amplifier with Headphone Crossfeed Director (HXD) adds more dimensionality to private listening.
mcintosh-ma2375-side
mcintosh-ma2375-back
McIntosh MA2375 Specifications
McIntosh Model MA2375
Product TypeVacuum Tube Integrated Amplifier
Price $15,000 (US)
Number of Channels 2
FTC Power Output Rating 75 Watts
Power Output per Channel: 75 Watts into 4, 8, or 16 ohms
Rated Power Band 20Hz to 20kHz
Total Harmonic Distortion 0.5% maximum with both channels operating from 250 milliwatts to rated power, 20Hz to 20kHz
Dynamic Headroom 1.2dB
Frequency Response +0, 0.5dB 20Hz to 20kHz
Frequency Response, +0, -3dB 10Hz to 50kHz
Sensitivity Phono 3mV
Sensitivity High Level (Balanced / Unbalanced) 600mV/300mV
Signal To Noise Ratio (Phono) 75dB
Signal To Noise Ratio (High Level Inputs) 95dB
Input Impedance (Balanced / Unbalanced) 44K/22K Phono:100-47kΩ; 50-400pF
Damping Factor >22
Maximum Output (Balanced / Unbalanced) 16V/8V
Inputs 2 x Balanced Input
3 x Unbalanced Input
1 x Phono Input (configurable as either Moving Coil or Moving Magnet)
Outputs 1 x Unbalanced Variable
1 x Headphone -m 1/4” High Drive with Headphone Crossfeed Director (HXD®)
1 x Subwoofer
Home Theater PassThru Yes
Unbalanced Analog Connector Type: Premium gold-plated solid brass
Speaker Binding Post Type Patented Solid Cinch™ Speaker Binding Posts
Service Port Yes (1)
Control OptionsTone Controls – 5 Band Analog Equalizer
Tone Bypass and Input Assign
RS232 Control Input
Power Control Output
Rear Panel Data Port x 2
Rear Panel IR Sensor Input
Input Level Match
Output Type Unity Coupled Output Transformer
Chassis Finish Polished stainless steel
Dimensions (WHD) 17-13/16” (45.2cm) x 9-15/16” (25.2cm) x 20 7/16” (51.9cm)
Unit Weight93 lbs (42.2 kg)
Shipping Weight 103 lbs (46.7 kg)
mcintosh-ma2375-rear-corner
mcintosh-ma2375-rear-inputs
The Bottom Line
The McIntosh MA2375 is aimed at listeners who want a traditional all-vacuum-tube integrated amplifier, not one of McIntosh’s hybrid designs like the MA252 or MA352. Its key distinctions are the 75-watt KT88 output stage, McIntosh Unity Coupled Circuit Output Transformers, support for 4-, 8-, and 16-ohm loudspeakers, a built-in vacuum tube headphone amplifier, and full MM/MC phono compatibility.
What it does not offer is equally important: no DAC, no streaming, no HDMI eARC, no Bluetooth, and no room correction. At $15,000, the MA2375 is competing less with value-focused tube integrated amps and more with higher-end integrated amplifiers from Unison Research, Audio Research, Pass Labs, and MOON by Simaudio.
The MA2375 is for listeners who already have their digital front end sorted and want a McIntosh all-tube integrated with phono, headphone listening, and traditional analog control in one chassis.
mcintosh-ma2375-top-front
Price & Availability
The McIntosh MA2375 Tube Integrated Amplifier will be available for $15,000 through authorized McIntosh retailers, online dealers, or Custom Integrators
For more information: mcintoshlabs.com
The $6,500 MOON 371 challenges expensive separates with exceptional sound, serious engineering, and a few surprises. Is this Simaudio’s finest value yet?
Hi-Fi Components
Bose now spans ANC, luxury hi-fi, connected audio, automotive and gaming. The FMOD acquisition makes its larger strategy harder to ignore.
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Loudspeakers
Can OJAS bring new listeners to high-end audio? Devon Turnbull’s Cooper Hewitt listening room shows why the industry needs to leave its bubble.
Klipsch debuts Reference Premiere III at Audio Advice Live 2026 with Onkyo, a 7.4.4 Atmos system, anniversary Klipschorn and Rebellion.
