iFi Go Pod Max: Because Your $2K IEMs Deserve Better Than a Dongle
The iFi Go Pod Max turns wired IEMs wireless with Bluetooth 5.4, balanced amp, and high-res audio—elevating sound while exposing your IEMs’ true colors.
iFi Go pod MAX wireless IEM Adapters
After dropping the GO Pod and the GO Pod Air, iFi is back with a new top-shelf option for IEM nerds who want to cut the cord without tanking sound quality. The new Go Pod Max now takes the flagship slot in the lineup, promising upgraded wireless performance and more codec support for your high-end in-ears—because apparently, $2,000 IEMs deserve a proper Bluetooth throne.
iFi GO Pod Explained: Cutting the Cord Without Killing Your Sound
IEMs are great, but they’re stuck in the wired age—meaning you need a physical connection to a source or DAC to actually use them. Enter the iFi Go Pod lineup, which finally gives your IEMs some wireless freedom without totally trashing the sound quality.
Using the Go Pod Max is simple: unplug the cable from your IEMs and snap the left and right pods onto the earpieces. Then pair those pods to your phone or whatever Bluetooth source you’re rocking. Slip the ear loops behind your ears, and boom—your wired IEMs just went full TWS (True Wireless Stereo) status. Basically, your fancy wired buds learned to walk on their own.
ifi-go-pod-max-up
The iFi Go Pod MAX
Key features of the iFi GO Pod Max include:
Exterior Design: The Go pod Max features precision-machined aluminium cases that are stylishly designed.
Built-in UV Sterilisation: To maintain peak performance and hygiene, the Go pod has four high-intensity UV lights that sterilise your earphones between uses.
Hi-Fi Circuitry: Separate Bluetooth, DAC, and amp stages are provided to ensure the best possible audio quality through the IEMs.
Qualcomm Bluetooth Chips: Each pod features a flagship Qualcomm QCC5181 chipset, capable of receiving CD-quality audio completely cable-free with zero data loss when using the aptX Lossless codec. For the listener, this means no sonic trade-offs, despite being wireless.
If your source device doesn’t support lossless Bluetooth, the GO Pod Max allows listeners to choose from a wide range of other leading high-resolution codecs, including LDAC and aptX Adaptive.
DAC: Bluetooth reception is managed exclusively by the Qualcomm QCC5181 chipset. From there, audio data is passed to a Cirrus Logic MasterHIFI DAC – carefully chosen by iFi for its dynamic performance and low power consumption. Finally, the signal is delivered to a fully balanced amplification stage, supported by a dedicated clock system that ensures perfect timing and synergy across the entire audio chain.
K2HD Technology: iFi has partnered with JVCKENWOOD to integrate K2HD Sound Processing Technology into the GO pod Max. K2HD interpolates lost data, restoring natural-sounding harmonics and providing the depth, warmth, and soul of the original performance. For the listener, the result is a more authentic listening experience from their standard CD-quality library with up to 24-bit/96kHz quality.
ifi-go-pod-max-artha
Auto Impedance Matching: The Go Pod Max automatically detects the impedance of your connected IEMs and adjusts on the fly. It supports four impedance levels—16Ω, 32Ω, 64Ω, and 300Ω—ensuring optimal performance across a broad spectrum of IEMs, including the highest-impedance models out there.
Built-in Mics: For clear phone calls, the Go Pod Max features dual microphones with Qualcomm’s cVc echo cancellation and noise suppression, delivering crystal-clear voice quality whether you’re in a quiet room or a noisy street.
Interchangeable Ear Loops: The Go Pod Max’s interchangeable ear loops have been redesigned for better softness and comfort. It comes with standard 2-pin and MMCX connectors to fit most IEMs, while also offering T2, Pentaconn Ear, and A2DC options for users with more specialized setups.
Multitasking: The Go Pod Max carries over the productivity-boosting features of its predecessors. Intuitive touch controls on each pod let you manage music, answer calls, adjust volume, or launch voice assistants like Siri or Gemini with a simple tap—perfect for when your hands are full or you’re on the move.
35-Hour Playtime: The Go Pods Max provides IEMs with 7 hours of wireless playback time plus 28 hours more from the charging case
Comparison
ifi-go-pod-max-comparison
IFI ModelGo Pod Max (2025)Go Pod Air (2025)Go Pod (2023)
Product TypeWireless IEM AdapterWireless IEM AdapterWireless IEM Adapter
Price$599$249$399
Pod Chassis Material Aluminium & Textured Polymer  Textured Polymer Textured Polymer
Case Chassis Material Aluminium & Textured PolymerTextured Polymer Textured Polymer
Bluetooth Version 5.4 5.2 5.2
Bluetooth Codecs aptX Lossless, LDAC, LHDC/HWA, aptX Adaptive, aptX HD, aptX, AAC, SBC LDAC, LHDC/HWA, aptX Adaptive, aptX HD, aptX, AAC, SBC LDAC, LHDC/HWA, aptX Adaptive, aptX HD, aptX, AAC, SBC
Bluetooth ChipsetQCC5181  QCC5144QCC5144
Connection Types Supported MMCX, 2-Pin (Included); A2DC, T2, Pentaconn (Optional) MMCX, 2-Pin (Included); A2DC, T2, Pentaconn  MMCX, 2-Pin (Included); A2DC, T2, Pentaconn (Optional)
K2HD Technology Sound Processing YesNoNo
Ingress Protection RatingIPX5  IPX5  IPX5
Auto-Impedance Detection 16/32/64/300 Ohms 16/32/64 Ohms16/32/64/300 Ohms
Output Power≥120mW/1.96V @ 32 Ohms ≥57mW/0.96V @ 32 Ohms ≥120mW/1.96V @ 32 Ohms ≥120mW/1.96V @ 32 Ohms
DNR ≥129dB(A) @ 32 Ohms, 20 20kHz  ≥121dB(A) @ 32 Ohms, 20 20kHz  ≥129dB(A) @ 32 Ohms, 20 20kHz
SNR≥132dB(A) @ 300 Ohms, 20 20kHz  ≥124dB(A) @ 64 Ohms  ≥132dB(A) @ 300 Ohms, 20 20kHz
THD+N0.002% (20-20kHz)≤0.002% (1kHz/32Ω)≤0.002% (1kHz/32Ω)
Battery Life7 Hours; 35 Hours including Charging Case 7 Hours; 35 Hours including Charging Case 7 Hours; 35 Hours including Charging Case
Charging OptionsUSB-C; 5V/1A or 5V/2A with Qi certified chargerUSB-C 5V/0.7A5V/1A or 5V/2A Qi certified charger
Charging Time<1.5 hours (Pods);
<2 hours (Charging Case)
~1.5h (Pods)
1h (Charging Case)
~1.5h (Pods)
 ~2h (Charging Case)
Dimensions47.5 x 16.1 x 9.5mm (Pods)
116 x 76 x 47.8mm (Charging Case)
Pod 47.5 x 16.1 x 9.5 mm;
Charging Case 94 x 94 x 45 mm
Pod | 43.5 x 16.4 x 9.5 mm
Charging case | 116 x 76 x 38.5 mm
Net Weight 24.5g (Pods)
185g (Charging Case)
10g (Pods)
106g (Charging Case)
12g (Pods) 1
26g (Charging Case)
What’s In The Box1x Charging Case
1x Ear Loop (0.78 mm 2-Pin)
1x Ear Loop (MMCX)
1x USB Charging cable
1x User Manual
1-year Warranty Card
1x Compact Charging Case
1x 0.78mm 2-Pin Ear Loops (set)
1x MMCX Ear Loops (set)
1x Instruction card
1x Charging Case
1x Ear Loop (MMCX)
1x User Manual
ifi-go-pod-max-hifiman
The Bottom Line
iFi continues to deliver practical, well-priced solutions with the Go Pod Max—the third device in its lineup designed to turn wired IEMs into true wireless earbuds. With features like Bluetooth 5.4, 24/96 audio support, balanced amplification, automatic impedance matching, plus JVCKEWOOD’s K2HD processing and high-end DAC tech, the Go Pod Max offers serious upgrades for your IEMs.
That said, it won’t magically transform a $50 pair of IEMs into category leaders. Instead, it will both elevate what’s good and expose any flaws—making it a game-changer for those who want wireless freedom without compromising the core sound of their favorite IEMs.
Pricing & Availability
For more information: ifi-audio.com
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Victrola and Third Man Records Limited Edition Turntable and Speakers Victrola and Third Man Records Limited Edition Turntable and Speakers
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
2026 TCL QM8L 4K TV Lifestyle 2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
Dan D'Agostino Momentum C2Z Preamplifier with Power Supply Dan D'Agostino Momentum C2Z Preamplifier with Power Supply
Dan D’Agostino Momentum C2Z preamplifier refines the C2 with Z circuitry and FET output stage. If you have to ask the price this is...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
A skeptical, experience-driven take on hi-fi accessories that actually work—QED, Advance Paris, IsoAcoustics, IsoTek, iFi, ddHiFi—minus the snake oil.
Our picks for the best desktop and portable DAC/Amps for audiophiles of 2025 include Burson Audio, JDS Labs, FiiO, iFi Audio and Rotel.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
Our favorite Dongle DACs in 2025 for audiophiles include models from Questyle, Audioengine, iFi and Campfire Audio.
With the Dongle DAC market shaking itself out in 2024, the $129 Questyle 15c leapfrogged the competition.
At $229, the iFi ZEN CAN 3 Headphone Amp is optimized for headphones with xMEMs drivers but will work with what you already have?
