Final Launches UX1000 & UX5000 Wireless Noise Cancelling Headphones at Low Prices
Final’s UX1000 budget wireless ANC headphones are only $65, while the step-up UX5000 add aptX Adaptive and LDAC for $250.
Final UX1000 and UX5000 Wireless Headphones
Following the UX2000 and UX3000 in 2022 and the UX3000 SV refresh in early 2025, Final is expanding its wireless headphones lineup with two new models: the ultra-budget UX1000 ($65) and the more refined UX5000 ($250). Details are still coming in, but early specs confirm that both target the value end of the market with aptX support, while the UX5000 steps up with LDAC to compete with far more expensive wireless headphones. Here’s what we know so far.
UX1000
final-ux1000-headphones-black-greige
Final UX1000
The UX1000 is Final’s new entry-level wireless ANC headphone, positioned below the UX3000 and UX3000 SV and aimed at listeners who want an affordable option without giving up the benefits of Final’s design and engineering experience.
Tuning: Final has tuned the UX1000 for clarity and long-term listening comfort. Driver performance is optimized first, with EQ applied only where it is needed to address minor Bluetooth artifacts. The result is deep and controlled bass with crisp and well-defined highs that avoid fatigue.
High Performance Hybrid ANC: Many budget ANC headphones raise isolation at the expense of sound quality. Final takes a different approach with its Hybrid ANC system, which is designed to preserve the headphone’s natural tuning. Feedforward and feedback microphones work together to reduce ambient noise across a wide range of environments, allowing the character of the headphone to remain intact. An Ambient Mode allows outside sounds to come through when needed, making it easy to stay aware of travel announcements or have quick conversations without taking the headphones off.
final-ux1000-headphones-greige-lifestyle
Final U1000
Lightweight Design with a Premium Finish: The UX1000 is built for all day use with a light frame, soft padding, and an easy fit that holds up during long listening sessions. The design is simple and understated, offered in Black or Greige. A durable matte finish helps resist fingerprints, oils, and surface wear so the headphones maintain their appearance over time. When it is time to pack up, the foldable headband lets the UX1000 fit easily into bags or backpacks.
Playback Time: The UX1000 includes a battery rated for up to 70 hours of playback with ANC off and up to 40 hours with ANC on.
Bluetooth Support: The UX1000 uses Bluetooth 5.4 and supports multi point connection, allowing listeners to stay connected to two devices at the same time.
UX5000
final-ux5000-headphones-black-lifestyle
Final UX5000
Positioned above the UX3000 and UX3000 SV and informed by Final’s ongoing acoustic research, the UX5000 blends the company’s engineering heritage with modern wireless convenience. It is designed to present a three dimensional soundstage with balanced tonality.
Crystal Clear Balanced Sound: The UX5000 draws on acoustic principles developed for Final’s A series earphones. It is tuned for clarity across the full frequency range, supported by a precisely engineered internal sound cavity that shapes the presentation. The result is clear highs, solid bass, and strong depth. It is designed to handle everything from detailed orchestral recordings to gaming audio and more aggressive genres while keeping the presentation spacious and expressive.
Dynamic Driver and Bluetooth Implementation: The UX5000 uses a newly developed 40 mm dynamic driver that employs refined acoustic damping and filtering to improve performance. Wireless operation is handled by Qualcomm’s QCC3095 Bluetooth chip, which offers improved efficiency and expanded codec support. The UX5000 supports aptX, aptX Adaptive, and LDAC.
Designed for Everyday Comfort: The UX5000 carries Final’s minimalist industrial design language with soft ergonomic padding and a lightweight frame suited for long listening sessions. Every component is selected to support comfort, durability, and a clean aesthetic that works at home or on the go. Final also includes a practical carrying case that protects the headphones and makes daily transport easy.
Comparison
Final ModelUX1000UX5000
Product TypeWireless Noise Cancelling HeadphonesWireless Noise Cancelling Headphones
Price$64.99$249.99
Bluetooth Ver 5.4Ver 5.4
Frequency Response20Hz-20kHz20Hz-40kHz
Bluetooth CodecsSBC, AACSBC, AAC, aptX, aptX Adaptive, LDAC
Bluetooth ProfilesA2DP, AVRCP, HFP, GAVDPA2DP, AVRCP, HSP / HFP
Playback Time (ANC On)40 hours 45 hours
Playback Time (ANC Off)70 hours65 hours
Charging TimeApprox. 2 hoursApprox. 2 hrs
Battery Capacity 500 mAh700 mAh
Weight250g310 g
Included AccessoriesNot Indicated3.5 mm cable
Semi-hard carrying case
final-ux5000-headphones-black-on-ear
Final UX5000
The Bottom Line
Final may not have the brand recognition of some mainstream players, but they have earned real credibility in the headphone and earbud space, and our reviews of the UX2000 and UX3000 reflect that. The UX1000 gives them a true budget ANC option under $70, while the UX5000 moves them deeper into the crowded $250 wireless category where Skullcandy, OneOdio, CMF, and EarFun are all swinging for the same customer. If Final can deliver the tuning, build quality, and codec support they are promising here, the UX1000 and UX5000 should make the UX series a much stronger contender in the everyday wireless headphone market.
Price & Availability
The Final UX1000 is available for $64.99 at Amazon and selected retailers across the U.S., the UK (£49.99) and Europe (€63.99).
The Final UX5000 is available for $249.99 at Amazon and selected retailers across the U.S., the UK (£199.99) and Europe (€229.99).
Fosi Audio CanJam NYC 2026
Fosi Audio debuts the C3 AI Gaming Sound Card and MD3 Magnetic DAC/Amp at CanJam NYC 2026, expanding into gaming audio and portable hi-fi.
Woman wearing Meze Audio Astru IEM in-ear Woman wearing Meze Audio Astru IEM in-ear
Can one driver beat complex hybrids? Meze Audio unveils the $899 ASTRU flagship IEM at CanJam NYC 2026 with a single dynamic driver design.
HiFiMAN Arya WiFI and HE1000 WiFi Headphones HiFiMAN Arya WiFI and HE1000 WiFi Headphones
Can HiFiMAN’s HE1000 WiFi and Arya WiFi bring true high resolution audio to wireless planar open-back headphones? We’ll find out at CanJam NYC 2026.
2026 LG G6 and C6 OLED 4K TVs Angle View 2026 LG G6 and C6 OLED 4K TVs Angle View
LG announces pricing and availability for its 2026 OLED evo G6 and C6 TVs, featuring brighter panels, new processing, and enhanced gaming performance.
TCL CrystalClip Open-ear Wireless Earbuds Lifestyle Woman Holding White Charging Case TCL CrystalClip Open-ear Wireless Earbuds Lifestyle Woman Holding White Charging Case
TCL debuts CrystalClip open ear earbuds at MWC 2026 with air conduction audio, spatial sound, AI features, and a Swarovski crystal edition at a...
Liquid Death x Spotify Eternal Playlist Urn with lid off Liquid Death x Spotify Eternal Playlist Urn with lid off
Exclusive Videos
Spotify and Liquid Death launch the Eternal Playlist Urn and generator so your music lives on after you’re gone. Limited to...5 per customer.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Can the Sennheiser RS 275 finally fix late night TV listening and dialogue clarity without disturbing others through Auracast and low latency wireless audio?
Second generation écoute vacuum tube wireless noise cancelling headphones improve comfort and sound in a slightly modified design.
FiiO’s EH11 headphones and updated JM21 music player target commuters and travelers with retro design, hi-res Bluetooth, solid performance, and an affordable $240 combo.
Find out if your Bluetooth earbuds or wireless headphones are vulnerable, and update your firmware just in case.
Audeze’s Maxwell 2 raises the bar for gaming headsets, featuring SLAM technology with improved sound, comfort, and a new control app.
Extremely Loud Infinitely Expressive?Fender Audio makes a bold statement with ELIE E6 and E12 portable Bluetooth speakers and modular MIX wireless headphones.
