Meze Audio ASTRU Debuts at CanJam NYC 2026 as Flagship Single Dynamic Driver IEM
Can one driver beat complex hybrids? Meze Audio unveils the $899 ASTRU flagship IEM at CanJam NYC 2026 with a single dynamic driver design.
Woman wearing Meze Audio Astru IEM in-ear
Meze Audio has introduced the ASTRU ($899), a new top of the line single dynamic driver in-ear monitor (IEM) created for listeners who want true high end performance without venturing into the stratospheric pricing that now defines many flagship IEMs. Built around a focused design philosophy, ASTRU relies on a single dynamic driver to deliver a visceral, full bodied presentation that Meze says can rival the layering, imaging, and resolution typically associated with complex multi driver designs.
The new model will make its first public appearance at CanJam NYC 2026 this weekend. Meze says ASTRU will be available starting March 20 through mezeaudio.com, mezeaudio.eu, and selected retailers worldwide.
Find out more about the ASTRU IEM and STRADA headphones in our interview with Mircea Fanatan of Meze Audio at CanJam NYC 2026.
While Meze Audio is widely known for its award winning headphones such as the Empyrean II, 99 Classics 2nd Generation, 109 Pro, and the recently introduced STRADA, the Romanian brand has also shown it can build compelling in ear monitors as well. Its ADVAR IEM, which we reviewed favorably, stood out for its musical balance, solid build quality, and distinctive industrial design. With ASTRU, Meze appears ready to push further into the high end IEM space while sticking with a simpler single driver approach rather than joining the industry’s escalating multi driver arms race.
Meze Audio ASTRU
Advanced Multilayer Dynamic Driver Architecture
At the center of the ASTRU is a custom multilayer composite 10 mm dynamic driver designed to balance speed, control, and tonal weight. The diaphragm dome is constructed using more than 80 ultra thin layers of gold, applied through a 48 hour physical vacuum DC magnetron sputtering process. This technique allows extremely thin metallic layers to be deposited with high precision, helping maintain diaphragm rigidity while keeping mass low.
The gold layered dome is bonded to a titanium layer and mounted on a PEEK base, materials chosen for their strength, stability, and resistance to unwanted resonance. The result is a driver structure intended to deliver fast transient response, extended treble, and the fuller low frequency presence that dynamic drivers are known for, while maintaining clarity and control across the frequency range.
meze-audio-astru-iem-with-phone
Titanium Construction, Accessories, and Specifications
ASTRU’s housing reflects Meze Audio’s focus on durability, precision manufacturing, and long term comfort. The shell geometry has been carefully shaped to provide a secure and stable fit during extended listening sessions. Each earpiece is CNC machined from a single block of pure titanium and finished through a multi stage electroplating process that results in a smooth satin surface. According to Meze, producing each matched pair of shells requires up to seven days of precision machining and finishing, highlighting the level of manufacturing detail behind the design.
ASTRU is delivered as a complete listening package designed for portable high end audio use. The IEM includes a premium balanced cable equipped with CNC anodized aluminum hardware and a gold plated 4.4 mm balanced termination. This type of connection is commonly used with modern digital audio players and portable amplifiers because it offers improved channel separation and lower noise compared to standard single ended outputs. A 4.4 mm to 3.5 mm adapter is also included for compatibility with more traditional headphone outputs on Dongle DACs that may not offer a balanced output.
Additional accessories include five sizes of ear tips ranging from XS to XL to help users achieve a secure seal and proper acoustic performance. Meze also includes two carrying solutions: a protective pouch for everyday transport and a soft PU leather envelope designed for additional protection during travel or storage.
In terms of specifications, ASTRU offers a frequency range of 5 Hz to 35 kHz with a nominal impedance of 32 ohms and a sensitivity rating of 111dB SPL per milliwatt at 1 kHz. Total harmonic distortion is specified at less than 0.1 percent at 1 kHz. The IEM uses a standard 2-pin connector for cable attachment and weighs 13.4 grams (0.47 oz). These specifications indicate that ASTRU should be easy to drive with most modern digital audio players, portable DACs, and headphone amplifiers while still benefiting from higher quality source components.
meze-audio-astru-iem-in-ear
The Bottom Line
The Meze Audio ASTRU arrives at an interesting moment for the high end IEM market. With Empire Ears recently shutting down operations, one of the category’s most recognizable boutique brands has exited the stage, leaving more room for companies like Campfire Audio, Noble Audio, 64 Audio, and Astell&Kern to battle it out in the upper tier of the segment. Most of those competitors lean heavily into complex driver arrays, packing multiple balanced armatures, electrostatics, or hybrid configurations into increasingly elaborate designs.
Meze is taking a different path. Rather than joining the escalating multi driver arms race, ASTRU sticks with a single dynamic driver architecture and focuses on materials, diaphragm engineering, and acoustic tuning. The titanium housing, multilayer gold coated diaphragm, and balanced cable package suggest a product built with the same attention to industrial design and materials that has defined Meze’s headphone lineup.
What ASTRU offers is a simpler approach to high end IEM performance aimed at listeners who prefer the coherence, bass weight, and natural timbre that dynamic drivers are known for. What it does not offer is the kind of driver count marketing that dominates much of the $800 to $1500 IEM category. At $899, that places it in direct competition with multi driver models from several established brands. Whether buyers prioritize driver complexity or the sonic character of a well executed dynamic design will ultimately determine where ASTRU lands in this crowded field.
Price & Availability
ASTRU will be available for purchase starting March 20, 2026, on mezeaudio.com,
mezeaudio.eu and in selected retailers worldwide, with a suggested retail price of $899.
Splurge Audio Video Hi-Fi Tech Gifts 2026
Five drivers, rich bass, natural vocals, and smooth treble for $159. Can this tribrid IEM outperform DUNU's more expensive models?
The $519 EPZ 550 pairs five balanced-armature drivers with striking metalwork and refined sound, but its polite bass won't satisfy everyone.
DUNU PRS6 brings MEMS technology to a refined tribrid IEM with strong resolution, clean treble and a clear focus on competitive gaming.
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
Melody Wings’ $188 Uranus delivers airy, resolving sound from a quadbrid driver array, but BCD ringing and sharp treble may divide listeners.
The Juzear Light Shuttle combines tribrid drivers, strong sub-bass, clear mids and smooth treble in a competitive sub-$200 IEM.
$99 Bose Noise Cancelling Wired Earbuds arrive in 2026 with ANC, USB-C and no battery. Did the company that helped kill the cable just...
