FiiO Unveils EH11 Headphones and Upgraded JM21 DAP: Hi-Res Bluetooth, Retro Swagger, and a $240 Portable Combo Built for Commuters
FiiO’s EH11 headphones and updated JM21 music player target commuters and travelers with retro design, hi-res Bluetooth, solid performance, and an affordable $240 combo.
FiiO EH11 Retro Bluetooth Mini Headphones Lifestyle
FiiO keeps leaning into a space most audio brands still don’t quite understand: where personal style, portability, and genuinely competent sound overlap. The new EH11 Retro Bluetooth Mini Headphones are less about chasing spec-sheet bravado and more about meeting modern listeners where they actually live — commuting, traveling, and streaming wirelessly from their phones. We’ve already covered the JM21 at length and stand by the assessment that it delivers solid performance and strong value in the increasingly crowded DAP category, especially for listeners who want real controls and reliable hi-res Bluetooth without paying boutique prices.
The EH11 feels cut from the same cloth: compact, unapologetically retro, and clearly designed for people who care as much about how their gear looks and fits into daily life as how it measures on a lab bench.
fiio-eh11-heaphones
That idea clicked somewhere between Miami, Toronto, and New Jersey on a mostly empty American Airlines flight — no, nothing special in the air — sitting next to a young woman from Japan who spent most of the flight quietly streaming music from her Samsung Android phone to a pair of wireless earbuds I didn’t recognize. Between polite bows every time I had to get up for her rather frequent bathroom breaks and the obvious language barrier, striking up a “hey, want to try these earbuds I just reviewed?” conversation would’ve been peak creepy old guy territory.
Still, watching her style; understated, sharp, very Dragonslayer — it was obvious she was exactly the kind of listener the EH11 seems built for: someone who values portability, design, and frictionless wireless listening, without any interest in explaining their headphones to strangers.
Style-First Design Built for Commuters, Travelers, and Modern Mobile Listening
fiio-eh11-headphones-lifestyle-front
At first glance, the EH11’s compact wooden earcups immediately stand out. Drawing clear inspiration from 1980s-era mini on-ear headphones, the design combines exposed, transparent elements that reveal internal components with physical rotary knobs that serve as primary controls.
These dials allow users to adjust volume or skip tracks directly on the headphones, referencing vintage hi-fi ergonomics while remaining firmly aimed at portable, everyday use. Weighing 92 grams, the EH11 is positioned for extended wear during commuting and travel.
FiiO equips the EH11 with a 40 mm long-throw dynamic driver using a high-damping composite diaphragm. According to the company, this design lowers the driver’s resonant frequency to 60 Hz and is specified to deliver bass extension down to 17 Hz, with the goal of maintaining control and transient clarity across the frequency range.
fiio-eh11-headphone-pad
The EH11 uses a semi-open acoustic structure. Venting ports and internal damping are intended to reduce pressure buildup and the closed-in sensation often associated with on-ear headphones, while still managing airflow to limit sound leakage. FiiO states that this approach is designed to support a more open presentation, with less congestion in the midrange and treble and a broader perceived soundstage than fully closed on-ear designs.
Wireless connectivity is handled via Bluetooth with support for LDAC, allowing transmission rates of up to 990 kbps when paired with compatible devices, including FiiO’s JM21 digital audio player. A built-in microphone enables hands-free calling for mobile and home use.
Battery life is rated at up to 30 hours on a single charge, with a full recharge taking approximately 1.5 hours. The EH11 is compatible with the FiiO Control app, which provides access to EQ presets, user-adjustable equalization, low-latency modes, and firmware updates. FiiO also includes replaceable ear pads in two color options, allowing for basic customization and longer-term maintenance.
FiiO EH11 – Key Specifications
  • Frequency Response: 17 Hz to 40 kHz
  • Driver: 40 mm dynamic
  • Diaphragm: Composite material
  • Impedance: 16 ohms
  • Bluetooth Version: 5.4
  • Supported Codecs: SBC, AAC, LDAC
  • Battery Life: Up to 30 hours
  • Charging Time: Approx. 1.5 hours
  • Weight: About 92 g
  • Ear Cup Pressure: 1.7 N ± 0.3 N
FiiO JM21 Digital Audio Player: Compact Hi-Res DAP Built for Commuting and Bluetooth Streaming
Alongside the EH11 headphones, FiiO has also updated its JM21 portable digital audio player, refining a product we’ve already covered extensively and consistently viewed as a strong performance-for-the-money option in the compact DAP category. The key change for 2026 is the introduction of a 64GB model, replacing the earlier 32GB version and bringing several meaningful internal upgrades while keeping the overall design and feature set intact.
The new JM21 64GB version increases battery capacity to 3,100mAh, up from 2,400mAh, with FiiO rating it for up to 16 hours of playback from the single-ended output or approximately 12.5 hours using the balanced output. Memory has also been bumped from 3GB to 4GB of RAM, which should help with system responsiveness when navigating large libraries or using streaming apps. Aside from these changes, the player’s dimensions, layout, and core hardware remain unchanged.
Physically, the JM21 stays impressively compact, with an ultra-slim 13 mm chassis and a weight of 165 grams, making it genuinely pocket-friendly for commuting and travel. It runs Android 13 with FiiO’s custom UI, allowing access to all major high-resolution streaming services alongside local file playback through the FiiO Music app. Internal storage can be expanded via a microSD card slot supporting cards up to 2TB, accommodating large digital music libraries.
Audio duties are handled by dual Cirrus Logic CS43198 DACs, with one dedicated to the single-ended output and the other assigned to the balanced output. Headphone connectivity includes both 3.5 mm single-ended and 4.4 mm balancedoutputs.
Power output is rated at 360 mW into 16 ohms and 245 mW into 32 ohms from the single-ended jack, while the balanced output delivers up to 605 mW into 16 ohms and 700 mW into 32 ohms. Output power drops to 80 mW above 300 ohms, positioning the JM21 as a better match for efficient headphones and IEMs rather than high-impedance, power-hungry designs.
Wireless playback is also a major part of the JM21’s appeal. Bluetooth support includes SBC, AAC, aptX, aptX HD, LDAC, and LHDC, making it flexible for use with modern wireless headphones and speakers. Charging is handled via a fast-charge system, with a full recharge taking around two hours.
The Bottom Line
With the EH11 headphones and updated JM21 music player, FiiO is doubling down on a category many brands still ignore: portable, design-conscious audio that doesn’t require audiophile commitment or audiophile money. The EH11 stands out for its retro-inspired on-ear form factor, physical controls, LDAC Bluetooth support, and genuinely travel-friendly weight, while the JM21 remains one of the more approachable Android-based DAPs on the market thanks to its compact size, broad codec support, balanced output, and now-improved battery life and memory.
Neither product is trying to replace full-size reference headphones or desktop DACs, and that’s exactly why the pricing works. At roughly $240 for the EH11 and JM21 together, FiiO is offering real hardware controls, hi-res wireless support, expandable storage, and balanced output at a cost that undercuts most “entry-level” audiophile gear — without forcing buyers into disposable, app-locked ecosystems.
This combo is clearly aimed at commuters, frequent travelers, students, and style-aware listeners who want better sound and better control than a smartphone alone can provide, but who have zero interest in carrying a brick in their pocket or explaining their headphones to strangers. If you stream most of your music, move around a lot, and care as much about portability and design as you do about sound quality, the EH11 and JM21 make a strong, rational case — and do it without pretending to be something they’re not.
Where to buy:
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds
ASUS launches the ROG Cetra Open Wireless gaming earbuds with cross platform support for PC, Mac, PlayStation, Switch, iOS, and Android. Are open earbuds...
STAX SR-009S Headphones STAX SR-009S Headphones
STAX unveils the SR-009D, the latest evolution of its legendary SR-009 electrostatic headphone platform. Can the new flagship raise the bar again?
ABYSS Diana TC Signature Audiophile Headphones ABYSS Diana TC Signature Audiophile Headphones
Can the $4,995 ABYSS Diana TC Signature really compete with Audeze and Meze? We listened at CanJam NYC 2026 on a $30K Woo Audio...
Ferrum WANDLA GoldenSound Edition Gen 2 DAC/Preamp Ferrum WANDLA GoldenSound Edition Gen 2 DAC/Preamp
Ferrum debuts the WANDLA GoldenSound Edition Gen 2 at CanJam NYC 2026 with Tube Mode, Impact+ bass tuning, and new spatial audio controls.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Are HiFiMAN’s Arya WiFi and HE1000 WiFi planar headphones the future of wireless audiophile listening, or just very expensive experiments?
Can HiFiMAN’s HE1000 WiFi and Arya WiFi bring true high resolution audio to wireless planar open-back headphones? We’ll find out at CanJam NYC 2026.
Dongle DACs
Can the $199 FiiO BTR17 still compete in 2026? With dual ESS DACs, THX power, and LDAC support, this pocket DAC/amp aims close to...
Can the Sennheiser RS 275 finally fix late night TV listening and dialogue clarity without disturbing others through Auracast and low latency wireless audio?
DAPs
The FiiO JM21 portable DAP offers big power, Android 13, and wide flexibility, but does its neutral sound do enough to stand out?
Second generation écoute vacuum tube wireless noise cancelling headphones improve comfort and sound in a slightly modified design.
Over-Ear Headphones
Can FiiO’s $699 FT7 open-back planar headphones deliver true high-end sound, or do build issues hold them back?
