FiiO DARKSIDE PRO Linear Power Supply Promises Cleaner, Low Noise Power for Desktop Hi-Fi Under $200
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO can.
FiiO Darkside Pro Linear Power Supply
FiiO isn’t just busy in 2026, it is borderline relentless. The company has already rolled out close to 20 new products this year, with a roadmap that stretches for pages. DACs, amps, streamers, dongles you name it. But buried in that flood of new gear is something far less flashy and arguably more important: the DARKSIDE PRO.
Because here is the reality most brands do not like to talk about. A lot of entry level and mid tier gear from FiiO, Topping, SMSL, Schiit, WiiM, Eversolo ships with pretty mediocre power supplies. Cheap switching adapters. Lightweight wall warts that get the job done, technically, but do not exactly help performance. Noise creeps in, dynamics flatten out, and the gear never quite sounds like it should.
The FiiO DARKSIDE PRO goes straight at that problem. It is a linear power supply designed to clean up the foundation of your system, not dress it up. And it does not just work with a handful of FiiO products, it is compatible with a wide range of DACs, headphone amps, and streamers from multiple brands, provided the voltage and current match.
fiio-darkside-pro-front-back
At $159, it is also not a major financial leap. Which is why it makes a lot of sense as a first upgrade, often more impactful than swapping cables, and sometimes enough to hold off on replacing the component entirely. I have already got one on order for the K11 R2R and a few other pieces on my desk. That probably tells you everything you need to know.
The DARKSIDE PRO is built to address something most desktop systems overlook until it becomes a problem: power quality. Instead of relying on a standard switching adapter, FiiO uses a linear power supply design, which is inherently better at reducing high-frequency noise and electrical interference that can bleed into sensitive audio circuits. That matters because DACs and headphone amplifiers don’t just amplify music—they amplify whatever noise is riding along with the power.
At the heart of the DARKSIDE PRO is a 75W toroidal transformer paired with a fully discrete voltage regulation stage. Toroidal transformers are preferred in audio applications because they generate less electromagnetic interference and deliver more stable current under load. The discrete regulation stage further refines that output, reducing ripple and ensuring that voltage remains consistent even when the connected device demands more current during dynamic passages.
The unit provides selectable 12V or 15V output with up to 3A of current, which makes it compatible with a wide range of desktop gear. That includes FiiO’s own DACs and amplifiers like the K11, K13 R2R, K7, and other low-voltage components, as well as third-party DACs, streamers, and headphone amps that rely on external DC power. The ability to switch voltage is not just about compatibility—it allows users to match the exact requirements of their gear, avoiding underpowering or unnecessary stress on the circuit.
fiio-darkside-pro-black-silver-stack
Performance-wise, the benefit comes down to lowering the noise floor and improving system stability. With less ripple and cleaner DC output, connected devices can operate closer to their intended design limits. That can translate into tighter bass control, cleaner transients, and improved low-level detail—not because the power supply “adds” anything, but because it removes interference that shouldn’t be there in the first place.
There’s also a practical advantage in current reserve. With up to 3A on tap, the FiiO DARKSIDE PRO avoids the bottlenecks that cheaper switching supplies can introduce when a system demands more instantaneous power. That helps prevent compression or softening of dynamic peaks, especially with more demanding headphones or complex music.
What makes the DARKSIDE PRO useful is its role as a system-level upgrade. It doesn’t change your gear—it lets your gear perform the way it was designed to. For users building around FiiO’s growing desktop ecosystem, it’s a logical companion piece. And for anyone running sensitive DACs or headphone amps on generic wall adapters, it’s one of the few upgrades that can improve everything downstream without touching the signal path itself.
FiiO K13 R2R: Architecture, Power, and Real Control
fiio-darkside-pro-under-k13-r2r
FiiO DARKSIDE PRO under K13 R2R
The K13 R2R has been a long time coming. First announced last September, it took a few extra months to actually land, but now that it’s here, the value proposition is a lot clearer.
At its core is something you still almost never see at this price: a true, fully differential 24-bit resistor ladder DAC. FiiO’s four-channel design uses 192 precision thin-film resistors with tight tolerances, which isn’t just engineering flex—it directly improves linearity, channel balance, and low-level detail. The result is a presentation that feels more continuous and less clinical than the usual delta-sigma approach.
FiiO also gives you both NOS and OS modes, so you can choose between a smoother, more analog-leaning sound or something tighter and more technically precise. The DAC feeds a fully balanced amplifier capable of up to 2400mW per channel into 32 ohms, with low output impedance and multiple gain settings that make it flexible enough for everything from IEMs to planars.
On the digital side, it’s fully loaded: USB with up to 384kHz/32-bit PCM and DSD256 via XMOS, plus optical, coaxial, and I²S inputs, and Bluetooth 5.4 with LDAC for wireless. In other words, it covers just about every use case you’re likely to throw at a desktop unit in this range.
What makes the K13 R2R unique is obvious—the R2R DAC at $319. What matters just as much, though, is everything around it. Because here’s the part most people ignore: no DAC or headphone amp at this level reaches its potential on a cheap switching power supply. A better power source often delivers more meaningful gains than swapping cables—and in some cases, enough of an improvement that you don’t feel the need to upgrade the device at all.
Which is exactly why something like the FiiO DARKSIDE PRO exists in the first place.
fiio-darkside-pro-under-k13-r2r-desktop
The Bottom Line
The FiiO DARKSIDE PRO is for anyone running a DAC, streamer, or headphone amp on a basic wall adapter and wondering why it sounds a little flat. It makes sense because cleaner, more stable power can unlock performance you already paid for. At $159, it is a low risk upgrade that can deliver real gains without replacing your gear.
Where to buy:
For more information: fiio.com
Wharfedale Elysian R Series Loudspeakers in Grey
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
CD Players
FiiO raises prices on key DAPs starting April 2026 amid tariffs and rising costs, but with stronger rivals closing in, will buyers stick around?
Dongle DACs
Can the $199 FiiO BTR17 still compete in 2026? With dual ESS DACs, THX power, and LDAC support, this pocket DAC/amp aims close to...
DAPs
The FiiO JM21 portable DAP offers big power, Android 13, and wide flexibility, but does its neutral sound do enough to stand out?
FiiO’s EH11 headphones and updated JM21 music player target commuters and travelers with retro design, hi-res Bluetooth, solid performance, and an affordable $240 combo.
Over-Ear Headphones
Can FiiO’s $699 FT7 open-back planar headphones deliver true high-end sound, or do build issues hold them back?
Is the FiiO K11 R2R the most musically engaging DAC/headphone amp under $200, blending R2R texture with real-world balance at $175?
